[PostGIS] #6086: Regression failure on debbie
trac at osgeo.org
Wed Jun 24 09:29:58 PDT 2026
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.7.0
Component: QA/buildbots | Version: master
Resolution: | Keywords:
Comment (by robe):
Seeing this issue on berries too
debbie is running with
10:03:17 GEOS: 3.14.2dev-CAPI-1.20.5
10:03:17 PROJ: 9.6.0 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/var/lib/jenkins/.local/share/proj
DATABASE_PATH=/usr/share/proj/proj.db
10:03:17 SFCGAL: 2.0.0
10:03:17 GDAL: GDAL 3.14.0dev-aa6b7125fc, released 2026/06/24
10:03:17
berries
GDAL: GDAL 3.10.3, released 2025/04/01
09:08:44 raster/test/regress/loader/SourceOverview . failed (Failed
evaluating ./raster/test/regress/loader/SourceOverview-pre.pl: Could not
create ./raster/test/regress/loader/SourceOverview-generated.tif at
./raster/test/regress/loader/SourceOverview-pre.pl line 22.)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6086#comment:1>
