[SCM] PostGIS branch master updated. 3.7.0rc1-94-g026463814
Wed Oct 7 00:29:49 PDT 2026
the project "PostGIS".
       via  0264638140f7c516a5dca4387e7c742822488c3f (commit)
       via  9425e81dba350754a138ecb569d9f2cf3af5a88c (commit)
       via  7b4f46cde3afd117331828efdb38c8bd6ff0ad13 (commit)
       via  d03570c8597d49e4ca382283b3385c22f52a5b7a (commit)
      from  41ac1d9faf4cb737f12ece8eb6bbe2c38476bdf3 (commit)
revisions in full, below.
commit 0264638140f7c516a5dca4387e7c742822488c3f
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Oct 7 09:29:33 2026 +0200
    Add NEWS item
diff --git a/NEWS b/NEWS
index 0620786c3..ce2670387 100644
--- a/NEWS
+++ b/NEWS
@@ -66,6 +66,8 @@ PostgreSQL instance.
 * Enhancements *
+ - #6140, #6138, #6129, [topology] improve topology building and checking
+          robustness (Sandro Santilli)
  - #2045, pgsql2shp query dumps no longer require temporary table
           privileges (Darafei Praliaskouski)
  - #1577, [loader] Report unsupported .zip archive input before trying
commit 9425e81dba350754a138ecb569d9f2cf3af5a88c
Date:   Tue Oct 6 14:51:26 2026 +0200
    Add test for ST_AddEdgeModFace issue #6140
diff --git a/topology/test/regress/st_addedgemodface.sql b/topology/test/regress/st_addedgemodface.sql
index 62fdc09d6..fdbb4dcf4 100644
--- a/topology/test/regress/st_addedgemodface.sql
+++ b/topology/test/regress/st_addedgemodface.sql
@@ -542,6 +542,20 @@ END;
 $TEST$ LANGUAGE 'plpgsql';
 ROLLBACK; -- restores the topology
+-- Very close segments
+BEGIN;
+SELECT 't6140', 'start';
+SELECT NULL FROM CreateTopology('t6140');
+SELECT NULL FROM ST_AddIsoNode('t6140', 0, '01010000005163B45884333540352259FDE66A5140'); -- start node of edge 1
+SELECT NULL FROM ST_AddIsoNode('t6140', 0, '0101000000685E205B88333540B7363CF4E66A5140'); -- start node of edge 2
+SELECT NULL FROM ST_AddIsoNode('t6140', 0, '0101000000831D215B88333540107B41F4E66A5140'); -- end node of both edges
+SELECT NULL FROM ST_AddEdgeModFace('t6140', 1, 3, '0102000000030000005163B45884333540352259FDE66A51406043FEC3BA333540C0BFF081E66A5140831D215B88333540107B41F4E66A5140');
+SELECT 't6140', 'unexpected success', * FROM ST_AddEdgeModFace('t6140', 2, 3, '010200000002000000685E205B88333540B7363CF4E66A5140831D215B88333540107B41F4E66A5140');
+ROLLBACK;
 -- Cleanups
diff --git a/topology/test/regress/st_addedgemodface_expected b/topology/test/regress/st_addedgemodface_expected
index 7a4be20d8..4b92f3a5f 100644
--- a/topology/test/regress/st_addedgemodface_expected
+++ b/topology/test/regress/st_addedgemodface_expected
@@ -203,4 +203,6 @@ F33|POLYGON((38 40,38 43,41 43,41 40,38 40))
 F34|POLYGON((35 25,35 45,63 45,63 25,35 25))
 F35|POLYGON((9 14,9 22,21 22,21 14,9 14))
 ERROR:  Backend error: Corrupted topology: ring of edge 58 is topologically non-closed
+t6140|start
+ERROR:  SQL/MM Spatial exception - non-boundary intersection with edge 1 at or near POINT(21.2012993770454 69.6703463210545)
 Topology 'city_data' dropped
commit 7b4f46cde3afd117331828efdb38c8bd6ff0ad13
Date:   Tue Oct 6 14:48:54 2026 +0200
    Add test for ValidateTopology issue #6138
diff --git a/topology/test/regress/validatetopology.sql b/topology/test/regress/validatetopology.sql
index aa852bb0d..670b29159 100644
--- a/topology/test/regress/validatetopology.sql
+++ b/topology/test/regress/validatetopology.sql
@@ -243,3 +243,37 @@ VALUES
 SELECT '#6065', 'invalidities', * FROM topology.ValidateTopology('t6065');
 ROLLBACK;
+-- See https://trac.osgeo.org/postgis/ticket/6138
+BEGIN;
+SELECT NULL FROM CreateTopology('t6138');
+COPY t6138.node(node_id,geom) FROM stdin;
+1	0101000000831D215B88333540107B41F4E66A5140
+2	01010000005163B45884333540352259FDE66A5140
+3	0101000000685E205B88333540B7363CF4E66A5140
+COPY t6138.edge_data(
+  edge_id,
+  start_node,
+  end_node,
+  next_left_edge,
+  abs_next_left_edge,
+  next_right_edge,
+  abs_next_right_edge,
+  left_face,
+  right_face,
+  geom
+FROM stdin;
+1	2	1	-2	2	1	1	0	0	0102000000030000005163B45884333540352259FDE66A51406043FEC3BA333540C0BFF081E66A5140831D215B88333540107B41F4E66A5140
+2	3	1	-1	1	2	2	0	0	010200000002000000685E205B88333540B7363CF4E66A5140831D215B88333540107B41F4E66A5140
+SELECT NULL FROM setval('t6138.edge_data_edge_id_seq', 2);
+SELECT NULL FROM setval('t6138.node_node_id_seq', 3);
+SELECT 't6139', 'invalidity', * FROM ValidateTopology('t6138');
+SELECT 't6138', 'end of validation';
diff --git a/topology/test/regress/validatetopology_expected b/topology/test/regress/validatetopology_expected
index 5f667e048..efc2359ce 100644
--- a/topology/test/regress/validatetopology_expected
+++ b/topology/test/regress/validatetopology_expected
@@ -47,3 +47,5 @@
 #5766.2|overlapping bbox|("face has wrong mbr",0,)
 #5766.2|disjoint bbox|
 #6065|invalidities|hole not in advertised face|-4|
+t6139|invalidity|edge crosses edge|1|2
+t6138|end of validation
commit d03570c8597d49e4ca382283b3385c22f52a5b7a
Date:   Mon Oct 5 15:58:31 2026 +0200
    Implement edge crossing internally
    Adds a lwline_have_nonboundary_2d_intersection function,
    expose it to SQL via topology.TopoEdgesHaveInteriorIntersection
    Include unit tests for the liblwgeom function
    WARNING: changes topology error messages to not distinguish anymore
             between "crosses", "coincident" and "intersects".
diff --git a/liblwgeom/cunit/cu_algorithm.c b/liblwgeom/cunit/cu_algorithm.c
index d9b3c0e25..9c2434e4a 100644
--- a/liblwgeom/cunit/cu_algorithm.c
+++ b/liblwgeom/cunit/cu_algorithm.c
@@ -1880,6 +1880,157 @@ static void test_ptarray_simplify(void)
 	lwgeom_free(geom2);
+** Assert the intersection status of a pair of lines described by WKT.
+** The check must be symmetric, so both argument orders are verified.
+#define ASSERT_NONBOUNDARY_INTERSECTION(wkt1, wkt2, expected) \
+	do \
+		LWLINE *l1 = (LWLINE *)lwgeom_from_wkt(wkt1, LW_PARSER_CHECK_NONE); \
+		LWLINE *l2 = (LWLINE *)lwgeom_from_wkt(wkt2, LW_PARSER_CHECK_NONE); \
+		int exp = (expected); \
+		CU_ASSERT_EQUAL(lwline_have_nonboundary_2d_intersection(l1, l2), exp); \
+		CU_ASSERT_EQUAL(lwline_have_nonboundary_2d_intersection(l2, l1), exp); \
+		lwline_free(l1); \
+		lwline_free(l2); \
+	} while (0)
+static void test_lwline_have_nonboundary_2d_intersection(void)
+	/* Non intersecting lines */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(200 0, 400 0)", 0);
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 50, 100 50)", 0);
+	/* The two lines would cross, but only outside of both segments */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(200 100, 200 -100)", 0);
+	/* The two lines would touch, but only outside of both segments */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(-100 0, -50 0)", 0);
+	/* Lines parallel and apart, also on a diagonal */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 100)", "LINESTRING(0 50, 100 150)", 0);
+	/* Touching on a boundary point of both lines */
+	/* End to start */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(100 0, 200 0)", 0);
+	/* Start to start */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 0, 0 100)", 0);
+	/* Start to end */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(100 0, 100 100)", 0);
+	/* End to end */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(200 0, 100 0)", 0);
+	/* Same point, opposite directions */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(100 0, 0 0)", "LINESTRING(0 0, -100 0)", 0);
+	/* Collinear, touching end to start on a vertical line */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 0 100)", "LINESTRING(0 100, 0 200)", 0);
+	/* Collinear, touching end to start on a diagonal */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 100)", "LINESTRING(100 100, 200 200)", 0);
+	/* Collinear, touching on the interior vertex of the first line */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 50 0, 100 0)", "LINESTRING(100 0, 150 0)", 0);
+	/* Diverging from the shared start point */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 0, 50 50)", 0);
+	/* The endpoint of the second line is the start point of the first */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(-50 0, 0 0)", 0);
+	/* Zero length second line, on the boundary of the first one */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(100 0, 100 0)", 0);
+	/* Zero length lines, on the same point */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(50 50, 50 50)", "LINESTRING(50 50, 50 50)", 0);
+	/* Closed line, touching another line on its boundary point */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0, 100 100, 0 100, 0 0)",
+	                               "LINESTRING(0 0, -100 0)",
+	                               0);
+	/* Crossing lines */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 10, 50 -10)", 1);
+	/* Crossing on a diagonal */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 100)", "LINESTRING(0 100, 100 0)", 1);
+	/* Crossing, but one line is zero length and on the other one interior */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 0, 50 0)", 1);
+	/* Identical lines */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 0, 100 0)", 1);
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 50 0, 100 0)", "LINESTRING(0 0, 50 0, 100 0)", 1);
+	/* Identical lines, opposite direction, on a vertical */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 0 100)", "LINESTRING(0 100, 0 0)", 1);
+	/* Endpoint of one line on the interior of the other one */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 0, 50 50)", 1);
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 -50, 50 0)", 1);
+	/* Zero length first line, on the interior of the second one */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(50 0, 50 0)", "LINESTRING(0 0, 100 0)", 1);
+	/* Collinear, zero length second line on the interior of the first one */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 50 0, 100 0)", "LINESTRING(50 0, 50 0)", 1);
+	/* Interior vertex of the first line, endpoint of the second one */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 50 0, 100 0)", "LINESTRING(50 0, 50 100)", 1);
+	/* Interior vertex of the first line, interior of the second one */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 50 0, 100 0)", "LINESTRING(50 -50, 50 50)", 1);
+	/* Collinear, overlapping for a positive length */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 0, 150 0)", 1);
+	/* Collinear, overlapping for a positive length, opposite direction */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(100 0, 0 0)", "LINESTRING(-50 0, 50 0)", 1);
+	/* Collinear, second line contained in the first one */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(25 0, 75 0)", 1);
+	/* Collinear, overlapping on a diagonal */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 100)", "LINESTRING(50 50, 150 150)", 1);
+	/* Collinear, overlapping on a vertical */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 0 100)", "LINESTRING(0 50, 0 200)", 1);
+	/* Collinear, overlapping, the shared point is on the line boundary */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 0, 50 0)", 1);
+	/* Collinear, overlapping across multiple segments */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(-50 0, 25 0, 150 0)", 1);
+	/* Collinear, the second line is back and forth over the first one */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 0, 100 100, 50 0)", 1);
+	/* Second line touches an interior vertex of first line */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0, 200 0)", "LINESTRING(100 0, 100 -50)", 1);
+	** Multiple intersections on the same pair of lines, the shared
+	** boundary point must not hide the non-boundary ones
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 0, 50 50, 50 -50, 0 0)", 1);
+	                               "LINESTRING(0 0, 50 50, 100 0, 50 -50, 0 0)",
+	                               1);
+	/* Z and M coordinates are ignored */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING Z (0 0 100, 100 0 200)",
+	                               "LINESTRING M (50 10 1, 50 -10 2)",
+	                               1);
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING Z (0 0 1, 100 0 1)", "LINESTRING Z (0 0 2, 100 0 2)", 1);
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING ZM (0 0 1 1, 100 0 1 1)",
+	                               "LINESTRING Z (100 0 9, 100 0 9)",
+	                               0);
+	/* Empty lines have nothing to intersect */
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING EMPTY", "LINESTRING(0 0, 100 0)", 0);
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING EMPTY", 0);
+	ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING EMPTY", "LINESTRING EMPTY", 0);
+	/* Single point lines have no segment to intersect */
+		POINT4D pt;
+		LWLINE *single, *line;
+		pt.x = 0;
+		pt.y = 0;
+		pt.z = 0;
+		pt.m = 0;
+		single = lwline_construct_empty(SRID_UNKNOWN, 0, 0);
+		ptarray_append_point(single->points, &pt, LW_TRUE);
+		line = (LWLINE*)lwgeom_from_wkt("LINESTRING(0 0, 100 0)", LW_PARSER_CHECK_NONE);
+		CU_ASSERT_EQUAL( lwline_have_nonboundary_2d_intersection(single, line), 0 );
+		CU_ASSERT_EQUAL( lwline_have_nonboundary_2d_intersection(line, single), 0 );
+		CU_ASSERT_EQUAL( lwline_have_nonboundary_2d_intersection(single, single), 0 );
+		lwline_free(single);
+		lwline_free(line);
+	/* NULL lines are handled gracefully */
+	CU_ASSERT_EQUAL( lwline_have_nonboundary_2d_intersection(NULL, NULL), 0 );
 ** Used by test harness to register the tests in this file.
@@ -1920,4 +2071,5 @@ void algorithms_suite_setup(void)
 	PG_ADD_TEST(suite,test_lwpoly_construct_circle);
 	PG_ADD_TEST(suite,test_trim_bits);
 	PG_ADD_TEST(suite,test_lwgeom_remove_repeated_points);
+	PG_ADD_TEST(suite,test_lwline_have_nonboundary_2d_intersection);
diff --git a/liblwgeom/liblwgeom_internal.h b/liblwgeom/liblwgeom_internal.h
index d55f1bb1e..179ac4460 100644
--- a/liblwgeom/liblwgeom_internal.h
+++ b/liblwgeom/liblwgeom_internal.h
@@ -481,6 +481,7 @@ int ptarray_raycast_intersections(const POINTARRAY *pa, const POINT2D *p, int *o
 int ptarrayarc_raycast_intersections(const POINTARRAY *pa, const POINT2D *p, int *on_boundary);
 int lwcompound_contains_point(const LWCOMPOUND *comp, const POINT2D *pt);
 int lwgeom_contains_point(const LWGEOM *geom, const POINT2D *pt);
+int lwline_have_nonboundary_2d_intersection(const LWLINE *line1, const LWLINE *line2);
 * Split a line by a point and push components to the provided multiline.
diff --git a/liblwgeom/lwline.c b/liblwgeom/lwline.c
index 50185f510..d8398dfc0 100644
--- a/liblwgeom/lwline.c
+++ b/liblwgeom/lwline.c
@@ -747,3 +747,264 @@ lwline_extend(const LWLINE *line, double distance_forward, double distance_backw
 	return lwline_construct(line->srid, NULL, opa);
+* The ways two line segments can intersect.
+* Returned by lwsegment_intersection()
+enum LWSEGMENT_INTERSECTION
+	/* The segments do not intersect */
+	LWSEG_INTERSECT_NONE = 0,
+	/* The segments are collinear and overlap for a positive length */
+	LWSEG_INTERSECT_OVERLAP,
+	/* The segments cross at a point interior to both of them */
+	LWSEG_INTERSECT_CROSS,
+	/* The segments touch at a single point, an endpoint of one of them */
+	LWSEG_INTERSECT_POINT
+* Does the point lie on the segment, endpoints included?
+* Unlike lw_pt_on_segment(), which excludes the segment endpoints.
+* @param A1 first point of the segment
+* @param A2 second point of the segment
+* @param P the point to test
+* @return LW_TRUE if P is on the A1/A2 segment
+static int
+lw_pt_on_segment_inclusive(const POINT2D *A1, const POINT2D *A2, const POINT2D *P)
+	if ( lw_segment_side(A1, A2, P) != 0 )
+		return LW_FALSE;
+	/* The point is on the segment line, check it's within its extent */
+	return (P->x >= FP_MIN(A1->x, A2->x) && P->x <= FP_MAX(A1->x, A2->x) &&
+	        P->y >= FP_MIN(A1->y, A2->y) && P->y <= FP_MAX(A1->y, A2->y));
+* How do the segment (P1,P2) and the segment (Q1,Q2) intersect?
+* Only 2D coordinates are considered. Zero length segments are supported,
+* they can only intersect at their single point.
+* @param P1 first point of the first segment
+* @param P2 second point of the first segment
+* @param Q1 first point of the second segment
+* @param Q2 second point of the second segment
+* @param ipoint storage for the intersection point, set when the returned
+*               value is #LWSEG_INTERSECT_POINT
+* @return one of the #LWSEGMENT_INTERSECTION values
+static int
+lwsegment_intersection(const POINT2D *P1,
+                       const POINT2D *P2,
+                       const POINT2D *Q1,
+                       const POINT2D *Q2,
+                       POINT2D *ipoint)
+	int s11, s12, s21, s22;
+	int zeroP, zeroQ;
+	double len2, tQ1, tQ2, tmin, tmax;
+	zeroP = P2D_SAME_STRICT(P1, P2);
+	zeroQ = P2D_SAME_STRICT(Q1, Q2);
+	/* Zero length segments, if they intersect, do it on their single point */
+	if ( zeroP || zeroQ )
+		if ( zeroP && zeroQ )
+			if ( ! P2D_SAME_STRICT(P1, Q1) )
+				return LWSEG_INTERSECT_NONE;
+		else if ( zeroP )
+			if ( ! lw_pt_on_segment_inclusive(Q1, Q2, P1) )
+		else
+			if ( ! lw_pt_on_segment_inclusive(P1, P2, Q1) )
+		*ipoint = zeroP ? *P1 : *Q1;
+		return LWSEG_INTERSECT_POINT;
+	/* Are both endpoints of the second segment on the same side of the first? */
+	s11 = lw_segment_side(P1, P2, Q1);
+	s12 = lw_segment_side(P1, P2, Q2);
+	if ( (s11 > 0 && s12 > 0) || (s11 < 0 && s12 < 0) )
+	/* Are both endpoints of the first segment on the same side of the second? */
+	s21 = lw_segment_side(Q1, Q2, P1);
+	s22 = lw_segment_side(Q1, Q2, P2);
+	if ( (s21 > 0 && s22 > 0) || (s21 < 0 && s22 < 0) )
+	* Both endpoints of the second segment are on the line of the first,
+	* the segments are collinear and the intersection is their overlap.
+	* Use the projection on the (P1,P2) vector as the segment parameter,
+	* the overlap is the [0,len2] interval trimmed by the [tQ1,tQ2] one.
+	if ( s11 == 0 && s12 == 0 )
+		len2 = (P2->x - P1->x) * (P2->x - P1->x) +
+		       (P2->y - P1->y) * (P2->y - P1->y);
+		tQ1 = (Q1->x - P1->x) * (P2->x - P1->x) +
+		      (Q1->y - P1->y) * (P2->y - P1->y);
+		tQ2 = (Q2->x - P1->x) * (P2->x - P1->x) +
+		      (Q2->y - P1->y) * (P2->y - P1->y);
+		tmin = FP_MAX(0.0, FP_MIN(tQ1, tQ2));
+		tmax = FP_MIN(len2, FP_MAX(tQ1, tQ2));
+		/* No overlap at all */
+		if ( tmin > tmax )
+		/* The segments are collinear and share a positive length */
+		if ( tmin < tmax )
+			return LWSEG_INTERSECT_OVERLAP;
+		/* The segments touch on a single point, always a segment endpoint */
+		if ( tmin == 0.0 )
+			*ipoint = *P1;
+		else if ( tmin == len2 )
+			*ipoint = *P2;
+		else if ( tmin == tQ1 )
+			*ipoint = *Q1;
+		else if ( tmin == tQ2 )
+			*ipoint = *Q2;
+		else
+			/* Rounding fallback, the point is one of the four endpoints */
+			double t = tmin / len2;
+			ipoint->x = P1->x + t * (P2->x - P1->x);
+			ipoint->y = P1->y + t * (P2->y - P1->y);
+	* The segments are not collinear, they intersect on a single point.
+	* When that point is not a vertex of either segment it is interior
+	* to both of them.
+	if ( lw_pt_on_segment_inclusive(P1, P2, Q1) )
+		*ipoint = *Q1;
+	if ( lw_pt_on_segment_inclusive(P1, P2, Q2) )
+		*ipoint = *Q2;
+	if ( lw_pt_on_segment_inclusive(Q1, Q2, P1) )
+		*ipoint = *P1;
+	if ( lw_pt_on_segment_inclusive(Q1, Q2, P2) )
+		*ipoint = *P2;
+	return LWSEG_INTERSECT_CROSS;
+* Is the point a boundary point of the line, that is one of its endpoints?
+* Those are the only points of a line that may be shared with another line
+* without requiring any of them to be split.
+* @param line the line to test the point against
+* @return LW_TRUE if P is the first or the last point of the line
+static int
+lwline_point_is_boundary(const LWLINE *line, const POINT2D *P)
+	const POINT2D *start = getPoint2d_cp(line->points, 0);
+	const POINT2D *end = getPoint2d_cp(line->points, line->points->npoints - 1);
+	return P2D_SAME_STRICT(P, start) || P2D_SAME_STRICT(P, end);
+* Do two lines intersect anywhere but on a point shared by both of their
+* boundaries?
+* @param line1 first line
+* @param line2 second line
+* @return 1 if there's a non-boundary 2d intersection, 0 if there's NO
+*         non-boundary 2d intersection
+int
+lwline_have_nonboundary_2d_intersection(const LWLINE *line1, const LWLINE *line2)
+	const POINTARRAY *pa1, *pa2;
+	uint32_t i1, i2;
+	POINT2D ipoint;
+	if ( !line1 || !line2 )
+		return LW_FALSE;
+	pa1 = line1->points;
+	pa2 = line2->points;
+	/* Lines without segments can't intersect anything */
+	if ( !pa1 || !pa2 || pa1->npoints < 2 || pa2->npoints < 2 )
+		return LW_FALSE;
+	for (i1 = 0; i1 < pa1->npoints - 1; ++i1)
+		const POINT2D *p1 = getPoint2d_cp(pa1, i1);
+		const POINT2D *p2 = getPoint2d_cp(pa1, i1 + 1);
+		for (i2 = 0; i2 < pa2->npoints - 1; ++i2)
+			const POINT2D *q1 = getPoint2d_cp(pa2, i2);
+			const POINT2D *q2 = getPoint2d_cp(pa2, i2 + 1);
+			int inter;
+			inter = lwsegment_intersection(p1, p2, q1, q2, &ipoint);
+			/* Crossings and overlaps are never boundary only */
+			if ( inter == LWSEG_INTERSECT_CROSS ||
+			     inter == LWSEG_INTERSECT_OVERLAP )
+				return LW_TRUE;
+			** A touch on a point which is a boundary point of both lines
+			** is not a non-boundary intersection
+			if ( inter == LWSEG_INTERSECT_POINT &&
+			     ( ! lwline_point_is_boundary(line1, &ipoint) ||
+			       ! lwline_point_is_boundary(line2, &ipoint) ) )
+				return LW_TRUE;
+	return LW_FALSE;
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 04e32d140..d683673a7 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -54,56 +54,33 @@ _lwt_describe_point(const LWPOINT *pt, char *buf, size_t bufsize)
- * Report a deterministic GEOS-derived location for topology errors.
+ * Report a deterministic location for topology errors.
  * Normalize the intersection geometry so PointOnSurface is stable
  * across operand-order and platform differences.
-static bool
-_lwt_describe_intersection_point(const GEOSGeometry *g1, const GEOSGeometry *g2, char *buf, size_t bufsize)
+static int
+_lwt_describe_intersection_point(const LWGEOM *g1, const LWGEOM *g2, char *buf, size_t bufsize)
-	unsigned int n = 0;
-	POINT2D p;
-	GEOSGeometry *isect;
-	GEOSGeometry *surface_pt;
-	const GEOSCoordSequence *seq;
+	const POINT2D *p;
+	LWGEOM *isect;
+	LWGEOM *normalized;
+	LWGEOM *surface_pt;
-	isect = GEOSIntersection(g1, g2);
-	if (!isect)
-		return false;
+	isect = lwgeom_intersection(g1, g2);
+	if (!isect) return 0;
-	if (GEOSNormalize(isect) != 0)
-		GEOSGeom_destroy(isect);
-		return false;
+	normalized = lwgeom_clone_deep(isect);
+	lwgeom_free(isect);
+	lwgeom_normalize(normalized);
-	surface_pt = GEOSPointOnSurface(isect);
-	if (!surface_pt)
-		return false;
+	surface_pt = lwgeom_pointonsurface(normalized);
+	lwgeom_free(normalized);
+	p = getPoint2d_cp(lwgeom_as_lwpoint(surface_pt)->point, 0);
-	seq = GEOSGeom_getCoordSeq(surface_pt);
-	if (!seq)
-		GEOSGeom_destroy(surface_pt);
-		return false;
+	snprintf(buf, bufsize, "POINT(%.15g %.15g)", p->x, p->y);
+	lwgeom_free(surface_pt);
-	if (!GEOSCoordSeq_getSize(seq, &n) || !n)
-		return false;
-	if (!GEOSCoordSeq_getX(seq, 0, &p.x) || !GEOSCoordSeq_getY(seq, 0, &p.y))
-		return false;
-	snprintf(buf, bufsize, " at POINT(%.15g %.15g)", p.x, p.y);
-	return true;
+	return 1;
@@ -653,16 +630,7 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
   LWT_ISO_EDGE *edges;
   LWT_ISO_NODE *nodes;
   const GBOX *edgebox;
-  GEOSGeometry *edgegg;
-  initGEOS(lwnotice, lwgeom_geos_error);
-  edgegg = LWGEOM2GEOS(lwline_as_lwgeom(geom), 0);
-  if (!edgegg)
-    lwerror("Could not convert edge geometry to GEOS: %s", lwgeom_geos_errmsg);
-    return -1;
   edgebox = lwgeom_get_bbox( lwline_as_lwgeom(geom) );
   /* loop over each node within the edge's gbox */
@@ -680,16 +648,12 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
 	  LWT_ISO_NODE *node = &(nodes[i]);
 	  LWT_ELEMID node_id = node->node_id;
-	  /* check if the edge contains this node (not on boundary) */
-	  /* ST_RelateMatch(rec.relate, 'T********') */
 	  /* skip boundary nodes */
 	  if (node_id == start_node) continue;
 	  if (node_id == end_node) continue;
 	  if (!node->geom || !node->geom->point || !node->geom->point->npoints)
-		  GEOSGeom_destroy(edgegg);
 		  _lwt_release_nodes(nodes, num_nodes);
 		  lwerror("Internal error: lwt_be_getNodeWithinBox2D returned node %"
 		          LWTFMT_ELEMID " with no vertices", node_id);
@@ -702,7 +666,6 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
 		  char locinfo[128] = "";
 		  snprintf(locinfo, sizeof(locinfo), " at POINT(%.15g %.15g)", p.x, p.y);
 		  lwerror("SQL/MM Spatial exception - geometry crosses a node%s", locinfo);
 		  return -1;
@@ -716,7 +679,6 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
   LWDEBUGF(1, "lwt_be_getEdgeWithinBox2D returned %" PRIu64 " edges", num_edges);
   if (num_edges == UINT64_MAX)
     PGTOPO_BE_ERROR();
     return -1;
@@ -724,9 +686,6 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
     LWT_ISO_EDGE* edge = &(edges[i]);
     LWT_ELEMID edge_id = edge->edge_id;
-    GEOSGeometry *eegg;
-    char *relate;
-    int match;
     if ( edge_id == myself ) continue;
@@ -736,169 +695,22 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
       return -1;
-    eegg = LWGEOM2GEOS( lwline_as_lwgeom(edge->geom), 0 );
-    if ( ! eegg ) {
-      _lwt_release_edges(edges, num_edges);
-      return -1;
-    LWDEBUGF(2, "Edge %" LWTFMT_ELEMID " converted to GEOS", edge_id);
     /* check if the edge has a non-boundary-boundary intersection with our edge */
-    relate = GEOSRelateBoundaryNodeRule(eegg, edgegg, 2);
-    if ( ! relate ) {
-	    GEOSGeom_destroy(eegg);
-	    lwerror("GEOSRelateBoundaryNodeRule error: %s", lwgeom_geos_errmsg);
-	    return -1;
-    LWDEBUGF(2, "Edge %" LWTFMT_ELEMID " relate pattern is %s", edge_id, relate);
-    match = GEOSRelatePatternMatch(relate, "FF*F*****");
-    if ( match ) {
-      /* error or no interior intersection */
-      GEOSFree(relate);
-      if ( match == 2 ) {
-        lwerror("GEOSRelatePatternMatch error: %s", lwgeom_geos_errmsg);
-        return -1;
-      continue; /* no interior intersection */
-    match = GEOSRelatePatternMatch(relate, "1FFF*FFF2");
-    if ( match ) {
-	    char locinfo[128] = "";
-	    const char *locsuffix = match == 2                                                        ? ""
-				    : _lwt_describe_intersection_point(edgegg, eegg, locinfo, sizeof(locinfo))
-					? locinfo
-	    GEOSFree(relate);
-	    if (match == 2)
-	    else
-		    lwerror("SQL/MM Spatial exception - coincident edge %" LWTFMT_ELEMID "%s", edge_id, locsuffix);
-      return -1;
-    match = GEOSRelatePatternMatch(relate, "1********");
-    if ( match ) {
-					? locinfo
-	    GEOSFree(relate);
-	    if (match == 2)
-	    else
-		    lwerror("Spatial exception - geometry intersects edge %" LWTFMT_ELEMID "%s", edge_id, locsuffix);
-      return -1;
-    match = GEOSRelatePatternMatch(relate, "T********");
-    if ( match ) {
-					? locinfo
-	    GEOSFree(relate);
-	    if (match == 2)
-	    else
-		    lwerror(
-			"SQL/MM Spatial exception - geometry crosses edge %" LWTFMT_ELEMID "%s", edge_id, locsuffix);
-      return -1;
-    match = GEOSRelatePatternMatch(relate, "*T*******");
-    if ( match ) {
-					? locinfo
-	    GEOSFree(relate);
-	    if (match == 2)
-	    else
-		    lwerror("Spatial exception - geometry boundary touches interior of edge %" LWTFMT_ELEMID "%s",
-			    edge_id,
-			    locsuffix);
-      return -1;
-    match = GEOSRelatePatternMatch(relate, "***T*****");
-    if ( match ) {
-					? locinfo
-	    GEOSFree(relate);
-	    if (match == 2)
-	    else
-		    lwerror("Spatial exception - boundary of edge %" LWTFMT_ELEMID " touches interior of geometry%s",
-			    edge_id,
-			    locsuffix);
+    if ( lwline_have_nonboundary_2d_intersection(edge->geom, geom) )
+      char locinfo[128] = "";
+      _lwt_describe_intersection_point(lwline_as_lwgeom(edge->geom), lwline_as_lwgeom(geom), locinfo, sizeof(locinfo));
+      _lwt_release_edges(edges, num_edges);
+      lwerror("SQL/MM Spatial exception - non-boundary intersection with edge %" LWTFMT_ELEMID " at or near %s", edge_id, locinfo);
       return -1;
     LWDEBUGF(2, "Edge %" LWTFMT_ELEMID " analysis completed, it does no harm", edge_id);
-    GEOSFree(relate);
   LWDEBUGF(1, "No edge crossing detected among the %" PRIu64 " candidate edges", num_edges);
   if ( edges ) _lwt_release_edges(edges, num_edges);
               /* would be NULL if num_edges was 0 */
   return 0;
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index ab8232230..c96637b6e 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -5952,3 +5952,48 @@ Datum TopoRingIsCCW(PG_FUNCTION_ARGS)
   PG_RETURN_BOOL(isCCW);
+/*  TopoEdgesHaveInteriorIntersection(line1 geometry, line2 geometry) */
+Datum TopoEdgesHaveInteriorIntersection(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(TopoEdgesHaveInteriorIntersection);
+  GSERIALIZED *geom1, *geom2;
+  LWGEOM *lwgeom1, *lwgeom2;
+  int ret;
+  geom1 = PG_GETARG_GSERIALIZED_P(0);
+  lwgeom1 = lwgeom_from_gserialized(geom1);
+  geom2 = PG_GETARG_GSERIALIZED_P(1);
+  lwgeom2 = lwgeom_from_gserialized(geom2);
+  if ( lwgeom_is_empty(lwgeom1) || lwgeom_is_empty(lwgeom2) )
+	  lwgeom_free(lwgeom1);
+	  lwgeom_free(lwgeom2);
+	  PG_FREE_IF_COPY(geom1, 0);
+	  PG_FREE_IF_COPY(geom2, 1);
+	  PG_RETURN_BOOL(false);
+  if (lwgeom1->type != LINETYPE || lwgeom2->type != LINETYPE)
+	  lwpgerror("Unsupported geometry type passed to TopoEdgesHaveInteriorIntersection");
+	  PG_RETURN_NULL();
+  ret = lwline_have_nonboundary_2d_intersection(lwgeom_as_lwline(lwgeom1), lwgeom_as_lwline(lwgeom2));
+  PG_RETURN_BOOL(ret);
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index fb6f23c02..042e00e15 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -371,6 +371,11 @@ RETURNS BOOLEAN AS
 	'MODULE_PATHNAME', 'TopoRingIsCCW'
 LANGUAGE 'c' IMMUTABLE STRICT;
+CREATE OR REPLACE FUNCTION topology.TopoEdgesHaveInteriorIntersection(line1 geometry, line2 geometry)
+RETURNS BOOLEAN AS
+	'MODULE_PATHNAME', 'TopoEdgesHaveInteriorIntersection'
+LANGUAGE 'c' IMMUTABLE STRICT;
 -- Check that the edges forming all rings
 -- (as advertised by their next_right_edge/next_left_edge)
@@ -770,7 +775,7 @@ BEGIN
       e2.edge_id as id2,
       e1.geom as g1,
       e2.geom as g2,
-      ST_Relate(e1.geom, e2.geom, 2) as im
+      topology.TopoEdgesHaveInteriorIntersection(e1.geom, e2.geom) as cross
     FROM
       edge e1,
       edge e2
@@ -794,15 +799,14 @@ BEGIN
   LOOP --{
-    IF ST_RelateMatch(rec.im, 'FF*F*****') THEN
-      -- no interior-interior or interior-boundary intersections
-      CONTINUE;
+    IF rec.cross THEN
+      -- interior-interior or interior-boundary intersections found
+      retrec.error = 'edge crosses edge';
+      retrec.id1 = rec.id1;
+      retrec.id2 = rec.id2;
+      RETURN NEXT retrec;
     END IF;
-    retrec.error = 'edge crosses edge';
-    retrec.id1 = rec.id1;
-    retrec.id2 = rec.id2;
-    RETURN NEXT retrec;
   END LOOP; --}
   -- Check for edge start_node geometry mismatch
index 29aef17ce..7a4be20d8 100644
@@ -7,10 +7,10 @@ ERROR:  SQL/MM Spatial exception - non-existent node
 ERROR:  SQL/MM Spatial exception - curve not simple
 ERROR:  Invalid edge (no two distinct vertices exist)
-ERROR:  SQL/MM Spatial exception - coincident edge 8 at POINT(35 22)
-ERROR:  SQL/MM Spatial exception - geometry crosses edge 5 at POINT(57 33)
-ERROR:  SQL/MM Spatial exception - geometry crosses edge 4 at POINT(45 32)
-ERROR:  Spatial exception - geometry intersects edge 4 at POINT(36 38)
+ERROR:  SQL/MM Spatial exception - non-boundary intersection with edge 8 at or near POINT(35 22)
+ERROR:  SQL/MM Spatial exception - non-boundary intersection with edge 5 at or near POINT(57 33)
+ERROR:  SQL/MM Spatial exception - non-boundary intersection with edge 4 at or near POINT(45 32)
+ERROR:  SQL/MM Spatial exception - non-boundary intersection with edge 4 at or near POINT(36 38)
 L1
 L2
 T1|E7|8|-19|0|10
diff --git a/topology/test/regress/st_addedgenewfaces_expected b/topology/test/regress/st_addedgenewfaces_expected
index df23f1044..8a05ace86 100644
--- a/topology/test/regress/st_addedgenewfaces_expected
+++ b/topology/test/regress/st_addedgenewfaces_expected
 L1
 L2
 T1|E7|8|-19|0|11
diff --git a/topology/test/regress/st_addisoedge_expected b/topology/test/regress/st_addisoedge_expected
index 46d9f9916..05602c571 100644
--- a/topology/test/regress/st_addisoedge_expected
+++ b/topology/test/regress/st_addisoedge_expected
@@ -29,5 +29,5 @@ ERROR:  SQL/MM Spatial exception - not isolated node
 ERROR:  Closed edges would not be isolated, try ST_AddEdgeNewFaces
-ERROR:  SQL/MM Spatial exception - geometry crosses edge 2 at POINT(10 3.33333333333333)
+ERROR:  SQL/MM Spatial exception - non-boundary intersection with edge 2 at or near POINT(10 3.33333333333333)
 Topology 'tt' dropped
diff --git a/topology/test/regress/st_changeedgegeom_expected b/topology/test/regress/st_changeedgegeom_expected
index c4dd61a06..f1bc3c380 100644
--- a/topology/test/regress/st_changeedgegeom_expected
+++ b/topology/test/regress/st_changeedgegeom_expected
@@ -5,7 +5,7 @@ ERROR:  SQL/MM Spatial exception - geometry crosses a node at POINT(20 37)
 ERROR:  SQL/MM Spatial exception - non-existent edge 666
-ERROR:  SQL/MM Spatial exception - geometry crosses edge 1 at POINT(11.8 38)
+ERROR:  SQL/MM Spatial exception - non-boundary intersection with edge 1 at or near POINT(10.2 38)
 T2|Edge 5 changed
 T3|Edge 5 changed
 T4|Edge 26 changed
diff --git a/topology/test/regress/topology_error_location_expected b/topology/test/regress/topology_error_location_expected
index 85bd4abe3..c90c9aff9 100644
--- a/topology/test/regress/topology_error_location_expected
+++ b/topology/test/regress/topology_error_location_expected
@@ -5,5 +5,5 @@ n3|3
 n4|4
 NOTICE:  duplicate node: SQL/MM Spatial exception - coincident node at POINT(0 0)
 base_edge|1
-NOTICE:  crossing edge: SQL/MM Spatial exception - geometry crosses edge 1 at POINT(5 0)
+NOTICE:  crossing edge: SQL/MM Spatial exception - non-boundary intersection with edge 1 at or near POINT(5 0)
 dropped|t
Summary of changes:
 NEWS                                               |   2 +
 liblwgeom/cunit/cu_algorithm.c                     | 152 ++++++++++++
 liblwgeom/liblwgeom_internal.h                     |   1 +
 liblwgeom/lwline.c                                 | 261 +++++++++++++++++++++
 liblwgeom/topo/lwgeom_topo.c                       | 236 ++-----------------
 topology/postgis_topology.c                        |  45 ++++
 topology/sql/manage/ValidateTopology.sql.in        |  20 +-
 topology/test/regress/st_addedgemodface.sql        |  14 ++
 topology/test/regress/st_addedgemodface_expected   |  10 +-
 topology/test/regress/st_addedgenewfaces_expected  |   8 +-
 topology/test/regress/st_addisoedge_expected       |   2 +-
 topology/test/regress/st_changeedgegeom_expected   |   2 +-
 .../test/regress/topology_error_location_expected  |   2 +-
 topology/test/regress/validatetopology.sql         |  34 +++
 topology/test/regress/validatetopology_expected    |   2 +
 15 files changed, 560 insertions(+), 231 deletions(-)
hooks/post-receive
