[SCM] PostGIS branch master updated. 3.6.0rc2-479-gf3f83293a
git at osgeo.org
git at osgeo.org
Thu May 7 19:39:13 PDT 2026
the project "PostGIS".
via f3f83293aa7ba73988d579937a0251ee313f042f (commit)
from d36418658cee0538c9a162500f747be614b1e2d0 (commit)
revisions in full, below.
commit f3f83293aa7ba73988d579937a0251ee313f042f
Author: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>
Date: Fri May 8 00:43:01 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 99.9% (5538 of 5542 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 8bba9f185..29b8984e6 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-11-13 16:23+0000\n"
-"PO-Revision-Date: 2026-03-31 10:39+0000\n"
+"PO-Revision-Date: 2026-05-08 02:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -9793,9 +9793,9 @@ msgid ""
"ST_Endpoint(g)</code>) and <xref linkend=\"ST_IsSimple\"/> (does not self "
"intersect)."
msgstr ""
-"この<varname>LINESTRING</varname>が<xref linkend=\"ST_IsClosed\"/"
-">(<code>ST_StartPoint(g) ~= ST_Endpoint(g)</code>)かつ<xref "
-"linkend=\"ST_IsSimple\"/>(自己交差していない)場合には<varname>TRUE</varname>"
+"この<varname>LINESTRING</varname>が<xref linkend=\"ST_IsClosed\"/> (<code>"
+"ST_StartPoint(g) ~= ST_Endpoint(g)</code>)かつ<xref "
+"linkend=\"ST_IsSimple\"/> (自己交差していない)場合には<varname>TRUE</varname>"
"を返します。"
#. Tag: para
Summary of changes:
doc/po/ja/postgis-manual.po | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
