[SCM] PostGIS branch stable-3.6 updated. 3.6.2-11-gdaf6a4fd2
git at osgeo.org
git at osgeo.org
Mon Mar 23 09:43:37 PDT 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
via daf6a4fd267c0ba50598de359789ef7296dc1c1d (commit)
from 4728189d613fa7f0b7d8edd8534d02c3a82683bd (commit)
revisions in full, below.
commit daf6a4fd267c0ba50598de359789ef7296dc1c1d
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Mar 23 09:43:16 2026 -0700
Fully quality calls to helper functions
references #6060
diff --git a/NEWS b/NEWS
index e8519f017..5078062b0 100644
--- a/NEWS
+++ b/NEWS
@@ -20,6 +20,7 @@ topogeometry corruption:
and Daniel Bakker
- GH-850 Use quote_identifier to build tables in pgis_tablefromflatgeobuf (Ariel Mashraki)
- #6058, Use Pg composite_to_json() function in 19+ (Paul Ramsey)
+- #6060, fully quality calls to helper functions (Paul Ramsey)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 398031528..1df639e7c 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2251,18 +2251,18 @@ BEGIN
IF use_typmod THEN
BEGIN
EXECUTE 'ALTER TABLE ' || quote_ident(gcs.nspname) || '.' || quote_ident(gcs.relname) || ' ALTER COLUMN ' || quote_ident(gcs.attname) ||
- ' TYPE geometry(' || postgis_type_name(gtype, gndims, true) || ', ' || gsrid::text || ') ';
+ ' TYPE geometry(' || @extschema at .postgis_type_name(gtype, gndims, true) || ', ' || gsrid::text || ') ';
inserted := inserted + 1;
EXCEPTION
WHEN invalid_parameter_value OR feature_not_supported THEN
- RAISE WARNING 'Could not convert ''%'' in ''%.%'' to use typmod with srid %, type %: %', quote_ident(gcs.attname), quote_ident(gcs.nspname), quote_ident(gcs.relname), gsrid, postgis_type_name(gtype, gndims, true), SQLERRM;
+ RAISE WARNING 'Could not convert ''%'' in ''%.%'' to use typmod with srid %, type %: %', quote_ident(gcs.attname), quote_ident(gcs.nspname), quote_ident(gcs.relname), gsrid, @extschema at .postgis_type_name(gtype, gndims, true), SQLERRM;
gc_is_valid := false;
END;
ELSE
-- Try to apply srid check to column
constraint_successful = false;
- IF (gsrid > 0 AND postgis_constraint_srid(gcs.nspname, gcs.relname,gcs.attname) IS NULL ) THEN
+ IF (gsrid > 0 AND @extschema at .postgis_constraint_srid(gcs.nspname, gcs.relname,gcs.attname) IS NULL ) THEN
BEGIN
EXECUTE 'ALTER TABLE ONLY ' || quote_ident(gcs.nspname) || '.' || quote_ident(gcs.relname) ||
' ADD CONSTRAINT ' || quote_ident('enforce_srid_' || gcs.attname) ||
@@ -2276,7 +2276,7 @@ BEGIN
END IF;
-- Try to apply ndims check to column
- IF (gndims IS NOT NULL AND postgis_constraint_dims(gcs.nspname, gcs.relname,gcs.attname) IS NULL ) THEN
+ IF (gndims IS NOT NULL AND @extschema at .postgis_constraint_dims(gcs.nspname, gcs.relname,gcs.attname) IS NULL ) THEN
BEGIN
EXECUTE 'ALTER TABLE ONLY ' || quote_ident(gcs.nspname) || '.' || quote_ident(gcs.relname) || '
ADD CONSTRAINT ' || quote_ident('enforce_dims_' || gcs.attname) || '
@@ -2290,7 +2290,7 @@ BEGIN
END IF;
-- Try to apply geometrytype check to column
- IF (gtype IS NOT NULL AND postgis_constraint_type(gcs.nspname, gcs.relname,gcs.attname) IS NULL ) THEN
+ IF (gtype IS NOT NULL AND @extschema at .postgis_constraint_type(gcs.nspname, gcs.relname,gcs.attname) IS NULL ) THEN
BEGIN
ADD CONSTRAINT ' || quote_ident('enforce_geotype_' || gcs.attname) || '
@@ -2347,7 +2347,7 @@ DECLARE
BEGIN
-- Verify geometry type
- IF (postgis_type_name(new_type,new_dim) IS NULL )
+ IF (@extschema at .postgis_type_name(new_type,new_dim) IS NULL )
THEN
RAISE EXCEPTION 'Invalid type name "%(%)" - valid ones are:
POINT, MULTIPOINT,
@@ -2752,7 +2752,7 @@ BEGIN
END IF;
END IF;
- IF postgis_constraint_srid(real_schema, table_name, column_name) IS NOT NULL THEN
+ IF @extschema at .postgis_constraint_srid(real_schema, table_name, column_name) IS NOT NULL THEN
-- srid was enforced with constraints before, keep it that way.
-- Make up constraint name
cname = 'enforce_srid_' || column_name;
Summary of changes:
NEWS | 1 +
postgis/postgis.sql.in | 14 +++++++-------
2 files changed, 8 insertions(+), 7 deletions(-)
hooks/post-receive
