[SCM] PostGIS branch master updated. 3.6.0rc2-403-gc52110c83
git at osgeo.org
git at osgeo.org
Mon Mar 23 09:41:20 PDT 2026
the project "PostGIS".
via c52110c83f015716df310dd94d48ff76abdd7620 (commit)
from d63430387663f34c6edccac1bff47a5cf484d4c8 (commit)
revisions in full, below.
commit c52110c83f015716df310dd94d48ff76abdd7620
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Mar 23 09:41:10 2026 -0700
Build updates for new compilers, fully qualify some calls to postgis functions
diff --git a/liblwgeom/liblwgeom_internal.h b/liblwgeom/liblwgeom_internal.h
index 39baf8032..828c81eeb 100644
--- a/liblwgeom/liblwgeom_internal.h
+++ b/liblwgeom/liblwgeom_internal.h
@@ -72,6 +72,21 @@
#define STR_IEQUALS(A, B) (strcasecmp((A), (B)) == 0)
#define STR_ISTARTS(A, B) (strncasecmp((A), (B), strlen((B))) == 0)
+#ifndef FALLTHROUGH
+ #if defined(__cplusplus) && __cplusplus >= 201703L
+ #define FALLTHROUGH [[fallthrough]]
+ #elif defined(__STDC_VERSION__) && __STDC_VERSION__ >= 202311L
+ #elif defined(__clang__)
+ #define FALLTHROUGH __attribute__((fallthrough))
+ #elif defined(__GNUC__) && __GNUC__ >= 7
+ #elif defined(_MSC_VER) && _MSC_VER >= 1910
+ #else
+ #define FALLTHROUGH ((void)0)
+ #endif
+#endif
* this will change to NaN when I figure out how to
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 7806f6ccb..055375099 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2744,7 +2744,7 @@ Datum LWGEOM_angle(PG_FUNCTION_ARGS)
default: /*always executed*/
for (j = 0; j <= i; j++)
PG_FREE_IF_COPY(seri_geoms[j], j);
- pg_fallthrough; /* FALLTHROUGH */
+ FALLTHROUGH;
case 1:
lwpgerror("Empty geometry");
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 118a6499e..2a51d7352 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2294,18 +2294,18 @@ BEGIN
IF use_typmod THEN
BEGIN
EXECUTE 'ALTER TABLE ' || quote_ident(gcs.nspname) || '.' || quote_ident(gcs.relname) || ' ALTER COLUMN ' || quote_ident(gcs.attname) ||
- ' TYPE geometry(' || postgis_type_name(gtype, gndims, true) || ', ' || gsrid::text || ') ';
+ ' TYPE geometry(' || @extschema at .postgis_type_name(gtype, gndims, true) || ', ' || gsrid::text || ') ';
inserted := inserted + 1;
EXCEPTION
WHEN invalid_parameter_value OR feature_not_supported THEN
- RAISE WARNING 'Could not convert ''%'' in ''%.%'' to use typmod with srid %, type %: %', quote_ident(gcs.attname), quote_ident(gcs.nspname), quote_ident(gcs.relname), gsrid, postgis_type_name(gtype, gndims, true), SQLERRM;
+ RAISE WARNING 'Could not convert ''%'' in ''%.%'' to use typmod with srid %, type %: %', quote_ident(gcs.attname), quote_ident(gcs.nspname), quote_ident(gcs.relname), gsrid, @extschema at .postgis_type_name(gtype, gndims, true), SQLERRM;
gc_is_valid := false;
END;
ELSE
-- Try to apply srid check to column
constraint_successful = false;
- IF (gsrid > 0 AND postgis_constraint_srid(gcs.nspname, gcs.relname,gcs.attname) IS NULL ) THEN
+ IF (gsrid > 0 AND @extschema at .postgis_constraint_srid(gcs.nspname, gcs.relname,gcs.attname) IS NULL ) THEN
BEGIN
EXECUTE 'ALTER TABLE ONLY ' || quote_ident(gcs.nspname) || '.' || quote_ident(gcs.relname) ||
' ADD CONSTRAINT ' || quote_ident('enforce_srid_' || gcs.attname) ||
@@ -2319,7 +2319,7 @@ BEGIN
END IF;
-- Try to apply ndims check to column
- IF (gndims IS NOT NULL AND postgis_constraint_dims(gcs.nspname, gcs.relname,gcs.attname) IS NULL ) THEN
+ IF (gndims IS NOT NULL AND @extschema at .postgis_constraint_dims(gcs.nspname, gcs.relname,gcs.attname) IS NULL ) THEN
BEGIN
EXECUTE 'ALTER TABLE ONLY ' || quote_ident(gcs.nspname) || '.' || quote_ident(gcs.relname) || '
ADD CONSTRAINT ' || quote_ident('enforce_dims_' || gcs.attname) || '
@@ -2333,7 +2333,7 @@ BEGIN
END IF;
-- Try to apply geometrytype check to column
- IF (gtype IS NOT NULL AND postgis_constraint_type(gcs.nspname, gcs.relname,gcs.attname) IS NULL ) THEN
+ IF (gtype IS NOT NULL AND @extschema at .postgis_constraint_type(gcs.nspname, gcs.relname,gcs.attname) IS NULL ) THEN
BEGIN
ADD CONSTRAINT ' || quote_ident('enforce_geotype_' || gcs.attname) || '
@@ -2390,7 +2390,7 @@ DECLARE
BEGIN
-- Verify geometry type
- IF (postgis_type_name(new_type,new_dim) IS NULL )
+ IF (@extschema at .postgis_type_name(new_type,new_dim) IS NULL )
THEN
RAISE EXCEPTION 'Invalid type name "%(%)" - valid ones are:
POINT, MULTIPOINT,
@@ -2795,7 +2795,7 @@ BEGIN
END IF;
END IF;
- IF postgis_constraint_srid(real_schema, table_name, column_name) IS NOT NULL THEN
+ IF @extschema at .postgis_constraint_srid(real_schema, table_name, column_name) IS NOT NULL THEN
-- srid was enforced with constraints before, keep it that way.
-- Make up constraint name
cname = 'enforce_srid_' || column_name;
diff --git a/raster/rt_pg/rtpg_mapalgebra.c b/raster/rt_pg/rtpg_mapalgebra.c
index 0e355ebe3..57ce89a52 100644
--- a/raster/rt_pg/rtpg_mapalgebra.c
+++ b/raster/rt_pg/rtpg_mapalgebra.c
@@ -6567,7 +6567,7 @@ Datum RASTER_mapAlgebra2(PG_FUNCTION_ARGS)
switch (extenttype) {
case ET_FIRST:
i = 0;
+ FALLTHROUGH;
case ET_SECOND:
if (i > 1)
Summary of changes:
liblwgeom/liblwgeom_internal.h | 15 +++++++++++++++
postgis/lwgeom_functions_basic.c | 2 +-
postgis/postgis.sql.in | 14 +++++++-------
raster/rt_pg/rtpg_mapalgebra.c | 2 +-
4 files changed, 24 insertions(+), 9 deletions(-)
hooks/post-receive
