[SCM] PostGIS branch master updated. 3.6.0rc2-484-g77c71d1e1
git at osgeo.org
git at osgeo.org
Mon May 25 14:57:53 PDT 2026
the project "PostGIS".
via 77c71d1e18ab526a2bfd7acf3831d233ea56fbbe (commit)
from 9db5b1e16de4b83a4eedc52ce5d60760f9801845 (commit)
revisions in full, below.
commit 77c71d1e18ab526a2bfd7acf3831d233ea56fbbe
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon May 25 14:57:46 2026 -0700
Update comments on srid_check_latlong
diff --git a/postgis/geography_inout.c b/postgis/geography_inout.c
index ad809d9bd..edd41b14f 100644
--- a/postgis/geography_inout.c
+++ b/postgis/geography_inout.c
@@ -171,7 +171,7 @@ Datum geography_in(PG_FUNCTION_ARGS)
lwgeom = lwg_parser_result.geom;
- /* Error on any SRID != default */
+ /* Error on any non-geographic SRID */
srid_check_latlong(lwgeom->srid);
/* Convert to gserialized */
@@ -448,7 +448,7 @@ Datum geography_from_text(PG_FUNCTION_ARGS)
if ( lwgeom_parse_wkt(&lwg_parser_result, wkt, LW_PARSER_CHECK_ALL) == LW_FAILURE )
PG_PARSER_ERROR(lwg_parser_result);
srid_check_latlong(lwg_parser_result.geom->srid);
/* Clean up string */
@@ -476,7 +476,7 @@ Datum geography_from_binary(PG_FUNCTION_ARGS)
if ( ! lwgeom )
lwpgerror("Unable to parse WKB");
gser = gserialized_geography_from_lwgeom(lwgeom, -1);
@@ -500,7 +500,7 @@ Datum geography_from_geometry(PG_FUNCTION_ARGS)
lwgeom->srid = SRID_DEFAULT;
/* Force the geometry to have valid geodetic coordinate range. */
@@ -569,7 +569,7 @@ Datum geography_recv(PG_FUNCTION_ARGS)
PG_RETURN_NULL();
g_ser = gserialized_geography_from_lwgeom(lwgeom, geog_typmod);
Summary of changes:
postgis/geography_inout.c | 10 +++++-----
1 file changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
