[PostGIS] #6089: wrong node used when adding a new long line
PostGIS trac at osgeo.org
Mon Jun 29 04:17:31 PDT 2026
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:
 Component:  topology           |    Version:  master
Resolution:                     |   Keywords:
Comment (by Lars Aksel Opsahl):
 If tolerance 0 like this when adding the last it seems solve the problem.
 SELECT ARRAY(SELECT abs(add_case05) FROM
 topology.TopoGeo_addLinestring('test_34_2_bug','0102000020A210000002000000C01856A5171528406C5803DF1D71504064BFAEFB153728406C5803DF1D715040',0)
 add_case05)  ; -- log_add_to test_34_2
 But running with tolerance should also select the same node I assume.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6089#comment:3>
