[SCM] PostGIS branch master updated. 3.6.0rc2-493-g219496998
Fri May 29 10:58:55 PDT 2026
the project "PostGIS".
       via  21949699858347065db080de31687841ce834ea0 (commit)
       via  34fa82354980b365d674faf38d4e971d2284ff03 (commit)
       via  86ae2fb265311d1b3a27b8ade404780029545426 (commit)
      from  5001c51659429ac9fe07723f18ece81a7cbd2deb (commit)
revisions in full, below.
commit 21949699858347065db080de31687841ce834ea0
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri May 29 10:58:46 2026 -0700
    News item for #5988
diff --git a/NEWS b/NEWS
index 05e49ccf7..48dcf7ea2 100644
--- a/NEWS
+++ b/NEWS
@@ -72,6 +72,7 @@ This version requires GEOS 3.10 or higher
           (Darafei Praliaskouski)
  - GH-848, CG_AlphaShape now returns a MultiPolygon (Jean Felder)
  - Flatgeobuf schema mismatch vulnerability (NeuroWinter)
+ - #5899, pg_upgrade issue for non-standard geography SRID (Paul Ramsey)
 PostGIS 3.6.0
commit 34fa82354980b365d674faf38d4e971d2284ff03
Merge: 86ae2fb26 5001c5165
Date:   Fri May 29 10:51:44 2026 -0700
    Merge branch 'master' into master-srs-upgrade
commit 86ae2fb265311d1b3a27b8ade404780029545426
Date:   Fri May 29 16:21:02 2026 +0000
    When doing pg_upgrade on a table with Geography(type, srid)
    column, where the SRID is specified, but not 4326, the SRID
    lookup code will fail during schema transfer as the
    spatial_ref_sys table may be missing and unable to lookup
    the SRID number. This "fix" leans on the fact that most
    SRID numbers in PostGIS are already EPSG numbers so the
    lookup can be skipped most times.
diff --git a/libpgcommon/lwgeom_transform.c b/libpgcommon/lwgeom_transform.c
index 53fe0a5d3..fdb60b34a 100644
--- a/libpgcommon/lwgeom_transform.c
+++ b/libpgcommon/lwgeom_transform.c
@@ -176,6 +176,40 @@ GetProjStringsSPI(int32_t srid)
 		elog(ERROR, "Could not connect to database using SPI");
+	 * During pg_upgrade, geography typmod is parsed before spatial_ref_sys
+	 * exists or is populated. Check both conditions via catalog before
+	 * querying the table, to avoid a transaction-aborting error.
+	 * If either check fails, return "EPSG:<srid>" directly so PROJ can
+	 * resolve standard codes from its own database.
+	Oid nsp_oid = POSTGIS_CONSTANTS ? POSTGIS_CONSTANTS->install_nsp_oid : InvalidOid;
+	snprintf(proj_spi_buffer, spibufferlen,
+	         "SELECT 1 FROM pg_class "
+	         "WHERE relname = 'spatial_ref_sys' AND relnamespace = %u",
+	         nsp_oid);
+	spi_result = SPI_execute(proj_spi_buffer, true, 1);
+	bool srs_exists = (spi_result == SPI_OK_SELECT && SPI_processed > 0);
+	bool srs_populated = false;
+	if (srs_exists)
+		         "SELECT 1 FROM %s LIMIT 1",
+		         postgis_spatial_ref_sys());
+		srs_populated = (spi_result == SPI_OK_SELECT && SPI_processed > 0);
+	if (!srs_exists || !srs_populated)
+		char tmp[maxprojlen];
+		snprintf(tmp, maxprojlen, "EPSG:%d", srid);
+		strs.authtext = SPI_pstrdup(tmp);
+		SPI_finish();
+		return strs;
 	static char *proj_str_tmpl =
 	    "SELECT proj4text, auth_name, auth_srid, srtext "
 	    "FROM %s "
Summary of changes:
 NEWS                           |  1 +
 libpgcommon/lwgeom_transform.c | 34 ++++++++++++++++++++++++++++++++++
 2 files changed, 35 insertions(+)
hooks/post-receive
