[PostGIS] #6061: segmentation fault when loading geometries
trac at osgeo.org
Wed Mar 25 10:52:06 PDT 2026
Reporter: maxsynytsky1v | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.2
Component: postgis | Version: 3.6.x
Keywords: |
I have a set of data extracted from Oracle database with ora2pg.
The source geometries are Esri's ST_GEOMETRY and they are exported into
WKT using SDE functions (SDE.ST_ASTEXT).
During import I experience a crash of PostgreSQL cluster.
2026-03-25 17:39:30.083 GMT,,,1245799,,69bad932.130267,27,,2026-03-18
16:56:18 GMT,,0,LOG,00000,"server process (PID 1293403) was terminated by
signal 11: Segmentation fault","Failed process was running: COPY
<redacted> FROM STDIN;",,,,,,,,"","postmaster",,0
2026-03-25 17:39:30.083 GMT,,,1245799,,69bad932.130267,28,,2026-03-18
16:56:18 GMT,,0,LOG,00000,"terminating any other active server
processes",,,,,,,,,"","postmaster",,0
2026-03-25 17:39:30.091 GMT,,,1245799,,69bad932.130267,29,,2026-03-18
16:56:18 GMT,,0,LOG,00000,"all server processes terminated;
reinitializing",,,,,,,,,"","postmaster",,0
2026-03-25 17:39:30.122 GMT,,,1293440,,69c41dd2.13bc80,1,,2026-03-25
17:39:30 GMT,,0,LOG,00000,"database system was interrupted; last known up
at 2026-03-25 17:38:57 GMT",,,,,,,,,"","startup",,0
2026-03-25 17:39:31.277 GMT,,,1293440,,69c41dd2.13bc80,2,,2026-03-25
17:39:30 GMT,,0,LOG,00000,"database system was not properly shut down;
automatic recovery in progress",,,,,,,,,"","startup",,0
I am pretty sure the problem is not in the geometry extracted because the
rows are always different but the problem can be reproduced consistently.
For example:
psql:data/data.sql:7114983: SSL SYSCALL error: EOF detected
invalid socket
psql:data/data.sql:7114983: error: connection to server was lost
ERROR: an error occurs when importing file ./data/data.sql.
psql:data/data.sql:7115021: SSL SYSCALL error: EOF detected
invalid socket
psql:data/data.sql:7115021: error: connection to server was lost
psql:data/data.sql:7115004: SSL SYSCALL error: EOF detected
invalid socket
psql:data/data.sql:7115004: error: connection to server was lost
psql:data/data.sql:7115055: SSL SYSCALL error: EOF detected
invalid socket
psql:data/data.sql:7115055: error: connection to server was lost
I am using PostgreSQL 16.13 and PostGIS 3.6.2, OS is Debian 12.5.
I will be uploading a gdb core debug and I made sure that PostgreSQL and
PostGIS debug symbol packages are installed but I am running a release
PostgreSQL.
I redacted the debug to remove sensitive data but if you feel that this is
necessary I will talk to the manager(s) if we can disclose this.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6061>
