[SCM] PostGIS branch master updated. 3.6.0rc2-488-gd606f127f
Wed May 27 15:18:44 PDT 2026
the project "PostGIS".
       via  d606f127ffd1dc6ae1a7e415a1b293f8cbaa57c7 (commit)
       via  a12dd5a9e5952e1bfefb32dd891a43f781bd5e42 (commit)
       via  82f8e34b61f0f2b29bba3b408e81015d226573ec (commit)
      from  c90277228b4fd73680502f7756721fbbf00749c2 (commit)
revisions in full, below.
commit d606f127ffd1dc6ae1a7e415a1b293f8cbaa57c7
Merge: c90277228 a12dd5a9e
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed May 27 15:18:31 2026 -0700
    Merge branch 'master-flatbuf'
commit a12dd5a9e5952e1bfefb32dd891a43f781bd5e42
Date:   Wed May 27 21:53:39 2026 +0000
    Add tests for flatbuffer schema checking
diff --git a/regress/core/flatgeobuf.sql b/regress/core/flatgeobuf.sql
index df46eca1e..7fb731aa1 100644
--- a/regress/core/flatgeobuf.sql
+++ b/regress/core/flatgeobuf.sql
@@ -158,6 +158,38 @@ select 'E1', id, bool_1, ST_AsText(geom), bool_2 from ST_FromFlatGeobuf(null::fl
     ) q)
+select '--- Type mismatch detection ---';
+-- Setup: a long (bigint) column and a text column in separate tables
+select ST_FromFlatGeobufToTable('public', 'flatgeobuf_mm_long', (select ST_AsFlatGeobuf(q) fgb from (select
+    null::geometry, null::bigint as val) q));
+select ST_FromFlatGeobufToTable('public', 'flatgeobuf_mm_text', (select ST_AsFlatGeobuf(q) fgb from (select
+    null::geometry, null::text as val) q));
+select ST_FromFlatGeobufToTable('public', 'flatgeobuf_mm_twocols', (select ST_AsFlatGeobuf(q) fgb from (select
+    null::geometry, null::bigint as val1, null::bigint as val2) q));
+-- Type mismatch: file has bigint (long), target expects text
+select 'MM1' from ST_FromFlatGeobuf(null::flatgeobuf_mm_text, (
+    select ST_AsFlatGeobuf(q) fgb from (select null::geometry, 42::bigint as val) q));
+-- Count mismatch: file has 2 property columns, target type has 1
+select 'MM2' from ST_FromFlatGeobuf(null::flatgeobuf_mm_long, (
+    select ST_AsFlatGeobuf(q) fgb from (select null::geometry, 42::bigint as val1, 43::bigint as val2) q));
+select '--- Numeric widening ---';
+-- integer (int32 in file) widened to bigint in target
+select ST_FromFlatGeobufToTable('public', 'flatgeobuf_widen_i', (select ST_AsFlatGeobuf(q) fgb from (select
+select 'W1', id, val from ST_FromFlatGeobuf(null::flatgeobuf_widen_i, (
+    select ST_AsFlatGeobuf(q) fgb from (select null::geometry, 42::integer as val) q));
+-- real (float4 in file) widened to double precision in target
+select ST_FromFlatGeobufToTable('public', 'flatgeobuf_widen_f', (select ST_AsFlatGeobuf(q) fgb from (select
+    null::geometry, null::double precision as val) q));
+select 'W2', id, val from ST_FromFlatGeobuf(null::flatgeobuf_widen_f, (
+    select ST_AsFlatGeobuf(q) fgb from (select null::geometry, 1.5::real as val) q));
 select '--- Quoted identifiers ---';
 -- Verify that special characters in column names are properly quoted
@@ -181,3 +213,8 @@ drop table if exists public.flatgeobuf_t1;
 drop table if exists public.flatgeobuf_a1;
 drop table if exists public.flatgeobuf_e1;
 drop table if exists public.flatgeobuf_qi;
+drop table if exists public.flatgeobuf_mm_long;
+drop table if exists public.flatgeobuf_mm_text;
+drop table if exists public.flatgeobuf_mm_twocols;
+drop table if exists public.flatgeobuf_widen_i;
+drop table if exists public.flatgeobuf_widen_f;
diff --git a/regress/core/flatgeobuf_expected b/regress/core/flatgeobuf_expected
index c93738ff9..ea7e022cc 100644
--- a/regress/core/flatgeobuf_expected
+++ b/regress/core/flatgeobuf_expected
@@ -24,6 +24,12 @@ ERROR:  mixed geometry type is not supported
 A1|0||t|1|2|3|4|1.2|1.3|2016-06-23 03:44:52.134125+00|hello
 --- Exotic roundtrips ---
 E1|0|t|POINT(1.1 2.1)|f
+--- Type mismatch detection ---
+ERROR:  flatgeobuf: column "val" type mismatch: file type "Long" is not compatible with PostgreSQL type text
+ERROR:  flatgeobuf: column count mismatch: file has 2 columns, target type has 1
+--- Numeric widening ---
+W1|0|42
+W2|0|1.5
 QI1
 QI2
commit 82f8e34b61f0f2b29bba3b408e81015d226573ec
Date:   Wed May 27 21:52:25 2026 +0000
    Check that user-provided flatbuffer schema matches
    The flatbuffer import maps an incoming file to a provided
    table schema, and the consistency of those two schemes
    needs to be checked before data are copied across.
diff --git a/postgis/flatgeobuf.c b/postgis/flatgeobuf.c
index ae3f8fb53..c984557dd 100644
--- a/postgis/flatgeobuf.c
+++ b/postgis/flatgeobuf.c
@@ -287,8 +287,6 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 	POSTGIS_DEBUGF(3, "flatgeobuf: decode_properties from byte array with length %d at offset %d", size, offset);
-	// TODO: init isnull
 	if (size > 0 && size < (sizeof(uint16_t) + sizeof(uint8_t)))
 		elog(ERROR, "flatgeobuf: decode_properties: Unexpected properties data size %d", size);
 	while (offset + 1 < size) {
@@ -389,7 +387,10 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 			if (offset + sizeof(float) > size)
 				elog(ERROR, "flatgeobuf: decode_properties: Invalid size for float value");
 			memcpy(&value, data + offset, sizeof(float));
-			values[ci] = Float4GetDatum(value);
+			if (getBaseType(TupleDescAttr(ctx->tupdesc, ci)->atttypid) == FLOAT8OID)
+				values[ci] = Float8GetDatum((double) value);
+			else
+				values[ci] = Float4GetDatum(value);
 			offset += sizeof(float);
 			break;
@@ -467,7 +468,9 @@ void flatgeobuf_decode_row(struct flatgeobuf_decode_ctx *ctx)
 	uint32_t natts = ctx->tupdesc->natts;
 	Datum *values = palloc0(natts * sizeof(Datum));
-	bool *isnull = palloc0(natts * sizeof(bool));
+	bool *isnull = palloc(natts * sizeof(bool));
+	for (uint32_t j = 0; j < natts; j++) isnull[j] = true;
+	isnull[0] = false;
 	values[0] = Int32GetDatum(ctx->fid);
@@ -476,6 +479,7 @@ void flatgeobuf_decode_row(struct flatgeobuf_decode_ctx *ctx)
 	if (ctx->ctx->lwgeom != NULL) {
 		values[1] = PointerGetDatum(geometry_serialize(ctx->ctx->lwgeom));
+		isnull[1] = false;
 	} else {
 		POSTGIS_DEBUG(3, "geometry is null");
 		isnull[1] = true;
diff --git a/postgis/lwgeom_in_flatgeobuf.c b/postgis/lwgeom_in_flatgeobuf.c
index 97ed26b16..8fc2e6efb 100644
--- a/postgis/lwgeom_in_flatgeobuf.c
+++ b/postgis/lwgeom_in_flatgeobuf.c
@@ -67,6 +67,60 @@ static char *get_pgtype(uint8_t column_type) {
 	elog(ERROR, "unknown column_type %d", column_type);
+static const char *
+flatgeobuf_type_name(uint8_t fgb_type)
+	/* Names match FlatGeobuf::EnumNamesColumnType() in header_generated.h */
+	static const char * const names[] = {
+		"Byte", "UByte", "Bool", "Short", "UShort",
+		"Int", "UInt", "Long", "ULong",
+		"Float", "Double", "String", "Json", "DateTime", "Binary"
+	if (fgb_type >= sizeof(names) / sizeof(names[0]))
+		return "unknown";
+	return names[fgb_type];
+static bool
+flatgeobuf_type_compatible(uint8_t fgb_type, Oid pgtype)
+	switch (fgb_type)
+	case flatgeobuf_column_type_bool:
+		return pgtype == BOOLOID;
+	/* small integer types: allow widening into larger signed ints */
+	case flatgeobuf_column_type_byte:
+	case flatgeobuf_column_type_ubyte:
+	case flatgeobuf_column_type_short:
+	case flatgeobuf_column_type_ushort:
+		return pgtype == INT2OID || pgtype == INT4OID || pgtype == INT8OID;
+	/* int32: allow widening to bigint */
+	case flatgeobuf_column_type_int:
+		return pgtype == INT4OID || pgtype == INT8OID;
+	/* uint32 max exceeds INT4, must land in bigint */
+	case flatgeobuf_column_type_uint:
+		return pgtype == INT8OID;
+	case flatgeobuf_column_type_long:
+	case flatgeobuf_column_type_ulong:
+	/* float: allow widening to double (explicit conversion handled in decode) */
+	case flatgeobuf_column_type_float:
+		return pgtype == FLOAT4OID || pgtype == FLOAT8OID;
+	case flatgeobuf_column_type_double:
+		return pgtype == FLOAT8OID;
+	case flatgeobuf_column_type_string:
+		return pgtype == TEXTOID || pgtype == VARCHAROID;
+	case flatgeobuf_column_type_datetime:
+		return pgtype == DATEOID || pgtype == TIMEOID ||
+		       pgtype == TIMESTAMPOID || pgtype == TIMESTAMPTZOID;
+	case flatgeobuf_column_type_json:
+		return pgtype == JSONBOID;
+	case flatgeobuf_column_type_binary:
+		return pgtype == BYTEAOID;
+	return false;
 PG_FUNCTION_INFO_V1(pgis_tablefromflatgeobuf);
 Datum pgis_tablefromflatgeobuf(PG_FUNCTION_ARGS)
@@ -191,7 +245,29 @@ Datum pgis_fromflatgeobuf(PG_FUNCTION_ARGS)
 			SRF_RETURN_DONE(funcctx);
-		// TODO: get table and verify structure against header
+		/* Validate that the file schema matches the caller-supplied composite type.
+		 * tupdesc positions 0 (fid) and 1 (geom) are fixed; file columns start at 2. */
+		if (ctx->ctx->columns_size != (uint32_t)(tupdesc->natts - 2))
+			ereport(ERROR,
+				(errcode(ERRCODE_DATATYPE_MISMATCH),
+				 errmsg("flatgeobuf: column count mismatch: "
+				        "file has %u columns, target type has %d",
+				        ctx->ctx->columns_size, tupdesc->natts - 2)));
+		for (uint16_t col_i = 0; col_i < ctx->ctx->columns_size; col_i++)
+			flatgeobuf_column *col = ctx->ctx->columns[col_i];
+			Oid pgtype = getBaseType(TupleDescAttr(tupdesc, col_i + 2)->atttypid);
+			if (!flatgeobuf_type_compatible(col->type, pgtype))
+				ereport(ERROR,
+					 errmsg("flatgeobuf: column \"%s\" type mismatch: "
+					        "file type \"%s\" is not compatible with PostgreSQL type %s",
+					        col->name,
+					        flatgeobuf_type_name(col->type),
+					        format_type_be(pgtype))));
 		MemoryContextSwitchTo(oldcontext);
Summary of changes:
 postgis/flatgeobuf.c             | 12 ++++---
 postgis/lwgeom_in_flatgeobuf.c   | 78 +++++++++++++++++++++++++++++++++++++++-
 regress/core/flatgeobuf.sql      | 37 +++++++++++++++++++
 regress/core/flatgeobuf_expected |  6 ++++
 4 files changed, 128 insertions(+), 5 deletions(-)
hooks/post-receive
