[PostGIS] #6076: ST_Length() on GEOMETRYCOLLECTION for geography type
trac at osgeo.org
Wed May 6 07:46:05 PDT 2026
Reporter: paleolimbot | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.3
Component: postgis | Version: 3.6.x
Keywords: |
For all eight people that have ever calculated the length of a geometry
collection for the geography type (and all zero of them that *should*
have):
-- For geometry, ST_Length returns just the linestring length (1.0)
SELECT ST_Length(ST_GeomFromText('GEOMETRYCOLLECTION (POINT (5 5),
LINESTRING (0 0, 0 1), POLYGON ((0 0, 0 1, 1 0, 0 0)))'));
-- Result: 1.0
-- For geography, ST_Length is different
SELECT ST_Length(ST_GeogFromText('GEOMETRYCOLLECTION (POINT (5 5),
-- Result: 489367.83620021143
-- Expected: just the linestring length as geography (~110574 meters)
SELECT ST_Distance(ST_GeogFromText('POINT (0 0)'), ST_GeogFromText('POINT
(0 1)'));
-- Result: 110574.3885578
I tested using the postgis/postgis:18-3.6 docker image (with apologies if
this has been fixed since).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6076>
