[PostGIS] #6089: wrong node used when adding a new long line
PostGIS trac at osgeo.org
Mon Jun 29 04:23:05 PDT 2026
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:
 Component:  topology           |    Version:  master
Resolution:                     |   Keywords:
Comment (by Lars Aksel Opsahl):
 Or running with tolerance -1 is also working correctly
 SELECT ARRAY(SELECT abs(add_case05) FROM
 topology.TopoGeo_addLinestring('test_34_2_bug','0102000020A210000002000000C01856A5171528406C5803DF1D71504064BFAEFB153728406C5803DF1D715040',-1)
 add_case05
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6089#comment:4>
