[SCM] PostGIS branch master updated. 3.6.0rc2-379-ga586d720e
Sun Mar 8 16:25:55 PDT 2026
the project "PostGIS".
       via  a586d720eb01112b22052865feca01a6d4b6eb9e (commit)
      from  7af31bf2cb1968d7f9f3a275e9723702788b8615 (commit)
revisions in full, below.
commit a586d720eb01112b22052865feca01a6d4b6eb9e
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Mon Mar 9 03:24:04 2026 +0400
    Fix #6048 ST_Clip sparse band selection crash
    Closes #6048
diff --git a/NEWS b/NEWS
index df835634c..4bbdc0e1d 100644
--- a/NEWS
+++ b/NEWS
@@ -39,6 +39,8 @@ This version requires GEOS 3.10 or higher
           grid size exceeds their extent (Darafei Praliaskouski)
  - #5959, Prevent histogram target overflow when analysing massive tables (Darafei Praliaskouski)
  - #4828, geometry_columns handles NOT VALID SRID checks without errors (Darafei Praliaskouski)
+ - #6048, [raster] ST_Clip no longer crashes when clipping sparse band
+          selections (Darafei Praliaskouski)
  - #5645, Docs: keep code operators ("=>") intact in translated manuals
           by enforcing verbatim CSS (Darafei Praliaskouski)
  - #5593, Docs: render manual images with GraphicsMagick without temporary files,
diff --git a/raster/rt_pg/rtpg_mapalgebra.c b/raster/rt_pg/rtpg_mapalgebra.c
index c1cac17c3..bb173aa29 100644
--- a/raster/rt_pg/rtpg_mapalgebra.c
+++ b/raster/rt_pg/rtpg_mapalgebra.c
@@ -11,6 +11,7 @@
  * Copyright (C) 2009-2011 Mateusz Loskot <mateusz at loskot.net>
  * Copyright (C) 2008-2009 Sandro Santilli <strk at kbt.io>
  * Copyright (C) 2013 Nathaniel Hunter Clay <clay.nathaniel at gmail.com>
+ * Copyright (C) 2026 Darafei Praliaskouski <me at komzpa.net>
  * This program is free software; you can redistribute it and/or
  * modify it under the terms of the GNU General Public License
@@ -2993,8 +2994,6 @@ Datum RASTER_clip(PG_FUNCTION_ARGS)
 	bool typbyval;
 	char typalign;
-	int i = 0;
-	int j = 0;
 	int k = 0;
 	rtpg_clip_arg arg = NULL;
 	LWGEOM *tmpgeom = NULL;
@@ -3004,12 +3003,6 @@ Datum RASTER_clip(PG_FUNCTION_ARGS)
 	double nodataval;
 	double offset[4] = {0.};
-	int input_x = 0;
-	int input_y = 0;
-	int mask_x = 0;
-	int mask_y = 0;
-	int x = 0;
-	int y = 0;
 	int width = 0;
 	int height = 0;
 	int mask_width = 0;
@@ -3145,6 +3138,8 @@ Datum RASTER_clip(PG_FUNCTION_ARGS)
 	/* nband (1) */
 	if (!PG_ARGISNULL(1)) {
+		uint32_t band_count = 0;
 		array = PG_GETARG_ARRAYTYPE_P(1);
 		etype = ARR_ELEMTYPE(array);
 		get_typlenbyvalalign(etype, &typlen, &typbyval, &typalign);
@@ -3177,23 +3172,26 @@ Datum RASTER_clip(PG_FUNCTION_ARGS)
 			PG_RETURN_NULL();
-		for (i = 0, j = 0; i < arg->numbands; i++) {
-			if (nulls[i]) continue;
+		for (uint32_t i = 0; i < (uint32_t)arg->numbands; i++)
+			if (nulls[i])
+				continue;
 			switch (etype) {
 				case INT2OID:
-					arg->band[j].nband = DatumGetInt16(e[i]) - 1;
+					arg->band[band_count].nband = DatumGetInt16(e[i]) - 1;
 					break;
 				case INT4OID:
-					arg->band[j].nband = DatumGetInt32(e[i]) - 1;
+					arg->band[band_count].nband = DatumGetInt32(e[i]) - 1;
 					break;
-			j++;
+			band_count++;
-		if (j < arg->numbands) {
-			arg->band = repalloc(arg->band, sizeof(struct rtpg_clip_band_t) * j);
+		if (band_count < (uint32_t)arg->numbands)
+			arg->band = repalloc(arg->band, sizeof(struct rtpg_clip_band_t) * band_count);
 			if (arg->band == NULL) {
 				rtpg_clip_arg_destroy(arg);
 				PG_FREE_IF_COPY(pgraster, 0);
@@ -3202,12 +3200,14 @@ Datum RASTER_clip(PG_FUNCTION_ARGS)
 				PG_RETURN_NULL();
-			arg->numbands = j;
+			arg->numbands = (int)band_count;
 		/* validate band */
-		for (i = 0; i < arg->numbands; i++) {
-			if (!rt_raster_has_band(arg->raster, arg->band[i].nband)) {
+			if (!rt_raster_has_band(arg->raster, arg->band[i].nband))
 				elog(NOTICE, "Band at index %d not found in raster", arg->band[i].nband + 1);
@@ -3235,8 +3235,9 @@ Datum RASTER_clip(PG_FUNCTION_ARGS)
 				PG_RETURN_NULL();
-				arg->band[i].nband = i;
+				arg->band[i].nband = (int)i;
 				arg->band[i].hasnodata = 0;
 				arg->band[i].nodataval = 0;
@@ -3269,7 +3270,8 @@ Datum RASTER_clip(PG_FUNCTION_ARGS)
 		/* it doesn't matter if there are more nodataval */
-		for (i = 0, j = 0; i < arg->numbands; i++, j++) {
+		for (int32_t i = 0, j = 0; i < arg->numbands; i++, j++)
 			/* cap j to the last nodataval element */
 			if (j >= k)
 				j = k - 1;
@@ -3359,8 +3361,16 @@ Datum RASTER_clip(PG_FUNCTION_ARGS)
 	mask_band = rt_raster_get_band(arg->mask, 0);
 		input_band = rt_raster_get_band(arg->raster, arg->band[i].nband);
+		if (!input_band)
+			rtpg_clip_arg_destroy(arg);
+			PG_FREE_IF_COPY(pgraster, 0);
+			elog(ERROR, "RASTER_clip: Could not get input band at index %d", arg->band[i].nband);
+			PG_RETURN_NULL();
 		/* band metadata */
 		pixtype = rt_band_get_pixtype(input_band);
@@ -3378,7 +3388,8 @@ Datum RASTER_clip(PG_FUNCTION_ARGS)
 			nodataval = rt_band_get_min_value(input_band);
-		if (rt_raster_generate_new_band(rtn, pixtype, nodataval, hasnodata, nodataval, i) < 0) {
+		if (rt_raster_generate_new_band(rtn, pixtype, nodataval, hasnodata, nodataval, (int)i) < 0)
 			elog(ERROR, "RASTER_clip: Could not add new band in output raster");
@@ -3389,16 +3400,32 @@ Datum RASTER_clip(PG_FUNCTION_ARGS)
 			continue;
-		output_band = rt_raster_get_band(rtn, arg->band[i].nband);
+		 * Output bands are packed densely in request order, regardless of
+		 * the source band numbers used to populate them.
+		output_band = rt_raster_get_band(rtn, (int)i);
+		if (!output_band)
+			elog(ERROR, "RASTER_clip: Could not get output band at index %u", i);
+			PG_RETURN_NULL();
-		if (!mask_band) {
+		if (!mask_band)
 			continue;
-		for (y = 0; y < height; y++) {
-			for (x = 0; x < width; x++) {
-				mask_x = x - (int)offset[2];
-				mask_y = y - (int)offset[3];
+		for (int y = 0; y < height; y++)
+			for (int x = 0; x < width; x++)
+				int mask_x = x - (int)offset[2];
+				int mask_y = y - (int)offset[3];
+				int input_x = x - (int)offset[0];
+				int input_y = y - (int)offset[1];
 				if (!(
 					mask_x >= 0 &&
@@ -3420,9 +3447,6 @@ Datum RASTER_clip(PG_FUNCTION_ARGS)
 					continue;
-				input_x = x - (int)offset[0];
-				input_y = y - (int)offset[1];
 				if (rt_band_get_pixel(input_band, input_x, input_y, &value, &isnodata) != ES_NONE) {
diff --git a/raster/test/regress/rt_clip.sql b/raster/test/regress/rt_clip.sql
index 462e73b21..af358506c 100644
--- a/raster/test/regress/rt_clip.sql
+++ b/raster/test/regress/rt_clip.sql
@@ -172,4 +172,61 @@ FROM ST_Clip(
 		1, '8BUI', 1, 0
 	ST_GeomFromText('POLYGON((0 0.0009999, 0.0001 0.0009999, 0.0001 0.0009, 0 0.0009, 0 0.0009999))')
-) AS rast;
\ No newline at end of file
+) AS rast;
+-- #6048 clipping a sparse band selection should populate dense output bands
+WITH test_rast AS (
+	SELECT ST_AddBand(
+		ST_AddBand(
+			ST_AddBand(
+				ST_SetSRID(
+					ST_MakeEmptyRaster(4, 4, 0, 4, 1, -1, 0, 0),
+					4326
+				'8BUI'::text, 11, 1
+			'8BUI'::text, 22, 2
+		'8BUI'::text, 33, 3
+	) AS rast
+), test_geom AS (
+	SELECT ST_SetSRID(ST_MakeEnvelope(1, 1, 3, 3), 4326) AS geom
+SELECT '#6048.1',
+	ST_Width(rast),
+	ST_Height(rast),
+	ST_NumBands(rast),
+	ST_BandNoDataValue(rast, 1)::int,
+	ST_Value(rast, 1, 2, 2)::int
+FROM (
+	SELECT _ST_Clip(rast, ARRAY[3], geom, ARRAY[255, 255, 255], FALSE) AS rast
+	FROM test_rast, test_geom
+) AS clipped;
+		ST_AddBand(
+			ST_AddBand(
+				ST_SetSRID(
+					4326
+	) AS rast
+), test_geom AS (
+SELECT '#6048.2',
+	ST_BandNoDataValue(rast, 2)::int,
+	ST_Value(rast, 1, 2, 2)::int,
+	ST_Value(rast, 2, 2, 2)::int
+FROM (
+	SELECT _ST_Clip(rast, ARRAY[3, 1], geom, ARRAY[253, 251], FALSE) AS rast
+) AS clipped;
diff --git a/raster/test/regress/rt_clip_expected b/raster/test/regress/rt_clip_expected
index c704cb356..c2754b520 100644
--- a/raster/test/regress/rt_clip_expected
+++ b/raster/test/regress/rt_clip_expected
@@ -1065,3 +1065,5 @@
 4|2|5|3|4|4|f|3|POLYGON((3 -3,4 -3,4 -4,3 -4,3 -3))|16
 4|2|5|3|4|4|t|3|POLYGON((3 -3,4 -3,4 -4,3 -4,3 -3))|16
 0|0.001|10|10
+#6048.1|4|4|1|255|33
+#6048.2|2|253|251|33|11
Summary of changes:
 NEWS                                 |  2 +
 raster/rt_pg/rtpg_mapalgebra.c       | 88 +++++++++++++++++++++++-------------
 raster/test/regress/rt_clip.sql      | 59 +++++++++++++++++++++++-
 raster/test/regress/rt_clip_expected |  2 +
 4 files changed, 118 insertions(+), 33 deletions(-)
hooks/post-receive
