[PostGIS] #6077: Some notes about enhancements to the postgis manual
trac at osgeo.org
Wed May 6 21:37:59 PDT 2026
Reporter: jidanni | Owner: robe
Type: enhancement | Status: new
Priority: low | Milestone: PostGIS 3.6.3
Component: documentation | Version: 3.6.x
Keywords: |
Hi. Here are some notes I made about enhancements for the postgis manual.
I had better give them to you before even I no longer know what I was
thinking.
geometry CG_Visibility( geometry polygon, geometry point);
geometry CG_Visibility( geometry polygon, geometry pointA, geometry
pointB);
point and segment missing in example images.
The geometry dimension is a property of geometry types. Point types have
dimension 0, linear types have dimension 1, and polygonal types have
dimension 2. Collections have the dimension of the maximum element
dimension.
Mention what has dimensions 3 and 4 etc.!
Geometries are topologically closed, so they always contain their
boundary. The boundary is a geometry of dimension one less than that of
the geometry itself.
Give examples.
The OGC geometry model defines validity rules for each geometry type.
These rules ensure that geometry values represents realistic situations
(e.g. it is possible to specify a polygon with a hole lying outside ITS
xxxthe shell, but this makes no sense geometrically and is thus invalid).
PostGIS also allows storing and manipulating invalid geometry values. This
allows detecting and fixing them if needed. See Section 4.4, “Geometry
Validation”
A MultiPolygon is a collection of non-overlapping, non-adjacent Polygons.
Polygons in the collection may touch only at a finite number of points.
Explain adjacent vs. touching. Finite number? 17? Wait, way down below
this is explained. Add a link to that please. (That works offline.)
A PolyhedralSurface is a contiguous collection of patches or facets which
share some edges. Each patch is a planar Polygon. If the Polygon
coordinates have Z ordinates then the surface is 3-dimensional. ADD PIC.
Else too abstract.
VALUES ( ST_GeomFromText('POINT(-126.4 45.32)', 312), 'A Place');
Mention again that 312 is the SRID.
The geometry data type is opaque, which means that all access is done via
invoking functions on geometry values. Functions allow creating geometry
objects, accessing or updating all internal fields, and compute new
geometry values. COMPUTING.
By default, all distance and area calculations are done on the spheroid.
You should find that the results of calculations in local areas match up
will with local planar results in good local projections. Over larger
areas, the spheroidal calculations will be more accurate than any
calculation done on a projected plane.
OK, BUT REMIND what is the difference between the two.
coord_dimension
The coordinate dimension (2, 3 or 4) of the column.
Mention why no 0 or 1.
It may be required to identify all road segments that cross each other,
not at a point, but in a line (perhaps to validate some business rule).
BUSINESS RULE: like insurance policy no valid on two-way one lane roads?
name | roads_km
SURREY | 1539.47553551242
Nanometers necessary here?
SELEcT ST_AsText(geom)
SELECT ST_AsText(ST_Letters('Yo'), 1); #The 1 overrides the font?
Index is 1-based as for OGC specs since version 0.8.0. Backward indexing
(negative index) is not in OGC[MISSING PERIOD] Previous versions
implemented this as 0-based instead.
SELECT ST_AsText(geom) as line, ST_AsText(ST_Reverse(geom)) As reverseline
FROM
(SELECT ST_MakeLine(ST_Point(1,2),
ST_Point(1,10)) As geom) as foo;
FOO NEEDED?
Find broadcasting towers that receiver with limited range can receive.
^a
EPSG:26986 is state plane Massachusetts meters[Period]
float ST_Angle( geometry point1, geometry point2, geometry point3,
geometry point4);
float ST_Angle( geometry point1, geometry point2, geometry point3[,
geometry point4]);
ST_LengthSpheroid( geometry a_geometry, spheroid a_spheroid);
Description
Calculates the length or perimeter of a geometry on an ellipsoid. This is
useful if the coordinates of the geometry are in longitude/latitude and a
length is desired without reprojection. The spheroid is specified by a
text value as follows:
..... s/ellipsoid/sphorid / or say why...
float ST_MinimumClearance( geometry g);
need pictures to explain better.
Examples: 2.5Dish
Note this is not a true intersection, compare to the same example using
ST_3DIntersection.
[No image provided: so Say if we are to imagine a 2.5 meter satellite dish
or what.]
ST_Node( geo ADD IMAGE.
Thanks.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6077>
