[SCM] PostGIS branch master updated. 3.6.0rc2-372-g88ad88be1
git at osgeo.org
git at osgeo.org
Fri Mar 6 13:15:11 PST 2026
the project "PostGIS".
via 88ad88be10d113781a2a8f4e67820a3cdb40638b (commit)
from 15349103ef89627d9be54a67bd81eabed3ca1072 (commit)
revisions in full, below.
commit 88ad88be10d113781a2a8f4e67820a3cdb40638b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Mar 6 11:28:09 2026 -0800
Remove rare extension priv escalation case, where account
with extension create privs can escalate to superuser
by piggy backing on an extension creation event.
From Sven Klemm (Tiger Data) and Allistair Ishmael Hakim (allistair.sh)
diff --git a/libpgcommon/sql/AddToSearchPath.sql.inc b/libpgcommon/sql/AddToSearchPath.sql.inc
index a5e02279e..ff313406c 100644
--- a/libpgcommon/sql/AddToSearchPath.sql.inc
+++ b/libpgcommon/sql/AddToSearchPath.sql.inc
@@ -16,10 +16,10 @@ DECLARE
BEGIN
WITH settings AS (
SELECT unnest(setconfig) config
- FROM pg_db_role_setting
+ FROM pg_catalog.pg_db_role_setting
WHERE setdatabase = (
SELECT oid
- FROM pg_database
+ FROM pg_catalog.pg_database
WHERE datname = current_database()
) and setrole = 0
@@ -30,10 +30,10 @@ BEGIN
RAISE NOTICE 'cur_search_path from pg_db_role_setting is %', var_cur_search_path;
-- only run this test if person creating the extension is a super user
- IF var_cur_search_path IS NULL AND (SELECT rolsuper FROM pg_roles where rolname = CURRENT_USER) THEN
+ IF var_cur_search_path IS NULL AND (SELECT rolsuper FROM pg_catalog.pg_roles where rolname = CURRENT_USER) THEN
SELECT setting
INTO var_cur_search_path
- FROM pg_file_settings
+ FROM pg_catalog.pg_file_settings
WHERE name = 'search_path' AND applied;
RAISE NOTICE 'cur_search_path from pg_file_settings is %', var_cur_search_path;
@@ -42,7 +42,7 @@ BEGIN
IF var_cur_search_path IS NULL THEN
SELECT boot_val
- FROM pg_settings
+ FROM pg_catalog.pg_settings
WHERE name = 'search_path';
RAISE NOTICE 'cur_search_path from pg_settings is %', var_cur_search_path;
@@ -63,7 +63,8 @@ BEGIN
RETURN var_result;
END
$BODY$
-SET search_path = pg_catalog -- make safe
+-- explicitly move pg_temp after pg_catalog in search path
+SET search_path = pg_catalog, pg_temp
LANGUAGE 'plpgsql' VOLATILE STRICT
Summary of changes:
libpgcommon/sql/AddToSearchPath.sql.inc | 13 +++++++------
1 file changed, 7 insertions(+), 6 deletions(-)
hooks/post-receive
