[PostGIS] #6141: GHA crashing when installing raster
PostGIS trac at osgeo.org
Mon Oct 5 00:06:36 PDT 2026
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.7.0
Component:  raster   |    Version:  master
 Keywords:           |
 Since commit [fb915a6/git]
 GHA some runs CI at least (pg18-geosmain-gdal311-proj96,
 pg17-geos313-gdal39-proj94,pg16-geos312-gdal37-proj921, (pg19-geosmain-
 gdalmaster-proj98, tests)  ] have been failing but not all have been
 failing with:
 https://github.com/postgis/postgis/actions/runs/34256040959/job/102161980677
 It doesn't seem isolated to coverage or tests or garden, but I do notice
 it is happening with those running gdal 3.7 or higher.  It is not
 happening on winnie or debbie though which are running the newest so
 presume it must be some extra compile switch maybe that GHA has triggering
 it.
 RUNTESTFLAGS: --verbose --sfcgal --topology --raster
 RUNTESTFLAGS_INTERNAL: --after-create-db-script
 ./raster/test/regress/hooks/hook-before-create-raster.sql --before-
 upgrade-script ./raster/test/regress/hooks/hook-before-upgrade-raster.sql
 --before-upgrade-script ./topology/test/regress/hooks/hook-before-upgrade-
 topology.sql --after-create-db-script ./regress/hooks/hook-after-create-
 db.sql --before-upgrade-script ./regress/hooks/hook-before-upgrade.sql
 --after-upgrade-script ./regress/hooks/hook-after-upgrade-check-sql-
 object-resolution.sql --after-upgrade-script ./regress/hooks/hook-after-
 upgrade.sql --after-create-script   ./regress/hooks/hook-after-create.sql
 --before-uninstall-script ./regress/hooks/hook-before-uninstall.sql
 --after-upgrade-script ./topology/test/regress/hooks/hook-after-upgrade-
 topology.sql --after-upgrade-script ./raster/test/regress/hooks/hook-
 after-upgrade-raster.sql
 Creating database 'postgis_reg-3.7'.
 Running after-create-db-script ./raster/test/regress/hooks/hook-before-
 create-raster.sql
 Running after-create-db-script ./regress/hooks/hook-after-create-db.sql
 Loading PostGIS in 'postgis_reg-3.7 using scripts from
 /src/postgis/regress/00-regress-install/share/contrib/postgis'
 Loading Topology into 'postgis_reg-3.7'
 Loading Raster into 'postgis_reg-3.7'
  failed (Error encountered loading /src/postgis/regress/00-regress-
 install/share/contrib/postgis/rtpostgis.sql:
 /tmp/pgis_reg/regress_log.tmp)
 NOTICE:  schema "public" already exists, skipping
 psql:/src/postgis/regress/00-regress-
 install/share/contrib/postgis/rtpostgis.sql:109: server closed the
 connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
 install/share/contrib/postgis/rtpostgis.sql:109: error: connection to
 server was lost
 make: *** [regress/runtest.mk:24: check-regress] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6141>
