[SCM] PostGIS branch master updated. 3.7.0rc1-80-gce378b4e2
Thu Oct 1 09:49:13 PDT 2026
the project "PostGIS".
       via  ce378b4e246875c38d102756d96016465e532b31 (commit)
      from  443d2ca5c611918d010bd6ca289cf3d3395d01fe (commit)
revisions in full, below.
commit ce378b4e246875c38d102756d96016465e532b31
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Oct 1 12:49:07 2026 -0400
    Replace stale pg18 GHA images
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index c9d4d16c1..44a6de01c 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -21,7 +21,7 @@ jobs:
       matrix:
         ci:
         # Use the last stable releases to run more tests
-        - { tag: pg18-geosmain-gdal311-proj96, mode: tests }
+        - { tag: pg18-geos314-gdal311-proj96, mode: tests }
         - { tag: pg17-geos313-gdal39-proj94, mode: coverage }
         # - { tag: pg17-geos313-gdal39-proj94, mode: garden }
         - { tag: pg16-geos312-gdal37-proj921, mode: coverage }
@@ -37,7 +37,7 @@ jobs:
         #- { tag: pg14-clang-geos39-gdal31-proj71, mode: usan_clang }
         # Run tests with different dependency combinations
         - { tag: pg19-geosmain-gdalmaster-proj98, mode: tests }
-        - { tag: pg18-geosmain-gdal311-proj96, mode: standard_conforming_strings_off }
+        - { tag: pg18-geos314-gdal311-proj96, mode: standard_conforming_strings_off }
         - { tag: pg19-geosmain-gdalmaster-proj98, mode: garden }
     runs-on: ubuntu-latest
Summary of changes:
 .github/workflows/ci.yml | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
