[SCM] PostGIS branch master updated. 3.7.0rc1-79-g443d2ca5c
git at osgeo.org
git at osgeo.org
Thu Oct 1 02:39:21 PDT 2026
the project "PostGIS".
via 443d2ca5c611918d010bd6ca289cf3d3395d01fe (commit)
from a73efc1cd7b02ec00ea3896fd121ff13bdde3c47 (commit)
revisions in full, below.
commit 443d2ca5c611918d010bd6ca289cf3d3395d01fe
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Thu Oct 1 08:07:00 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 100.0% (6059 of 6059 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index fe7da27ab..38bb1fb5b 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -11,7 +11,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2026-08-04 15:37+0000\n"
-"PO-Revision-Date: 2026-10-01 06:40+0000\n"
+"PO-Revision-Date: 2026-10-01 09:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -6455,8 +6455,9 @@ msgid ""
"command> is not necessary as <command>configure</command> has already been "
"generated."
msgstr ""
-"PostGIS をアーカイブファイルで入手する場合には、<command>configure</command> "
-"が既に生成されているので <command>./autogen.sh</command> は不要です。"
+"PostGIS をアーカイブファイルで入手する場合には <command>./autogen.sh</"
+"command> の実行は <command>configure</command> が既に生成されているので不要で"
+"す。"
#. Tag: title
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 7 ++++---
1 file changed, 4 insertions(+), 3 deletions(-)
hooks/post-receive
