[PostGIS] #5995: Add pg_upgrade testing in CI
trac at osgeo.org
Tue Jun 23 23:42:21 PDT 2026
Reporter: strk | Owner: robe
Type: task | Status: closed
Priority: medium | Milestone: PostGIS 3.7.0
Component: QA/buildbots | Version: master
Resolution: fixed | Keywords: pg_upgrade
Changes (by Regina Obe <lr@…>):
* resolution: => fixed
* status: new => closed
Comment:
In [changeset:"d9cdac922f99e86154f7ab04392280c61c87c912/git" d9cdac9/git]:
{{{#!CommitTicketReference repository="git"
revision="d9cdac922f99e86154f7ab04392280c61c87c912"
Add pg_upgrade coverage to Woodie CI
Add a Woodpecker regression step that installs the PostgreSQL 14 and 18
builds, then runs the cluster upgrade helper across them.
Seed that upgrade with a geography table shape matching the failure
reported in ticket #5899, so pg_upgrade coverage exercises PostGIS data
before postgis_extensions_upgrade().
Make the helper initialize newer target clusters without data checksums
when supported, matching the historical default used by older clusters,
and stop the upgraded cluster during cleanup.
Closes #5995 for PostGIS 3.7.0
Closes https://github.com/postgis/postgis/pull/1028
Closes https://gitea.osgeo.org/postgis/postgis/pulls/298
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5995#comment:1>
