[SCM] PostGIS branch master updated. 3.7.0rc1-95-g33904db91
git at osgeo.org
git at osgeo.org
Wed Oct 7 00:39:35 PDT 2026
the project "PostGIS".
via 33904db915bb3c2ff0f23a69f047bfdb5b93fcc0 (commit)
from 0264638140f7c516a5dca4387e7c742822488c3f (commit)
revisions in full, below.
commit 33904db915bb3c2ff0f23a69f047bfdb5b93fcc0
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Sep 30 11:06:26 2026 +0200
Add ST_IsSimpleDetail
Includes documentation and regress test
Relies on GEOS-3.16 new function GEOSisSimpleWithParams
Closes #6131
diff --git a/NEWS b/NEWS
index ce2670387..3c03c50db 100644
--- a/NEWS
+++ b/NEWS
@@ -32,6 +32,7 @@ PostgreSQL instance.
* New Features *
+ - #6132, ST_IsSimpleDetail (Sandro Santilli)
- #1124, #2935, #3033, #4658, #4659, [loader] Rework loader arguments:
shp2pgsql can create UNLOGGED tables and choose the feature id column
name, shp2pgsql --drop-table can emit DROP TABLE before prepare
diff --git a/doc/reference_accessor.xml b/doc/reference_accessor.xml
index a82717960..df968563b 100644
--- a/doc/reference_accessor.xml
+++ b/doc/reference_accessor.xml
@@ -2004,6 +2004,72 @@ FROM (SELECT 'LINESTRING(0 0,0 1,1 0,1 1,0 0)'::geometry AS geom) AS foo;</progr
</refsection>
</refentry>
+ <refentry xml:id="ST_IsSimpleDetail">
+ <refnamediv>
+ <refname>ST_IsSimpleDetail</refname>
+ <refpurpose>Report locations of self-intersection or self-tangency, if any.</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>simple_detail <function>ST_IsSimpleDetail</function></funcdef>
+ <paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
+ <paramdef choice="opt"><type>integer </type> <parameter>findAllLocations = 0</parameter></paramdef>
+ <paramdef choice="opt"><type>integer </type> <parameter>boundaryNodeRule = 1</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>Returns a <varname>simple_detail</varname> row,
+ containing a boolean (<varname>simple</varname>) stating if a geometry is simple
+ and a geometry (<varname>location</varname>) pointing out where it is non-simple.</para>
+ <para>
+The optional <varname>findAllLocations</varname> parameter can be set to 1 to report all non-simple locations, rather than just one.
+ </para>
+ <para>
+The optional <varname>boundaryNodeRule</varname> values are:
+ </para>
+ <itemizedlist>
+ <listitem><para><code>1</code>: <emphasis role="bold">OGC-Mod2</emphasis> - line endpoints are in the Boundary if they occur an odd number of times.
+ This is the rule defined by the OGC SFS standard, and is the default for <function>ST_Relate</function>.
+ </para></listitem>
+ <listitem><para><code>2</code>: <emphasis role="bold">Endpoint</emphasis> - all endpoints are in the Boundary.
+ <listitem><para><code>3</code>: <emphasis role="bold">MultivalentEndpoint</emphasis> - endpoints are in the Boundary if they occur more than once.
+ In other words, the boundary is all the "attached" or "inner" endpoints (but not the "unattached/outer" ones).
+ <listitem><para><code>4</code>: <emphasis role="bold">MonovalentEndpoint</emphasis> - endpoints are in the Boundary if they occur only once.
+ In other words, the boundary is all the "unattached" or "outer" endpoints.
+ </itemizedlist>
+ <para role="availability" conformance="3.7.0">Availability: 3.7.0</para>
+ </refsection>
+ <refsection>
+ <title>Examples</title>
+ <programlisting>SELECT ST_IsSimple('POLYGON((1 2,3 4,5 6,1 2))');</programlisting>
+<screen>f</screen>
+<programlisting>SELECT ST_IsSimple('LINESTRING(1 1,2 2,2 3.5,1 3,1 2,2 1)');</programlisting>
+<screen>f</screen>
+ </refsection>
+ <refsection>
+ <title>See Also</title>
+ <para><xref linkend="ST_IsSimple"/></para>
+ </refsection>
+ </refentry>
<refentry xml:id="ST_M">
<refnamediv>
<refname>ST_M</refname>
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 89d0501f5..9bd495bae 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -53,6 +53,7 @@
Datum isvalid(PG_FUNCTION_ARGS);
Datum isvalidreason(PG_FUNCTION_ARGS);
Datum isvaliddetail(PG_FUNCTION_ARGS);
+Datum issimpledetail(PG_FUNCTION_ARGS);
Datum buffer(PG_FUNCTION_ARGS);
Datum ST_Intersection(PG_FUNCTION_ARGS);
Datum convexhull(PG_FUNCTION_ARGS);
@@ -1782,6 +1783,92 @@ Datum issimple(PG_FUNCTION_ARGS)
PG_RETURN_BOOL(result);
+PG_FUNCTION_INFO_V1(issimpledetail);
+#if POSTGIS_GEOS_VERSION < 31600
+ lwpgerror("The GEOS version this PostGIS binary "
+ "was compiled against (%d) doesn't support "
+ "'GEOSisSimpleWithParams' function (3.16.0+ required)",
+ POSTGIS_GEOS_VERSION);
+ PG_RETURN_NULL();
+#else /* POSTGIS_GEOS_VERSION >= 31600 */
+ GSERIALIZED *geom = NULL;
+ const GEOSGeometry *g1 = NULL;
+ char *values[2]; /* simple bool, location geometry */
+ GEOSGeometry *geos_location = NULL;
+ LWGEOM *location = NULL;
+ int8_t simple = 0;
+ HeapTupleHeader result;
+ TupleDesc tupdesc;
+ HeapTuple tuple;
+ AttInMetadata *attinmeta;
+ int findAllLocations = 0;
+ int boundaryNodeRule = 0;
+ * Build a tuple description for a
+ * simple_detail tuple
+ get_call_result_type(fcinfo, 0, &tupdesc);
+ BlessTupleDesc(tupdesc);
+ * generate attribute metadata needed later to produce
+ * tuples from raw C strings
+ attinmeta = TupleDescGetAttInMetadata(tupdesc);
+ geom = PG_GETARG_GSERIALIZED_P(0);
+ findAllLocations = PG_GETARG_INT32(1);
+ boundaryNodeRule = PG_GETARG_INT32(2);
+ initGEOS(lwpgnotice, lwgeom_geos_error);
+ g1 = POSTGIS2GEOS(geom);
+ if ( ! g1 )
+ lwpgerror("Geometry could not be converted to GEOS: %s", lwgeom_geos_errmsg);
+ PG_RETURN_NULL();
+ GEOSisSimpleParams *params = GEOSisSimpleParams_create();
+ GEOSisSimpleParams_setBoundaryNodeRule(params, boundaryNodeRule);
+ GEOSisSimpleParams_setFindAllLocations(params, findAllLocations);
+ simple = GEOSisSimpleWithParams(g1, params, &geos_location);
+ GEOSisSimpleParams_destroy(params);
+ GEOSGeom_destroy((GEOSGeometry *)g1);
+ if (simple == 2)
+ /* NOTE: should only happen on OOM or similar */
+ lwpgerror("GEOSisSimpleDetail threw an exception!");
+ PG_RETURN_NULL(); /* never gets here */
+ if ( geos_location )
+ location = GEOS2LWGEOM(geos_location, GEOSHasZ(geos_location));
+ GEOSGeom_destroy(geos_location);
+ /* the boolean simplicity */
+ values[0] = simple ? "t" : "f";
+ /* the location */
+ values[1] = location ? lwgeom_to_hexwkb_buffer(location, WKB_EXTENDED) : 0;
+ tuple = BuildTupleFromCStrings(attinmeta, values);
+ result = (HeapTupleHeader) palloc(tuple->t_len);
+ memcpy(result, tuple->t_data, tuple->t_len);
+ heap_freetuple(tuple);
+ PG_RETURN_HEAPTUPLEHEADER(result);
+#endif /* POSTGIS_GEOS_VERSION >= 31400 */
PG_FUNCTION_INFO_V1(isring);
Datum isring(PG_FUNCTION_ARGS)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 2dbfd3e74..34d50836a 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -5043,6 +5043,18 @@ CREATE OR REPLACE FUNCTION ST_IsSimple(geometry)
LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
_COST_MEDIUM;
+-- Availability: 3.7.0
+CREATE TYPE simple_detail AS (
+ simple bool,
+ location geometry
+CREATE OR REPLACE FUNCTION ST_IsSimpleDetail(geom geometry, findAllLocations integer DEFAULT 0, boundaryNodeRule integer DEFAULT 1, OUT simple boolean, OUT location geometry)
+ AS 'MODULE_PATHNAME', 'issimpledetail'
+ LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+ _COST_MEDIUM;
-- Availability: 2.0.0
CREATE OR REPLACE FUNCTION ST_IsCollection(geometry)
RETURNS boolean
diff --git a/regress/core/issimpledetail.sql b/regress/core/issimpledetail.sql
new file mode 100644
index 000000000..00134a02d
--- /dev/null
+++ b/regress/core/issimpledetail.sql
@@ -0,0 +1,5 @@
+SELECT 't1', simple, ST_AsText(location) FROM ST_IsSimpleDetail('LINESTRING(0 0, 10 0)'::geometry);
+SELECT 't2', simple, ST_AsText(location) FROM ST_IsSimpleDetail('LINESTRING(0 0, 10 0, 5 10, 5 -10)'::geometry);
+SELECT 't3', simple, ST_AsText(location) FROM ST_IsSimpleDetail('LINESTRING(0 0, 10 0, 5 10, 5 -10, 2 2)'::geometry, 1);
+SELECT 't4', simple, ST_AsText(location) FROM ST_IsSimpleDetail('MULTILINESTRING((0 0, -10 0, -10 -10, 0 0),(0 0,10 0,10 10,0 0))'::geometry, 1, 1);
+SELECT 't5', simple, ST_AsText(location) FROM ST_IsSimpleDetail('MULTILINESTRING((0 0, -10 0, -10 -10, 0 0),(0 0,10 0,10 10,0 0))'::geometry, 1, 2);
diff --git a/regress/core/issimpledetail_expected b/regress/core/issimpledetail_expected
index 000000000..13ae6182e
--- /dev/null
+++ b/regress/core/issimpledetail_expected
@@ -0,0 +1,5 @@
+t1|t|
+t2|f|POINT(5 0)
+t3|f|MULTIPOINT((2.5 0),(5 0))
+t4|f|POINT(0 0)
+t5|t|
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index c64c329e3..3940b4cb9 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -196,6 +196,11 @@ ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" "<=" 31200),1)
$(top_srcdir)/regress/core/relate_bnr
endif
+ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 31600),1)
+ TESTS += \
+ $(top_srcdir)/regress/core/issimpledetail
+endif
ifeq ($(INTERRUPTTESTS),yes)
# Allow CI servers to configure --with-interrupt-tests
TESTS += \
Summary of changes:
NEWS | 1 +
doc/reference_accessor.xml | 66 +++++++++++++++++++++++++++
postgis/lwgeom_geos.c | 87 ++++++++++++++++++++++++++++++++++++
postgis/postgis.sql.in | 12 +++++
regress/core/issimpledetail.sql | 5 +++
regress/core/issimpledetail_expected | 5 +++
regress/core/tests.mk.in | 5 +++
7 files changed, 181 insertions(+)
create mode 100644 regress/core/issimpledetail.sql
create mode 100644 regress/core/issimpledetail_expected
hooks/post-receive
