[PostGIS] #6062: More error XX000: SQL/MM Spatial exception - geometry
PostGIS trac at osgeo.org
Mon Mar 30 00:25:45 PDT 2026
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.6.2
 Component:  topology           |    Version:  3.6.x
Resolution:                     |   Keywords:
Comment (by strk):
 It seems to be a problem with the snapping phase. The incoming line
 (yellow) fails to snap to the bottom-right vertices of the existing edges
 (green). The red line is the result of the snap.
 [[Image(screen01.png)]]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6062#comment:2>
