[PostGIS] #6144: ST_CreateOverview function errors
trac at osgeo.org
Fri Oct 9 01:11:58 PDT 2026
Reporter: amorevosgeo | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.5
Component: postgis | Version: 3.5.x
Keywords: |
PostgreSQL and POSTGIS version:
PostgreSQL 16.10 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 11.5.0
20240719 (Red Hat 11.5.0-5), 64-bit
POSTGIS="3.5.0 d2c3ca4" [EXTENSION] PGSQL="160" GEOS="3.12.2-CAPI-1.18.2"
SFCGAL="SFCGAL 2.2.0, CGAL 5.6.2, BOOST 1.75.0" PROJ="9.6.2
NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/var/lib/pgsql/.local/share/proj
DATABASE_PATH=/usr/proj96/share/proj/proj.db" (compiled against PROJ
9.12.2) GDAL="GDAL 3.8.5, released 2024/04/02" LIBXML="2.9.13"
LIBJSON="0.14" RASTER
1. IF block:
IF sinfo.tw IS NULL or sinfo.tw IS NULL THEN
RAISE EXCEPTION 'cannot create overview without tilesize constraint,
try select AddRasterConstraints(''%'', ''%'');', tab::text, col;
END IF;
Here, "sinfo.**tw**" is compared with NULL twice. In the second case, it
should be "sinfo.**th**".
2. sql block:
sql := 'CREATE TABLE ' || quote_ident(sinfo.sch)
|| '.' || quote_ident(ttab)
|| ' AS SELECT ST_Retile($1, $2, $3, $4, $5, $6, $7) '
|| quote_ident(col);
EXECUTE sql USING tab, col, sinfo.ext,
sinfo.sfx * factor, sinfo.sfy * factor,
sinfo.tw, sinfo.th, algo;
Here, ST_Retile() has 7 args but USING has 8 args:
$1 => tab,[[BR]]
$2 => col,[[BR]]
$3 => sinfo.ext,[[BR]]
$4 => sinfo.sfx * factor,[[BR]]
$5 => sinfo.sfy * factor,[[BR]]
$6 => sinfo.tw,[[BR]]
$7 => sinfo.th,[[BR]]
$8 => algo
Without the eighth argument ("algo"), ST_Retile() will always use the
default value (text algo='NearestNeighbor').
These errors are also found in earlier versions (PostGIS 3.2.0 and
newest).
These errors are also found in current PostGIS repository:
https://gitea.osgeo.org/postgis/postgis/src/branch/master/raster/rt_pg/rtpostgis.sql.in
1. Row 8858.
2. Row 8869.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6144>
