[SCM] PostGIS branch stable-3.3 updated. 3.3.10-139-gb53d3bd9a
git at osgeo.org
git at osgeo.org
Fri Oct 2 08:04:55 PDT 2026
the project "PostGIS".
The branch, stable-3.3 has been updated
via b53d3bd9a5b5edaa24c09bb581b2c99a6205fc5d (commit)
from 4bfae5b54cea43313c63e52252edb879be870ece (commit)
revisions in full, below.
commit b53d3bd9a5b5edaa24c09bb581b2c99a6205fc5d
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Oct 2 16:45:01 2026 +0200
Fix issue reference
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index d7e0aa305..2fe98d3e6 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -337,14 +337,14 @@ FROM TopoGeo_AddLinestring('bug3412',
SELECT 't3412.end', DropTopology('bug3412');
-- See http://trac.osgeo.org/postgis/ticket/3711
-SELECT 't3371.start', topology.CreateTopology('bug3711', 0, 0, true) > 1;
-SELECT 't3371.L1', topology.TopoGeo_AddLineString('bug3711',
+SELECT 't3711.start', topology.CreateTopology('bug3711', 0, 0, true) > 1;
+SELECT 't3711.L1', topology.TopoGeo_AddLineString('bug3711',
'LINESTRING (618369 4833784 0.88, 618370 4833784 1.93, 618370 4833780 1.90)'
::geometry, 0);
-SELECT 't3371.L2', count(*) FROM topology.TopoGeo_AddLineString( 'bug3711',
+SELECT 't3711.L2', count(*) FROM topology.TopoGeo_AddLineString( 'bug3711',
'LINESTRING (618370 4833780 1.92, 618370 4833784 1.90, 618371 4833780 1.93)'
::geometry, 0);
-SELECT 't3371.end', topology.DropTopology('bug3711');
+SELECT 't3711.end', topology.DropTopology('bug3711');
-- See http://trac.osgeo.org/postgis/ticket/3838
SELECT 't3838.start', topology.CreateTopology('bug3838') > 1;
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index 1a526208c..322681293 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -189,10 +189,10 @@ t3412.start|t
t3412.L1|1
t3412.L2|4
t3412.end|Topology 'bug3412' dropped
-t3371.start|t
-t3371.L1|1
-t3371.L2|2
-t3371.end|Topology 'bug3711' dropped
+t3711.start|t
+t3711.L1|1
+t3711.L2|2
+t3711.end|Topology 'bug3711' dropped
t3838.start|t
t3838.L1|1
t3838.L2|6
Summary of changes:
topology/test/regress/topogeo_addlinestring.sql | 8 ++++----
topology/test/regress/topogeo_addlinestring_expected | 8 ++++----
2 files changed, 8 insertions(+), 8 deletions(-)
hooks/post-receive
