[SCM] PostGIS branch master updated. 3.6.0rc2-378-g7af31bf2c
git at osgeo.org
git at osgeo.org
Sun Mar 8 15:48:30 PDT 2026
the project "PostGIS".
via 7af31bf2cb1968d7f9f3a275e9723702788b8615 (commit)
from 9025206e69f7e8865b26d61ff771eee8d236d614 (commit)
revisions in full, below.
commit 7af31bf2cb1968d7f9f3a275e9723702788b8615
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Mar 9 02:46:35 2026 +0400
#5973: Respect pg_config bindir for utility installs
Closes #5973
diff --git a/NEWS b/NEWS
index 6ed876e0c..df835634c 100644
--- a/NEWS
+++ b/NEWS
@@ -32,6 +32,9 @@ This version requires GEOS 3.10 or higher
* Bug Fixes *
+ - #5973, Install PostGIS utilities under `pg_config --bindir` by default
+ and document `pg_config`-derived install paths more accurately
+ (Darafei Praliaskouski)
- #5948, [topology] Prevent MakeTopologyPrecise from erasing edges when
grid size exceeds their extent (Darafei Praliaskouski)
- #5959, Prevent histogram target overflow when analysing massive tables (Darafei Praliaskouski)
diff --git a/README.postgis b/README.postgis
index 21faf6dbf..ed38b126f 100644
--- a/README.postgis
+++ b/README.postgis
@@ -247,11 +247,9 @@ Installation paths will typically be derived by ``pg_config``:
- Lib in ``pg_config --pkglibdir``
- Binaries (loader/dumper) in ``pg_config --bindir``
- - Important support files in ``[prefix]/share/contrib``
- - Manual pages in ``[prefix]/man``
- - Documentation in in ``[prefix]/share/doc``
-Where `[prefix]` above is extracted from ``pg_config --configure``.
+ - Important support files in ``pg_config --sharedir``/contrib
+ - Manual pages in ``pg_config --mandir``
+ - Documentation in ``pg_config --docdir``
You can change them using ``./configure`` switches. See CONFIGURATION section.
diff --git a/configure.ac b/configure.ac
index d5fb6cc1b..ce0e97a11 100644
--- a/configure.ac
+++ b/configure.ac
@@ -622,6 +622,15 @@ if test "x$SUPPORT_POSTGRESQL" = "xyes"; then dnl {
AC_SUBST([PGSQL_BINDIR])
+ dnl Keep explicit --bindir, --exec-prefix, and --prefix overrides, but
+ dnl default utilities to the PostgreSQL bindir when the autoconf install
+ dnl directories were left entirely untouched.
+ if test "x$bindir" = 'x${exec_prefix}/bin' \
+ && test "x$exec_prefix" = xNONE \
+ && test "x$prefix" = xNONE; then
+ bindir="$PGSQL_BINDIR"
+ fi
dnl Extract the share directory
PGSQL_SHAREDIR=`"$PG_CONFIG" --sharedir`
@@ -670,6 +679,7 @@ if test "$prefix" != "NONE" -a "x$PG_CONFIG" != "xno"; then
AC_MSG_RESULT([ ignore the --prefix. For your info, using the values determined from ])
AC_MSG_RESULT([ $PG_CONFIG we will be installing: ])
AC_MSG_RESULT([ * postgis shared library in $PGSQL_LIBDIR ])
+ AC_MSG_RESULT([ * postgis utilities in $bindir ])
AC_MSG_RESULT([ * postgis SQL files in $PGSQL_SHAREDIR/contrib/postgis-$POSTGIS_MAJOR_VERSION.$POSTGIS_MINOR_VERSION ])
AC_MSG_RESULT([------------------------------------------------------------------------])
fi
@@ -2023,6 +2033,8 @@ fi
AC_MSG_RESULT([ PostgreSQL config: ${PG_CONFIG}])
AC_MSG_RESULT([ PostgreSQL version: ${PGSQL_FULL_VERSION}])
+ AC_MSG_RESULT([ PostgreSQL bindir: ${PGSQL_BINDIR}])
+ AC_MSG_RESULT([ PostGIS utilities: ${bindir}])
else
AC_MSG_RESULT([ PostgreSQL support: DISABLED])
fi
Summary of changes:
NEWS | 3 +++
README.postgis | 8 +++-----
configure.ac | 12 ++++++++++++
3 files changed, 18 insertions(+), 5 deletions(-)
hooks/post-receive
