[SCM] PostGIS branch master updated. 3.6.0rc2-380-g20fcd89ae
git at osgeo.org
git at osgeo.org
Mon Mar 9 02:09:48 PDT 2026
the project "PostGIS".
via 20fcd89ae646c2557cf892251242bc16a76a927c (commit)
from a586d720eb01112b22052865feca01a6d4b6eb9e (commit)
revisions in full, below.
commit 20fcd89ae646c2557cf892251242bc16a76a927c
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Mar 9 13:00:44 2026 +0400
#1599 Improve country-aware address normalization
Canonicalize explicit country tokens in the address parser, carry country through norm_addy, and add regressions for country-aware tiger normalization while keeping tiger usable without address_standardizer.
Closes #1599
diff --git a/NEWS b/NEWS
index 4bbdc0e1d..d9bf639d8 100644
--- a/NEWS
+++ b/NEWS
@@ -41,6 +41,10 @@ This version requires GEOS 3.10 or higher
- #4828, geometry_columns handles NOT VALID SRID checks without errors (Darafei Praliaskouski)
- #6048, [raster] ST_Clip no longer crashes when clipping sparse band
selections (Darafei Praliaskouski)
+ - #1599, [address_standardizer] parse_address() and normalize_address() now
+ canonicalize trailing country tokens to ISO 3166-1 alpha-2 codes and
+ expose country on normalized addresses
+ (Darafei Praliaskouski)
- #5645, Docs: keep code operators ("=>") intact in translated manuals
by enforcing verbatim CSS (Darafei Praliaskouski)
- #5593, Docs: render manual images with GraphicsMagick without temporary files,
diff --git a/doc/extras_address_standardizer.xml b/doc/extras_address_standardizer.xml
index 287151ca4..d5735096d 100644
--- a/doc/extras_address_standardizer.xml
+++ b/doc/extras_address_standardizer.xml
@@ -14,8 +14,9 @@
<para>The parser works from right to left looking first at the macro elements
for postcode, state/province, city, and then looks micro elements to determine
if we are dealing with a house number street or intersection or landmark.
-It currently does not look for a country code or name, but that could be
-introduced in the future.</para>
+It conservatively recognizes trailing country tokens and canonicalizes them to
+ISO 3166-1 alpha-2 codes. Explicit country aliases update the parsed country,
+and otherwise the default US or CA inference still applies.</para>
<variablelist>
<varlistentry>
<term>Country code</term>
diff --git a/doc/installation.xml b/doc/installation.xml
index 35b05227f..e6805f8c0 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -925,7 +925,7 @@ test test-standardize_address_2 ... ok
<programlisting>cd extensions/postgis_tiger_geocoder
make install
make installcheck
- </programlisting></para>
+ </programlisting></para>
<para>output should look like:
<screen>============== dropping database "contrib_regression" ==============
DROP DATABASE
diff --git a/extensions/address_standardizer/address_parser.c b/extensions/address_standardizer/address_parser.c
index 3e1c642bf..cbe318942 100644
--- a/extensions/address_standardizer/address_parser.c
+++ b/extensions/address_standardizer/address_parser.c
@@ -21,8 +21,10 @@
#endif
Datum parse_address(PG_FUNCTION_ARGS);
+Datum strip_explicit_country(PG_FUNCTION_ARGS);
PG_FUNCTION_INFO_V1(parse_address);
+PG_FUNCTION_INFO_V1(strip_explicit_country);
@@ -110,3 +112,18 @@ Datum parse_address(PG_FUNCTION_ARGS)
return result;
+Datum
+strip_explicit_country(PG_FUNCTION_ARGS)
+ char *input;
+ char *working;
+ char country_code[3] = {0};
+ input = text_to_cstring(PG_GETARG_TEXT_P(0));
+ working = pstrdup(input);
+ if (strip_explicit_country_token(working, country_code))
+ PG_RETURN_TEXT_P(cstring_to_text(working));
+ PG_RETURN_TEXT_P(cstring_to_text(input));
diff --git a/extensions/address_standardizer/address_standardizer.c b/extensions/address_standardizer/address_standardizer.c
index 363185529..5adb43666 100644
--- a/extensions/address_standardizer/address_standardizer.c
+++ b/extensions/address_standardizer/address_standardizer.c
@@ -386,11 +386,19 @@ static const char *
stdaddr_field_value(const STDADDR *stdaddr, size_t offset)
const char *const *field_value;
+ const char *canonical_country;
if (!stdaddr)
return NULL;
field_value = (const char *const *)((const char *)stdaddr + offset);
+ if (offset == offsetof(STDADDR, country) && *field_value)
+ canonical_country = country_code_from_name(*field_value);
+ if (canonical_country)
+ return canonical_country;
return *field_value;
diff --git a/extensions/address_standardizer/address_standardizer_functions.sql.in b/extensions/address_standardizer/address_standardizer_functions.sql.in
index 65c3e919b..535a28de3 100644
--- a/extensions/address_standardizer/address_standardizer_functions.sql.in
+++ b/extensions/address_standardizer/address_standardizer_functions.sql.in
@@ -47,3 +47,7 @@ CREATE OR REPLACE FUNCTION parse_address(IN text,
AS 'MODULE_PATHNAME', 'parse_address'
LANGUAGE 'c' IMMUTABLE STRICT;
+CREATE OR REPLACE FUNCTION strip_explicit_country(IN text)
+ RETURNS text
+ AS 'MODULE_PATHNAME', 'strip_explicit_country'
+ LANGUAGE 'c' IMMUTABLE STRICT;
diff --git a/extensions/address_standardizer/expected/test-standardize_address_1.out b/extensions/address_standardizer/expected/test-standardize_address_1.out
index 73604c0b6..ff6dbd83d 100644
--- a/extensions/address_standardizer/expected/test-standardize_address_1.out
+++ b/extensions/address_standardizer/expected/test-standardize_address_1.out
@@ -13,31 +13,31 @@ select * from standardize_address('us_lex'::text, 'us_gaz'::text, 'us_rules'::te
SELECT '#2981' As ticket, * FROM standardize_address('us_lex','us_gaz','us_rules', '1566 NEW STATE HWY, RAYNHAM, MA');
ticket | building | house_num | predir | qual | pretype | name | suftype | sufdir | ruralroute | extra | city | state | country | postcode | box | unit
- #2981 | | 1566 | | | | NEW STATE HIGHWAY | | | | | RAYNHAM | MASSACHUSETTS | USA | | |
+ #2981 | | 1566 | | | | NEW STATE HIGHWAY | | | | | RAYNHAM | MASSACHUSETTS | US | | |
(1 row)
SELECT '#2978a' As ticket, * FROM standardize_address('us_lex','us_gaz','us_rules', '10-20 DORRANCE ST PROVIDENCE RI' );
- #2978a | | 10 20 | | | | DORRANCE | STREET | | | | PROVIDENCE | RHODE ISLAND | USA | | |
+ #2978a | | 10 20 | | | | DORRANCE | STREET | | | | PROVIDENCE | RHODE ISLAND | US | | |
(1 row)
SELECT '#2978b' As ticket, * FROM standardize_address('us_lex','us_gaz','us_rules', '10 20 DORRANCE ST PROVIDENCE RI' );
- #2978b | | 10 20 | | | | DORRANCE | STREET | | | | PROVIDENCE | RHODE ISLAND | USA | | |
+ #2978b | | 10 20 | | | | DORRANCE | STREET | | | | PROVIDENCE | RHODE ISLAND | US | | |
(1 row)
SELECT '#2978c' As ticket, * FROM standardize_address('us_lex','us_gaz','us_rules', '10-20 DORRANCE ST, PROVIDENCE, RI');
- #2978c | | 10 20 | | | | DORRANCE | STREET | | | | PROVIDENCE | RHODE ISLAND | USA | | |
+ #2978c | | 10 20 | | | | DORRANCE | STREET | | | | PROVIDENCE | RHODE ISLAND | US | | |
(1 row)
SELECT '#state_only_macro' AS ticket, * FROM standardize_address('us_lex','us_gaz','us_rules', '25 Prince Street, NC 09985');
- #state_only_macro | | 25 | | | | PRINCE | STREET | | | | | NORTH CAROLINA | USA | 09985 | |
+ #state_only_macro | | 25 | | | | PRINCE | STREET | | | | | NORTH CAROLINA | US | 09985 | |
(1 row)
SELECT '#5299a' AS ticket, * FROM standardize_address('us_lex', 'us_gaz', 'us_rules','1 Timepiece Point','Boston, MA, 02220');
@@ -55,7 +55,7 @@ SELECT '#5299b' AS ticket, * FROM standardize_address('us_lex', 'us_gaz', 'us_r
SELECT '#5695a' AS ticket, * FROM standardize_address('us_lex', 'us_gaz', 'us_rules', 'ONE E PIMA ST STE 999, TUCSON, AZ');
- #5695a | | 1 | EAST | | | PIMA | STREET | | | | TUCSON | ARIZONA | USA | | | SUITE 999
+ #5695a | | 1 | EAST | | | PIMA | STREET | | | | TUCSON | ARIZONA | US | | | SUITE 999
(1 row)
DO $$
diff --git a/extensions/address_standardizer/parseaddress-api.c b/extensions/address_standardizer/parseaddress-api.c
index 8abf1d1b2..408a592f3 100644
--- a/extensions/address_standardizer/parseaddress-api.c
+++ b/extensions/address_standardizer/parseaddress-api.c
@@ -2,6 +2,7 @@
* parseaddres.c - utility to crack a string into address, city st zip
* Copyright 2006 Stephen Woodbridge
+ * Copyright 2026 Darafei Praliaskouski <me at komzpa.net>
* This code is released under and MIT-X style license,
@@ -9,13 +10,10 @@
* woodbri at swoodbridge.com
* woodbr at imaptools.com
- * TODO:
- * * add recognition of country before or after postalcode
#include <string.h>
+#include <stdlib.h>
#include <ctype.h>
#include <stdio.h>
@@ -48,6 +46,23 @@ const char *parseaddress_cvsid();
char *clean_leading_punct(char *s);
static int is_parse_separator(unsigned char c);
static size_t normalize_address_input(char *s);
+static size_t normalize_country_token(const char *src, char *dst, size_t dst_size);
+static bool ends_with_supported_macro(const char *s);
+static bool extract_trailing_country(char *s, char *country_code);
+static const char *const us_zip_regex = "\\b(\\d{5})[-\\s]{0,1}?(\\d{0,4})?$";
+static const char *const canada_zip_regex = "\\b([a-z]\\d[a-z]\\s?\\d[a-z]\\d)$";
+static const char *const canada_province_regex = "^(?-xism:(?i:(?=[abmnopqsy])(?:n[ltsu]|[am]b|[bq]c|on|pe|sk|yt)))$";
+static const char *const us_ca_state_regex =
+ "\\b(?-xism:(?i:(?=[abcdfghiklmnopqrstuvwy])(?:a(?:l(?:a(?:bam|sk)a|berta)?|mer(?:ican)?\\ samoa|r(?:k(?:ansas)?|izona)?|[kszb])|s(?:a(?:moa|skatchewan)|outh\\ (?:carolin|dakot)a|\\ (?:carolin|dakot)a|[cdk])|c(?:a(?:lif(?:ornia)?)?|o(?:nn(?:ecticut)?|lorado)?|t)|d(?:e(?:la(?:ware)?)?|istrict\\ of\\ columbia|c)|f(?:l(?:(?:orid)?a)?|ederal\\ states\\ of\\ micronesia|m)|m(?:i(?:c(?:h(?:igan)?|ronesia)|nn(?:esota)?|ss(?:(?:issipp|our)i)?)?|a(?:r(?:shall(?:\\ is(?:l(?:and)?)?)?|yland)|ss(?:achusetts)?|ine|nitoba)?|o(?:nt(?:ana)?)?|[ehdnstpb])|g(?:u(?:am)?|(?:eorgi)?a)|h(?:awai)?i|i(?:d(?:aho)?|l(?:l(?:inois)?)?|n(?:d(?:iana)?)?|(?:ow)?a)|k(?:(?:ansa)?s|(?:entuck)?y)|l(?:a(?:bordor)?|ouisiana)|n(?:e(?:w(?:\\ (?:foundland(?:\\ and\\ labordor)?|hampshire|jersey|mexico|(?:yor|brunswic)k)|foundland)|(?:brask|vad)a)?|o(?:rth(?:\\ (?:mariana(?:\\ is(?:l(?:and)?)?)?|(?:carolin|dakot)a)|west\\ territor(?:ies|y))|va\\ scotia)|\\ (?:carolin|dakot)a|u(?:navut)?|[vhjmycdblsf]|w?t)|o(?:h(?:io)?|k(
?:lahoma)?|r(?:egon)?|n(?:t(?:ario)?)?)|p(?:a(?:lau)?|e(?:nn(?:sylvania)?|i)?|r(?:ince\\ edward\\ island)?|w|uerto\\ rico)|r(?:hode\\ island|i)|t(?:e(?:nn(?:essee)?|xas)|[nx])|ut(?:ah)?|v(?:i(?:rgin(?:\\ islands|ia))?|(?:ermon)?t|a)|w(?:a(?:sh(?:ington)?)?|i(?:sc(?:onsin)?)?|y(?:oming)?|(?:est)?\\ virginia|v)|b(?:ritish\\ columbia|c)|q(?:uebe)?c|y(?:ukon|t))))$";
+typedef struct country_alias {
+ const char *alias;
+ const char *alpha2;
+} CountryAlias;
+static const CountryAlias country_aliases[] = {
+#include "parseaddress-countries.h"
static int
@@ -97,6 +112,171 @@ normalize_address_input(char *s)
return write_pos;
+static size_t
+normalize_country_token(const char *src, char *dst, size_t dst_size)
+ size_t write_pos = 0;
+ bool previous_was_space = false;
+ if (!src || !dst || !dst_size)
+ return 0;
+ for (; *src != '\0' && write_pos + 1 < dst_size; src++)
+ unsigned char current = (unsigned char)*src;
+ if (isalpha(current))
+ dst[write_pos++] = (char)toupper(current);
+ previous_was_space = false;
+ continue;
+ if (isspace(current) || ispunct(current))
+ if (!write_pos || previous_was_space)
+ continue;
+ dst[write_pos++] = ' ';
+ previous_was_space = true;
+ if (write_pos && dst[write_pos - 1] == ' ')
+ write_pos--;
+ dst[write_pos] = '\0';
+ return write_pos;
+static int
+compare_country_alias(const void *lhs, const void *rhs)
+ const CountryAlias *left = (const CountryAlias *)lhs;
+ const CountryAlias *right = (const CountryAlias *)rhs;
+ return strcmp(left->alias, right->alias);
+const char *
+country_code_from_name(const char *country_name)
+ CountryAlias key;
+ char normalized_country[128];
+ const CountryAlias *match;
+ if (!normalize_country_token(country_name, normalized_country, sizeof(normalized_country)))
+ return NULL;
+ key.alias = normalized_country;
+ key.alpha2 = NULL;
+ match = bsearch(
+ &key, country_aliases, lengthof(country_aliases), sizeof(country_aliases[0]), compare_country_alias);
+ return match ? match->alpha2 : NULL;
+ * Recognize the right-most macro shape that this parser already knows how to
+ * consume. That lets us conservatively strip trailing countries without
+ * erasing ordinary trailing qualifiers, and still supports short ZIP fragments
+ * once they are paired with a valid trailing state/province.
+static bool
+ends_with_supported_macro(const char *s)
+ int macro_ovect[OVECCOUNT];
+ int rc;
+ char *state_probe;
+ if (!s || *s == '\0')
+ return false;
+ rc = match((char *)us_zip_regex, (char *)s, macro_ovect, 0);
+ if (rc >= 2)
+ return true;
+ rc = match((char *)canada_zip_regex, (char *)s, macro_ovect, PARSE_CASELESS);
+ if (rc >= 1)
+ return true;
+ rc = match((char *)us_ca_state_regex, (char *)s, macro_ovect, PARSE_CASELESS);
+ if (rc > 0)
+ return true;
+ rc = match("\\b(\\d{2,4})$", (char *)s, macro_ovect, 0);
+ if (rc < 2)
+ return false;
+ state_probe = pstrdup(s);
+ *(state_probe + macro_ovect[0]) = '\0';
+ (void)clean_trailing_punct(state_probe);
+ rc = match((char *)us_ca_state_regex, state_probe, macro_ovect, PARSE_CASELESS);
+ pfree(state_probe);
+ return rc > 0;
+ * Strip a trailing country token before macro parsing so postcode and state
+ * extraction still see the expected right-most fields. Known US/CA country
+ * tokens update the country code; other recognized country names are stripped
+ * without changing the default country inference.
+static bool
+extract_trailing_country(char *s, char *country_code)
+ int split_ovect[OVECCOUNT];
+ int rc;
+ const char *matched_country_code;
+ char saved;
+ if (!s || !country_code)
+ return false;
+ rc = match("([\\s,]+)([A-Za-z][A-Za-z\\s]{1,})$", s, split_ovect, 0);
+ if (rc < 3)
+ return false;
+ saved = s[split_ovect[0]];
+ s[split_ovect[0]] = '\0';
+ matched_country_code = country_code_from_name(s + split_ovect[4]);
+ if (!matched_country_code)
+ s[split_ovect[0]] = saved;
+ return false;
+ if (!ends_with_supported_macro(s))
+ return false;
+ strcpy(country_code, matched_country_code);
+ (void)clean_trailing_punct(s);
+ return true;
+bool
+strip_explicit_country_token(char *s, char *country_code)
+ size_t normalized_length;
+ return false;
+ normalized_length = normalize_address_input(s);
+ if (!normalized_length)
+ return false;
+ return extract_trailing_country(s, country_code);
const char *
get_state_regex(const char *st)
@@ -253,11 +433,10 @@ parseaddress(HHash *stH, char *s, int *reterr)
#include "parseaddress-regex.h"
int ovect[OVECCOUNT];
- char *stregx;
- char *caregx;
char *state = NULL;
char *regx;
+ bool explicit_country = false;
int rc;
ADDRESS *ret;
#ifdef USE_HSEARCH
@@ -299,14 +478,16 @@ parseaddress(HHash *stH, char *s, int *reterr)
ret->cc = (char *)palloc0(3 * sizeof(char));
strcpy(ret->cc, "US");
+ explicit_country = extract_trailing_country(s, ret->cc);
/* get US zipcode components */
- rc = match("\\b(\\d{5})[-\\s]{0,1}?(\\d{0,4})?$", s, ovect, 0);
+ rc = match((char *)us_zip_regex, s, ovect, 0);
if (rc >= 2)
ret->zip = (char *)palloc0((ovect[3] - ovect[2] + 1) * sizeof(char));
strncpy(ret->zip, s + ovect[2], ovect[3] - ovect[2]);
- if (rc >= 3)
+ if (rc >= 3 && ovect[5] > ovect[4])
ret->zipplus = (char *)palloc0((ovect[5] - ovect[4] + 1) * sizeof(char));
strncpy(ret->zipplus, s + ovect[4], ovect[5] - ovect[4]);
@@ -317,27 +498,54 @@ parseaddress(HHash *stH, char *s, int *reterr)
/* get canada zipcode components */
else
- rc = match("\\b([a-z]\\d[a-z]\\s?\\d[a-z]\\d)$", s, ovect, PARSE_CASELESS);
+ rc = match((char *)canada_zip_regex, s, ovect, PARSE_CASELESS);
if (rc >= 1)
ret->zip = (char *)palloc0((ovect[1] - ovect[0] + 1) * sizeof(char));
strncpy(ret->zip, s + ovect[0], ovect[1] - ovect[0]);
- strcpy(ret->cc, "CA");
+ if (!explicit_country)
+ strcpy(ret->cc, "CA");
/* truncate the postalcode off the string */
*(s + ovect[0]) = '\0';
+ else
+ int state_ovect[OVECCOUNT];
+ * Accept a short trailing ZIP fragment only when removing it exposes
+ * a valid trailing state/province. That keeps "MA 021" working
+ * without turning arbitrary suffixes like "Suite 201" into ZIPs.
+ rc = match("\\b(\\d{2,4})$", s, ovect, 0);
+ if (rc >= 2)
+ *(state_probe + ovect[0]) = '\0';
+ rc = match((char *)us_ca_state_regex, state_probe, state_ovect, PARSE_CASELESS);
+ if (rc > 0)
+ ret->zip = (char *)palloc0((ovect[3] - ovect[2] + 1) * sizeof(char));
+ strncpy(ret->zip, s + ovect[2], ovect[3] - ovect[2]);
+ *(s + ovect[0]) = '\0';
/* clean trailing punctuation */
+ explicit_country = extract_trailing_country(s, ret->cc) || explicit_country;
/* get state components */
- caregx = "^(?-xism:(?i:(?=[abmnopqsy])(?:n[ltsu]|[am]b|[bq]c|on|pe|sk|yt)))$";
- stregx =
- "\\b(?-xism:(?i:(?=[abcdfghiklmnopqrstuvwy])(?:a(?:l(?:a(?:bam|sk)a|berta)?|mer(?:ican)?\\ samoa|r(?:k(?:ansas)?|izona)?|[kszb])|s(?:a(?:moa|skatchewan)|outh\\ (?:carolin|dakot)a|\\ (?:carolin|dakot)a|[cdk])|c(?:a(?:lif(?:ornia)?)?|o(?:nn(?:ecticut)?|lorado)?|t)|d(?:e(?:la(?:ware)?)?|istrict\\ of\\ columbia|c)|f(?:l(?:(?:orid)?a)?|ederal\\ states\\ of\\ micronesia|m)|m(?:i(?:c(?:h(?:igan)?|ronesia)|nn(?:esota)?|ss(?:(?:issipp|our)i)?)?|a(?:r(?:shall(?:\\ is(?:l(?:and)?)?)?|yland)|ss(?:achusetts)?|ine|nitoba)?|o(?:nt(?:ana)?)?|[ehdnstpb])|g(?:u(?:am)?|(?:eorgi)?a)|h(?:awai)?i|i(?:d(?:aho)?|l(?:l(?:inois)?)?|n(?:d(?:iana)?)?|(?:ow)?a)|k(?:(?:ansa)?s|(?:entuck)?y)|l(?:a(?:bordor)?|ouisiana)|n(?:e(?:w(?:\\ (?:foundland(?:\\ and\\ labordor)?|hampshire|jersey|mexico|(?:yor|brunswic)k)|foundland)|(?:brask|vad)a)?|o(?:rth(?:\\ (?:mariana(?:\\ is(?:l(?:and)?)?)?|(?:carolin|dakot)a)|west\\ territor(?:ies|y))|va\\ scotia)|\\ (?:carolin|dakot)a|u(?:navut)?|[vhjmycdblsf]|w?t)|o(?:h(?:io)?|k
(?:lahoma)?|r(?:egon)?|n(?:t(?:ario)?)?)|p(?:a(?:lau)?|e(?:nn(?:sylvania)?|i)?|r(?:ince\\ edward\\ island)?|w|uerto\\ rico)|r(?:hode\\ island|i)|t(?:e(?:nn(?:essee)?|xas)|[nx])|ut(?:ah)?|v(?:i(?:rgin(?:\\ islands|ia))?|(?:ermon)?t|a)|w(?:a(?:sh(?:ington)?)?|i(?:sc(?:onsin)?)?|y(?:oming)?|(?:est)?\\ virginia|v)|b(?:ritish\\ columbia|c)|q(?:uebe)?c|y(?:ukon|t))))$";
- rc = match(stregx, s, ovect, PARSE_CASELESS);
+ rc = match((char *)us_ca_state_regex, s, ovect, PARSE_CASELESS);
if (rc > 0)
state = (char *)palloc0((ovect[1] - ovect[0] + 1) * sizeof(char));
@@ -371,8 +579,8 @@ parseaddress(HHash *stH, char *s, int *reterr)
/* check if it a Canadian Province */
- rc = match(caregx, ret->st, ovect, PARSE_CASELESS);
- if (rc > 0)
+ rc = match((char *)canada_province_regex, ret->st, ovect, PARSE_CASELESS);
+ if (rc > 0 && !explicit_country)
// if (ret->cc) printf(" CC: %s\n", ret->cc);
diff --git a/extensions/address_standardizer/parseaddress-api.h b/extensions/address_standardizer/parseaddress-api.h
index 4dffb5ab8..bb47558e7 100644
--- a/extensions/address_standardizer/parseaddress-api.h
+++ b/extensions/address_standardizer/parseaddress-api.h
@@ -57,6 +57,8 @@ typedef struct address_struct {
int clean_trailing_punct(char *s);
void strtoupper(char *s);
int match(char *pattern, char *s, int *ovect, int options);
+const char *country_code_from_name(const char *country_name);
+bool strip_explicit_country_token(char *s, char *country_code);
ADDRESS *parseaddress(HHash *stH, char *s, int *err);
int load_state_hash(HHash *stH);
void free_state_hash(HHash *stH);
diff --git a/extensions/address_standardizer/parseaddress-countries.h b/extensions/address_standardizer/parseaddress-countries.h
new file mode 100644
index 000000000..3b94c4932
--- /dev/null
+++ b/extensions/address_standardizer/parseaddress-countries.h
@@ -0,0 +1,942 @@
+ * Country aliases for parse_address(), generated from iso-codes and
+ * a small compatibility alias set. Keep this list sorted by alias.
+{"ABW", "AW"},
+{"AD", "AD"},
+{"AE", "AE"},
+{"AF", "AF"},
+{"AFG", "AF"},
+{"AFGHANISTAN", "AF"},
+{"AG", "AG"},
+{"AGO", "AO"},
+{"AI", "AI"},
+{"AIA", "AI"},
+{"AL", "AL"},
+{"ALA", "AX"},
+{"ALAND ISLANDS", "AX"},
+{"ALB", "AL"},
+{"ALBANIA", "AL"},
+{"ALGERIA", "DZ"},
+{"AM", "AM"},
+{"AMERICAN SAMOA", "AS"},
+{"AND", "AD"},
+{"ANDORRA", "AD"},
+{"ANGOLA", "AO"},
+{"ANGUILLA", "AI"},
+{"ANTARCTICA", "AQ"},
+{"ANTIGUA AND BARBUDA", "AG"},
+{"AO", "AO"},
+{"AQ", "AQ"},
+{"AR", "AR"},
+{"ARAB REPUBLIC OF EGYPT", "EG"},
+{"ARE", "AE"},
+{"ARG", "AR"},
+{"ARGENTINA", "AR"},
+{"ARGENTINE REPUBLIC", "AR"},
+{"ARM", "AM"},
+{"ARMENIA", "AM"},
+{"ARUBA", "AW"},
+{"AS", "AS"},
+{"ASM", "AS"},
+{"AT", "AT"},
+{"ATA", "AQ"},
+{"ATF", "TF"},
+{"ATG", "AG"},
+{"AU", "AU"},
+{"AUS", "AU"},
+{"AUSTRALIA", "AU"},
+{"AUSTRIA", "AT"},
+{"AUT", "AT"},
+{"AW", "AW"},
+{"AX", "AX"},
+{"AZ", "AZ"},
+{"AZE", "AZ"},
+{"AZERBAIJAN", "AZ"},
+{"BA", "BA"},
+{"BAHAMAS", "BS"},
+{"BAHRAIN", "BH"},
+{"BANGLADESH", "BD"},
+{"BARBADOS", "BB"},
+{"BB", "BB"},
+{"BD", "BD"},
+{"BDI", "BI"},
+{"BE", "BE"},
+{"BEL", "BE"},
+{"BELARUS", "BY"},
+{"BELGIUM", "BE"},
+{"BELIZE", "BZ"},
+{"BEN", "BJ"},
+{"BENIN", "BJ"},
+{"BERMUDA", "BM"},
+{"BES", "BQ"},
+{"BF", "BF"},
+{"BFA", "BF"},
+{"BG", "BG"},
+{"BGD", "BD"},
+{"BGR", "BG"},
+{"BH", "BH"},
+{"BHR", "BH"},
+{"BHS", "BS"},
+{"BHUTAN", "BT"},
+{"BI", "BI"},
+{"BIH", "BA"},
+{"BJ", "BJ"},
+{"BL", "BL"},
+{"BLM", "BL"},
+{"BLR", "BY"},
+{"BLZ", "BZ"},
+{"BM", "BM"},
+{"BMU", "BM"},
+{"BN", "BN"},
+{"BO", "BO"},
+{"BOL", "BO"},
+{"BOLIVARIAN REPUBLIC OF VENEZUELA", "VE"},
+{"BOLIVIA", "BO"},
+{"BOLIVIA PLURINATIONAL STATE OF", "BO"},
+{"BONAIRE SINT EUSTATIUS AND SABA", "BQ"},
+{"BOSNIA AND HERZEGOVINA", "BA"},
+{"BOSNIA HERZEGOVINA", "BA"},
+{"BOTSWANA", "BW"},
+{"BOUVET ISLAND", "BV"},
+{"BQ", "BQ"},
+{"BR", "BR"},
+{"BRA", "BR"},
+{"BRAZIL", "BR"},
+{"BRB", "BB"},
+{"BRITAIN", "GB"},
+{"BRITISH INDIAN OCEAN TERRITORY", "IO"},
+{"BRITISH VIRGIN ISLANDS", "VG"},
+{"BRN", "BN"},
+{"BRUNEI DARUSSALAM", "BN"},
+{"BS", "BS"},
+{"BT", "BT"},
+{"BTN", "BT"},
+{"BULGARIA", "BG"},
+{"BURKINA FASO", "BF"},
+{"BURMA", "MM"},
+{"BURUNDI", "BI"},
+{"BV", "BV"},
+{"BVT", "BV"},
+{"BW", "BW"},
+{"BWA", "BW"},
+{"BY", "BY"},
+{"BZ", "BZ"},
+{"CA", "CA"},
+{"CABO VERDE", "CV"},
+{"CAF", "CF"},
+{"CAMBODIA", "KH"},
+{"CAMEROON", "CM"},
+{"CAN", "CA"},
+{"CANADA", "CA"},
+{"CAYMAN ISLANDS", "KY"},
+{"CC", "CC"},
+{"CCK", "CC"},
+{"CD", "CD"},
+{"CENTRAL AFRICAN REPUBLIC", "CF"},
+{"CF", "CF"},
+{"CG", "CG"},
+{"CH", "CH"},
+{"CHAD", "TD"},
+{"CHE", "CH"},
+{"CHILE", "CL"},
+{"CHINA", "CN"},
+{"CHL", "CL"},
+{"CHN", "CN"},
+{"CHRISTMAS ISLAND", "CX"},
+{"CI", "CI"},
+{"CIV", "CI"},
+{"CK", "CK"},
+{"CL", "CL"},
+{"CM", "CM"},
+{"CMR", "CM"},
+{"CN", "CN"},
+{"CO", "CO"},
+{"COCOS KEELING ISLANDS", "CC"},
+{"COD", "CD"},
+{"COG", "CG"},
+{"COK", "CK"},
+{"COL", "CO"},
+{"COLOMBIA", "CO"},
+{"COM", "KM"},
+{"COMMONWEALTH OF DOMINICA", "DM"},
+{"COMMONWEALTH OF THE BAHAMAS", "BS"},
+{"COMMONWEALTH OF THE NORTHERN MARIANA ISLANDS", "MP"},
+{"COMOROS", "KM"},
+{"CONGO", "CG"},
+{"CONGO THE DEMOCRATIC REPUBLIC OF THE", "CD"},
+{"COOK ISLANDS", "CK"},
+{"COSTA RICA", "CR"},
+{"COTE D IVOIRE", "CI"},
+{"CPV", "CV"},
+{"CR", "CR"},
+{"CRI", "CR"},
+{"CROATIA", "HR"},
+{"CU", "CU"},
+{"CUB", "CU"},
+{"CUBA", "CU"},
+{"CURACAO", "CW"},
+{"CUW", "CW"},
+{"CV", "CV"},
+{"CW", "CW"},
+{"CX", "CX"},
+{"CXR", "CX"},
+{"CY", "CY"},
+{"CYM", "KY"},
+{"CYP", "CY"},
+{"CYPRUS", "CY"},
+{"CZ", "CZ"},
+{"CZE", "CZ"},
+{"CZECH REPUBLIC", "CZ"},
+{"CZECHIA", "CZ"},
+{"DE", "DE"},
+{"DEMOCRATIC PEOPLE S REPUBLIC OF KOREA", "KP"},
+{"DEMOCRATIC REPUBLIC OF SAO TOME AND PRINCIPE", "ST"},
+{"DEMOCRATIC REPUBLIC OF TIMOR LESTE", "TL"},
+{"DEMOCRATIC SOCIALIST REPUBLIC OF SRI LANKA", "LK"},
+{"DENMARK", "DK"},
+{"DEU", "DE"},
+{"DJ", "DJ"},
+{"DJI", "DJ"},
+{"DJIBOUTI", "DJ"},
+{"DK", "DK"},
+{"DM", "DM"},
+{"DMA", "DM"},
+{"DNK", "DK"},
+{"DO", "DO"},
+{"DOM", "DO"},
+{"DOMINICA", "DM"},
+{"DOMINICAN REPUBLIC", "DO"},
+{"DZ", "DZ"},
+{"DZA", "DZ"},
+{"EAST TIMOR", "TL"},
+{"EASTERN REPUBLIC OF URUGUAY", "UY"},
+{"EC", "EC"},
+{"ECU", "EC"},
+{"ECUADOR", "EC"},
+{"EE", "EE"},
+{"EG", "EG"},
+{"EGY", "EG"},
+{"EGYPT", "EG"},
+{"EH", "EH"},
+{"EL SALVADOR", "SV"},
+{"EQUATORIAL GUINEA", "GQ"},
+{"ER", "ER"},
+{"ERI", "ER"},
+{"ERITREA", "ER"},
+{"ES", "ES"},
+{"ESH", "EH"},
+{"ESP", "ES"},
+{"EST", "EE"},
+{"ESTONIA", "EE"},
+{"ESWATINI", "SZ"},
+{"ET", "ET"},
+{"ETH", "ET"},
+{"ETHIOPIA", "ET"},
+{"FALKLAND ISLANDS MALVINAS", "FK"},
+{"FAROE ISLANDS", "FO"},
+{"FEDERAL DEMOCRATIC REPUBLIC OF ETHIOPIA", "ET"},
+{"FEDERAL DEMOCRATIC REPUBLIC OF NEPAL", "NP"},
+{"FEDERAL REPUBLIC OF GERMANY", "DE"},
+{"FEDERAL REPUBLIC OF NIGERIA", "NG"},
+{"FEDERAL REPUBLIC OF SOMALIA", "SO"},
+{"FEDERATED STATES OF MICRONESIA", "FM"},
+{"FEDERATIVE REPUBLIC OF BRAZIL", "BR"},
+{"FI", "FI"},
+{"FIJI", "FJ"},
+{"FIN", "FI"},
+{"FINLAND", "FI"},
+{"FJ", "FJ"},
+{"FJI", "FJ"},
+{"FK", "FK"},
+{"FLK", "FK"},
+{"FM", "FM"},
+{"FO", "FO"},
+{"FR", "FR"},
+{"FRA", "FR"},
+{"FRANCE", "FR"},
+{"FRENCH GUIANA", "GF"},
+{"FRENCH POLYNESIA", "PF"},
+{"FRENCH REPUBLIC", "FR"},
+{"FRENCH SOUTHERN TERRITORIES", "TF"},
+{"FRO", "FO"},
+{"FSM", "FM"},
+{"GA", "GA"},
+{"GAB", "GA"},
+{"GABON", "GA"},
+{"GABONESE REPUBLIC", "GA"},
+{"GAMBIA", "GM"},
+{"GB", "GB"},
+{"GBR", "GB"},
+{"GD", "GD"},
+{"GE", "GE"},
+{"GEO", "GE"},
+{"GEORGIA", "GE"},
+{"GERMANY", "DE"},
+{"GF", "GF"},
+{"GG", "GG"},
+{"GGY", "GG"},
+{"GH", "GH"},
+{"GHA", "GH"},
+{"GHANA", "GH"},
+{"GI", "GI"},
+{"GIB", "GI"},
+{"GIBRALTAR", "GI"},
+{"GIN", "GN"},
+{"GL", "GL"},
+{"GLP", "GP"},
+{"GM", "GM"},
+{"GMB", "GM"},
+{"GN", "GN"},
+{"GNB", "GW"},
+{"GNQ", "GQ"},
+{"GP", "GP"},
+{"GQ", "GQ"},
+{"GR", "GR"},
+{"GRAND DUCHY OF LUXEMBOURG", "LU"},
+{"GRC", "GR"},
+{"GRD", "GD"},
+{"GREAT BRITAIN", "GB"},
+{"GREECE", "GR"},
+{"GREENLAND", "GL"},
+{"GRENADA", "GD"},
+{"GRL", "GL"},
+{"GS", "GS"},
+{"GT", "GT"},
+{"GTM", "GT"},
+{"GU", "GU"},
+{"GUADELOUPE", "GP"},
+{"GUAM", "GU"},
+{"GUATEMALA", "GT"},
+{"GUERNSEY", "GG"},
+{"GUF", "GF"},
+{"GUINEA", "GN"},
+{"GUINEA BISSAU", "GW"},
+{"GUM", "GU"},
+{"GUY", "GY"},
+{"GUYANA", "GY"},
+{"GW", "GW"},
+{"GY", "GY"},
+{"HAITI", "HT"},
+{"HASHEMITE KINGDOM OF JORDAN", "JO"},
+{"HEARD ISLAND AND MCDONALD ISLANDS", "HM"},
+{"HELLENIC REPUBLIC", "GR"},
+{"HK", "HK"},
+{"HKG", "HK"},
+{"HM", "HM"},
+{"HMD", "HM"},
+{"HN", "HN"},
+{"HND", "HN"},
+{"HOLY SEE VATICAN CITY STATE", "VA"},
+{"HONDURAS", "HN"},
+{"HONG KONG", "HK"},
+{"HONG KONG SPECIAL ADMINISTRATIVE REGION OF CHINA", "HK"},
+{"HR", "HR"},
+{"HRV", "HR"},
+{"HT", "HT"},
+{"HTI", "HT"},
+{"HU", "HU"},
+{"HUN", "HU"},
+{"HUNGARY", "HU"},
+{"ICELAND", "IS"},
+{"ID", "ID"},
+{"IDN", "ID"},
+{"IE", "IE"},
+{"IL", "IL"},
+{"IM", "IM"},
+{"IMN", "IM"},
+{"IN", "IN"},
+{"IND", "IN"},
+{"INDEPENDENT STATE OF PAPUA NEW GUINEA", "PG"},
+{"INDEPENDENT STATE OF SAMOA", "WS"},
+{"INDIA", "IN"},
+{"INDONESIA", "ID"},
+{"IO", "IO"},
+{"IOT", "IO"},
+{"IQ", "IQ"},
+{"IR", "IR"},
+{"IRAN", "IR"},
+{"IRAN ISLAMIC REPUBLIC OF", "IR"},
+{"IRAQ", "IQ"},
+{"IRELAND", "IE"},
+{"IRL", "IE"},
+{"IRN", "IR"},
+{"IRQ", "IQ"},
+{"IS", "IS"},
+{"ISL", "IS"},
+{"ISLAMIC REPUBLIC OF AFGHANISTAN", "AF"},
+{"ISLAMIC REPUBLIC OF IRAN", "IR"},
+{"ISLAMIC REPUBLIC OF MAURITANIA", "MR"},
+{"ISLAMIC REPUBLIC OF PAKISTAN", "PK"},
+{"ISLE OF MAN", "IM"},
+{"ISR", "IL"},
+{"ISRAEL", "IL"},
+{"IT", "IT"},
+{"ITA", "IT"},
+{"ITALIAN REPUBLIC", "IT"},
+{"ITALY", "IT"},
+{"IVORY COAST", "CI"},
+{"JAM", "JM"},
+{"JAMAICA", "JM"},
+{"JAPAN", "JP"},
+{"JE", "JE"},
+{"JERSEY", "JE"},
+{"JEY", "JE"},
+{"JM", "JM"},
+{"JO", "JO"},
+{"JOR", "JO"},
+{"JORDAN", "JO"},
+{"JP", "JP"},
+{"JPN", "JP"},
+{"KAZ", "KZ"},
+{"KAZAKHSTAN", "KZ"},
+{"KE", "KE"},
+{"KEN", "KE"},
+{"KENYA", "KE"},
+{"KG", "KG"},
+{"KGZ", "KG"},
+{"KH", "KH"},
+{"KHM", "KH"},
+{"KI", "KI"},
+{"KINGDOM OF BAHRAIN", "BH"},
+{"KINGDOM OF BELGIUM", "BE"},
+{"KINGDOM OF BHUTAN", "BT"},
+{"KINGDOM OF CAMBODIA", "KH"},
+{"KINGDOM OF DENMARK", "DK"},
+{"KINGDOM OF ESWATINI", "SZ"},
+{"KINGDOM OF LESOTHO", "LS"},
+{"KINGDOM OF MOROCCO", "MA"},
+{"KINGDOM OF NORWAY", "NO"},
+{"KINGDOM OF SAUDI ARABIA", "SA"},
+{"KINGDOM OF SPAIN", "ES"},
+{"KINGDOM OF SWEDEN", "SE"},
+{"KINGDOM OF THAILAND", "TH"},
+{"KINGDOM OF THE NETHERLANDS", "NL"},
+{"KINGDOM OF TONGA", "TO"},
+{"KIR", "KI"},
+{"KIRIBATI", "KI"},
+{"KM", "KM"},
+{"KN", "KN"},
+{"KNA", "KN"},
+{"KOR", "KR"},
+{"KOREA DEMOCRATIC PEOPLE S REPUBLIC OF", "KP"},
+{"KOREA REPUBLIC OF", "KR"},
+{"KP", "KP"},
+{"KR", "KR"},
+{"KUWAIT", "KW"},
+{"KW", "KW"},
+{"KWT", "KW"},
+{"KY", "KY"},
+{"KYRGYZ REPUBLIC", "KG"},
+{"KYRGYZSTAN", "KG"},
+{"KZ", "KZ"},
+{"LA", "LA"},
+{"LAO", "LA"},
+{"LAO PEOPLE S DEMOCRATIC REPUBLIC", "LA"},
+{"LAOS", "LA"},
+{"LATVIA", "LV"},
+{"LB", "LB"},
+{"LBN", "LB"},
+{"LBR", "LR"},
+{"LBY", "LY"},
+{"LC", "LC"},
+{"LCA", "LC"},
+{"LEBANESE REPUBLIC", "LB"},
+{"LEBANON", "LB"},
+{"LESOTHO", "LS"},
+{"LI", "LI"},
+{"LIBERIA", "LR"},
+{"LIBYA", "LY"},
+{"LIE", "LI"},
+{"LIECHTENSTEIN", "LI"},
+{"LITHUANIA", "LT"},
+{"LK", "LK"},
+{"LKA", "LK"},
+{"LR", "LR"},
+{"LS", "LS"},
+{"LSO", "LS"},
+{"LT", "LT"},
+{"LTU", "LT"},
+{"LU", "LU"},
+{"LUX", "LU"},
+{"LUXEMBOURG", "LU"},
+{"LV", "LV"},
+{"LVA", "LV"},
+{"LY", "LY"},
+{"MA", "MA"},
+{"MAC", "MO"},
+{"MACAO", "MO"},
+{"MACAO SPECIAL ADMINISTRATIVE REGION OF CHINA", "MO"},
+{"MADAGASCAR", "MG"},
+{"MAF", "MF"},
+{"MALAWI", "MW"},
+{"MALAYSIA", "MY"},
+{"MALDIVES", "MV"},
+{"MALI", "ML"},
+{"MALTA", "MT"},
+{"MAR", "MA"},
+{"MARSHALL ISLANDS", "MH"},
+{"MARTINIQUE", "MQ"},
+{"MAURITANIA", "MR"},
+{"MAURITIUS", "MU"},
+{"MAYOTTE", "YT"},
+{"MC", "MC"},
+{"MCO", "MC"},
+{"MD", "MD"},
+{"MDA", "MD"},
+{"MDG", "MG"},
+{"MDV", "MV"},
+{"ME", "ME"},
+{"MEX", "MX"},
+{"MEXICO", "MX"},
+{"MF", "MF"},
+{"MG", "MG"},
+{"MH", "MH"},
+{"MHL", "MH"},
+{"MICRONESIA", "FM"},
+{"MICRONESIA FEDERATED STATES OF", "FM"},
+{"MK", "MK"},
+{"MKD", "MK"},
+{"ML", "ML"},
+{"MLI", "ML"},
+{"MLT", "MT"},
+{"MM", "MM"},
+{"MMR", "MM"},
+{"MN", "MN"},
+{"MNE", "ME"},
+{"MNG", "MN"},
+{"MNP", "MP"},
+{"MO", "MO"},
+{"MOLDOVA", "MD"},
+{"MOLDOVA REPUBLIC OF", "MD"},
+{"MONACO", "MC"},
+{"MONGOLIA", "MN"},
+{"MONTENEGRO", "ME"},
+{"MONTSERRAT", "MS"},
+{"MOROCCO", "MA"},
+{"MOZ", "MZ"},
+{"MOZAMBIQUE", "MZ"},
+{"MP", "MP"},
+{"MQ", "MQ"},
+{"MR", "MR"},
+{"MRT", "MR"},
+{"MS", "MS"},
+{"MSR", "MS"},
+{"MT", "MT"},
+{"MTQ", "MQ"},
+{"MU", "MU"},
+{"MUS", "MU"},
+{"MV", "MV"},
+{"MW", "MW"},
+{"MWI", "MW"},
+{"MX", "MX"},
+{"MY", "MY"},
+{"MYANMAR", "MM"},
+{"MYS", "MY"},
+{"MYT", "YT"},
+{"MZ", "MZ"},
+{"NA", "NA"},
+{"NAM", "NA"},
+{"NAMIBIA", "NA"},
+{"NAURU", "NR"},
+{"NC", "NC"},
+{"NCL", "NC"},
+{"NE", "NE"},
+{"NEPAL", "NP"},
+{"NER", "NE"},
+{"NETHERLANDS", "NL"},
+{"NEW CALEDONIA", "NC"},
+{"NEW ZEALAND", "NZ"},
+{"NF", "NF"},
+{"NFK", "NF"},
+{"NG", "NG"},
+{"NGA", "NG"},
+{"NI", "NI"},
+{"NIC", "NI"},
+{"NICARAGUA", "NI"},
+{"NIGER", "NE"},
+{"NIGERIA", "NG"},
+{"NIU", "NU"},
+{"NIUE", "NU"},
+{"NL", "NL"},
+{"NLD", "NL"},
+{"NO", "NO"},
+{"NOR", "NO"},
+{"NORFOLK ISLAND", "NF"},
+{"NORTH KOREA", "KP"},
+{"NORTH MACEDONIA", "MK"},
+{"NORTHERN MARIANA ISLANDS", "MP"},
+{"NORWAY", "NO"},
+{"NP", "NP"},
+{"NPL", "NP"},
+{"NR", "NR"},
+{"NRU", "NR"},
+{"NU", "NU"},
+{"NZ", "NZ"},
+{"NZL", "NZ"},
+{"OM", "OM"},
+{"OMAN", "OM"},
+{"OMN", "OM"},
+{"PA", "PA"},
+{"PAK", "PK"},
+{"PAKISTAN", "PK"},
+{"PALAU", "PW"},
+{"PALESTINE", "PS"},
+{"PALESTINE STATE OF", "PS"},
+{"PAN", "PA"},
+{"PANAMA", "PA"},
+{"PAPUA NEW GUINEA", "PG"},
+{"PARAGUAY", "PY"},
+{"PCN", "PN"},
+{"PE", "PE"},
+{"PEOPLE S DEMOCRATIC REPUBLIC OF ALGERIA", "DZ"},
+{"PEOPLE S REPUBLIC OF BANGLADESH", "BD"},
+{"PEOPLE S REPUBLIC OF CHINA", "CN"},
+{"PER", "PE"},
+{"PERU", "PE"},
+{"PF", "PF"},
+{"PG", "PG"},
+{"PH", "PH"},
+{"PHILIPPINES", "PH"},
+{"PHL", "PH"},
+{"PITCAIRN", "PN"},
+{"PK", "PK"},
+{"PL", "PL"},
+{"PLURINATIONAL STATE OF BOLIVIA", "BO"},
+{"PLW", "PW"},
+{"PM", "PM"},
+{"PN", "PN"},
+{"PNG", "PG"},
+{"POL", "PL"},
+{"POLAND", "PL"},
+{"PORTUGAL", "PT"},
+{"PORTUGUESE REPUBLIC", "PT"},
+{"PR", "PR"},
+{"PRI", "PR"},
+{"PRINCIPALITY OF ANDORRA", "AD"},
+{"PRINCIPALITY OF LIECHTENSTEIN", "LI"},
+{"PRINCIPALITY OF MONACO", "MC"},
+{"PRK", "KP"},
+{"PRT", "PT"},
+{"PRY", "PY"},
+{"PS", "PS"},
+{"PSE", "PS"},
+{"PT", "PT"},
+{"PUERTO RICO", "PR"},
+{"PW", "PW"},
+{"PY", "PY"},
+{"PYF", "PF"},
+{"QA", "QA"},
+{"QAT", "QA"},
+{"QATAR", "QA"},
+{"RE", "RE"},
+{"REPUBLIC OF ALBANIA", "AL"},
+{"REPUBLIC OF ANGOLA", "AO"},
+{"REPUBLIC OF ARMENIA", "AM"},
+{"REPUBLIC OF AUSTRIA", "AT"},
+{"REPUBLIC OF AZERBAIJAN", "AZ"},
+{"REPUBLIC OF BELARUS", "BY"},
+{"REPUBLIC OF BENIN", "BJ"},
+{"REPUBLIC OF BOSNIA AND HERZEGOVINA", "BA"},
+{"REPUBLIC OF BOTSWANA", "BW"},
+{"REPUBLIC OF BULGARIA", "BG"},
+{"REPUBLIC OF BURUNDI", "BI"},
+{"REPUBLIC OF CABO VERDE", "CV"},
+{"REPUBLIC OF CAMEROON", "CM"},
+{"REPUBLIC OF CHAD", "TD"},
+{"REPUBLIC OF CHILE", "CL"},
+{"REPUBLIC OF COLOMBIA", "CO"},
+{"REPUBLIC OF COSTA RICA", "CR"},
+{"REPUBLIC OF COTE D IVOIRE", "CI"},
+{"REPUBLIC OF CROATIA", "HR"},
+{"REPUBLIC OF CUBA", "CU"},
+{"REPUBLIC OF CYPRUS", "CY"},
+{"REPUBLIC OF DJIBOUTI", "DJ"},
+{"REPUBLIC OF ECUADOR", "EC"},
+{"REPUBLIC OF EL SALVADOR", "SV"},
+{"REPUBLIC OF EQUATORIAL GUINEA", "GQ"},
+{"REPUBLIC OF ESTONIA", "EE"},
+{"REPUBLIC OF FIJI", "FJ"},
+{"REPUBLIC OF FINLAND", "FI"},
+{"REPUBLIC OF GHANA", "GH"},
+{"REPUBLIC OF GUATEMALA", "GT"},
+{"REPUBLIC OF GUINEA", "GN"},
+{"REPUBLIC OF GUINEA BISSAU", "GW"},
+{"REPUBLIC OF GUYANA", "GY"},
+{"REPUBLIC OF HAITI", "HT"},
+{"REPUBLIC OF HONDURAS", "HN"},
+{"REPUBLIC OF ICELAND", "IS"},
+{"REPUBLIC OF INDIA", "IN"},
+{"REPUBLIC OF INDONESIA", "ID"},
+{"REPUBLIC OF IRAQ", "IQ"},
+{"REPUBLIC OF KAZAKHSTAN", "KZ"},
+{"REPUBLIC OF KENYA", "KE"},
+{"REPUBLIC OF KIRIBATI", "KI"},
+{"REPUBLIC OF LATVIA", "LV"},
+{"REPUBLIC OF LIBERIA", "LR"},
+{"REPUBLIC OF LITHUANIA", "LT"},
+{"REPUBLIC OF MADAGASCAR", "MG"},
+{"REPUBLIC OF MALAWI", "MW"},
+{"REPUBLIC OF MALDIVES", "MV"},
+{"REPUBLIC OF MALI", "ML"},
+{"REPUBLIC OF MALTA", "MT"},
+{"REPUBLIC OF MAURITIUS", "MU"},
+{"REPUBLIC OF MOLDOVA", "MD"},
+{"REPUBLIC OF MOZAMBIQUE", "MZ"},
+{"REPUBLIC OF MYANMAR", "MM"},
+{"REPUBLIC OF NAMIBIA", "NA"},
+{"REPUBLIC OF NAURU", "NR"},
+{"REPUBLIC OF NICARAGUA", "NI"},
+{"REPUBLIC OF NORTH MACEDONIA", "MK"},
+{"REPUBLIC OF PALAU", "PW"},
+{"REPUBLIC OF PANAMA", "PA"},
+{"REPUBLIC OF PARAGUAY", "PY"},
+{"REPUBLIC OF PERU", "PE"},
+{"REPUBLIC OF POLAND", "PL"},
+{"REPUBLIC OF SAN MARINO", "SM"},
+{"REPUBLIC OF SENEGAL", "SN"},
+{"REPUBLIC OF SERBIA", "RS"},
+{"REPUBLIC OF SEYCHELLES", "SC"},
+{"REPUBLIC OF SIERRA LEONE", "SL"},
+{"REPUBLIC OF SINGAPORE", "SG"},
+{"REPUBLIC OF SLOVENIA", "SI"},
+{"REPUBLIC OF SOUTH AFRICA", "ZA"},
+{"REPUBLIC OF SOUTH SUDAN", "SS"},
+{"REPUBLIC OF SURINAME", "SR"},
+{"REPUBLIC OF TAJIKISTAN", "TJ"},
+{"REPUBLIC OF THE CONGO", "CG"},
+{"REPUBLIC OF THE GAMBIA", "GM"},
+{"REPUBLIC OF THE MARSHALL ISLANDS", "MH"},
+{"REPUBLIC OF THE NIGER", "NE"},
+{"REPUBLIC OF THE PHILIPPINES", "PH"},
+{"REPUBLIC OF THE SUDAN", "SD"},
+{"REPUBLIC OF TRINIDAD AND TOBAGO", "TT"},
+{"REPUBLIC OF TUNISIA", "TN"},
+{"REPUBLIC OF TURKIYE", "TR"},
+{"REPUBLIC OF UGANDA", "UG"},
+{"REPUBLIC OF UZBEKISTAN", "UZ"},
+{"REPUBLIC OF VANUATU", "VU"},
+{"REPUBLIC OF YEMEN", "YE"},
+{"REPUBLIC OF ZAMBIA", "ZM"},
+{"REPUBLIC OF ZIMBABWE", "ZW"},
+{"REU", "RE"},
+{"REUNION", "RE"},
+{"RO", "RO"},
+{"ROMANIA", "RO"},
+{"ROU", "RO"},
+{"RS", "RS"},
+{"RU", "RU"},
+{"RUS", "RU"},
+{"RUSSIA", "RU"},
+{"RUSSIAN FEDERATION", "RU"},
+{"RW", "RW"},
+{"RWA", "RW"},
+{"RWANDA", "RW"},
+{"RWANDESE REPUBLIC", "RW"},
+{"SA", "SA"},
+{"SAINT BARTHELEMY", "BL"},
+{"SAINT HELENA ASCENSION AND TRISTAN DA CUNHA", "SH"},
+{"SAINT KITTS AND NEVIS", "KN"},
+{"SAINT LUCIA", "LC"},
+{"SAINT MARTIN FRENCH PART", "MF"},
+{"SAINT PIERRE AND MIQUELON", "PM"},
+{"SAINT VINCENT AND THE GRENADINES", "VC"},
+{"SAMOA", "WS"},
+{"SAN MARINO", "SM"},
+{"SAO TOME AND PRINCIPE", "ST"},
+{"SAU", "SA"},
+{"SAUDI ARABIA", "SA"},
+{"SB", "SB"},
+{"SC", "SC"},
+{"SD", "SD"},
+{"SDN", "SD"},
+{"SE", "SE"},
+{"SEN", "SN"},
+{"SENEGAL", "SN"},
+{"SERBIA", "RS"},
+{"SEYCHELLES", "SC"},
+{"SG", "SG"},
+{"SGP", "SG"},
+{"SGS", "GS"},
+{"SH", "SH"},
+{"SHN", "SH"},
+{"SI", "SI"},
+{"SIERRA LEONE", "SL"},
+{"SINGAPORE", "SG"},
+{"SINT MAARTEN DUTCH PART", "SX"},
+{"SJ", "SJ"},
+{"SJM", "SJ"},
+{"SK", "SK"},
+{"SL", "SL"},
+{"SLB", "SB"},
+{"SLE", "SL"},
+{"SLOVAK REPUBLIC", "SK"},
+{"SLOVAKIA", "SK"},
+{"SLOVENIA", "SI"},
+{"SLV", "SV"},
+{"SM", "SM"},
+{"SMR", "SM"},
+{"SN", "SN"},
+{"SO", "SO"},
+{"SOCIALIST REPUBLIC OF VIET NAM", "VN"},
+{"SOLOMON ISLANDS", "SB"},
+{"SOM", "SO"},
+{"SOMALIA", "SO"},
+{"SOUTH AFRICA", "ZA"},
+{"SOUTH GEORGIA AND THE SOUTH SANDWICH ISLANDS", "GS"},
+{"SOUTH KOREA", "KR"},
+{"SOUTH SUDAN", "SS"},
+{"SPAIN", "ES"},
+{"SPM", "PM"},
+{"SR", "SR"},
+{"SRB", "RS"},
+{"SRI LANKA", "LK"},
+{"SS", "SS"},
+{"SSD", "SS"},
+{"ST", "ST"},
+{"STATE OF ISRAEL", "IL"},
+{"STATE OF KUWAIT", "KW"},
+{"STATE OF QATAR", "QA"},
+{"STP", "ST"},
+{"SUDAN", "SD"},
+{"SULTANATE OF OMAN", "OM"},
+{"SUR", "SR"},
+{"SURINAME", "SR"},
+{"SV", "SV"},
+{"SVALBARD AND JAN MAYEN", "SJ"},
+{"SVK", "SK"},
+{"SVN", "SI"},
+{"SWE", "SE"},
+{"SWEDEN", "SE"},
+{"SWISS CONFEDERATION", "CH"},
+{"SWITZERLAND", "CH"},
+{"SWZ", "SZ"},
+{"SX", "SX"},
+{"SXM", "SX"},
+{"SY", "SY"},
+{"SYC", "SC"},
+{"SYR", "SY"},
+{"SYRIA", "SY"},
+{"SYRIAN ARAB REPUBLIC", "SY"},
+{"SZ", "SZ"},
+{"TAIWAN", "TW"},
+{"TAIWAN PROVINCE OF CHINA", "TW"},
+{"TAJIKISTAN", "TJ"},
+{"TANZANIA", "TZ"},
+{"TANZANIA UNITED REPUBLIC OF", "TZ"},
+{"TC", "TC"},
+{"TCA", "TC"},
+{"TCD", "TD"},
+{"TD", "TD"},
+{"TF", "TF"},
+{"TG", "TG"},
+{"TGO", "TG"},
+{"TH", "TH"},
+{"THA", "TH"},
+{"THAILAND", "TH"},
+{"THE STATE OF ERITREA", "ER"},
+{"THE STATE OF PALESTINE", "PS"},
+{"TIMOR LESTE", "TL"},
+{"TJ", "TJ"},
+{"TJK", "TJ"},
+{"TK", "TK"},
+{"TKL", "TK"},
+{"TKM", "TM"},
+{"TL", "TL"},
+{"TLS", "TL"},
+{"TM", "TM"},
+{"TN", "TN"},
+{"TO", "TO"},
+{"TOGO", "TG"},
+{"TOGOLESE REPUBLIC", "TG"},
+{"TOKELAU", "TK"},
+{"TON", "TO"},
+{"TONGA", "TO"},
+{"TR", "TR"},
+{"TRINIDAD AND TOBAGO", "TT"},
+{"TT", "TT"},
+{"TTO", "TT"},
+{"TUN", "TN"},
+{"TUNISIA", "TN"},
+{"TUR", "TR"},
+{"TURKEY", "TR"},
+{"TURKIYE", "TR"},
+{"TURKMENISTAN", "TM"},
+{"TURKS AND CAICOS ISLANDS", "TC"},
+{"TUV", "TV"},
+{"TUVALU", "TV"},
+{"TV", "TV"},
+{"TW", "TW"},
+{"TWN", "TW"},
+{"TZ", "TZ"},
+{"TZA", "TZ"},
+{"U K", "GB"},
+{"U S", "US"},
+{"U S A", "US"},
+{"UA", "UA"},
+{"UG", "UG"},
+{"UGA", "UG"},
+{"UGANDA", "UG"},
+{"UK", "GB"},
+{"UKR", "UA"},
+{"UKRAINE", "UA"},
+{"UM", "UM"},
+{"UMI", "UM"},
+{"UNION OF THE COMOROS", "KM"},
+{"UNITED ARAB EMIRATES", "AE"},
+{"UNITED KINGDOM", "GB"},
+{"UNITED KINGDOM OF GREAT BRITAIN AND NORTHERN IRELAND", "GB"},
+{"UNITED MEXICAN STATES", "MX"},
+{"UNITED REPUBLIC OF TANZANIA", "TZ"},
+{"UNITED STATES", "US"},
+{"UNITED STATES MINOR OUTLYING ISLANDS", "UM"},
+{"UNITED STATES OF AMERICA", "US"},
+{"URUGUAY", "UY"},
+{"URY", "UY"},
+{"US", "US"},
+{"USA", "US"},
+{"UY", "UY"},
+{"UZ", "UZ"},
+{"UZB", "UZ"},
+{"UZBEKISTAN", "UZ"},
+{"VA", "VA"},
+{"VANUATU", "VU"},
+{"VAT", "VA"},
+{"VATICAN CITY", "VA"},
+{"VC", "VC"},
+{"VCT", "VC"},
+{"VE", "VE"},
+{"VEN", "VE"},
+{"VENEZUELA", "VE"},
+{"VENEZUELA BOLIVARIAN REPUBLIC OF", "VE"},
+{"VG", "VG"},
+{"VGB", "VG"},
+{"VI", "VI"},
+{"VIET NAM", "VN"},
+{"VIETNAM", "VN"},
+{"VIR", "VI"},
+{"VIRGIN ISLANDS BRITISH", "VG"},
+{"VIRGIN ISLANDS OF THE UNITED STATES", "VI"},
+{"VIRGIN ISLANDS U S", "VI"},
+{"VN", "VN"},
+{"VNM", "VN"},
+{"VU", "VU"},
+{"VUT", "VU"},
+{"WALLIS AND FUTUNA", "WF"},
+{"WESTERN SAHARA", "EH"},
+{"WF", "WF"},
+{"WLF", "WF"},
+{"WS", "WS"},
+{"WSM", "WS"},
+{"YE", "YE"},
+{"YEM", "YE"},
+{"YEMEN", "YE"},
+{"YT", "YT"},
+{"ZA", "ZA"},
+{"ZAF", "ZA"},
+{"ZAMBIA", "ZM"},
+{"ZIMBABWE", "ZW"},
+{"ZM", "ZM"},
+{"ZMB", "ZM"},
+{"ZW", "ZW"},
+{"ZWE", "ZW"},
diff --git a/extensions/address_standardizer/test-parseaddress.sql.in b/extensions/address_standardizer/test-parseaddress.sql.in
index b2a1224c0..f327354f5 100644
--- a/extensions/address_standardizer/test-parseaddress.sql.in
+++ b/extensions/address_standardizer/test-parseaddress.sql.in
@@ -69,6 +69,15 @@ copy test_parse_address (instring, outstring) from stdin;
@@ sttype words$
123 oak ln, marie ny (123,"oak ln",,"123 oak ln",marie,NY,,,US)
123 oak ln, new marie ny (123,"oak ln",,"123 oak ln","new marie",NY,,,US)
+529 Main Street, Boston, MA 021 (529,"Main Street",,"529 Main Street",Boston,MA,021,,US)
+529 Main Street, Boston, MA 021, France (529,"Main Street",,"529 Main Street",Boston,MA,021,,FR)
+100 Peachtree St, Atlanta, Georgia (100,"Peachtree St",,"100 Peachtree St",Atlanta,GA,,,US)
+212 n 3rd ave, Minneapolis, mn 55401, USA (212,"n 3rd ave",,"212 n 3rd ave",Minneapolis,MN,55401,,US)
+26 Court Street, Boston, Massachusetts 02109, FR (26,"Court Street",,"26 Court Street",Boston,MA,02109,,FR)
+26 Court Street, Boston, MA 02109, Rear (26,"Court Street, Boston, MA 02109",,"26 Court Street, Boston, MA 02109",Rear,,,,US)
+212 N 3rd Ave, Minneapolis, MN 55401, Suite A (212,"N 3rd Ave, Minneapolis, MN 55401",,"212 N 3rd Ave, Minneapolis, MN 55401","Suite A",,,,US)
+26 Court Street, Boston, Massachusetts 02109, France (26,"Court Street",,"26 Court Street",Boston,MA,02109,,FR)
+10 Main Street, Toronto, ON M5V 2T6, France (10,"Main Street",,"10 Main Street",Toronto,ON,"M5V 2T6",,FR)
select id, instring, outstring as expected, parse_address(instring) as got_result
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index e0faf1caf..d2b5029d4 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -30,7 +30,7 @@ DATA_built = \
$(NULL)
REGRESS = test-normalize_address test-upgrade
-REGRESS_OPTS = --load-extension=fuzzystrmatch --load-extension=postgis --load-extension=$(EXTENSION)
+REGRESS_OPTS = --load-extension=fuzzystrmatch --load-extension=postgis
EXTSCHEMA_SUPPORTED = yes
## PostgreSQL < 16 doesn't understand new @extschema:extname@ syntax, so strip it
@@ -46,6 +46,7 @@ ifeq (@ADDRESS_STANDARDIZER@,address_standardizer)
REGRESS += test-pagc_normalize_address
REGRESS_OPTS += --load-extension=address_standardizer
endif
+REGRESS_OPTS += --load-extension=$(EXTENSION)
all: sql/$(EXTENSION)_pre.sql sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--ANY--$(EXTVERSION).sql sql/test-normalize_address.sql sql/test-pagc_normalize_address.sql expected/test-normalize_address.out expected/test-pagc_normalize_address.out sql/test-upgrade.sql expected/test-upgrade.out
diff --git a/extensions/postgis_tiger_geocoder/postgis_tiger_geocoder.control.in b/extensions/postgis_tiger_geocoder/postgis_tiger_geocoder.control.in
index 647cba6b8..ed256b89d 100644
--- a/extensions/postgis_tiger_geocoder/postgis_tiger_geocoder.control.in
+++ b/extensions/postgis_tiger_geocoder/postgis_tiger_geocoder.control.in
@@ -5,4 +5,4 @@ relocatable = false
schema = tiger
requires = 'postgis,fuzzystrmatch'
superuser= false
-no_relocate = 'postgis,fuzzystrmatch'
\ No newline at end of file
+no_relocate = 'postgis,fuzzystrmatch'
diff --git a/extensions/postgis_tiger_geocoder/sql_bits/norm_addy_create.sql.in b/extensions/postgis_tiger_geocoder/sql_bits/norm_addy_create.sql.in
index 7b70bf876..121548f8b 100644
--- a/extensions/postgis_tiger_geocoder/sql_bits/norm_addy_create.sql.in
+++ b/extensions/postgis_tiger_geocoder/sql_bits/norm_addy_create.sql.in
@@ -9,5 +9,6 @@ CREATE TYPE norm_addy AS (
stateAbbrev VARCHAR,
zip VARCHAR,
parsed BOOLEAN,
- zip4 varchar,
- address_alphanumeric varchar);
+ zip4 varchar(4),
+ address_alphanumeric varchar,
+ country varchar(2));
diff --git a/extensions/postgis_tiger_geocoder/sql_bits/norm_addy_upgrade.sql.in b/extensions/postgis_tiger_geocoder/sql_bits/norm_addy_upgrade.sql.in
index 99bf4364c..77561fa14 100644
--- a/extensions/postgis_tiger_geocoder/sql_bits/norm_addy_upgrade.sql.in
+++ b/extensions/postgis_tiger_geocoder/sql_bits/norm_addy_upgrade.sql.in
@@ -1,2 +1,3 @@
ALTER TYPE tiger.norm_addy ADD ATTRIBUTE zip4 varchar(4);
-ALTER TYPE tiger.norm_addy ADD ATTRIBUTE address_alphanumeric varchar;
+ALTER TYPE tiger.norm_addy ADD ATTRIBUTE address_alphanumeric varchar;
+ALTER TYPE tiger.norm_addy ADD ATTRIBUTE country varchar(2);
diff --git a/extensions/postgis_tiger_geocoder/sql_bits/upgrade_before.sql.in b/extensions/postgis_tiger_geocoder/sql_bits/upgrade_before.sql.in
index 5bba06428..bcaba281d 100644
--- a/extensions/postgis_tiger_geocoder/sql_bits/upgrade_before.sql.in
+++ b/extensions/postgis_tiger_geocoder/sql_bits/upgrade_before.sql.in
@@ -1,10 +1,41 @@
-- these introduced in PostGIS 2.4
DO language plpgsql
- BEGIN
- ALTER TYPE tiger.norm_addy ADD ATTRIBUTE zip4 varchar;
+DECLARE
+ norm_addy_relid oid := (SELECT typrelid FROM pg_type WHERE oid = 'tiger.norm_addy'::regtype);
+BEGIN
+ * Check each attribute independently so upgrades from releases that already
+ * have zip4/address_alphanumeric still pick up newer additions like country.
+ IF NOT EXISTS (
+ SELECT 1
+ FROM pg_attribute
+ WHERE attrelid = norm_addy_relid
+ AND attname = 'zip4'
+ AND NOT attisdropped
+ ) THEN
+ ALTER TYPE tiger.norm_addy ADD ATTRIBUTE zip4 varchar(4);
+ END IF;
+ IF NOT EXISTS (
+ SELECT 1
+ FROM pg_attribute
+ AND attname = 'address_alphanumeric'
+ ) THEN
- EXCEPTION
- WHEN others THEN -- ignore the error probably cause it already exists
- END;
+ END IF;
+ IF NOT EXISTS (
+ SELECT 1
+ FROM pg_attribute
+ AND attname = 'country'
+ ) THEN
+ ALTER TYPE tiger.norm_addy ADD ATTRIBUTE country varchar(2);
+ END IF;
+END;
diff --git a/extras/tiger_geocoder/create_geocode.sql b/extras/tiger_geocoder/create_geocode.sql
index 58647c154..daaa98f33 100644
--- a/extras/tiger_geocoder/create_geocode.sql
+++ b/extras/tiger_geocoder/create_geocode.sql
@@ -34,7 +34,7 @@ CREATE TYPE norm_addy AS (
location VARCHAR,
zip VARCHAR,
- parsed BOOLEAN, zip4 varchar, address_alphanumeric varchar);
+ parsed BOOLEAN, zip4 varchar(4), address_alphanumeric varchar, country varchar(2));
-- System/General helper functions
\i utility/utmzone.sql
@@ -82,4 +82,4 @@ COMMIT;
-- Tiger to PostGIS Topology
-- only usable if you have topology installed
-\i topology/tiger_topology_loader.sql
+\i topology/tiger_topology_loader.sql
diff --git a/extras/tiger_geocoder/normalize/normalize_address.sql b/extras/tiger_geocoder/normalize/normalize_address.sql
index 7af89b318..59bd9f148 100644
--- a/extras/tiger_geocoder/normalize/normalize_address.sql
+++ b/extras/tiger_geocoder/normalize/normalize_address.sql
@@ -71,6 +71,8 @@ DECLARE
rec RECORD;
ws VARCHAR;
rawInput VARCHAR;
+ parse_address_helper oid := to_regprocedure('parse_address(text)');
+ strip_country_helper oid := to_regprocedure('strip_explicit_country(text)');
-- is this a highway
-- (we treat these differently since the road name often comes after the streetType)
isHighway boolean := false;
@@ -87,6 +89,22 @@ BEGIN
RETURN result;
END IF;
+ * Legacy tiger SQL can still be installed without address_standardizer.
+ * Probe for the newer country helpers before using them.
+ IF parse_address_helper IS NOT NULL THEN
+ EXECUTE 'SELECT NULLIF((parse_address($1)).country, '''')'
+ INTO result.country
+ USING rawInput;
+ END IF;
+ IF strip_country_helper IS NOT NULL THEN
+ EXECUTE 'SELECT strip_explicit_country($1)'
+ INTO rawInput
+ USING rawInput;
+ END IF;
ws := E'[ ,.\t\n\f\r]';
IF debug_flag THEN
diff --git a/extras/tiger_geocoder/normalize/pprint_addy.sql b/extras/tiger_geocoder/normalize/pprint_addy.sql
index 900ee952b..f9ad31347 100644
--- a/extras/tiger_geocoder/normalize/pprint_addy.sql
+++ b/extras/tiger_geocoder/normalize/pprint_addy.sql
@@ -37,7 +37,13 @@ BEGIN
|| COALESCE(input.stateAbbrev || ' ' , '')
|| cull_null(input.zip) || COALESCE('-' || input.zip4, '');
- RETURN trim(result);
+ result := trim(result);
+ IF result <> '' AND input.country IS NOT NULL THEN
+ result := result || ', ' || input.country;
+ END IF;
+ RETURN result;
END;
$_$ LANGUAGE plpgsql IMMUTABLE;
diff --git a/extras/tiger_geocoder/pagc_normalize/pagc_normalize_address.sql b/extras/tiger_geocoder/pagc_normalize/pagc_normalize_address.sql
index e1acdaddc..befce7643 100644
--- a/extras/tiger_geocoder/pagc_normalize/pagc_normalize_address.sql
+++ b/extras/tiger_geocoder/pagc_normalize/pagc_normalize_address.sql
@@ -20,10 +20,12 @@ BEGIN
rawInput := trim(in_rawinput);
var_parse_rec := parse_address(rawInput);
result.location := var_parse_rec.city;
result.stateAbbrev := trim(var_parse_rec.state);
result.zip := var_parse_rec.zip;
result.zip4 := NULLIF(var_parse_rec.zipplus,'');
+ result.country := NULLIF(var_parse_rec.country,'');
var_rec := standardize_address('pagc_lex'
, 'pagc_gaz'
@@ -39,6 +41,7 @@ BEGIN
result.streetName := trim(var_rec.name);
result.location := trim(var_rec.city);
result.stateAbbrev := trim(var_rec.state);
+ result.country := COALESCE(NULLIF(var_rec.country,''), result.country);
--this should be broken out separately like pagc, but normalizer doesn't have a slot for it
result.streettypeAbbrev := trim(COALESCE(var_rec.suftype, var_rec.pretype));
result.preDirAbbrev := trim(var_rec.predir);
@@ -49,4 +52,4 @@ BEGIN
END
LANGUAGE plpgsql IMMUTABLE STRICT
- COST 100;
+ COST 100;
diff --git a/extras/tiger_geocoder/regress/normalize_address_regress b/extras/tiger_geocoder/regress/normalize_address_regress
index 6a417acaa..676bb7698 100644
--- a/extras/tiger_geocoder/regress/normalize_address_regress
+++ b/extras/tiger_geocoder/regress/normalize_address_regress
@@ -1,45 +1,51 @@
-#887|2450|N|COLORADO|St|||PHILADELPHIA|PA|19132|t||2450
-#1051a|212||3rd|Ave|N|Suite 560|Minneapolis|MN|55401|t||212
-#1051b|3937||43RD|Ave|S||MINNEAPOLIS|MN|55406|t||3937
-#1051c|212|N|3rd|Ave|||Minneapolis|MN|55401|t||212
-#1051d|212||3rd|Ave|N||Minneapolis|MN|55401|t||212
-529||Main|St|||Boston|MA|02129|t||529
-529||Main|St|||Boston|MA||t||529
-529||Main|St||Apt 201|Boston|MA|02129|t||529
-529||Main|St||Apt 201|Boston|MA||t||529
-#1108a|529||Main|St||Suite 201|Boston|MA|02129|t||529
-#1073a|212||3rd|Ave|N||MINNEAPOLIS|MN|553404|t|4|212
-#1073b|212||3rd|Ave|N||MINNEAPOLIS|MN|55401|t||212
-#1073c|529||Main|St|||Boston|MA|021|t||529
-#1086a|949|N|3rd|St|||New Hyde Park|NY|11040|t||949
-#1086b|949|N|3rd|St|||New Hyde Park|NY|11040|t||949
-#1076a|16725||24|Co Rd|||Plymouth|MN|55447|t||16725
-#1076b|16725||24|Co Rd|||Plymouth|MN|55447|t||16725
-#1076c|13800||9|Co Hwy|||Andover|MN|55304|t||13800
-#1076d|13800||9||||Andover|MN|55304|t||13800
-#1076e|14||Forest|Rd|||Acton|MA||t||14
-#1076f|1940||C|Co Rd|W||Roseville|MN|55113|t||1940
-#1076g|3900||6|Rte|||Eastham|MA|02642|t||3900
-#1076h|4533||PARK|Ave|S||MINNEAPOLIS|MN|55407|t||4533
-#1076i|4533||33|Co Rd|||MINNEAPOLIS|MN|55407|t||4533
-#1109a|4373||LAKE|Dr|||ROBBINSDALE|MN|55422|t||4373
-#1109b|4373||LAKE|Dr|||ROBBINSDALE|MN|55422|t||4373
-#1074a|3420||RHODE ISLAND|Ave|S||ST. LOUIS PARK|MN|55426|t||3420
-#1074b|26||Court|St|||Boston|MA|02109|t||26
-#1112a|8401|W|35W|Svc Dr|NE||Blaine|MN|55449|t||8401
-#1112b|8401||35W||||Blaine|MN|55449|t||8401
-#1112c|8401||35W||W||Blaine|MN|55449|t||8401
-#1112d|8401|W|35W||||Blaine|MN|55449|t||8401
-#1112e|8401|W|35W||||Blaine|MN|55449|t||8401
-#1125a|19596 Co Rd 480, COLCORD, OK 74338
-#1125b|4345 353 Rte, SALAMANCA, NY 14779|4345||353|Rte|||SALAMANCA|NY|14779|t||4345
-#1125c|19799 State Rte O, COSBY, MO 64436|19799||O|State Rte|||COSBY|MO|64436|t||19799
-#1125d|Interstate Interstate 90, Boston, MA|||Interstate 90||||Boston|MA||t||Interstate
-#1125e|I-90 I-90,Boston, MA|||I-90,Boston|||||MA||t||I-90
-#1125f|I I 90, Boston, MA|||I 90||||Boston|MA||t||I
-#1310a|1110 W CAPITOL Ave, WEST SACRAMENTO, CA|1110|W|CAPITOL|Ave|||WEST SACRAMENTO|CA||t||1110
-#1614a|8435 Co Rd 20 SE, ROCHESTER, MN 55904|8435||20|Co Rd|SE||ROCHESTER|MN|55904|t||8435
-#1614b|3208 US Hwy 52, Rochester, MN 55901|3208||52|US Hwy|||Rochester|MN|55901|t||3208
-#1108a|529 Main St, Suite 201, Boston, MA 02129|529||Main|St||Suite 201|Boston|MA|02129|t||529
+#887|2450|N|COLORADO|St|||PHILADELPHIA|PA|19132|t||2450|US
+#1051a|212||3rd|Ave|N|Suite 560|Minneapolis|MN|55401|t||212|US
+#1051b|3937||43RD|Ave|S||MINNEAPOLIS|MN|55406|t||3937|US
+#1051c|212|N|3rd|Ave|||Minneapolis|MN|55401|t||212|US
+#1599|212|N|3rd|Ave|||Minneapolis|MN|55401|t||212|US
+#1599b|212|N|3rd|Ave|||Minneapolis|MN|55401|t||212|FR
+#1599c|26||Court|St|||Boston|MA|02109|t||26|FR
+#1599d|529||Main|St|||Boston|MA|021|t||529|FR
+#1599e|26||Court|St|||Boston|MA|02109|t||26|FR
+#1051d|212||3rd|Ave|N||Minneapolis|MN|55401|t||212|US
+529||Main|St|||Boston|MA|02129|t||529|US
+529||Main|St|||Boston|MA||t||529|US
+529||Main|St||Apt 201|Boston|MA|02129|t||529|US
+529||Main|St||Apt 201|Boston|MA||t||529|US
+#1108a|529||Main|St||Suite 201|Boston|MA|02129|t||529|US
+#1073a|212||3rd|Ave|N||MINNEAPOLIS|MN|553404|t|4|212|US
+#1073b|212||3rd|Ave|N||MINNEAPOLIS|MN|55401|t||212|US
+#1073c|529||Main|St|||Boston|MA|021|t||529|US
+#1086a|949|N|3rd|St|||New Hyde Park|NY|11040|t||949|US
+#1086b|949|N|3rd|St|||New Hyde Park|NY|11040|t||949|US
+#1076a|16725||24|Co Rd|||Plymouth|MN|55447|t||16725|US
+#1076b|16725||24|Co Rd|||Plymouth|MN|55447|t||16725|US
+#1076c|13800||9|Co Hwy|||Andover|MN|55304|t||13800|US
+#1076d|13800||9||||Andover|MN|55304|t||13800|US
+#1076e|14||Forest|Rd|||Acton|MA||t||14|US
+#1076f|1940||C|Co Rd|W||Roseville|MN|55113|t||1940|US
+#1076g|3900||6|Rte|||Eastham|MA|02642|t||3900|US
+#1076h|4533||PARK|Ave|S||MINNEAPOLIS|MN|55407|t||4533|US
+#1076i|4533||33|Co Rd|||MINNEAPOLIS|MN|55407|t||4533|US
+#1109a|4373||LAKE|Dr|||ROBBINSDALE|MN|55422|t||4373|US
+#1109b|4373||LAKE|Dr|||ROBBINSDALE|MN|55422|t||4373|US
+#1074a|3420||RHODE ISLAND|Ave|S||ST. LOUIS PARK|MN|55426|t||3420|US
+#1074b|26||Court|St|||Boston|MA|02109|t||26|US
+#1112a|8401|W|35W|Svc Dr|NE||Blaine|MN|55449|t||8401|US
+#1112b|8401||35W||||Blaine|MN|55449|t||8401|US
+#1112c|8401||35W||W||Blaine|MN|55449|t||8401|US
+#1112d|8401|W|35W||||Blaine|MN|55449|t||8401|US
+#1112e|8401|W|35W||||Blaine|MN|55449|t||8401|US
+#1125a|19596 Co Rd 480, COLCORD, OK 74338, US
+#1125b|4345 353 Rte, SALAMANCA, NY 14779, US|4345||353|Rte|||SALAMANCA|NY|14779|t||4345|US
+#1125c|19799 State Rte O, COSBY, MO 64436, US|19799||O|State Rte|||COSBY|MO|64436|t||19799|US
+#1125d|Interstate Interstate 90, Boston, MA, US|||Interstate 90||||Boston|MA||t||Interstate|US
+#1125e|I-90 I-90,Boston, MA, US|||I-90,Boston|||||MA||t||I-90|US
+#1125f|I I 90, Boston, MA, US|||I 90||||Boston|MA||t||I|US
+#1599g|
+#1310a|1110 W CAPITOL Ave, WEST SACRAMENTO, CA, US|1110|W|CAPITOL|Ave|||WEST SACRAMENTO|CA||t||1110|US
+#1614a|8435 Co Rd 20 SE, ROCHESTER, MN 55904, US|8435||20|Co Rd|SE||ROCHESTER|MN|55904|t||8435|US
+#1614b|3208 US Hwy 52, Rochester, MN 55901, US|3208||52|US Hwy|||Rochester|MN|55901|t||3208|US
+#1108a|529 Main St, Suite 201, Boston, MA 02129, US|529||Main|St||Suite 201|Boston|MA|02129|t||529|US
diff --git a/extras/tiger_geocoder/regress/normalize_address_regress.sql b/extras/tiger_geocoder/regress/normalize_address_regress.sql
index 0447bdfdf..46749542e 100644
--- a/extras/tiger_geocoder/regress/normalize_address_regress.sql
+++ b/extras/tiger_geocoder/regress/normalize_address_regress.sql
@@ -3,6 +3,11 @@ SELECT '#887' As ticket, * FROM normalize_address('2450 N COLORADO ST, PHILADELP
SELECT '#1051a' As ticket, * FROM normalize_address('212 3rd Ave N Suite 560, Minneapolis, MN 55401');
SELECT '#1051b' As ticket, * FROM normalize_address('3937 43RD AVE S, MINNEAPOLIS, MN 55406');
SELECT '#1051c' As ticket, * FROM normalize_address('212 N 3rd Ave, Minneapolis, MN 55401');
+SELECT '#1599' As ticket, * FROM normalize_address('212 n 3rd ave, Minneapolis, mn 55401, USA');
+SELECT '#1599b' As ticket, * FROM normalize_address('212 n 3rd ave, Minneapolis, mn 55401, France');
+SELECT '#1599c' As ticket, * FROM normalize_address('26 Court Street, Boston, Massachusetts 02109, France');
+SELECT '#1599d' As ticket, * FROM normalize_address('529 Main Street, Boston, MA 021, France');
+SELECT '#1599e' As ticket, * FROM normalize_address('26 Court Street, Boston, Massachusetts 02109, FR');
-- City missing , -- NOTE this one won't normalize right if you don't have MN data loaded
SELECT '#1051d' As ticket, * FROM normalize_address('212 3rd Ave N Minneapolis, MN 55401');
-- comma in wrong spot
@@ -86,6 +91,7 @@ SELECT '#1125d' As ticket, pprint_addy(addy), addy.* FROM normalize_address('Int
SELECT '#1125e' As ticket, pprint_addy(addy), addy.* FROM normalize_address('I-90,Boston, MA') As addy;
--broke this one too
SELECT '#1125f' As ticket, pprint_addy(addy), addy.* FROM normalize_address('I 90,Boston, MA') As addy;
+SELECT '#1599g' As ticket, pprint_addy(ROW(NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,true,NULL,NULL,'US')::norm_addy);
-- location with prefixes getting caught in post prefix
SELECT '#1310a' As ticket, pprint_addy(addy), addy.* FROM normalize_address('1110 W CAPITOL AVE, WEST SACRAMENTO, CA') As addy;
diff --git a/extras/tiger_geocoder/regress/pagc_normalize_address_regress b/extras/tiger_geocoder/regress/pagc_normalize_address_regress
index 95216890b..9ea5fefd6 100644
--- a/extras/tiger_geocoder/regress/pagc_normalize_address_regress
+++ b/extras/tiger_geocoder/regress/pagc_normalize_address_regress
@@ -1,53 +1,58 @@
true
-#887|2450|N|COLORADO|ST|||PHILADELPHIA|PA|19132|t||2450
-#1051a|212||3RD|AVE|N|STE 560|MINNEAPOLIS|MN|55401|t||212
-#1051b|3937||43RD|AVE|S||MINNEAPOLIS|MN|55406|t||3937
-#1051c|212|N|3RD|AVE|||MINNEAPOLIS|MN|55401|t||212
-#1051d|212||3RD|AVE|N||MINNEAPOLIS|MN|55401|t||212
-529||MAIN|ST|||BOSTON|MA|02129|t||529
-529||MAIN|ST|||BOSTON|MA||t||529
-529||MAIN|ST||APT 201|BOSTON|MA|02129|t||529
-529||MAIN|ST||APT 201|BOSTON|MA||t||529
-#1108a|529||MAIN|ST||STE 201|BOSTON|MA|02129|t||529
-#1073a|212||3RD|AVE|N||MINNEAPOLIS|MN|55340|t|4|212
-#1073b|212||3RD|AVE|N||MINNEAPOLIS|MN|55401|t||212
-#1073c|529||MAIN|ST||BOSTON|MASSACHUSETTS||021|t||529
-#1086a|949|N|3RD|ST|||NEW HYDE PARK|NY|11040|t||949
-#1086b|949|N|3RD|ST|||NEW HYDE PARK|NY|11040|t||949
-#1076a|16725||24|CO RD|||PLYMOUTH|MN|55447|t||16725
-#1076b|16725||24|CO RD|||PLYMOUTH|MN|55447|t||16725
-#1076c|13800||9|CO HWY|||ANDOVER|MN|55304|t||13800
-#1076d|13800||9||||ANDOVER|MN|55304|t||13800
-#1076e|14||FOREST|RD|||ACTON|MA||t||14
-#1076f|1940||C|CO RD|W||ROSEVILLE|MN|55113|t||1940
-#1076g|3900||6|RTE|||EASTHAM|MA|02642|t||3900
-#1076h|4533||PARK|AVE|S||MINNEAPOLIS|MN|55407|t||4533
-#1076i|4533||33|CO RD|||MINNEAPOLIS|MN|55407|t||4533
-#1109a|4373||LAKE|DR|||ROBBINSDALE|MN|55422|t||4373
-#1109b|4373||LAKE|DR|||ROBBINSDALE|MN|55422|t||4373
-#1074a|3420||RHODE ISLAND|AVE|S||SAINT LOUIS PARK|MN|55426|t||3420
-#1074b|26||COURT|ST|||BOSTON|MA|02109|t||26
-#1112a|8401|W|35 W|SVC DR|NE||BLAINE|MN|55449|t||8401
-#1112b|8401||35 W||||BLAINE|MN|55449|t||8401
-#1112c|8401||35 W||W||BLAINE|MN|55449|t||8401
-#1112d|8401|W|35||W||BLAINE|MN|55449|t||8401
-#1112e|8401|W|35||W||BLAINE|MN|55449|t||8401
-#1125a|19596 CO RD 480, COLCORD, OK 74338
-#1125b|4345 353 RTE, SALAMANCA, NY 14779|4345||353|RTE|||SALAMANCA|NY|14779|t||4345
-#1125c|19799 STATE RTE 0, COSBY, MO 64436|19799||0|STATE RTE|||COSBY|MO|64436|t||19799
-#1125d|||||||||||t||
-#1125e|||||||||||t||
-#1125f|||||||||||t||
-#1310a|1110 W CAPITOL AVE, WEST SACRAMENTO, CA|1110|W|CAPITOL|AVE|||WEST SACRAMENTO|CA||t||1110
-#1614a|8435 CO RD 20 SE, ROCHESTER, MN 55904|8435||20|CO RD|SE||ROCHESTER|MN|55904|t||8435
-#1614b|3208 US RTE 52, ROCHESTER, MN 55901|3208||52|US RTE|||ROCHESTER|MN|55901|t||3208
-#1108a|529 MAIN ST, STE 201, BOSTON, MA 02129|529||MAIN|ST||STE 201|BOSTON|MA|02129|t||529
-#3259a|212||3RD|AVE|N|STE 560|MINNEAPOLIS|MN|55401|t||212
-#3259b|3937||43RD|AVE|S||MINNEAPOLIS|MN|55406|t||3937
-#2981|1566||NEW STATE HWY||||RAYNHAM|MA||t||1566
-#2978a|10||DORRANCE|ST|||PROVIDENCE|RI||t||10 20
-#2978b|10||DORRANCE|ST|||PROVIDENCE|RI||t||10 20
-#2978c|10||DORRANCE|ST|||PROVIDENCE|RI||t||10 20
+#887|2450|N|COLORADO|ST|||PHILADELPHIA|PA|19132|t||2450|US
+#1051a|212||3RD|AVE|N|STE 560|MINNEAPOLIS|MN|55401|t||212|US
+#1051b|3937||43RD|AVE|S||MINNEAPOLIS|MN|55406|t||3937|US
+#1051c|212|N|3RD|AVE|||MINNEAPOLIS|MN|55401|t||212|US
+#1599|212|N|3RD|AVE|||MINNEAPOLIS|MN|55401|t||212|US
+#1599b|212|N|3RD|AVE|||MINNEAPOLIS|MN|55401|t||212|FR
+#1599c|26||COURT|ST|||BOSTON|MA|02109|t||26|FR
+#1599d|529||MAIN|ST|||BOSTON|MA|021|t||529|FR
+#1599e|26||COURT|ST|||BOSTON|MA|02109|t||26|FR
+#1051d|212||3RD|AVE|N||MINNEAPOLIS|MN|55401|t||212|US
+529||MAIN|ST|||BOSTON|MA|02129|t||529|US
+529||MAIN|ST|||BOSTON|MA||t||529|US
+529||MAIN|ST||APT 201|BOSTON|MA|02129|t||529|US
+529||MAIN|ST||APT 201|BOSTON|MA||t||529|US
+#1108a|529||MAIN|ST||STE 201|BOSTON|MA|02129|t||529|US
+#1073a|212||3RD|AVE|N||MINNEAPOLIS|MN|55340|t|4|212|US
+#1073b|212||3RD|AVE|N||MINNEAPOLIS|MN|55401|t||212|US
+#1073c|529||MAIN|ST|||BOSTON|MA|021|t||529|US
+#1086a|949|N|3RD|ST|||NEW HYDE PARK|NY|11040|t||949|US
+#1086b|949|N|3RD|ST|||NEW HYDE PARK|NY|11040|t||949|US
+#1076a|16725||24|CO RD|||PLYMOUTH|MN|55447|t||16725|US
+#1076b|16725||24|CO RD|||PLYMOUTH|MN|55447|t||16725|US
+#1076c|13800||9|CO HWY|||ANDOVER|MN|55304|t||13800|US
+#1076d|13800||9||||ANDOVER|MN|55304|t||13800|US
+#1076e|14||FOREST|RD|||ACTON|MA||t||14|US
+#1076f|1940||C|CO RD|W||ROSEVILLE|MN|55113|t||1940|US
+#1076g|3900||6|RTE|||EASTHAM|MA|02642|t||3900|US
+#1076h|4533||PARK|AVE|S||MINNEAPOLIS|MN|55407|t||4533|US
+#1076i|4533||33|CO RD|||MINNEAPOLIS|MN|55407|t||4533|US
+#1109a|4373||LAKE|DR|||ROBBINSDALE|MN|55422|t||4373|US
+#1109b|4373||LAKE|DR|||ROBBINSDALE|MN|55422|t||4373|US
+#1074a|3420||RHODE ISLAND|AVE|S||SAINT LOUIS PARK|MN|55426|t||3420|US
+#1074b|26||COURT|ST|||BOSTON|MA|02109|t||26|US
+#1112a|8401|W|35 W|SVC DR|NE||BLAINE|MN|55449|t||8401|US
+#1112b|8401||35 W||||BLAINE|MN|55449|t||8401|US
+#1112c|8401||35 W||W||BLAINE|MN|55449|t||8401|US
+#1112d|8401|W|35||W||BLAINE|MN|55449|t||8401|US
+#1112e|8401|W|35||W||BLAINE|MN|55449|t||8401|US
+#1125a|19596 CO RD 480, COLCORD, OK 74338, US
+#1125b|4345 353 RTE, SALAMANCA, NY 14779, US|4345||353|RTE|||SALAMANCA|NY|14779|t||4345|US
+#1125c|19799 STATE RTE 0, COSBY, MO 64436, US|19799||0|STATE RTE|||COSBY|MO|64436|t||19799|US
+#1125d|||||||||||t|||US
+#1125e|||||||||||t|||US
+#1125f|||||||||||t|||US
+#1310a|1110 W CAPITOL AVE, WEST SACRAMENTO, CA, US|1110|W|CAPITOL|AVE|||WEST SACRAMENTO|CA||t||1110|US
+#1614a|8435 CO RD 20 SE, ROCHESTER, MN 55904, US|8435||20|CO RD|SE||ROCHESTER|MN|55904|t||8435|US
+#1614b|3208 US RTE 52, ROCHESTER, MN 55901, US|3208||52|US RTE|||ROCHESTER|MN|55901|t||3208|US
+#1108a|529 MAIN ST, STE 201, BOSTON, MA 02129, US|529||MAIN|ST||STE 201|BOSTON|MA|02129|t||529|US
+#3259a|212||3RD|AVE|N|STE 560|MINNEAPOLIS|MN|55401|t||212|US
+#3259b|3937||43RD|AVE|S||MINNEAPOLIS|MN|55406|t||3937|US
+#2981|1566||NEW STATE HWY||||RAYNHAM|MA||t||1566|US
+#2978a|10||DORRANCE|ST|||PROVIDENCE|RI||t||10 20|US
+#2978b|10||DORRANCE|ST|||PROVIDENCE|RI||t||10 20|US
+#2978c|10||DORRANCE|ST|||PROVIDENCE|RI||t||10 20|US
false
diff --git a/extras/tiger_geocoder/regress/pagc_normalize_address_regress.sql b/extras/tiger_geocoder/regress/pagc_normalize_address_regress.sql
index abd6d094b..783732fce 100644
--- a/extras/tiger_geocoder/regress/pagc_normalize_address_regress.sql
+++ b/extras/tiger_geocoder/regress/pagc_normalize_address_regress.sql
@@ -7,6 +7,11 @@ SELECT '#1051a' As ticket, * FROM normalize_address('212 3rd Ave N Suite 560, Mi
-- this currently turns 3rd to 3, we want to fix to keep 3rd as is
diff --git a/extras/tiger_geocoder/upgrade_geocode.sql b/extras/tiger_geocoder/upgrade_geocode.sql
index 1057a3a8b..c98decd9f 100644
--- a/extras/tiger_geocoder/upgrade_geocode.sql
+++ b/extras/tiger_geocoder/upgrade_geocode.sql
@@ -28,12 +28,43 @@ ALTER TABLE state_lookup ADD CONSTRAINT state_lookup_statefp_key UNIQUE(statefp)
DO language plpgsql
- BEGIN
+DECLARE
+BEGIN
+ IF NOT EXISTS (
+ SELECT 1
+ FROM pg_attribute
+ ) THEN
+ END IF;
+ IF NOT EXISTS (
+ SELECT 1
+ FROM pg_attribute
+ ) THEN
- EXCEPTION
- END;
+ END IF;
+ IF NOT EXISTS (
+ SELECT 1
+ FROM pg_attribute
+ ) THEN
+ END IF;
+END;
CREATE INDEX idx_tiger_edges_countyfp ON edges USING btree(countyfp);
Summary of changes:
NEWS | 4 +
doc/extras_address_standardizer.xml | 5 +-
doc/installation.xml | 2 +-
extensions/address_standardizer/address_parser.c | 17 +
.../address_standardizer/address_standardizer.c | 8 +
.../address_standardizer_functions.sql.in | 4 +
.../expected/test-standardize_address_1.out | 12 +-
extensions/address_standardizer/parseaddress-api.c | 242 +++++-
extensions/address_standardizer/parseaddress-api.h | 2 +
.../address_standardizer/parseaddress-countries.h | 942 +++++++++++++++++++++
.../address_standardizer/test-parseaddress.sql.in | 9 +
extensions/postgis_tiger_geocoder/Makefile.in | 3 +-
.../postgis_tiger_geocoder.control.in | 2 +-
.../sql_bits/norm_addy_create.sql.in | 5 +-
.../sql_bits/norm_addy_upgrade.sql.in | 3 +-
.../sql_bits/upgrade_before.sql.in | 43 +-
extras/tiger_geocoder/create_geocode.sql | 4 +-
.../tiger_geocoder/normalize/normalize_address.sql | 18 +
extras/tiger_geocoder/normalize/pprint_addy.sql | 8 +-
.../pagc_normalize/pagc_normalize_address.sql | 5 +-
.../regress/normalize_address_regress | 96 ++-
.../regress/normalize_address_regress.sql | 6 +
.../regress/pagc_normalize_address_regress | 107 +--
.../regress/pagc_normalize_address_regress.sql | 5 +
extras/tiger_geocoder/upgrade_geocode.sql | 41 +-
25 files changed, 1451 insertions(+), 142 deletions(-)
create mode 100644 extensions/address_standardizer/parseaddress-countries.h
hooks/post-receive
