[SCM] PostGIS branch stable-3.2 updated. 3.2.10-124-g5a237b001
Fri Oct 2 08:05:28 PDT 2026
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  5a237b0013e91d5170386d11d34236e6800c850f (commit)
      from  33aa84aca21938a1f0ca74067627b225e6ce77d5 (commit)
revisions in full, below.
commit 5a237b0013e91d5170386d11d34236e6800c850f
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Oct 2 16:45:01 2026 +0200
    Fix issue reference
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index 415733548..394a3ebd2 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -337,14 +337,14 @@ FROM TopoGeo_AddLinestring('bug3412',
 SELECT 't3412.end', DropTopology('bug3412');
 -- See http://trac.osgeo.org/postgis/ticket/3711
-SELECT 't3371.start', topology.CreateTopology('bug3711', 0, 0, true) > 1;
-SELECT 't3371.L1', topology.TopoGeo_AddLineString('bug3711',
+SELECT 't3711.start', topology.CreateTopology('bug3711', 0, 0, true) > 1;
+SELECT 't3711.L1', topology.TopoGeo_AddLineString('bug3711',
 'LINESTRING (618369 4833784 0.88, 618370 4833784 1.93, 618370 4833780 1.90)'
 ::geometry, 0);
-SELECT 't3371.L2', count(*) FROM topology.TopoGeo_AddLineString( 'bug3711',
+SELECT 't3711.L2', count(*) FROM topology.TopoGeo_AddLineString( 'bug3711',
 'LINESTRING (618370 4833780 1.92, 618370 4833784 1.90, 618371 4833780 1.93)'
 ::geometry, 0);
-SELECT 't3371.end', topology.DropTopology('bug3711');
+SELECT 't3711.end', topology.DropTopology('bug3711');
 -- See http://trac.osgeo.org/postgis/ticket/3838
 SELECT 't3838.start', topology.CreateTopology('bug3838') > 1;
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index 1a526208c..322681293 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -189,10 +189,10 @@ t3412.start|t
 t3412.L1|1
 t3412.L2|4
 t3412.end|Topology 'bug3412' dropped
-t3371.start|t
-t3371.L1|1
-t3371.L2|2
-t3371.end|Topology 'bug3711' dropped
+t3711.start|t
+t3711.L1|1
+t3711.L2|2
+t3711.end|Topology 'bug3711' dropped
 t3838.start|t
 t3838.L1|1
 t3838.L2|6
Summary of changes:
 topology/test/regress/topogeo_addlinestring.sql      | 8 ++++----
 topology/test/regress/topogeo_addlinestring_expected | 8 ++++----
 2 files changed, 8 insertions(+), 8 deletions(-)
hooks/post-receive
