[SCM] PostGIS branch master updated. 3.6.0rc2-692-g1b06d92d1
Tue Jun 30 21:55:26 PDT 2026
the project "PostGIS".
       via  1b06d92d11c04f330e2a7f4954d3892746d47a11 (commit)
       via  660635ab17acf42496510f8b27fa0ee97a50634c (commit)
       via  bfb670aac42999d96e13294f3e644118db65c755 (commit)
       via  2fef6f67fd352a5bcda7efe0376706a2d7a52100 (commit)
       via  c2f7090acccf6fc30d4f4732d727db501525eb49 (commit)
      from  4e470f1534795ae4a4c52ad5ad35b8744af9d708 (commit)
revisions in full, below.
commit 1b06d92d11c04f330e2a7f4954d3892746d47a11
Merge: 660635ab1 2fef6f67f
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Wed Jul 1 08:53:56 2026 +0400
    Merge pull request https://github.com/postgis/postgis/pull/1124
    ci: mark outdated failed runs as stale
commit 660635ab17acf42496510f8b27fa0ee97a50634c
Merge: 4e470f153 bfb670aac
    Merge pull request https://github.com/postgis/postgis/pull/1136
    utils: fix Berrie64 Trac badge link
commit bfb670aac42999d96e13294f3e644118db65c755
Date:   Wed Jul 1 02:38:20 2026 +0400
diff --git a/utils/ci-trac-line.sh b/utils/ci-trac-line.sh
index d0abef4f4..cb2dfe0c9 100755
--- a/utils/ci-trac-line.sh
+++ b/utils/ci-trac-line.sh
@@ -16,7 +16,7 @@ cat <<EOF
 || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie&build=last:\${params.reference=refs/heads/stable-${VER}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie, alt=status, height="20", title='PG 10.1(branch), GDAL 2.1 branch, GEOS 3.6')]] || \\
 || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie32&build=last:\${params.reference=refs/heads/stable-${VER}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32, alt=status, height="20", title='PG 10.1(branch), GDAL 2.1 branch, GEOS 3.6')]] || \\
 || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie&build=last:\${params.reference=refs/heads/stable-${VER}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie, alt=status, height="20", title='PG 12(branch), GDAL 2.4.0 branch, GEOS 3.7.1')]] || \\
-|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie64&build=last:\${params.reference=refs/heads/stable-${VER}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie64?build=last:\${params.reference=refs/heads/stable-${VER}, alt=status, height="20", title='PG 12(branch), GDAL 2.4.0 branch, GEOS 3.7.1')]] || \\
+|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie64&build=last:\${params.reference=refs/heads/stable-${VER}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie64, alt=status, height="20", title='PG 12(branch), GDAL 2.4.0 branch, GEOS 3.7.1')]] || \\
 || [[Image(https://github.com/postgis/postgis/actions/workflows/ci-freebsd.yml/badge.svg?branch=stable-${VER}, link=https://github.com/postgis/postgis/actions/workflows/ci-freebsd.yml?query=branch%3Astable-${VER}, alt=status, height="20", title='FreeBSD')]] || \\
 || [[Image(https://github.com/postgis/postgis/actions/workflows/ci-macos.yml/badge.svg?branch=stable-${VER}, link=https://github.com/postgis/postgis/actions/workflows/ci-macos.yml?query=branch%3Astable-${VER}, alt=status, height="20", title='macOS')]] || \\
 || [[Image(https://gitlab.com/postgis/postgis/badges/stable-${VER}/pipeline.svg, link=https://gitlab.com/postgis/postgis/-/commits/stable-${VER}, alt=status, height="20", title='32/64 bit trixie, PG 15, GDAL 2.4.0, GEOS 3.7.1, PROJ 5.2.0')]] || \\
commit 2fef6f67fd352a5bcda7efe0376706a2d7a52100
Date:   Mon Jun 29 10:51:35 2026 +0400
    ci: preserve fresh successes in stale checks
diff --git a/utils/ci-status.py b/utils/ci-status.py
index a58fc8b83..4ddef3801 100755
--- a/utils/ci-status.py
+++ b/utils/ci-status.py
@@ -793,8 +793,10 @@ def stale_after_hours(config, check):
 def apply_staleness(result, config, check):
     threshold = stale_after_hours(config, check)
-    distance_count, distance_ref = result_revision_distance(config, result)
-    if result["status"] != IN_PROGRESS and distance_count and distance_count > 0:
+    distance_count, distance_ref = None, None
+    if result["status"] != IN_PROGRESS:
+        distance_count, distance_ref = result_revision_distance(config, result)
+    if result["status"] not in (IN_PROGRESS, SUCCESS) and distance_count and distance_count > 0:
         stale = dict(result)
         stale["revision_commits_behind"] = distance_count
         stale["revision_compare_ref"] = distance_ref
commit c2f7090acccf6fc30d4f4732d727db501525eb49
Date:   Sat Jun 27 22:49:46 2026 +0400
index 92a0bf8ee..a58fc8b83 100755
@@ -608,6 +608,11 @@ def jenkins_revision(build):
         sha1 = revision.get("SHA1")
         if sha1:
             return sha1
+    params = jenkins_parameters(build)
+    for name in ("after", "BRANCH", "commit", "GIT_COMMIT"):
+        value = params.get(name)
+        if value and len(value) == 40 and all(ch in "0123456789abcdefABCDEF" for ch in value):
+            return value
     return None
@@ -787,16 +792,24 @@ def stale_after_hours(config, check):
+    threshold = stale_after_hours(config, check)
+    if result["status"] != IN_PROGRESS and distance_count and distance_count > 0:
+        stale = dict(result)
+        stale["revision_commits_behind"] = distance_count
+        stale["revision_compare_ref"] = distance_ref
+        stale["revision_distance"] = revision_distance_text(distance_count, distance_ref)
+        stale["status"] = STALE
+        stale["message"] = f"{result.get('message', 'CI run')} ({stale['revision_distance']})"
+        return stale
     if result["status"] != SUCCESS:
         return result
-    threshold = stale_after_hours(config, check)
     completed_at = parse_time(result.get("completed_at"))
     if threshold is None or completed_at is None:
         return result
     age = utc_now() - completed_at
     if age.total_seconds() <= threshold * 3600:
         return result
     if distance_count == 0:
         return result
Summary of changes:
 utils/ci-status.py    | 19 +++++++++++++++++--
 utils/ci-trac-line.sh |  2 +-
 2 files changed, 18 insertions(+), 3 deletions(-)
hooks/post-receive
