[PostGIS] #6141: GHA crashing when installing raster
PostGIS trac at osgeo.org
Mon Oct 5 00:27:04 PDT 2026
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.7.0
 Component:  raster   |    Version:  master
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> Since commit [fb915a6/git]
> GHA some runs CI at least (pg18-geosmain-gdal311-proj96,
> pg17-geos313-gdal39-proj94,pg16-geos312-gdal37-proj921, (pg19-geosmain-
> gdalmaster-proj98, tests)  ] have been failing but not all have been
> failing with:
> https://github.com/postgis/postgis/actions/runs/34256040959/job/102161980677
> It doesn't seem isolated to coverage or tests or garden, but I do notice
> it is happening with those running gdal 3.7 or higher.  It is not
> happening on winnie or debbie though which are running the newest so
> presume it must be some extra compile switch maybe that GHA has
> triggering it.
> RUNTESTFLAGS: --verbose --sfcgal --topology --raster
> RUNTESTFLAGS_INTERNAL: --after-create-db-script
> ./raster/test/regress/hooks/hook-before-create-raster.sql --before-
> upgrade-script ./raster/test/regress/hooks/hook-before-upgrade-raster.sql
> --before-upgrade-script ./topology/test/regress/hooks/hook-before-
> upgrade-topology.sql --after-create-db-script ./regress/hooks/hook-after-
> create-db.sql --before-upgrade-script ./regress/hooks/hook-before-
> upgrade.sql --after-upgrade-script ./regress/hooks/hook-after-upgrade-
> check-sql-object-resolution.sql --after-upgrade-script ./regress/hooks
> /hook-after-upgrade.sql --after-create-script   ./regress/hooks/hook-
> after-create.sql --before-uninstall-script ./regress/hooks/hook-before-
> uninstall.sql --after-upgrade-script ./topology/test/regress/hooks/hook-
> after-upgrade-topology.sql --after-upgrade-script
> ./raster/test/regress/hooks/hook-after-upgrade-raster.sql
> Creating database 'postgis_reg-3.7'.
> Running after-create-db-script ./raster/test/regress/hooks/hook-before-
> create-raster.sql
> Running after-create-db-script ./regress/hooks/hook-after-create-db.sql
> Loading PostGIS in 'postgis_reg-3.7 using scripts from
> /src/postgis/regress/00-regress-install/share/contrib/postgis'
> Loading Topology into 'postgis_reg-3.7'
> Loading Raster into 'postgis_reg-3.7'
>  failed (Error encountered loading /src/postgis/regress/00-regress-
> install/share/contrib/postgis/rtpostgis.sql:
> /tmp/pgis_reg/regress_log.tmp)
> NOTICE:  schema "public" already exists, skipping
> psql:/src/postgis/regress/00-regress-
> install/share/contrib/postgis/rtpostgis.sql:109: server closed the
> connection unexpectedly
>         This probably means the server terminated abnormally
>         before or while processing the request.
> install/share/contrib/postgis/rtpostgis.sql:109: error: connection to
> server was lost
> make: *** [regress/runtest.mk:24: check-regress] Error 1
New description:
 Since commit [fb915a676/git]
 failing with:
 presume it must be some extra compile switch maybe that GHA has triggering
 it.
 --before-upgrade-script ./topology/test/regress/hooks/hook-before-upgrade-
 topology.sql --after-create-db-script ./regress/hooks/hook-after-create-
 db.sql --before-upgrade-script ./regress/hooks/hook-before-upgrade.sql
 --after-upgrade-script ./regress/hooks/hook-after-upgrade-check-sql-
 object-resolution.sql --after-upgrade-script ./regress/hooks/hook-after-
 upgrade.sql --after-create-script   ./regress/hooks/hook-after-create.sql
 --before-uninstall-script ./regress/hooks/hook-before-uninstall.sql
 --after-upgrade-script ./topology/test/regress/hooks/hook-after-upgrade-
 topology.sql --after-upgrade-script ./raster/test/regress/hooks/hook-
 create-raster.sql
 server was lost
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6141#comment:1>
