[SCM] PostGIS branch master updated. 3.6.0rc2-694-gb9fc9d0e4
git at osgeo.org
git at osgeo.org
Tue Jun 30 22:00:34 PDT 2026
the project "PostGIS".
via b9fc9d0e46257f3d5843b289ab7e2b7a4d134f8c (commit)
via bbfd0865f4c84c10dd2f1edc6d0d1b0ac08f7bf0 (commit)
from 1b06d92d11c04f330e2a7f4954d3892746d47a11 (commit)
revisions in full, below.
commit b9fc9d0e46257f3d5843b289ab7e2b7a4d134f8c
Merge: 1b06d92d1 bbfd0865f
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Wed Jul 1 08:58:26 2026 +0400
Merge pull request https://github.com/postgis/postgis/pull/1018
loader: detect pgsql2shp query keywords case-insensitively
commit bbfd0865f4c84c10dd2f1edc6d0d1b0ac08f7bf0
Date: Sat Jun 20 10:29:55 2026 +0400
Closes #4616
diff --git a/NEWS b/NEWS
index a636077cb..9c6cd8f3b 100644
--- a/NEWS
+++ b/NEWS
@@ -96,6 +96,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
when padding is not requested (Darafei Praliaskouski)
- #2623, Generate a pgsql2shp GID field when exporting geometry-only
shapefiles (Darafei Praliaskouski)
+ - #4616, Detect pgsql2shp query keywords case-insensitively
+ (Darafei Praliaskouski)
- #2838, Emit valid X3D Coordinate nodes for 2D polygon output
- Fix WKB and TWKB parser resource exhaustion on malformed input
diff --git a/loader/pgsql2shp-cli.c b/loader/pgsql2shp-cli.c
index 4ce700521..075aa8d47 100644
--- a/loader/pgsql2shp-cli.c
+++ b/loader/pgsql2shp-cli.c
@@ -19,6 +19,9 @@
#include "pgsql2shp-core.h"
#include "../postgis_config.h"
+#include <ctype.h>
+#include <strings.h>
#define xstr(s) str(s)
#define str(s) #s
@@ -55,6 +58,16 @@ usage(int status)
exit(status);
+static int
+is_user_query_argument(const char *argument)
+ while (isspace((unsigned char)*argument))
+ argument++;
+ return (!strncasecmp(argument, "SELECT", 6) && isspace((unsigned char)argument[6])) ||
+ (!strncasecmp(argument, "WITH", 4) && isspace((unsigned char)argument[4]));
int
main(int argc, char **argv)
@@ -137,11 +150,7 @@ main(int argc, char **argv)
if (pgis_optind < argc)
/* User-defined queries begin with SELECT or WITH */
- if ( !strncmp(argv[pgis_optind], "SELECT ", 7) ||
- !strncmp(argv[pgis_optind], "select ", 7) ||
- !strncmp(argv[pgis_optind], "WITH ", 5) ||
- !strncmp(argv[pgis_optind], "with ", 5)
+ if (is_user_query_argument(argv[pgis_optind]))
config->usrquery = argv[pgis_optind];
diff --git a/regress/dumper/mixedcasequery.dmp b/regress/dumper/mixedcasequery.dmp
new file mode 100644
index 000000000..73eca7b5f
--- /dev/null
+++ b/regress/dumper/mixedcasequery.dmp
@@ -0,0 +1 @@
+Select * FROM (VALUES ('This is Test 1', 'TT1', 'red', ST_Point(0, 0)), ('This is Test 2', 'TT2', 'green', ST_Point(0, 100))) AS m (address, some_very_long_name, color, geom)
diff --git a/regress/dumper/mixedcasequery_expected.dbf b/regress/dumper/mixedcasequery_expected.dbf
index 000000000..255c05b0d
Binary files /dev/null and b/regress/dumper/mixedcasequery_expected.dbf differ
diff --git a/regress/dumper/mixedcasequery_expected.shp b/regress/dumper/mixedcasequery_expected.shp
index 000000000..829055595
Binary files /dev/null and b/regress/dumper/mixedcasequery_expected.shp differ
diff --git a/regress/dumper/mixedcasequery_expected.shx b/regress/dumper/mixedcasequery_expected.shx
index 000000000..314770b3d
Binary files /dev/null and b/regress/dumper/mixedcasequery_expected.shx differ
diff --git a/regress/dumper/tests.mk.in b/regress/dumper/tests.mk.in
index 7b852ffd7..05ebba220 100644
--- a/regress/dumper/tests.mk.in
+++ b/regress/dumper/tests.mk.in
@@ -21,6 +21,7 @@ TESTS += \
$(top_srcdir)/regress/dumper/nullsintable \
$(top_srcdir)/regress/dumper/null3d \
$(top_srcdir)/regress/dumper/numeric \
+ $(top_srcdir)/regress/dumper/mixedcasequery \
$(top_srcdir)/regress/dumper/withclause
ifeq ($(shell expr "$(POSTGIS_PGSQL_VERSION)" ">=" 150),1)
Summary of changes:
NEWS | 2 ++
loader/pgsql2shp-cli.c | 19 ++++++++++++++-----
regress/dumper/{mfiledmp.dmp => mixedcasequery.dmp} | 3 +--
...ause_expected.dbf => mixedcasequery_expected.dbf} | Bin
...edmp_expected.shp => mixedcasequery_expected.shp} | Bin
...edmp_expected.shx => mixedcasequery_expected.shx} | Bin
regress/dumper/tests.mk.in | 1 +
7 files changed, 18 insertions(+), 7 deletions(-)
copy regress/dumper/{mfiledmp.dmp => mixedcasequery.dmp} (52%)
copy regress/dumper/{withclause_expected.dbf => mixedcasequery_expected.dbf} (100%)
copy regress/dumper/{mfiledmp_expected.shp => mixedcasequery_expected.shp} (100%)
copy regress/dumper/{mfiledmp_expected.shx => mixedcasequery_expected.shx} (100%)
hooks/post-receive
