[SCM] PostGIS branch master updated. 3.6.0rc2-490-g5001c5165
git at osgeo.org
git at osgeo.org
Thu May 28 05:56:06 PDT 2026
the project "PostGIS".
via 5001c51659429ac9fe07723f18ece81a7cbd2deb (commit)
from 706d43bea8fe7501142145bf9e94a49263b903db (commit)
revisions in full, below.
commit 5001c51659429ac9fe07723f18ece81a7cbd2deb
Author: Sandro Santilli <strk at kbt.io>
Date: Thu May 28 14:34:29 2026 +0200
Give terse error from CreateTopology when target already exists
Also avoids incrementing topology sequence in those cases.
Closes #5860
diff --git a/topology/sql/manage/CreateTopology.sql.in b/topology/sql/manage/CreateTopology.sql.in
index 5fafa474f..7c82277ae 100644
--- a/topology/sql/manage/CreateTopology.sql.in
+++ b/topology/sql/manage/CreateTopology.sql.in
@@ -38,10 +38,10 @@ DECLARE
dataColumnType TEXT := 'INT4';
BEGIN
--- FOR rec IN SELECT * FROM pg_namespace WHERE text(nspname) = atopology
--- LOOP
--- RAISE EXCEPTION 'SQL/MM Spatial exception - schema already exists';
--- END LOOP;
+ FOR rec IN SELECT * FROM pg_namespace WHERE text(nspname) = atopology
+ LOOP
+ RAISE EXCEPTION 'schema "%" already exists', atopology;
+ END LOOP;
-- Prevent negative
IF topoid < 0 THEN
Summary of changes:
topology/sql/manage/CreateTopology.sql.in | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
