[SCM] PostGIS branch stable-3.3 updated. 3.3.9-4-g9562c2020
git at osgeo.org
git at osgeo.org
Fri Mar 6 13:11:45 PST 2026
the project "PostGIS".
The branch, stable-3.3 has been updated
via 9562c2020b0ecac01cec2d7877666425b41e81a8 (commit)
from 1ff46f6490e1ffb1506d9f6bf84188b9179282e7 (commit)
revisions in full, below.
commit 9562c2020b0ecac01cec2d7877666425b41e81a8
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Mar 6 13:11:11 2026 -0800
Remove rare extension priv escalation case, where account
with extension create privs can escalate to superuser
by piggy backing on an extension creation event.
From Sven Klemm (Tiger Data) and Allistair Ishmael Hakim (allistair.sh)
References #6055
diff --git a/NEWS b/NEWS
index ff1eb5bf2..95563125a 100644
--- a/NEWS
+++ b/NEWS
@@ -4,7 +4,10 @@ PostGIS 3.3.10
* Bug Fixes and Enhancements *
- #5998, [tiger_geododer] Do not create tiger_data as part
- of postgis_tiger_geocoder extension, create/update (Regina Obe)
+ of postgis_tiger_geocoder extension, create/update (Regina Obe)
+ - #6055, Remove rare extension priv escalation case.
+ Reported by Sven Klemm (Tiger Data) and Allistair Ishmael Hakim (allistair.sh)
PostGIS 3.3.9
2026-02-09
diff --git a/libpgcommon/sql/AddToSearchPath.sql.inc b/libpgcommon/sql/AddToSearchPath.sql.inc
index a5e02279e..ff313406c 100644
--- a/libpgcommon/sql/AddToSearchPath.sql.inc
+++ b/libpgcommon/sql/AddToSearchPath.sql.inc
@@ -16,10 +16,10 @@ DECLARE
BEGIN
WITH settings AS (
SELECT unnest(setconfig) config
- FROM pg_db_role_setting
+ FROM pg_catalog.pg_db_role_setting
WHERE setdatabase = (
SELECT oid
- FROM pg_database
+ FROM pg_catalog.pg_database
WHERE datname = current_database()
) and setrole = 0
@@ -30,10 +30,10 @@ BEGIN
RAISE NOTICE 'cur_search_path from pg_db_role_setting is %', var_cur_search_path;
-- only run this test if person creating the extension is a super user
- IF var_cur_search_path IS NULL AND (SELECT rolsuper FROM pg_roles where rolname = CURRENT_USER) THEN
+ IF var_cur_search_path IS NULL AND (SELECT rolsuper FROM pg_catalog.pg_roles where rolname = CURRENT_USER) THEN
SELECT setting
INTO var_cur_search_path
- FROM pg_file_settings
+ FROM pg_catalog.pg_file_settings
WHERE name = 'search_path' AND applied;
RAISE NOTICE 'cur_search_path from pg_file_settings is %', var_cur_search_path;
@@ -42,7 +42,7 @@ BEGIN
IF var_cur_search_path IS NULL THEN
SELECT boot_val
- FROM pg_settings
+ FROM pg_catalog.pg_settings
WHERE name = 'search_path';
RAISE NOTICE 'cur_search_path from pg_settings is %', var_cur_search_path;
@@ -63,7 +63,8 @@ BEGIN
RETURN var_result;
END
$BODY$
-SET search_path = pg_catalog -- make safe
+-- explicitly move pg_temp after pg_catalog in search path
+SET search_path = pg_catalog, pg_temp
LANGUAGE 'plpgsql' VOLATILE STRICT
Summary of changes:
NEWS | 5 ++++-
libpgcommon/sql/AddToSearchPath.sql.inc | 13 +++++++------
2 files changed, 11 insertions(+), 7 deletions(-)
hooks/post-receive
