[SCM] PostGIS branch master updated. 3.6.0rc2-475-g05682d312
git at osgeo.org
git at osgeo.org
Thu May 7 03:06:11 PDT 2026
the project "PostGIS".
via 05682d312a8b67ba7b90dfd5f89993ff082c054b (commit)
from 0e794aa474544d0da986d4ba7a807103b97c129a (commit)
revisions in full, below.
commit 05682d312a8b67ba7b90dfd5f89993ff082c054b
Author: Jean Felder <jean.felder at oslandia.com>
Date: Sun May 3 19:02:44 2026 +0200
sfcgal: Adapt CG_ExtrudeStraightSkeleton test to triangulation improvements
The geometry returned by CG_ExtrudeStraightSkeleton, when extrude and
roof parameters are set was triangulated. Since SFCGAL 2.3, the
triangles can be merged when the underlying surface is coplanar. This
gives a smoother result and a polyhedralsurface which has less
patches.
Adapt the unit test to work with all SFCGAL versions by comparing the
number of generated patches.
See: https://gitlab.com/sfcgal/SFCGAL/-/merge_requests/730
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index e3abfbac0..b27b72804 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -2103,7 +2103,7 @@ It always gives a 2D result even when used on a 3D geometry.</para></note>
<title>Examples</title>
<para>
<programlisting>SELECT ST_AsText(CG_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 3.0, 2.0));</programlisting>
- <screen>POLYHEDRALSURFACE Z (((0 0 0,0 4 0,4 4 0,4 5 0,5 5 0,5 0 0,0 0 0),(1 1 0,2 1 0,2 2 0,1 2 0,1 1 0)),((0 0 0,0 0 2,0 4 2,0 4 0,0 0 0)),((0 4 0,0 4 2,4 4 2,4 4 0,0 4 0)),((4 4 0,4 4 2,4 5 2,4 5 0,4 4 0)),((4 5 0,4 5 2,5 5 2,5 5 0,4 5 0)),((5 5 0,5 5 2,5 0 2,5 0 0,5 5 0)),((5 0 0,5 0 2,0 0 2,0 0 0,5 0 0)),((1 1 0,1 1 2,2 1 2,2 1 0,1 1 0)),((2 1 0,2 1 2,2 2 2,2 2 0,2 1 0)),((2 2 0,2 2 2,1 2 2,1 2 0,2 2 0)),((1 2 0,1 2 2,1 1 2,1 1 0,1 2 0)),((0.5 2.5 2.5,0 0 2,0.5 0.5 2.5,0.5 2.5 2.5)),((1 3 3,0 4 2,0.5 2.5 2.5,1 3 3)),((0.5 2.5 2.5,0 4 2,0 0 2,0.5 2.5 2.5)),((2.5 0.5 2.5,5 0 2,3.5 1.5 3.5,2.5 0.5 2.5)),((0 0 2,5 0 2,2.5 0.5 2.5,0 0 2)),((0.5 0.5 2.5,0 0 2,2.5 0.5 2.5,0.5 0.5 2.5)),((4.5 3.5 2.5,5 5 2,4.5 4.5 2.5,4.5 3.5 2.5)),((3.5 2.5 3.5,3.5 1.5 3.5,4.5 3.5 2.5,3.5 2.5 3.5)),((4.5 3.5 2.5,5 0 2,5 5 2,4.5 3.5 2.5)),((3.5 1.5 3.5,5 0 2,4.5 3.5 2.5,3.5 1.5 3.5)),((5 5 2,4 5 2,4.5 4.5 2.5,5 5 2)),((4.5 4.5 2.5,4 4 2,4.5 3.5 2.5,4.5 4.5 2.5)),((4.5 4.5 2.5,4 5 2,4 4
2,4.5 4.5 2.5)),((3 3 3,0 4 2,1 3 3,3 3 3)),((3.5 2.5 3.5,4.5 3.5 2.5,3 3 3,3.5 2.5 3.5)),((3 3 3,4 4 2,0 4 2,3 3 3)),((4.5 3.5 2.5,4 4 2,3 3 3,4.5 3.5 2.5)),((2 1 2,1 1 2,0.5 0.5 2.5,2 1 2)),((2.5 0.5 2.5,2 1 2,0.5 0.5 2.5,2.5 0.5 2.5)),((1 1 2,1 2 2,0.5 2.5 2.5,1 1 2)),((0.5 0.5 2.5,1 1 2,0.5 2.5 2.5,0.5 0.5 2.5)),((1 3 3,2 2 2,3 3 3,1 3 3)),((0.5 2.5 2.5,1 2 2,1 3 3,0.5 2.5 2.5)),((1 3 3,1 2 2,2 2 2,1 3 3)),((2 2 2,2 1 2,2.5 0.5 2.5,2 2 2)),((3.5 2.5 3.5,3 3 3,3.5 1.5 3.5,3.5 2.5 3.5)),((3.5 1.5 3.5,2 2 2,2.5 0.5 2.5,3.5 1.5 3.5)),((3 3 3,2 2 2,3.5 1.5 3.5,3 3 3)))</screen>
+ <screen>POLYHEDRALSURFACE Z (((0 0 0,0 4 0,4 4 0,4 5 0,5 5 0,5 0 0,0 0 0),(1 1 0,2 1 0,2 2 0,1 2 0,1 1 0)),((0 0 0,0 0 2,0 4 2,0 4 0,0 0 0)),((0 4 0,0 4 2,4 4 2,4 4 0,0 4 0)),((4 4 0,4 4 2,4 5 2,4 5 0,4 4 0)),((4 5 0,4 5 2,5 5 2,5 5 0,4 5 0)),((5 5 0,5 5 2,5 0 2,5 0 0,5 5 0)),((5 0 0,5 0 2,0 0 2,0 0 0,5 0 0)),((1 1 0,1 1 2,2 1 2,2 1 0,1 1 0)),((2 1 0,2 1 2,2 2 2,2 2 0,2 1 0)),((2 2 0,2 2 2,1 2 2,1 2 0,2 2 0)),((1 2 0,1 2 2,1 1 2,1 1 0,1 2 0)),((0 4 2,0 0 2,0.5 0.5 2.5,0.5 2.5 2.5,1 3 3,0 4 2)),((0 0 2,5 0 2,3.5 1.5 3.5,2.5 0.5 2.5,0.5 0.5 2.5,0 0 2)),((5 0 2,5 5 2,4.5 4.5 2.5,4.5 3.5 2.5,3.5 2.5 3.5,3.5 1.5 3.5,5 0 2)),((5 5 2,4 5 2,4.5 4.5 2.5,5 5 2)),((4 5 2,4 4 2,4.5 3.5 2.5,4.5 4.5 2.5,4 5 2)),((4 4 2,0 4 2,1 3 3,3 3 3,3.5 2.5 3.5,4.5 3.5 2.5,4 4 2)),((2 1 2,1 1 2,0.5 0.5 2.5,2.5 0.5 2.5,2 1 2)),((1 1 2,1 2 2,0.5 2.5 2.5,0.5 0.5 2.5,1 1 2)),((1 2 2,2 2 2,3 3 3,1 3 3,0.5 2.5 2.5,1 2 2)),((2 2 2,2 1 2,2.5 0.5 2.5,3.5 1.5 3.5,3.5 2.5 3.5,3 3 3,2 2 2)))</screen>
</para>
</refsection>
<refsection>
diff --git a/sfcgal/regress/extrudestraigthskeleton.sql b/sfcgal/regress/extrudestraigthskeleton.sql
index 11d12dbf4..fc273cd58 100644
--- a/sfcgal/regress/extrudestraigthskeleton.sql
+++ b/sfcgal/regress/extrudestraigthskeleton.sql
@@ -1,43 +1,72 @@
-SELECT 'Extrude roof', ST_AsText(CG_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 2.0));
-WITH
- version_info AS (
- -- The result depends on the SFCGAL Version.
- -- Prior to version 2.2, it contained extra patches.
- SELECT
- string_to_array(postgis_sfcgal_version (), '.')::INT[] AS sfcgal_version_array
- skeleton AS (
- SELECT
- ST_NumPatches (
- CG_ExtrudeStraightSkeleton (
- 'POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))',
- 3.0,
- 2.0
- ) AS num_patches
- check_patches AS (
- SELECT
- sfcgal_version_array,
- num_patches,
- sfcgal_version_array <= ARRAY[2, 1, 0]
- AND num_patches = 49
- OR (
- sfcgal_version_array > ARRAY[2, 1, 0]
- AND num_patches = 39
- ) AS test_result
- FROM
- skeleton,
- version_info
-SELECT
- 'Extrude building and roof',
- test_result
-FROM
- check_patches;
+WITH version_info AS (
+ SELECT string_to_array(postgis_sfcgal_version(), '.')::int[] AS sfcgal_version_array
+roof AS (
+ SELECT
+ ST_NumPatches(
+ CG_ExtrudeStraightSkeleton(
+ 'POLYGON ((0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))',
+ 2.0
+ ) AS num_patches,
+ sfcgal_version_array
+ FROM version_info
+building_and_roof AS (
+ SELECT
+ ST_NumPatches(
+ 3.0,
+ 2.0
+ ) AS num_patches,
+ FROM version_info
+SELECT 'Extrude roof',
+ -- The result depends on the SFCGAL version.
+ -- Since version 2.3, the result is simplified by merging
+ -- triangles before storing the result, resulting in fewer
+ -- patches.
+ sfcgal_version_array < ARRAY[2,3,0]
+ AND num_patches = 38
+ OR (
+ sfcgal_version_array >= ARRAY[2,3,0]
+ AND num_patches = 11
+FROM roof
+UNION ALL
+SELECT 'Extrude building and roof',
+ -- Prior to version 2.2, it contained extra patches.
+ -- patches.
+ sfcgal_version_array < ARRAY[2,2,0]
+ AND num_patches = 49
+ OR (
+ sfcgal_version_array >= ARRAY[2,2,0]
+ AND sfcgal_version_array < ARRAY[2,3,0]
+ AND num_patches = 39
+ OR (
+ AND num_patches = 21
+FROM building_and_roof;
SELECT 'Empty building and roof', ST_AsText(CG_ExtrudeStraightSkeleton(ST_GeomFromText('POLYGON EMPTY',4326), 20.1, 20.1));
SELECT 'Empty roof', ST_AsText(CG_ExtrudeStraightSkeleton(ST_GeomFromText('POLYGON EMPTY',4326), 20.1));
diff --git a/sfcgal/regress/extrudestraigthskeleton_expected b/sfcgal/regress/extrudestraigthskeleton_expected
index 8a8ac4ddc..b64e6d458 100644
--- a/sfcgal/regress/extrudestraigthskeleton_expected
+++ b/sfcgal/regress/extrudestraigthskeleton_expected
@@ -1,4 +1,4 @@
-Extrude roof|POLYHEDRALSURFACE Z (((4 5 0,5 5 0,4 4 0,4 5 0)),((2 1 0,5 0 0,0 0 0,2 1 0)),((5 5 0,5 0 0,4 4 0,5 5 0)),((2 1 0,0 0 0,1 1 0,2 1 0)),((1 2 0,1 1 0,0 0 0,1 2 0)),((0 4 0,2 2 0,1 2 0,0 4 0)),((0 4 0,1 2 0,0 0 0,0 4 0)),((4 4 0,5 0 0,2 2 0,4 4 0)),((4 4 0,2 2 0,0 4 0,4 4 0)),((2 2 0,5 0 0,2 1 0,2 2 0)),((0.5 2.5 0.5,0 0 0,0.5 0.5 0.5,0.5 2.5 0.5)),((1 3 1,0 4 0,0.5 2.5 0.5,1 3 1)),((0.5 2.5 0.5,0 4 0,0 0 0,0.5 2.5 0.5)),((2.5 0.5 0.5,5 0 0,3.5 1.5 1.5,2.5 0.5 0.5)),((0 0 0,5 0 0,2.5 0.5 0.5,0 0 0)),((0.5 0.5 0.5,0 0 0,2.5 0.5 0.5,0.5 0.5 0.5)),((4.5 3.5 0.5,5 5 0,4.5 4.5 0.5,4.5 3.5 0.5)),((3.5 2.5 1.5,3.5 1.5 1.5,4.5 3.5 0.5,3.5 2.5 1.5)),((4.5 3.5 0.5,5 0 0,5 5 0,4.5 3.5 0.5)),((3.5 1.5 1.5,5 0 0,4.5 3.5 0.5,3.5 1.5 1.5)),((5 5 0,4 5 0,4.5 4.5 0.5,5 5 0)),((4.5 4.5 0.5,4 4 0,4.5 3.5 0.5,4.5 4.5 0.5)),((4.5 4.5 0.5,4 5 0,4 4 0,4.5 4.5 0.5)),((3 3 1,0 4 0,1 3 1,3 3 1)),((3.5 2.5 1.5,4.5 3.5 0.5,3 3 1,3.5 2.5 1.5)),((3 3 1,4 4 0,0 4 0,3 3 1)),((4.5 3.5 0.5,4 4 0,3 3 1,4.5 3
.5 0.5)),((2 1 0,1 1 0,0.5 0.5 0.5,2 1 0)),((2.5 0.5 0.5,2 1 0,0.5 0.5 0.5,2.5 0.5 0.5)),((1 1 0,1 2 0,0.5 2.5 0.5,1 1 0)),((0.5 0.5 0.5,1 1 0,0.5 2.5 0.5,0.5 0.5 0.5)),((1 3 1,2 2 0,3 3 1,1 3 1)),((0.5 2.5 0.5,1 2 0,1 3 1,0.5 2.5 0.5)),((1 3 1,1 2 0,2 2 0,1 3 1)),((2 2 0,2 1 0,2.5 0.5 0.5,2 2 0)),((3.5 2.5 1.5,3 3 1,3.5 1.5 1.5,3.5 2.5 1.5)),((3.5 1.5 1.5,2 2 0,2.5 0.5 0.5,3.5 1.5 1.5)),((3 3 1,2 2 0,3.5 1.5 1.5,3 3 1)))
+Extrude roof|t
Extrude building and roof|t
Empty building and roof|POLYHEDRALSURFACE EMPTY
Empty roof|POLYHEDRALSURFACE EMPTY
Summary of changes:
doc/reference_sfcgal.xml | 2 +-
sfcgal/regress/extrudestraigthskeleton.sql | 111 +++++++++++++++---------
sfcgal/regress/extrudestraigthskeleton_expected | 2 +-
3 files changed, 72 insertions(+), 43 deletions(-)
hooks/post-receive
