[SCM] PostGIS branch stable-3.3 updated. 3.3.10-17-g5802fccea
Tue Jun 23 13:08:12 PDT 2026
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  5802fcceacc56bc8f0bef8746c7f615a719fada7 (commit)
       via  3ac0ce9ce074901bfdfe3ef7a26904cd180943a1 (commit)
       via  25fba64468a5fb8b5a99a040f6e3bcb2026360bd (commit)
      from  ebb7fa94d8566759a7d17788203d2d4c51af9251 (commit)
revisions in full, below.
commit 5802fcceacc56bc8f0bef8746c7f615a719fada7
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jun 23 13:07:48 2026 -0700
    News item for OSSFuzz 525548201
diff --git a/NEWS b/NEWS
index 990128c02..ad5468f05 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,7 @@ PostGIS 3.3.11
  - #5916, ST_Split hang with very large ordinates (Paul Ramsey)
  - #5989, CurvePolygon distance corner case (Paul Ramsey)
  - OSSFuzz 525554772, avoid signed integer overflow (Even Rouault)
+ - OSSFuzz 525548201, avoid overly nested inputs (Darafei Praliaskouski)
 PostGIS 3.3.10
commit 3ac0ce9ce074901bfdfe3ef7a26904cd180943a1
Date:   Tue Jun 23 13:05:11 2026 -0700
    checkout v6
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 9948f2c57..d79f9234d 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -46,7 +46,7 @@ jobs:
     #     sudo apt-get -y -o Dpkg::Options::="--force-confnew" install docker-ce
     - name: 'Check Out'
-      uses: actions/checkout at v2
+      uses: actions/checkout at v6
     - name: 'Prepare Image'
       run: |
diff --git a/.github/workflows/msys.yml b/.github/workflows/msys.yml
index abbd824e5..f80c2cacf 100644
--- a/.github/workflows/msys.yml
+++ b/.github/workflows/msys.yml
@@ -21,7 +21,7 @@ jobs:
     steps:
       # see https://github.com/msys2/setup-msys2
     - name: checkout
     - name: '${{ matrix.icon }} Setup MSYS2'
       uses: msys2/setup-msys2 at v2
       with:
commit 25fba64468a5fb8b5a99a040f6e3bcb2026360bd
Date:   Tue Jun 23 19:42:15 2026 +0000
    OSSFuzz 5121296892231680, avoid overly nested inputs
diff --git a/liblwgeom/cunit/cu_in_twkb.c b/liblwgeom/cunit/cu_in_twkb.c
index d8f24c9d8..77aea6fd6 100644
--- a/liblwgeom/cunit/cu_in_twkb.c
+++ b/liblwgeom/cunit/cu_in_twkb.c
@@ -255,9 +255,39 @@ test_twkb_in_coordinate_delta_overflow(void)
 	ASSERT_STRING_EQUAL(cu_error_msg, "");
 	CU_ASSERT_PTR_NOT_NULL(geom);
-	if (geom != NULL)
-		lwgeom_free(geom);
+	lwgeom_free(geom);
+static void
+test_twkb_in_deep_collection(void)
+	const size_t ngeoms = 201;
+	const size_t twkb_size = ngeoms * 3 + 2;
+	uint8_t *twkb = lwalloc(twkb_size);
+	LWGEOM *geom;
+	size_t i;
+	for (i = 0; i < ngeoms; i++)
+		/* GEOMETRYCOLLECTION with default precision and one child. */
+		twkb[3 * i] = 0x07;
+		twkb[3 * i + 1] = 0x00;
+		twkb[3 * i + 2] = 0x01;
+	twkb[3 * ngeoms] = 0x01;     /* POINT with default precision. */
+	twkb[3 * ngeoms + 1] = 0x10; /* Empty geometry. */
 	cu_error_msg_reset();
+	geom = lwgeom_from_twkb(twkb, twkb_size, LW_PARSER_CHECK_NONE);
+	/* Recursive collection parsing must reject hostile nesting before the C
+	 * stack becomes the effective input validator.
+	ASSERT_STRING_EQUAL(cu_error_msg, "Geometry has too many chained collections");
+	CU_ASSERT_PTR_NULL(geom);
+	lwfree(twkb);
@@ -276,4 +306,5 @@ void twkb_in_suite_setup(void)
 	PG_ADD_TEST(suite, test_twkb_in_collection);
 	PG_ADD_TEST(suite, test_twkb_in_precision);
 	PG_ADD_TEST(suite, test_twkb_in_coordinate_delta_overflow);
+	PG_ADD_TEST(suite, test_twkb_in_deep_collection);
diff --git a/liblwgeom/lwin_twkb.c b/liblwgeom/lwin_twkb.c
index 069a70609..a638449d3 100644
--- a/liblwgeom/lwin_twkb.c
+++ b/liblwgeom/lwin_twkb.c
@@ -29,6 +29,8 @@
 #include "varint.h"
 #define TWKB_IN_MAXCOORDS 4
+/** Max depth in a geometry. Matches the WKB parser recursion limit. */
+#define LW_PARSER_MAX_DEPTH 200
 * Used for passing the parse state between the parsing functions.
@@ -42,6 +44,7 @@ typedef struct
 	uint32_t check; /* Simple validity checks on geometries */
 	uint32_t lwtype; /* Current type we are handling */
+	uint8_t depth;   /* Current recursion level, to prevent stack overflows */
 	uint8_t has_bbox;
 	uint8_t has_size;
@@ -467,6 +470,7 @@ static LWCOLLECTION* lwcollection_from_twkb_state(twkb_parse_state *s)
 	int ngeoms, i;
 	LWGEOM *geom = NULL;
 	LWCOLLECTION *col = lwcollection_construct_empty(s->lwtype, SRID_UNKNOWN, s->has_z, s->has_m);
+	uint8_t start_depth = s->depth;
 	LWDEBUG(2,"Entering lwcollection_from_twkb_state");
@@ -485,16 +489,28 @@ static LWCOLLECTION* lwcollection_from_twkb_state(twkb_parse_state *s)
 			twkb_parse_state_varint_skip(s);
+	s->depth++;
+	if (s->depth >= LW_PARSER_MAX_DEPTH)
+		lwcollection_free(col);
+		lwerror("Geometry has too many chained collections");
+		s->depth = start_depth;
+		return NULL;
 	for ( i = 0; i < ngeoms; i++ )
 		geom = lwgeom_from_twkb_state(s);
-		if ( lwcollection_add_lwgeom(col, geom) == NULL )
+		if (!geom || lwcollection_add_lwgeom(col, geom) == NULL)
-			lwerror("Unable to add geometry (%p) to collection (%p)", geom, col);
 			return NULL;
+	s->depth--;
 	return col;
@@ -648,7 +664,7 @@ LWGEOM* lwgeom_from_twkb_state(twkb_parse_state *s)
 			break;
-	if ( has_bbox )
+	if (has_bbox && geom)
 		geom->bbox = gbox_clone(&bbox);
 	return geom;
Summary of changes:
 .github/workflows/ci.yml     |  2 +-
 .github/workflows/msys.yml   |  2 +-
 NEWS                         |  1 +
 liblwgeom/cunit/cu_in_twkb.c | 35 +++++++++++++++++++++++++++++++++--
 liblwgeom/lwin_twkb.c        | 22 +++++++++++++++++++---
 5 files changed, 55 insertions(+), 7 deletions(-)
hooks/post-receive
