[SCM] PostGIS branch stable-3.4 updated. 3.4.6-19-g80c17c66b
git at osgeo.org
git at osgeo.org
Tue Jun 23 13:08:10 PDT 2026
the project "PostGIS".
The branch, stable-3.4 has been updated
via 80c17c66b8b47bf5d090ed7e9571d91508e24cba (commit)
via 7caa19b965a7f43b46fa46a8fa59112f8bfa2cf4 (commit)
via c87feff26b02821afce79de2e79bcb3805d1db07 (commit)
from 02deebafbf3cc3f5fb932c6f919d77193512cf40 (commit)
revisions in full, below.
commit 80c17c66b8b47bf5d090ed7e9571d91508e24cba
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Jun 23 13:07:47 2026 -0700
News item for OSSFuzz 525548201
diff --git a/NEWS b/NEWS
index eec3e88d6..a736cdc7b 100644
--- a/NEWS
+++ b/NEWS
@@ -9,6 +9,7 @@ PostGIS 3.4.7
- #5989, CurvePolygon distance corner case (Paul Ramsey)
- #5357, ST_LineFromEncodedPolyline dropping close points (Paul Ramsey)
- OSSFuzz 525554772, avoid signed integer overflow (Even Rouault)
+ - OSSFuzz 525548201, avoid overly nested inputs (Darafei Praliaskouski)
PostGIS 3.4.6
commit 7caa19b965a7f43b46fa46a8fa59112f8bfa2cf4
Date: Tue Jun 23 13:05:02 2026 -0700
checkout v6
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 6bc061033..9945ea4f6 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -42,7 +42,7 @@ jobs:
# sudo apt-get -y -o Dpkg::Options::="--force-confnew" install docker-ce
- name: 'Check Out'
- uses: actions/checkout at v3
+ uses: actions/checkout at v6
- name: 'Prepare Image'
run: |
diff --git a/.github/workflows/msys.yml b/.github/workflows/msys.yml
index 602f177c2..5a68ee1be 100644
--- a/.github/workflows/msys.yml
+++ b/.github/workflows/msys.yml
@@ -22,7 +22,7 @@ jobs:
steps:
# see https://github.com/msys2/setup-msys2
- name: checkout
- name: '${{ matrix.icon }} Setup MSYS2'
uses: msys2/setup-msys2 at v2
with:
commit c87feff26b02821afce79de2e79bcb3805d1db07
Date: Tue Jun 23 19:42:15 2026 +0000
OSSFuzz 5121296892231680, avoid overly nested inputs
diff --git a/liblwgeom/cunit/cu_in_twkb.c b/liblwgeom/cunit/cu_in_twkb.c
index d8f24c9d8..77aea6fd6 100644
--- a/liblwgeom/cunit/cu_in_twkb.c
+++ b/liblwgeom/cunit/cu_in_twkb.c
@@ -255,9 +255,39 @@ test_twkb_in_coordinate_delta_overflow(void)
ASSERT_STRING_EQUAL(cu_error_msg, "");
CU_ASSERT_PTR_NOT_NULL(geom);
- if (geom != NULL)
- lwgeom_free(geom);
+ lwgeom_free(geom);
+static void
+test_twkb_in_deep_collection(void)
+ const size_t ngeoms = 201;
+ const size_t twkb_size = ngeoms * 3 + 2;
+ uint8_t *twkb = lwalloc(twkb_size);
+ LWGEOM *geom;
+ size_t i;
+ for (i = 0; i < ngeoms; i++)
+ /* GEOMETRYCOLLECTION with default precision and one child. */
+ twkb[3 * i] = 0x07;
+ twkb[3 * i + 1] = 0x00;
+ twkb[3 * i + 2] = 0x01;
+ twkb[3 * ngeoms] = 0x01; /* POINT with default precision. */
+ twkb[3 * ngeoms + 1] = 0x10; /* Empty geometry. */
cu_error_msg_reset();
+ geom = lwgeom_from_twkb(twkb, twkb_size, LW_PARSER_CHECK_NONE);
+ /* Recursive collection parsing must reject hostile nesting before the C
+ * stack becomes the effective input validator.
+ ASSERT_STRING_EQUAL(cu_error_msg, "Geometry has too many chained collections");
+ CU_ASSERT_PTR_NULL(geom);
+ lwfree(twkb);
@@ -276,4 +306,5 @@ void twkb_in_suite_setup(void)
PG_ADD_TEST(suite, test_twkb_in_collection);
PG_ADD_TEST(suite, test_twkb_in_precision);
PG_ADD_TEST(suite, test_twkb_in_coordinate_delta_overflow);
+ PG_ADD_TEST(suite, test_twkb_in_deep_collection);
diff --git a/liblwgeom/lwin_twkb.c b/liblwgeom/lwin_twkb.c
index 069a70609..a638449d3 100644
--- a/liblwgeom/lwin_twkb.c
+++ b/liblwgeom/lwin_twkb.c
@@ -29,6 +29,8 @@
#include "varint.h"
#define TWKB_IN_MAXCOORDS 4
+/** Max depth in a geometry. Matches the WKB parser recursion limit. */
+#define LW_PARSER_MAX_DEPTH 200
* Used for passing the parse state between the parsing functions.
@@ -42,6 +44,7 @@ typedef struct
uint32_t check; /* Simple validity checks on geometries */
uint32_t lwtype; /* Current type we are handling */
+ uint8_t depth; /* Current recursion level, to prevent stack overflows */
uint8_t has_bbox;
uint8_t has_size;
@@ -467,6 +470,7 @@ static LWCOLLECTION* lwcollection_from_twkb_state(twkb_parse_state *s)
int ngeoms, i;
LWGEOM *geom = NULL;
LWCOLLECTION *col = lwcollection_construct_empty(s->lwtype, SRID_UNKNOWN, s->has_z, s->has_m);
+ uint8_t start_depth = s->depth;
LWDEBUG(2,"Entering lwcollection_from_twkb_state");
@@ -485,16 +489,28 @@ static LWCOLLECTION* lwcollection_from_twkb_state(twkb_parse_state *s)
twkb_parse_state_varint_skip(s);
+ s->depth++;
+ if (s->depth >= LW_PARSER_MAX_DEPTH)
+ lwcollection_free(col);
+ lwerror("Geometry has too many chained collections");
+ s->depth = start_depth;
+ return NULL;
for ( i = 0; i < ngeoms; i++ )
geom = lwgeom_from_twkb_state(s);
- if ( lwcollection_add_lwgeom(col, geom) == NULL )
+ if (!geom || lwcollection_add_lwgeom(col, geom) == NULL)
- lwerror("Unable to add geometry (%p) to collection (%p)", geom, col);
return NULL;
+ s->depth--;
return col;
@@ -648,7 +664,7 @@ LWGEOM* lwgeom_from_twkb_state(twkb_parse_state *s)
break;
- if ( has_bbox )
+ if (has_bbox && geom)
geom->bbox = gbox_clone(&bbox);
return geom;
Summary of changes:
.github/workflows/ci.yml | 2 +-
.github/workflows/msys.yml | 2 +-
NEWS | 1 +
liblwgeom/cunit/cu_in_twkb.c | 35 +++++++++++++++++++++++++++++++++--
liblwgeom/lwin_twkb.c | 22 +++++++++++++++++++---
5 files changed, 55 insertions(+), 7 deletions(-)
hooks/post-receive
