[PostGIS] #6075: Extend ST_GetFaceGeometry with a optional srid parameter for geom
trac at osgeo.org
Wed May 27 22:37:57 PDT 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.6.3
Component: topology | Version: 3.6.x
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
So, if I understand you correctly, spatial relationships cannot be handled
properly for all objects using simple features. For cases like this, we
need to use topology.
What initially caused this issue was that I failed to include all data
from the input layers after the data was gridded. To capture all the data,
I had to extend the bounding box when reading the simple feature input
data.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6075#comment:3>
