[SCM] PostGIS branch master updated. 3.6.0rc2-381-gd2a87d630
git at osgeo.org
git at osgeo.org
Mon Mar 9 04:23:45 PDT 2026
the project "PostGIS".
via d2a87d6305a558906618f7df087ffdcf8a60d988 (commit)
from 20fcd89ae646c2557cf892251242bc16a76a927c (commit)
revisions in full, below.
commit d2a87d6305a558906618f7df087ffdcf8a60d988
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Mar 9 14:34:50 2026 +0400
Fix #1461 geocode_intersection spacing fallback
Add a narrow normalized-fullname comparison so geocode_intersection matches TIGER highway names when spacing around hyphens differs, without changing suffix-form route parsing or type-less second-street scoring.
Closes #1461
diff --git a/NEWS b/NEWS
index d9bf639d8..c6d77cc77 100644
--- a/NEWS
+++ b/NEWS
@@ -41,6 +41,9 @@ This version requires GEOS 3.10 or higher
- #4828, geometry_columns handles NOT VALID SRID checks without errors (Darafei Praliaskouski)
- #6048, [raster] ST_Clip no longer crashes when clipping sparse band
selections (Darafei Praliaskouski)
+ - #1461, [tiger geocoder] geocode_intersection now tolerates irregular
+ spacing in highway names such as `I- 635` vs `I-635`
+ (OpenAI)
- #1599, [address_standardizer] parse_address() and normalize_address() now
canonicalize trailing country tokens to ISO 3166-1 alpha-2 codes and
expose country on normalized addresses
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index d2b5029d4..c103b3069 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -29,7 +29,7 @@ DATA_built = \
sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql \
$(NULL)
-REGRESS = test-normalize_address test-upgrade
+REGRESS = test-normalize_address test-geocode_intersection_spacing test-upgrade
REGRESS_OPTS = --load-extension=fuzzystrmatch --load-extension=postgis
EXTSCHEMA_SUPPORTED = yes
@@ -48,7 +48,7 @@ ifeq (@ADDRESS_STANDARDIZER@,address_standardizer)
endif
REGRESS_OPTS += --load-extension=$(EXTENSION)
-all: sql/$(EXTENSION)_pre.sql sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--ANY--$(EXTVERSION).sql sql/test-normalize_address.sql sql/test-pagc_normalize_address.sql expected/test-normalize_address.out expected/test-pagc_normalize_address.out sql/test-upgrade.sql expected/test-upgrade.out
+all: sql/$(EXTENSION)_pre.sql sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--ANY--$(EXTVERSION).sql sql/test-normalize_address.sql sql/test-geocode_intersection_spacing.sql sql/test-pagc_normalize_address.sql expected/test-normalize_address.out expected/test-geocode_intersection_spacing.out expected/test-pagc_normalize_address.out sql/test-upgrade.sql expected/test-upgrade.out
.PHONY: expected
@@ -71,6 +71,9 @@ endif
expected/test-normalize_address.out: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/normalize_address_regress | expected
cat $^ > $@
+expected/test-geocode_intersection_spacing.out: sql_bits/test_tuples_only_unaligned.sql.in sql_bits/test-geocode_intersection_spacing.out.in | expected
+ cat $^ > $@
expected/test-pagc_normalize_address.out: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/pagc_normalize_address_regress | expected
cat $^ > $@
@@ -78,6 +81,9 @@ expected/test-pagc_normalize_address.out: sql_bits/test_tuples_only_unaligned.sq
sql/test-normalize_address.sql: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/normalize_address_regress.sql | sql
cat $^ > $@
+sql/test-geocode_intersection_spacing.sql: sql_bits/test_tuples_only_unaligned.sql.in sql_bits/test-geocode_intersection_spacing.sql.in | sql
+ cat $^ > $@
sql/test-upgrade.sql: | sql
echo 'ALTER EXTENSION ${EXTENSION} UPDATE TO "ANY"; ALTER EXTENSION ${EXTENSION} UPDATE TO "$(EXTVERSION)"' > $@
diff --git a/extensions/postgis_tiger_geocoder/sql_bits/test-geocode_intersection_spacing.out.in b/extensions/postgis_tiger_geocoder/sql_bits/test-geocode_intersection_spacing.out.in
new file mode 100644
index 000000000..805fad2d3
--- /dev/null
+++ b/extensions/postgis_tiger_geocoder/sql_bits/test-geocode_intersection_spacing.out.in
@@ -0,0 +1,4 @@
+#1461c|353|Rte
+#1461a|100 N Belt Line Rd, Coppell, TX 75019|POINT(-96.99 32.986)|5
+#1461b|100 N Belt Line Rd, Coppell, TX 75019|POINT(-96.99 32.986)|5
+#1461d|50 Weld Ave, Coppell, TX 75019|POINT(-96.98 32.98)|4
diff --git a/extensions/postgis_tiger_geocoder/sql_bits/test-geocode_intersection_spacing.sql.in b/extensions/postgis_tiger_geocoder/sql_bits/test-geocode_intersection_spacing.sql.in
index 000000000..304f928ee
--- /dev/null
+++ b/extensions/postgis_tiger_geocoder/sql_bits/test-geocode_intersection_spacing.sql.in
@@ -0,0 +1,63 @@
+\o /dev/null
+BEGIN;
+INSERT INTO tiger.zip_lookup_base(zip, state, county, city, statefp)
+VALUES ('75019', 'Texas', 'Dallas', 'Coppell', '48');
+INSERT INTO tiger.place(statefp, placefp, plcidfp, name)
+VALUES ('48', '00001', '4800001', 'Coppell');
+INSERT INTO tiger.faces(tfid, statefp, placefp)
+VALUES (2001, '48', '00001');
+INSERT INTO tiger.edges(statefp, countyfp, tlid, tfidl, tfidr, fullname, tnidf, tnidt, the_geom)
+VALUES
+ ('48', '113', 1001, 2001, 2001, 'N Belt Line Rd', 10, 11,
+ ST_GeomFromText('MULTILINESTRING((-96.990000 32.986000,-96.990000 32.987000))', 4269)),
+ ('48', '113', 1002, 2001, 2001, 'I- 635', 10, 12,
+ ST_GeomFromText('MULTILINESTRING((-96.991000 32.986000,-96.989000 32.986000))', 4269)),
+ ('48', '113', 1003, 2001, 2001, 'Weld Ave', 20, 21,
+ ST_GeomFromText('MULTILINESTRING((-96.980000 32.980000,-96.980000 32.982000))', 4269)),
+ ('48', '113', 1004, 2001, 2001, 'School Terrace', 20, 22,
+ ST_GeomFromText('MULTILINESTRING((-96.981000 32.980000,-96.980000 32.980000))', 4269)),
+ ('48', '113', 1005, 2001, 2001, 'Schools', 21, 23,
+ ST_GeomFromText('MULTILINESTRING((-96.981000 32.982000,-96.980000 32.982000))', 4269));
+INSERT INTO tiger.featnames(statefp, tlid, fullname, name, predirabrv, suftypabrv, pretypabrv)
+VALUES
+ ('48', 1001, 'N Belt Line Rd', 'Belt Line', 'N', 'Rd', NULL),
+ ('48', 1002, 'I- 635', '635', NULL, NULL, 'I-'),
+ ('48', 1003, 'Weld Ave', 'Weld', NULL, 'Ave', NULL),
+ ('48', 1004, 'School Terrace', 'School', NULL, 'Ter', NULL),
+ ('48', 1005, 'Schools', 'Schools', NULL, NULL, NULL);
+INSERT INTO tiger.addr(statefp, tlid, fromhn, tohn, side, zip)
+VALUES
+ ('48', 1001, '100', '198', 'L', '75019'),
+ ('48', 1002, '0', '0', 'L', '75019'),
+ ('48', 1003, '50', '98', 'L', '75019'),
+ ('48', 1004, '0', '0', 'L', '75019'),
+ ('48', 1005, '0', '0', 'L', '75019');
+\o
+SELECT '#1461c' AS ticket, streetname, streettypeabbrev
+FROM normalize_address('0 353 Rte, Coppell, TX');
+SELECT '#1461a' AS ticket, pprint_addy(addy), ST_AsText(ST_SnapToGrid(geomout, 0.000001)), rating
+FROM geocode_intersection('N. Belt Line', 'I- 635', 'TX', 'Coppell')
+ORDER BY rating
+LIMIT 1;
+SELECT '#1461b' AS ticket, pprint_addy(addy), ST_AsText(ST_SnapToGrid(geomout, 0.000001)), rating
+FROM geocode_intersection('N. Belt Line', 'I-635', 'TX', 'Coppell')
+ORDER BY rating
+LIMIT 1;
+SELECT '#1461d' AS ticket, pprint_addy(addy), ST_AsText(ST_SnapToGrid(geomout, 0.000001)), rating
+FROM geocode_intersection('Weld', 'School', 'TX', 'Coppell')
+ORDER BY rating
+LIMIT 1;
+\o /dev/null
+ROLLBACK;
+\o
diff --git a/extras/tiger_geocoder/geocode/geocode_intersection.sql b/extras/tiger_geocoder/geocode/geocode_intersection.sql
index 3029e23c1..599a1e108 100644
--- a/extras/tiger_geocoder/geocode/geocode_intersection.sql
+++ b/extras/tiger_geocoder/geocode/geocode_intersection.sql
@@ -23,6 +23,12 @@ $$
DECLARE
var_na_road norm_addy;
var_na_inter1 norm_addy;
+ var_road_name text;
+ var_road_fullname text;
+ var_inter_name text;
+ var_inter_fullname text;
+ var_road_input_normalized text;
+ var_inter_input_normalized text;
var_sql text := '';
var_zip varchar(5)[];
in_statefp varchar(2) ;
@@ -36,6 +42,12 @@ BEGIN
var_na_road := normalize_address('0 ' || roadway1 || ', ' || COALESCE(in_city,'') || ', ' || in_state || ' ' || in_zip);
var_na_inter1 := normalize_address('0 ' || roadway2 || ', ' || COALESCE(in_city,'') || ', ' || in_state || ' ' || in_zip);
END IF;
+ var_road_name := trim(lower(COALESCE(var_na_road.streetName, '')));
+ var_road_fullname := trim(lower(var_na_road.streetName || ' ' || COALESCE(var_na_road.streetTypeAbbrev,'')));
+ var_inter_name := trim(lower(COALESCE(var_na_inter1.streetName, '')));
+ var_inter_fullname := trim(lower(var_na_inter1.streetName || ' ' || COALESCE(var_na_inter1.streetTypeAbbrev,'')));
+ var_road_input_normalized := normalize_street_name(trim(lower(roadway1)));
+ var_inter_input_normalized := normalize_street_name(trim(lower(roadway2)));
in_statefp := statefp FROM state_lookup As s WHERE s.abbrev = upper(in_state);
IF COALESCE(in_zip,'') > '' THEN -- limit search to 2 plus or minus the input zip
var_zip := zip_range(in_zip, -2,2);
@@ -54,42 +66,61 @@ BEGIN
END IF;
var_sql := '
WITH
- a1 AS (SELECT f.*, addr.fromhn, addr.tohn, addr.side , addr.zip
- FROM (SELECT * FROM tiger.featnames
- WHERE statefp = $1 AND ( lower(name) = $2 ' ||
- CASE WHEN length(var_na_road.streetName) > 5 THEN ' or lower(fullname) LIKE $6 || ''%'' ' ELSE '' END || ')'
- || ') AS f LEFT JOIN (SELECT * FROM tiger.addr As addr WHERE addr.statefp = $1) As addr ON (addr.tlid = f.tlid AND addr.statefp = f.statefp)
- WHERE $5::text[] IS NULL OR addr.zip = ANY($5::text[]) OR addr.zip IS NULL
- ORDER BY CASE WHEN lower(f.fullname) = $6 THEN 0 ELSE 1 END
- LIMIT 50000
+ a1 AS (SELECT f.*, addr.fromhn, addr.tohn, addr.side , addr.zip
+ FROM (SELECT * FROM tiger.featnames
+ WHERE statefp = $1 AND (
+ lower(name) = $2 ' ||
+ CASE WHEN length(var_na_road.streetName) > 5 THEN ' or lower(fullname) LIKE $6 || ''%'' ' ELSE '' END ||
+ ' or normalize_street_name(fullname) = $10)'
+ || ') AS f LEFT JOIN (SELECT * FROM tiger.addr As addr WHERE addr.statefp = $1) As addr ON (addr.tlid = f.tlid AND addr.statefp = f.statefp)
+ WHERE $5::text[] IS NULL OR addr.zip = ANY($5::text[]) OR addr.zip IS NULL
+ ORDER BY CASE
+ WHEN lower(f.fullname) = $6 OR normalize_street_name(f.fullname) = $10 THEN 0
+ ELSE 1 END
+ LIMIT 50000
a2 AS (SELECT f.*, addr.fromhn, addr.tohn, addr.side , addr.zip
- WHERE statefp = $1 AND ( lower(name) = $4 ' ||
- CASE WHEN length(var_na_inter1.streetName) > 5 THEN ' or lower(fullname) LIKE $7 || ''%'' ' ELSE '' END || ')'
- || ' ) AS f LEFT JOIN (SELECT * FROM tiger.addr As addr WHERE addr.statefp = $1) AS addr ON (addr.tlid = f.tlid AND addr.statefp = f.statefp)
- WHERE $5::text[] IS NULL OR addr.zip = ANY($5::text[]) or addr.zip IS NULL
- ORDER BY CASE WHEN lower(f.fullname) = $7 THEN 0 ELSE 1 END
- LIMIT 50000
- e1 AS (SELECT e.the_geom, e.tnidf, e.tnidt, a.*,
- CASE WHEN a.side = ''L'' THEN e.tfidl ELSE e.tfidr END AS tfid
- FROM a1 As a
- INNER JOIN tiger.edges AS e ON (e.statefp = a.statefp AND a.tlid = e.tlid)
- WHERE e.statefp = $1
- ORDER BY CASE WHEN lower(a.name) = $4 THEN 0 ELSE 1 END + CASE WHEN lower(e.fullname) = $7 THEN 0 ELSE 1 END
- LIMIT 5000) ,
- e2 AS (SELECT e.the_geom, e.tnidf, e.tnidt, a.*,
- FROM (SELECT * FROM tiger.edges WHERE statefp = $1) AS e INNER JOIN a2 AS a ON (e.statefp = a.statefp AND a.tlid = e.tlid)
- INNER JOIN e1 ON (e.statefp = e1.statefp
- AND ARRAY[e.tnidf, e.tnidt] && ARRAY[e1.tnidf, e1.tnidt] )
+ lower(name) = $4 ' ||
+ CASE WHEN length(var_na_inter1.streetName) > 5 THEN ' or lower(fullname) LIKE $7 || ''%'' ' ELSE '' END ||
+ ' or normalize_street_name(fullname) = $11)'
+ || ' ) AS f LEFT JOIN (SELECT * FROM tiger.addr As addr WHERE addr.statefp = $1) AS addr ON (addr.tlid = f.tlid AND addr.statefp = f.statefp)
+ WHERE $5::text[] IS NULL OR addr.zip = ANY($5::text[]) or addr.zip IS NULL
+ ORDER BY CASE
+ WHEN lower(f.fullname) = $7 OR normalize_street_name(f.fullname) = $11 THEN 0
+ ELSE 1 END
+ LIMIT 50000
+ e1 AS (SELECT e.the_geom, e.tnidf, e.tnidt, a.*,
+ CASE WHEN a.side = ''L'' THEN e.tfidl ELSE e.tfidr END AS tfid
+ FROM a1 As a
+ INNER JOIN tiger.edges AS e ON (e.statefp = a.statefp AND a.tlid = e.tlid)
+ WHERE e.statefp = $1
+ ORDER BY CASE
+ WHEN lower(a.name) = $4 THEN 0 ELSE 1 END
+ + CASE
+ WHEN lower(e.fullname) = $7 OR normalize_street_name(e.fullname) = $11 THEN 0
+ ELSE 1 END
+ LIMIT 5000) ,
+ e2 AS (SELECT e.the_geom, e.tnidf, e.tnidt, a.*,
+ FROM (SELECT * FROM tiger.edges WHERE statefp = $1) AS e INNER JOIN a2 AS a ON (e.statefp = a.statefp AND a.tlid = e.tlid)
+ INNER JOIN e1 ON (e.statefp = e1.statefp
+ AND ARRAY[e.tnidf, e.tnidt] && ARRAY[e1.tnidf, e1.tnidt] )
- WHERE (lower(e.fullname) = $7 or lower(a.name) LIKE $4 || ''%'')
- LIMIT 5000
- segs AS (SELECT DISTINCT ON(e1.tlid, e1.side)
+ WHERE (
+ lower(e.fullname) = $7
+ OR normalize_street_name(e.fullname) = $11
+ OR lower(a.name) LIKE $4 || ''%'')
+ ORDER BY CASE
+ + CASE
+ ELSE 1 END
+ LIMIT 5000
+ segs AS (SELECT DISTINCT ON(e1.tlid, e1.side)
CASE WHEN e1.tnidf = e2.tnidf OR e1.tnidf = e2.tnidt THEN
e1.fromhn
ELSE
@@ -101,9 +132,15 @@ BEGIN
ELSE ST_EndPoint(ST_GeometryN(ST_Multi(e1.the_geom),1)) END AS geom ,
CASE WHEN lower(p.name) = $3 THEN 0 ELSE 1 END
+ tiger.levenshtein_ignore_case(p.name, $3)
- + tiger.levenshtein_ignore_case(e1.name || COALESCE('' '' || e1.sufqualabr, ''''),$2) +
- CASE WHEN e1.fullname = $6 THEN 0 ELSE tiger.levenshtein_ignore_case(e1.fullname, $6) END +
- + tiger.levenshtein_ignore_case(e2.name || COALESCE('' '' || e2.sufqualabr, ''''),$4)
+ + tiger.levenshtein_ignore_case(e1.name || COALESCE('' '' || e1.sufqualabr, ''''),$2)
+ + CASE
+ WHEN lower(e1.fullname) = $6 OR normalize_street_name(e1.fullname) = $10 THEN 0
+ ELSE tiger.levenshtein_ignore_case(e1.fullname, $6)
+ END
+ + CASE
+ WHEN normalize_street_name(e2.fullname) = $11 THEN 0
+ ELSE tiger.levenshtein_ignore_case(e2.name || COALESCE('' '' || e2.sufqualabr, ''''),$4)
+ END
AS a_rating
FROM e1
INNER JOIN e2 ON (
@@ -115,23 +152,16 @@ BEGIN
FROM segs ORDER BY a_rating LIMIT $9';
IF var_debug THEN
- RAISE NOTICE 'sql: %', replace(replace(replace(
- replace(replace(replace(
- replace(
- replace(
- replace(var_sql, '$1', quote_nullable(in_statefp)),
- '$2', quote_nullable(lower(var_na_road.streetName) ) ),
- '$3', quote_nullable(lower(in_city)) ),
- '$4', quote_nullable(lower(var_na_inter1.streetName) ) ),
- '$5', quote_nullable(var_zip) ),
- '$6', quote_nullable(lower(var_na_road.streetName || ' ' || COALESCE(var_na_road.streetTypeAbbrev,'') )) ) ,
- '$7', quote_nullable(trim(lower(var_na_inter1.streetName || ' ' || COALESCE(var_na_inter1.streetTypeAbbrev,'') )) ) ) ,
- '$8', quote_nullable(in_state ) ), '$9', num_results::text );
+ RAISE NOTICE 'sql: %', var_sql;
+ RAISE NOTICE 'args: %, %, %, %, %, %, %, %, %, %, %',
+ in_statefp, var_road_name, lower(in_city), var_inter_name, var_zip,
+ var_road_fullname, var_inter_fullname, in_state, num_results,
+ var_road_input_normalized, var_inter_input_normalized;
END IF;
- FOR results IN EXECUTE var_sql USING in_statefp, trim(lower(var_na_road.streetName)), lower(in_city), lower(var_na_inter1.streetName), var_zip,
- trim(lower(var_na_road.streetName || ' ' || COALESCE(var_na_road.streetTypeAbbrev,''))),
- trim(lower(var_na_inter1.streetName || ' ' || COALESCE(var_na_inter1.streetTypeAbbrev,''))), in_state, num_results LOOP
+ FOR results IN EXECUTE var_sql USING in_statefp, var_road_name, lower(in_city), var_inter_name, var_zip,
+ var_road_input_normalized, var_inter_input_normalized LOOP
ADDY.preDirAbbrev := results.fedirp;
ADDY.streetName := results.fename;
ADDY.streetTypeAbbrev := results.fetype;
diff --git a/extras/tiger_geocoder/geocode/other_helper_functions.sql b/extras/tiger_geocoder/geocode/other_helper_functions.sql
index 41513bc1e..4af024ca5 100644
--- a/extras/tiger_geocoder/geocode/other_helper_functions.sql
+++ b/extras/tiger_geocoder/geocode/other_helper_functions.sql
@@ -30,6 +30,24 @@ $$ SELECT abs(to_number( CASE WHEN trim(substring($1,1,5)) ~ '^[0-9]+$' THEN $1
LANGUAGE sql IMMUTABLE STRICT
COST 200 PARALLEL SAFE;
+-- Canonicalize separator-only formatting differences in road names without
+-- collapsing all punctuation, so highway names like I-635 and I- 635
+-- compare equally while still distinguishing unrelated names.
+CREATE OR REPLACE FUNCTION normalize_street_name(input_street varchar)
+ RETURNS varchar AS
+ SELECT trim(
+ regexp_replace(
+ regexp_replace(lower($1), E'\\s*-\\s*', '-', 'g'),
+ E'\\s+',
+ 'g'
+ )::varchar;
+LANGUAGE sql IMMUTABLE STRICT
+COST 5 PARALLEL SAFE;
-- function return true or false if 2 numeric streets are equal such as 15th St, 23rd st
-- it compares just the numeric part of the street for equality
-- PURPOSE: handle bad formats such as 23th St so 23th St = 23rd St
Summary of changes:
NEWS | 3 +
extensions/postgis_tiger_geocoder/Makefile.in | 10 +-
.../test-geocode_intersection_spacing.out.in | 4 +
.../test-geocode_intersection_spacing.sql.in | 63 ++++++++++
.../geocode/geocode_intersection.sql | 134 +++++++++++++--------
.../geocode/other_helper_functions.sql | 18 +++
6 files changed, 178 insertions(+), 54 deletions(-)
create mode 100644 extensions/postgis_tiger_geocoder/sql_bits/test-geocode_intersection_spacing.out.in
create mode 100644 extensions/postgis_tiger_geocoder/sql_bits/test-geocode_intersection_spacing.sql.in
hooks/post-receive
