[SCM] PostGIS branch master updated. 3.6.0rc2-663-g98bf6ad50
git at osgeo.org
git at osgeo.org
Wed Jun 24 01:21:09 PDT 2026
the project "PostGIS".
via 98bf6ad503163840afa6422b99dad6f4c5b658ce (commit)
from d9cdac922f99e86154f7ab04392280c61c87c912 (commit)
revisions in full, below.
commit 98bf6ad503163840afa6422b99dad6f4c5b658ce
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Thu Jun 18 19:29:57 2026 +0400
topology: avoid MinGW format warnings
Use PostgreSQL integer-to-string helpers when topology backend diagnostics need 64-bit element ids or row counts. This avoids MinGW printf-format warnings without changing appendStringInfo SQL builders.
Closes https://trac.osgeo.org/postgis/ticket/5904
Closes https://github.com/postgis/postgis/pull/975
diff --git a/NEWS b/NEWS
index 36b96fe56..e3d1d2fa9 100644
--- a/NEWS
+++ b/NEWS
@@ -117,6 +117,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
- #2386, Add missing raster2pgsql man page (Darafei Praliaskouski)
- #5975, Initialize skipped union-find cluster ids deterministically
+ - #5904, [topology] Avoid MinGW format warnings when logging topology ids
+ (Darafei Praliaskouski)
- GH-885, [topology] Avoid GMP overflow in ring orientation for very large
finite coordinates (Darafei Praliaskouski)
- GH-892, Add OSS-Fuzz coverage for TWKB and serialized raster inputs,
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 0599fc010..2eb19bb67 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -13,7 +13,7 @@
#include "postgres.h"
#include "fmgr.h"
#include "c.h" /* for UINT64_FORMAT and uint64 */
-#include "utils/builtins.h" /* for cstring_to_text */
+#include "utils/builtins.h" /* for cstring_to_text, pg_lltoa, pg_ulltoa_n */
#include "utils/elog.h"
#include "utils/memutils.h" /* for transaction contexts */
#include "utils/array.h" /* for ArrayType */
@@ -98,6 +98,23 @@ struct LWT_BE_TOPOLOGY_T
/* utility funx */
+#define LWT_BE_INT64_BUFSIZE 32
+static const char *
+lwt_be_int64_to_str(int64 value, char *buf)
+ pg_lltoa(value, buf);
+ return buf;
+lwt_be_uint64_to_str(uint64 value, char *buf)
+ int len = pg_ulltoa_n(value, buf);
+ buf[len] = '\0';
+ return buf;
static void cberror(const LWT_BE_DATA* be, const char *fmt, ...)
__attribute__ (( format(printf, 2, 3) ));
@@ -1291,13 +1308,12 @@ cb_getRingEdges(const LWT_BE_TOPOLOGY *topo, LWT_ELEMID edge, uint64_t *numelems
*numelems = SPI_processed;
if ( ! SPI_processed )
- cberror(
- topo->be_data,
- "No edge with id %" LWTFMT_ELEMID" in Topology \"%s\"",
- ABS(edge),
- topo->name
- return NULL;
+ char edge_id[LWT_BE_INT64_BUFSIZE];
+ cberror(topo->be_data,
+ "No edge with id %s in Topology \"%s\"",
+ lwt_be_int64_to_str(ABS(edge), edge_id),
+ topo->name);
+ return NULL;
if (limit && *numelems == (uint64_t)limit)
@@ -1337,12 +1353,11 @@ cb_getRingEdges(const LWT_BE_TOPOLOGY *topo, LWT_ELEMID edge, uint64_t *numelems
dat = SPI_getbinval(row, rowdesc, sidecol, &isnull);
if ( isnull )
- lwfree(edges);
- cberror(topo->be_data, "Edge %" LWTFMT_ELEMID
- " has NULL next_%s_edge",
- val, sidetext);
- *numelems = UINT64_MAX;
- return NULL;
+ lwfree(edges);
+ cberror(topo->be_data, "Edge %s has NULL next_%s_edge", lwt_be_int64_to_str(val, edge_id), sidetext);
+ *numelems = UINT64_MAX;
+ return NULL;
nextedge = tuple_get_int64(rowdesc, sidecol, dat);
POSTGIS_DEBUGF(1, "Last component in ring of edge %"
@@ -1350,12 +1365,13 @@ cb_getRingEdges(const LWT_BE_TOPOLOGY *topo, LWT_ELEMID edge, uint64_t *numelems
edge, val, sidetext, nextedge);
if ( nextedge != edge )
- lwfree(edges);
- cberror(topo->be_data, "Corrupted topology: ring of edge %"
- LWTFMT_ELEMID " is topologically non-closed",
- edge);
- return NULL;
+ lwfree(edges);
+ "Corrupted topology: ring of edge %s is topologically non-closed",
+ lwt_be_int64_to_str(edge, edge_id));
+ return NULL;
@@ -1606,10 +1622,12 @@ cb_getNodeWithinDistance2D(const LWT_BE_TOPOLOGY *topo,
if ( fields ) addNodeFields(sql, fields);
else
- lwpgwarning("liblwgeom-topo invoked 'getNodeWithinDistance2D' "
- "backend callback with limit=" UINT64_FORMAT " and no fields",
- elems_requested);
- appendStringInfo(sql, "*");
+ char limit_str[LWT_BE_INT64_BUFSIZE];
+ lwpgwarning(
+ "liblwgeom-topo invoked 'getNodeWithinDistance2D' "
+ "backend callback with limit=%s and no fields",
+ lwt_be_int64_to_str(elems_requested, limit_str));
+ appendStringInfo(sql, "*");
appendStringInfo(sql, " FROM \"%s\".node", topo->name);
@@ -1725,10 +1743,12 @@ cb_insertNodes(const LWT_BE_TOPOLOGY *topo, LWT_ISO_NODE *nodes, uint64_t numele
if (SPI_processed != numelems)
+ char processed_str[LWT_BE_INT64_BUFSIZE];
+ char expected_str[LWT_BE_INT64_BUFSIZE];
- "processed " UINT64_FORMAT " rows, expected " UINT64_FORMAT,
- (uint64)SPI_processed,
- (uint64)numelems);
+ "processed %s rows, expected %s",
+ lwt_be_uint64_to_str((uint64)SPI_processed, processed_str),
+ lwt_be_uint64_to_str((uint64)numelems, expected_str));
return 0;
@@ -1785,10 +1805,12 @@ cb_insertEdges(const LWT_BE_TOPOLOGY *topo, LWT_ISO_EDGE *edges, uint64_t numele
POSTGIS_DEBUGF(1, "cb_insertEdges query processed " UINT64_FORMAT " rows", SPI_processed);
if ( SPI_processed != (uint64) numelems )
return -1;
@@ -1846,10 +1868,12 @@ cb_insertFaces(const LWT_BE_TOPOLOGY *topo, LWT_ISO_FACE *faces, uint64_t numele
POSTGIS_DEBUGF(1, "cb_insertFaces query processed " UINT64_FORMAT " rows", SPI_processed);
return -1;
@@ -2242,7 +2266,10 @@ cb_getNextEdgeId( const LWT_BE_TOPOLOGY* topo )
if ( SPI_processed != 1 )
- cberror(topo->be_data, "processed " UINT64_FORMAT " rows, expected 1", (uint64)SPI_processed);
+ "processed %s rows, expected 1",
+ lwt_be_uint64_to_str((uint64)SPI_processed, processed_str));
return -1;
@@ -2575,11 +2602,20 @@ cb_checkTopoGeomRemEdge ( const LWT_BE_TOPOLOGY* topo,
SPI_freetuptable(SPI_tuptable);
- cberror(topo->be_data, "TopoGeom %s in layer %s "
- "(%s.%s.%s) cannot be represented "
- "dropping edge %" LWTFMT_ELEMID,
- tg_id, layer_id, schema_name, table_name,
- col_name, rem_edge);
+ "TopoGeom %s in layer %s "
+ "(%s.%s.%s) cannot be represented "
+ "dropping edge %s",
+ tg_id,
+ layer_id,
+ schema_name,
+ table_name,
+ col_name,
+ lwt_be_int64_to_str(rem_edge, edge_id));
return 0;
@@ -2634,12 +2670,22 @@ cb_checkTopoGeomRemEdge ( const LWT_BE_TOPOLOGY* topo,
- "healing faces %" LWTFMT_ELEMID
- " and %" LWTFMT_ELEMID,
- col_name, face_right, face_left);
+ char face_left_id[LWT_BE_INT64_BUFSIZE];
+ char face_right_id[LWT_BE_INT64_BUFSIZE];
+ "healing faces %s and %s",
+ tg_id,
+ layer_id,
+ schema_name,
+ table_name,
+ col_name,
+ lwt_be_int64_to_str(face_right, face_right_id),
+ lwt_be_int64_to_str(face_left, face_left_id));
return 0;
@@ -2697,11 +2743,20 @@ cb_checkTopoGeomRemIsoEdge ( const LWT_BE_TOPOLOGY* topo,
+ tg_id,
+ layer_id,
+ schema_name,
+ table_name,
+ col_name,
return 0;
@@ -2769,12 +2824,22 @@ cb_checkTopoGeomRemNode ( const LWT_BE_TOPOLOGY* topo,
- "healing edges %" LWTFMT_ELEMID
- col_name, edge1, edge2);
+ char edge1_id[LWT_BE_INT64_BUFSIZE];
+ char edge2_id[LWT_BE_INT64_BUFSIZE];
+ "healing edges %s and %s",
+ tg_id,
+ layer_id,
+ schema_name,
+ table_name,
+ col_name,
+ lwt_be_int64_to_str(edge1, edge1_id),
+ lwt_be_int64_to_str(edge2, edge2_id));
return 0;
@@ -2818,13 +2883,24 @@ cb_checkTopoGeomRemNode ( const LWT_BE_TOPOLOGY* topo,
- "removing node %" LWTFMT_ELEMID
- " connecting edges %" LWTFMT_ELEMID
- col_name, rem_node, edge1, edge2);
+ char node_id[LWT_BE_INT64_BUFSIZE];
+ "removing node %s connecting edges %s and %s",
+ tg_id,
+ layer_id,
+ schema_name,
+ table_name,
+ col_name,
+ lwt_be_int64_to_str(rem_node, node_id),
return 0;
@@ -2885,11 +2961,20 @@ cb_checkTopoGeomRemIsoNode ( const LWT_BE_TOPOLOGY* topo, LWT_ELEMID rem_node )
- "removing node %" LWTFMT_ELEMID,
- col_name, rem_node);
+ "removing node %s",
+ tg_id,
+ layer_id,
+ schema_name,
+ table_name,
+ col_name,
+ lwt_be_int64_to_str(rem_node, node_id));
return 0;
@@ -3202,13 +3287,12 @@ cb_computeFaceMBR(const LWT_BE_TOPOLOGY *topo, LWT_ELEMID face)
- cberror(
- topo->be_data,
- "Face with id %" LWTFMT_ELEMID" in topology \"%s\" has no edges",
- face,
- topo->name
- return NULL;
+ char face_id[LWT_BE_INT64_BUFSIZE];
+ "Face with id %s in topology \"%s\" has no edges",
+ lwt_be_int64_to_str(face, face_id),
+ topo->name);
+ return NULL;
row = SPI_tuptable->vals[0];
@@ -3216,13 +3300,12 @@ cb_computeFaceMBR(const LWT_BE_TOPOLOGY *topo, LWT_ELEMID face)
if ( isnull )
- cberror(
- topo->be_data,
- "Face with id %" LWTFMT_ELEMID" in topology \"%s\" has null edges ?",
- face,
- topo->name
- return NULL;
+ "Face with id %s in topology \"%s\" has null edges ?",
+ topo->name);
+ return NULL;
geom = (GSERIALIZED *)PG_DETOAST_DATUM(dat);
@@ -3237,13 +3320,12 @@ cb_computeFaceMBR(const LWT_BE_TOPOLOGY *topo, LWT_ELEMID face)
else
- cberror(
- topo->be_data,
- "Face with id %" LWTFMT_ELEMID" in topology \"%s\" has empty MBR ?",
- face,
- topo->name
- return NULL;
+ "Face with id %s in topology \"%s\" has empty MBR ?",
+ topo->name);
+ return NULL;
lwgeom_free(lwg);
if ( DatumGetPointer(dat) != (Pointer)geom ) pfree(geom);
Summary of changes:
NEWS | 2 +
topology/postgis_topology.c | 260 +++++++++++++++++++++++++++++---------------
2 files changed, 173 insertions(+), 89 deletions(-)
hooks/post-receive
