[PostGIS] #6010: ST_SetBandNoDataValue can't handle infinite no data
trac at osgeo.org
Wed May 6 10:20:04 PDT 2026
Reporter: | Owner: robe
GISuser5432 |
Type: defect | Status: new
Priority: low | Milestone: PostGIS 3.2.10
Component: raster | Version: 3.6.x
Resolution: | Keywords: ST_Polygon (raster) ; Raster;
| PostGIS_Raster;
Comment (by GISuser5432):
The problem is not only **Infinity** in that example (which I think
originally was 64BF maximum and not Infinity).
The ST_Polygon(rast) returns the NoData areas (by mistake) when the NoData
is 3.4028234663852886e which is the maximum of **32BF** pixel type.
However, on an old server with PostGIS 2.4.3, ST_Polygon(rast) works well
even with 32BF max.
I attached test_st_polygonit_dump.sql that is the export of a raster in
which the NoData is the maximum of 32BF pixel type.
Previously, in older version PostGIS, I have in my old server,
ST_Polygon(raster) was working well to find the part of the raster that
has values.
However, the new PostGIS that I have in docker is not able to extract the
currect polygon when NoData is the max of 32BF.
When I convert the NoData to smaller values, then, it works well!!
the new version is:
POSTGIS="3.6.0 4c1967d" [EXTENSION] PGSQL="180" GEOS="3.13.1-CAPI-1.19.2"
PROJ="9.6.0 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 9.6.0)
GDAL="GDAL 3.10.3, released 2025/04/01" LIBXML="2.9.14" LIBJSON="0.18"
LIBPROTOBUF="1.5.1" WAGYU="0.5.0 (Internal)" RASTER
and also using the new version of PostGIS, the query you gave me returns
only 3.4028234663852886e+38 not Infinity and pixel type is 32BF:
SELECT (gv).val val1, ST_Area((gv).geom) AS nodata,
ST_Area(rast::Geometry)
FROM test_st_polygon, ST_DumpAsPolygons(rast) AS gv
WHERE gv.val > 0;
[[Image(result_of_query.png)]]
Finally, I want to say that even in 32BF raster with a valid NoData value
equal to the maximum of 32BF, the ST_Polygon is not working in newer
versions while in very old versions it was working without any problem for
years. The old version on which ST_Polygon is working well is:
POSTGIS="2.4.3 r16312" PGSQL="100" GEOS="3.6.2-CAPI-1.10.2 4d2925d6"
PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.3, released 2017/11/20"
LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.2.1" RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6010#comment:5>
