[SCM] PostGIS branch master updated. 3.6.0rc2-662-gd9cdac922
Tue Jun 23 23:42:19 PDT 2026
the project "PostGIS".
       via  d9cdac922f99e86154f7ab04392280c61c87c912 (commit)
      from  7f94427119f424f36bf7a0b0d40dcdc32e2b6fdf (commit)
revisions in full, below.
commit d9cdac922f99e86154f7ab04392280c61c87c912
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sat Jun 20 12:10:52 2026 +0400
    Add pg_upgrade coverage to Woodie CI
    Add a Woodpecker regression step that installs the PostgreSQL 14 and 18 builds, then runs the cluster upgrade helper across them.
    Seed that upgrade with a geography table shape matching the failure reported in ticket #5899, so pg_upgrade coverage exercises PostGIS data before postgis_extensions_upgrade().
    Make the helper initialize newer target clusters without data checksums when supported, matching the historical default used by older clusters, and stop the upgraded cluster during cleanup.
    Closes #5995 for PostGIS 3.7.0
    Closes https://github.com/postgis/postgis/pull/1028
    Closes https://gitea.osgeo.org/postgis/postgis/pulls/298
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index 209af1a2a..f516bc4b3 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -131,3 +131,11 @@ steps:
       - <<: *steps-start-postgresql
       - <<: *steps-pg-install
       - <<: *steps-pg-test-all-upgrades
+  cluster-upgradecheck-pg14-to-pg18:
+    image: *test-image
+    depends_on: [ installcheck-pg14, installcheck-pg18 ]
+    commands:
+      - make -C build/pg14 install
+      - make -C build/pg18 install
+      - su postgres -c 'utils/check_cluster_upgrade.sh -i regress/hooks/cluster-upgrade-geography.sql /usr/lib/postgresql/14/bin/pg_config /usr/lib/postgresql/18/bin/pg_config'
diff --git a/regress/hooks/cluster-upgrade-geography.sql b/regress/hooks/cluster-upgrade-geography.sql
new file mode 100644
index 000000000..05fbbd318
--- /dev/null
+++ b/regress/hooks/cluster-upgrade-geography.sql
@@ -0,0 +1,13 @@
+CREATE EXTENSION postgis;
+CREATE SCHEMA procsch;
+CREATE TABLE procsch."MyTab" (
+    "id" bigint,
+    "loc" public.geography(Point, 4283)
+INSERT INTO procsch."MyTab"
+VALUES (1, 'SRID=4283;POINT(152.138672 -30.689888)'::geography);
+SELECT count(*) FROM procsch."MyTab";
diff --git a/utils/check_cluster_upgrade.sh b/utils/check_cluster_upgrade.sh
index 56b204be8..972279d7d 100755
--- a/utils/check_cluster_upgrade.sh
+++ b/utils/check_cluster_upgrade.sh
@@ -16,8 +16,15 @@ usage() {
 cleanup() {
   echo "-- Cleaning up --"
-  echo "Stopping postmaster on ${DATADIR} up"
-  ${BIN_OLD}/pg_ctl -D ${DATADIR} stop
+  if test -f "${DATADIR}/postmaster.pid"; then
+    if test -n "${BIN_NEW}"; then
+      echo "Stopping postmaster on ${DATADIR}"
+      ${BIN_NEW}/pg_ctl -D ${DATADIR} stop
+    else
+      ${BIN_OLD}/pg_ctl -D ${DATADIR} stop
+    fi
+  fi
   echo "Removing ${TMPDIR}"
   rm -rf ${TMPDIR}
@@ -56,6 +63,11 @@ if test -z "$PG_CONFIG_NEW"; then
   exit 1
 fi
+if test "$(id -u)" = "0"; then
+  echo "This script must be run as an unprivileged PostgreSQL cluster owner, not root" >&2
+  exit 1
+fi
 if test "$PG_CONFIG_OLD" = "$PG_CONFIG_NEW"; then
   echo "Old and new pg_config paths need be different" >&2
   exit 1
@@ -64,6 +76,11 @@ fi
 BIN_OLD=$(${PG_CONFIG_OLD} --bindir)
 BIN_NEW=$(${PG_CONFIG_NEW} --bindir)
+INITDB_NEW_OPTS=
+if ${BIN_NEW}/initdb --help | grep -q -- "--no-data-checksums"; then
+  INITDB_NEW_OPTS=--no-data-checksums
+fi
 echo "Testing cluster upgrade"
 echo "FROM: $(${PG_CONFIG_OLD} --version)"
 echo "  TO: $(${PG_CONFIG_NEW} --version)"
@@ -104,7 +121,7 @@ mv ${DATADIR} ${PGDATAOLD}
 export PGDATANEW=${DATADIR}
 echo "Creating TO cluster"
-${BIN_NEW}/initdb ${PGDATANEW} > ${LOGFILE} 2>&1 || {
+${BIN_NEW}/initdb ${INITDB_NEW_OPTS} ${PGDATANEW} > ${LOGFILE} 2>&1 || {
   cat ${LOGFILE} && exit 1
Summary of changes:
 .woodpecker/regress.yml                     |  8 ++++++++
 regress/hooks/cluster-upgrade-geography.sql | 13 +++++++++++++
 utils/check_cluster_upgrade.sh              | 23 ++++++++++++++++++++---
 3 files changed, 41 insertions(+), 3 deletions(-)
 create mode 100644 regress/hooks/cluster-upgrade-geography.sql
hooks/post-receive
