[SCM] PostGIS branch master updated. 3.7.0rc1-103-g83e528504
git at osgeo.org
git at osgeo.org
Fri Oct 9 01:35:02 PDT 2026
the project "PostGIS".
via 83e52850466d7566ae88f0ee832829cbd71a3ce1 (commit)
from 585ba4895376d5300bf9ec08ea5aef1fd8a2b728 (commit)
revisions in full, below.
commit 83e52850466d7566ae88f0ee832829cbd71a3ce1
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Oct 9 07:44:29 2026 +0000
Use exact arithmetic for edge crossing checks, move it to topology
Fixes #6143, including unit and regression test for it
diff --git a/liblwgeom/cunit/cu_algorithm.c b/liblwgeom/cunit/cu_algorithm.c
index 9c2434e4a..e98b571c2 100644
--- a/liblwgeom/cunit/cu_algorithm.c
+++ b/liblwgeom/cunit/cu_algorithm.c
@@ -1880,158 +1880,6 @@ static void test_ptarray_simplify(void)
lwgeom_free(geom2);
-** Assert the intersection status of a pair of lines described by WKT.
-** The check must be symmetric, so both argument orders are verified.
-#define ASSERT_NONBOUNDARY_INTERSECTION(wkt1, wkt2, expected) \
- do \
- LWLINE *l1 = (LWLINE *)lwgeom_from_wkt(wkt1, LW_PARSER_CHECK_NONE); \
- LWLINE *l2 = (LWLINE *)lwgeom_from_wkt(wkt2, LW_PARSER_CHECK_NONE); \
- int exp = (expected); \
- CU_ASSERT_EQUAL(lwline_have_nonboundary_2d_intersection(l1, l2), exp); \
- CU_ASSERT_EQUAL(lwline_have_nonboundary_2d_intersection(l2, l1), exp); \
- lwline_free(l1); \
- lwline_free(l2); \
- } while (0)
-static void test_lwline_have_nonboundary_2d_intersection(void)
- /* Non intersecting lines */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(200 0, 400 0)", 0);
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 50, 100 50)", 0);
- /* The two lines would cross, but only outside of both segments */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(200 100, 200 -100)", 0);
- /* The two lines would touch, but only outside of both segments */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(-100 0, -50 0)", 0);
- /* Lines parallel and apart, also on a diagonal */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 100)", "LINESTRING(0 50, 100 150)", 0);
- /* Touching on a boundary point of both lines */
- /* End to start */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(100 0, 200 0)", 0);
- /* Start to start */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 0, 0 100)", 0);
- /* Start to end */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(100 0, 100 100)", 0);
- /* End to end */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(200 0, 100 0)", 0);
- /* Same point, opposite directions */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(100 0, 0 0)", "LINESTRING(0 0, -100 0)", 0);
- /* Collinear, touching end to start on a vertical line */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 0 100)", "LINESTRING(0 100, 0 200)", 0);
- /* Collinear, touching end to start on a diagonal */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 100)", "LINESTRING(100 100, 200 200)", 0);
- /* Collinear, touching on the interior vertex of the first line */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 50 0, 100 0)", "LINESTRING(100 0, 150 0)", 0);
- /* Diverging from the shared start point */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 0, 50 50)", 0);
- /* The endpoint of the second line is the start point of the first */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(-50 0, 0 0)", 0);
- /* Zero length second line, on the boundary of the first one */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(100 0, 100 0)", 0);
- /* Zero length lines, on the same point */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(50 50, 50 50)", "LINESTRING(50 50, 50 50)", 0);
- /* Closed line, touching another line on its boundary point */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0, 100 100, 0 100, 0 0)",
- "LINESTRING(0 0, -100 0)",
- 0);
- /* Crossing lines */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 10, 50 -10)", 1);
- /* Crossing on a diagonal */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 100)", "LINESTRING(0 100, 100 0)", 1);
- /* Crossing, but one line is zero length and on the other one interior */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 0, 50 0)", 1);
- /* Identical lines */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 0, 100 0)", 1);
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 50 0, 100 0)", "LINESTRING(0 0, 50 0, 100 0)", 1);
- /* Identical lines, opposite direction, on a vertical */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 0 100)", "LINESTRING(0 100, 0 0)", 1);
- /* Endpoint of one line on the interior of the other one */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 0, 50 50)", 1);
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 -50, 50 0)", 1);
- /* Zero length first line, on the interior of the second one */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(50 0, 50 0)", "LINESTRING(0 0, 100 0)", 1);
- /* Collinear, zero length second line on the interior of the first one */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 50 0, 100 0)", "LINESTRING(50 0, 50 0)", 1);
- /* Interior vertex of the first line, endpoint of the second one */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 50 0, 100 0)", "LINESTRING(50 0, 50 100)", 1);
- /* Interior vertex of the first line, interior of the second one */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 50 0, 100 0)", "LINESTRING(50 -50, 50 50)", 1);
- /* Collinear, overlapping for a positive length */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 0, 150 0)", 1);
- /* Collinear, overlapping for a positive length, opposite direction */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(100 0, 0 0)", "LINESTRING(-50 0, 50 0)", 1);
- /* Collinear, second line contained in the first one */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(25 0, 75 0)", 1);
- /* Collinear, overlapping on a diagonal */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 100)", "LINESTRING(50 50, 150 150)", 1);
- /* Collinear, overlapping on a vertical */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 0 100)", "LINESTRING(0 50, 0 200)", 1);
- /* Collinear, overlapping, the shared point is on the line boundary */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 0, 50 0)", 1);
- /* Collinear, overlapping across multiple segments */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(-50 0, 25 0, 150 0)", 1);
- /* Collinear, the second line is back and forth over the first one */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 0, 100 100, 50 0)", 1);
- /* Second line touches an interior vertex of first line */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0, 200 0)", "LINESTRING(100 0, 100 -50)", 1);
- ** Multiple intersections on the same pair of lines, the shared
- ** boundary point must not hide the non-boundary ones
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 0, 50 50, 50 -50, 0 0)", 1);
- "LINESTRING(0 0, 50 50, 100 0, 50 -50, 0 0)",
- 1);
- /* Z and M coordinates are ignored */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING Z (0 0 100, 100 0 200)",
- "LINESTRING M (50 10 1, 50 -10 2)",
- 1);
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING Z (0 0 1, 100 0 1)", "LINESTRING Z (0 0 2, 100 0 2)", 1);
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING ZM (0 0 1 1, 100 0 1 1)",
- "LINESTRING Z (100 0 9, 100 0 9)",
- 0);
- /* Empty lines have nothing to intersect */
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING EMPTY", "LINESTRING(0 0, 100 0)", 0);
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING EMPTY", 0);
- ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING EMPTY", "LINESTRING EMPTY", 0);
- /* Single point lines have no segment to intersect */
- POINT4D pt;
- LWLINE *single, *line;
- pt.x = 0;
- pt.y = 0;
- pt.z = 0;
- pt.m = 0;
- single = lwline_construct_empty(SRID_UNKNOWN, 0, 0);
- ptarray_append_point(single->points, &pt, LW_TRUE);
- line = (LWLINE*)lwgeom_from_wkt("LINESTRING(0 0, 100 0)", LW_PARSER_CHECK_NONE);
- CU_ASSERT_EQUAL( lwline_have_nonboundary_2d_intersection(single, line), 0 );
- CU_ASSERT_EQUAL( lwline_have_nonboundary_2d_intersection(line, single), 0 );
- CU_ASSERT_EQUAL( lwline_have_nonboundary_2d_intersection(single, single), 0 );
- lwline_free(single);
- lwline_free(line);
- /* NULL lines are handled gracefully */
- CU_ASSERT_EQUAL( lwline_have_nonboundary_2d_intersection(NULL, NULL), 0 );
** Used by test harness to register the tests in this file.
@@ -2071,5 +1919,4 @@ void algorithms_suite_setup(void)
PG_ADD_TEST(suite,test_lwpoly_construct_circle);
PG_ADD_TEST(suite,test_trim_bits);
PG_ADD_TEST(suite,test_lwgeom_remove_repeated_points);
- PG_ADD_TEST(suite,test_lwline_have_nonboundary_2d_intersection);
diff --git a/liblwgeom/cunit/cu_topo.c b/liblwgeom/cunit/cu_topo.c
index 490b95058..41dfe9cdf 100644
--- a/liblwgeom/cunit/cu_topo.c
+++ b/liblwgeom/cunit/cu_topo.c
@@ -13,6 +13,7 @@
#include "liblwgeom_internal.h"
#include "topo/liblwgeom_topo.h"
+#include "lwgeom_geos.h"
#include "cu_tester.h"
static LWGEOM *
@@ -47,9 +48,169 @@ test_lwt_IsTopoRingCCW_large_finite_coordinates(void)
lwgeom_free(geom);
+** Assert the non-boundary intersection status of a pair of lines
+** described by WKT, as reported by the exact arithmetic predicate
+** used by the topology edge crossing checks.
+** The check must be symmetric, so both argument orders are verified.
+#define ASSERT_NONBOUNDARY_INTERSECTION(wkt1, wkt2, expected) \
+ do \
+ LWLINE *l1 = (LWLINE *)lwgeom_from_text(wkt1); \
+ LWLINE *l2 = (LWLINE *)lwgeom_from_text(wkt2); \
+ int exp = (expected); \
+ CU_ASSERT_EQUAL(lwt_LineHaveNonBoundary2DIntersection(l1, l2), exp); \
+ CU_ASSERT_EQUAL(lwt_LineHaveNonBoundary2DIntersection(l2, l1), exp); \
+ lwline_free(l1); \
+ lwline_free(l2); \
+ } while (0)
+static void
+test_lwt_LineHaveNonBoundary2DIntersection(void)
+ /* Non intersecting lines */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(200 0, 400 0)", 0);
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 50, 100 50)", 0);
+ /* The two lines would cross, but only outside of both segments */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(200 100, 200 -100)", 0);
+ /* The two lines would touch, but only outside of both segments */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(-100 0, -50 0)", 0);
+ /* Lines parallel and apart, also on a diagonal */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 100)", "LINESTRING(0 50, 100 150)", 0);
+ /* Touching on a boundary point of both lines */
+ /* End to start */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(100 0, 200 0)", 0);
+ /* Start to start */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 0, 0 100)", 0);
+ /* Start to end */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(100 0, 100 100)", 0);
+ /* End to end */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(200 0, 100 0)", 0);
+ /* Same point, opposite directions */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(100 0, 0 0)", "LINESTRING(0 0, -100 0)", 0);
+ /* Collinear, touching end to start on a vertical line */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 0 100)", "LINESTRING(0 100, 0 200)", 0);
+ /* Collinear, touching end to start on a diagonal */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 100)", "LINESTRING(100 100, 200 200)", 0);
+ /* Collinear, touching on the interior vertex of the first line */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 50 0, 100 0)", "LINESTRING(100 0, 150 0)", 0);
+ /* Diverging from the shared start point */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 0, 50 50)", 0);
+ /* The endpoint of the second line is the start point of the first */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(-50 0, 0 0)", 0);
+ /* Zero length second line, on the boundary of the first one */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(100 0, 100 0)", 0);
+ /* Zero length lines, on the same point */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(50 50, 50 50)", "LINESTRING(50 50, 50 50)", 0);
+ /* Closed line, touching another line on its boundary point */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0, 100 100, 0 100, 0 0)",
+ "LINESTRING(0 0, -100 0)",
+ 0);
+ /* Crossing lines */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 10, 50 -10)", 1);
+ /* Crossing on a diagonal */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 100)", "LINESTRING(0 100, 100 0)", 1);
+ /* Crossing, but one line is zero length and on the other one interior */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 0, 50 0)", 1);
+ /* Identical lines */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 0, 100 0)", 1);
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 50 0, 100 0)", "LINESTRING(0 0, 50 0, 100 0)", 1);
+ /* Identical lines, opposite direction, on a vertical */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 0 100)", "LINESTRING(0 100, 0 0)", 1);
+ /* Endpoint of one line on the interior of the other one */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 0, 50 50)", 1);
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 -50, 50 0)", 1);
+ /* Zero length first line, on the interior of the second one */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(50 0, 50 0)", "LINESTRING(0 0, 100 0)", 1);
+ /* Collinear, zero length second line on the interior of the first one */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 50 0, 100 0)", "LINESTRING(50 0, 50 0)", 1);
+ /* Interior vertex of the first line, endpoint of the second one */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 50 0, 100 0)", "LINESTRING(50 0, 50 100)", 1);
+ /* Interior vertex of the first line, interior of the second one */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 50 0, 100 0)", "LINESTRING(50 -50, 50 50)", 1);
+ /* Collinear, overlapping for a positive length */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 0, 150 0)", 1);
+ /* Collinear, overlapping for a positive length, opposite direction */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(100 0, 0 0)", "LINESTRING(-50 0, 50 0)", 1);
+ /* Collinear, second line contained in the first one */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(25 0, 75 0)", 1);
+ /* Collinear, overlapping on a diagonal */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 100)", "LINESTRING(50 50, 150 150)", 1);
+ /* Collinear, overlapping on a vertical */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 0 100)", "LINESTRING(0 50, 0 200)", 1);
+ /* Collinear, overlapping, the shared point is on the line boundary */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 0, 50 0)", 1);
+ /* Collinear, overlapping across multiple segments */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(-50 0, 25 0, 150 0)", 1);
+ /* Collinear, the second line is back and forth over the first one */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(50 0, 100 100, 50 0)", 1);
+ /* Second line touches an interior vertex of first line */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0, 200 0)", "LINESTRING(100 0, 100 -50)", 1);
+ ** Multiple intersections on the same pair of lines, the shared
+ ** boundary point must not hide the non-boundary ones
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING(0 0, 50 50, 50 -50, 0 0)", 1);
+ "LINESTRING(0 0, 50 50, 100 0, 50 -50, 0 0)",
+ 1);
+ /* Z and M coordinates are ignored */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING Z (0 0 100, 100 0 200)",
+ "LINESTRING M (50 10 1, 50 -10 2)",
+ 1);
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING Z (0 0 1, 100 0 1)", "LINESTRING Z (0 0 2, 100 0 2)", 1);
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING ZM (0 0 1 1, 100 0 1 1)",
+ "LINESTRING Z (100 0 9, 100 0 9)",
+ 0);
+ /* Empty lines have nothing to intersect */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING EMPTY", "LINESTRING(0 0, 100 0)", 0);
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(0 0, 100 0)", "LINESTRING EMPTY", 0);
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING EMPTY", "LINESTRING EMPTY", 0);
+ /* Single point lines have no segment to intersect */
+ POINT4D pt;
+ LWLINE *single, *line;
+ pt.x = 0;
+ pt.y = 0;
+ pt.z = 0;
+ pt.m = 0;
+ single = lwline_construct_empty(SRID_UNKNOWN, 0, 0);
+ ptarray_append_point(single->points, &pt, LW_TRUE);
+ line = (LWLINE *)lwgeom_from_text("LINESTRING(0 0, 100 0)");
+ CU_ASSERT_EQUAL( lwt_LineHaveNonBoundary2DIntersection(single, line), 0 );
+ CU_ASSERT_EQUAL( lwt_LineHaveNonBoundary2DIntersection(line, single), 0 );
+ CU_ASSERT_EQUAL( lwt_LineHaveNonBoundary2DIntersection(single, single), 0 );
+ lwline_free(single);
+ lwline_free(line);
+ /* NULL lines are handled gracefully */
+ CU_ASSERT_EQUAL( lwt_LineHaveNonBoundary2DIntersection(NULL, NULL), 0 );
+ /* The pair of lines below is disjoint
+ * See https://trac.osgeo.org/postgis/ticket/6143 */
+ ASSERT_NONBOUNDARY_INTERSECTION("LINESTRING(-1e12 -1e12, -1 1e-5)", "LINESTRING(1e5 -1e5, -1 -1e-11)", 0);
void
topo_suite_setup(void)
CU_pSuite suite = CU_add_suite("topology", NULL, NULL);
PG_ADD_TEST(suite, test_lwt_IsTopoRingCCW_large_finite_coordinates);
+ PG_ADD_TEST(suite, test_lwt_LineHaveNonBoundary2DIntersection);
diff --git a/liblwgeom/liblwgeom_internal.h b/liblwgeom/liblwgeom_internal.h
index 179ac4460..0e8cd9384 100644
--- a/liblwgeom/liblwgeom_internal.h
+++ b/liblwgeom/liblwgeom_internal.h
@@ -481,7 +481,23 @@ int ptarray_raycast_intersections(const POINTARRAY *pa, const POINT2D *p, int *o
int ptarrayarc_raycast_intersections(const POINTARRAY *pa, const POINT2D *p, int *on_boundary);
int lwcompound_contains_point(const LWCOMPOUND *comp, const POINT2D *pt);
int lwgeom_contains_point(const LWGEOM *geom, const POINT2D *pt);
-int lwline_have_nonboundary_2d_intersection(const LWLINE *line1, const LWLINE *line2);
+* The ways two line segments can intersect.
+* Returned by the exact segment intersection test used by the
+* topology module (lwt_segment_intersection_exact in lwgeom_topo.c).
+enum LWSEGMENT_INTERSECTION
+ /* The segments do not intersect */
+ LWSEG_INTERSECT_NONE = 0,
+ /* The segments are collinear and overlap for a positive length */
+ LWSEG_INTERSECT_OVERLAP,
+ /* The segments cross at a point interior to both of them */
+ LWSEG_INTERSECT_CROSS,
+ /* The segments touch at a single point, an endpoint of one of them */
+ LWSEG_INTERSECT_POINT
* Split a line by a point and push components to the provided multiline.
diff --git a/liblwgeom/lwline.c b/liblwgeom/lwline.c
index d8398dfc0..50185f510 100644
--- a/liblwgeom/lwline.c
+++ b/liblwgeom/lwline.c
@@ -747,264 +747,3 @@ lwline_extend(const LWLINE *line, double distance_forward, double distance_backw
return lwline_construct(line->srid, NULL, opa);
-* The ways two line segments can intersect.
-* Returned by lwsegment_intersection()
-enum LWSEGMENT_INTERSECTION
- /* The segments do not intersect */
- LWSEG_INTERSECT_NONE = 0,
- /* The segments are collinear and overlap for a positive length */
- LWSEG_INTERSECT_OVERLAP,
- /* The segments cross at a point interior to both of them */
- LWSEG_INTERSECT_CROSS,
- /* The segments touch at a single point, an endpoint of one of them */
- LWSEG_INTERSECT_POINT
-* Does the point lie on the segment, endpoints included?
-* Unlike lw_pt_on_segment(), which excludes the segment endpoints.
-* @param A1 first point of the segment
-* @param A2 second point of the segment
-* @param P the point to test
-* @return LW_TRUE if P is on the A1/A2 segment
-static int
-lw_pt_on_segment_inclusive(const POINT2D *A1, const POINT2D *A2, const POINT2D *P)
- if ( lw_segment_side(A1, A2, P) != 0 )
- return LW_FALSE;
- /* The point is on the segment line, check it's within its extent */
- return (P->x >= FP_MIN(A1->x, A2->x) && P->x <= FP_MAX(A1->x, A2->x) &&
- P->y >= FP_MIN(A1->y, A2->y) && P->y <= FP_MAX(A1->y, A2->y));
-* How do the segment (P1,P2) and the segment (Q1,Q2) intersect?
-* Only 2D coordinates are considered. Zero length segments are supported,
-* they can only intersect at their single point.
-* @param P1 first point of the first segment
-* @param P2 second point of the first segment
-* @param Q1 first point of the second segment
-* @param Q2 second point of the second segment
-* @param ipoint storage for the intersection point, set when the returned
-* value is #LWSEG_INTERSECT_POINT
-* @return one of the #LWSEGMENT_INTERSECTION values
-static int
-lwsegment_intersection(const POINT2D *P1,
- const POINT2D *P2,
- const POINT2D *Q1,
- const POINT2D *Q2,
- POINT2D *ipoint)
- int s11, s12, s21, s22;
- int zeroP, zeroQ;
- double len2, tQ1, tQ2, tmin, tmax;
- zeroP = P2D_SAME_STRICT(P1, P2);
- zeroQ = P2D_SAME_STRICT(Q1, Q2);
- /* Zero length segments, if they intersect, do it on their single point */
- if ( zeroP || zeroQ )
- if ( zeroP && zeroQ )
- if ( ! P2D_SAME_STRICT(P1, Q1) )
- return LWSEG_INTERSECT_NONE;
- else if ( zeroP )
- if ( ! lw_pt_on_segment_inclusive(Q1, Q2, P1) )
- else
- if ( ! lw_pt_on_segment_inclusive(P1, P2, Q1) )
- *ipoint = zeroP ? *P1 : *Q1;
- return LWSEG_INTERSECT_POINT;
- /* Are both endpoints of the second segment on the same side of the first? */
- s11 = lw_segment_side(P1, P2, Q1);
- s12 = lw_segment_side(P1, P2, Q2);
- if ( (s11 > 0 && s12 > 0) || (s11 < 0 && s12 < 0) )
- /* Are both endpoints of the first segment on the same side of the second? */
- s21 = lw_segment_side(Q1, Q2, P1);
- s22 = lw_segment_side(Q1, Q2, P2);
- if ( (s21 > 0 && s22 > 0) || (s21 < 0 && s22 < 0) )
- * Both endpoints of the second segment are on the line of the first,
- * the segments are collinear and the intersection is their overlap.
- * Use the projection on the (P1,P2) vector as the segment parameter,
- * the overlap is the [0,len2] interval trimmed by the [tQ1,tQ2] one.
- if ( s11 == 0 && s12 == 0 )
- len2 = (P2->x - P1->x) * (P2->x - P1->x) +
- (P2->y - P1->y) * (P2->y - P1->y);
- tQ1 = (Q1->x - P1->x) * (P2->x - P1->x) +
- (Q1->y - P1->y) * (P2->y - P1->y);
- tQ2 = (Q2->x - P1->x) * (P2->x - P1->x) +
- (Q2->y - P1->y) * (P2->y - P1->y);
- tmin = FP_MAX(0.0, FP_MIN(tQ1, tQ2));
- tmax = FP_MIN(len2, FP_MAX(tQ1, tQ2));
- /* No overlap at all */
- if ( tmin > tmax )
- /* The segments are collinear and share a positive length */
- if ( tmin < tmax )
- return LWSEG_INTERSECT_OVERLAP;
- /* The segments touch on a single point, always a segment endpoint */
- if ( tmin == 0.0 )
- *ipoint = *P1;
- else if ( tmin == len2 )
- *ipoint = *P2;
- else if ( tmin == tQ1 )
- *ipoint = *Q1;
- else if ( tmin == tQ2 )
- *ipoint = *Q2;
- else
- /* Rounding fallback, the point is one of the four endpoints */
- double t = tmin / len2;
- ipoint->x = P1->x + t * (P2->x - P1->x);
- ipoint->y = P1->y + t * (P2->y - P1->y);
- * The segments are not collinear, they intersect on a single point.
- * When that point is not a vertex of either segment it is interior
- * to both of them.
- if ( lw_pt_on_segment_inclusive(P1, P2, Q1) )
- *ipoint = *Q1;
- if ( lw_pt_on_segment_inclusive(P1, P2, Q2) )
- *ipoint = *Q2;
- if ( lw_pt_on_segment_inclusive(Q1, Q2, P1) )
- *ipoint = *P1;
- if ( lw_pt_on_segment_inclusive(Q1, Q2, P2) )
- *ipoint = *P2;
- return LWSEG_INTERSECT_CROSS;
-* Is the point a boundary point of the line, that is one of its endpoints?
-* Those are the only points of a line that may be shared with another line
-* without requiring any of them to be split.
-* @param line the line to test the point against
-* @return LW_TRUE if P is the first or the last point of the line
-static int
-lwline_point_is_boundary(const LWLINE *line, const POINT2D *P)
- const POINT2D *start = getPoint2d_cp(line->points, 0);
- const POINT2D *end = getPoint2d_cp(line->points, line->points->npoints - 1);
- return P2D_SAME_STRICT(P, start) || P2D_SAME_STRICT(P, end);
-* Do two lines intersect anywhere but on a point shared by both of their
-* boundaries?
-* @param line1 first line
-* @param line2 second line
-* @return 1 if there's a non-boundary 2d intersection, 0 if there's NO
-* non-boundary 2d intersection
-int
-lwline_have_nonboundary_2d_intersection(const LWLINE *line1, const LWLINE *line2)
- const POINTARRAY *pa1, *pa2;
- uint32_t i1, i2;
- POINT2D ipoint;
- if ( !line1 || !line2 )
- return LW_FALSE;
- pa1 = line1->points;
- pa2 = line2->points;
- /* Lines without segments can't intersect anything */
- if ( !pa1 || !pa2 || pa1->npoints < 2 || pa2->npoints < 2 )
- return LW_FALSE;
- for (i1 = 0; i1 < pa1->npoints - 1; ++i1)
- const POINT2D *p1 = getPoint2d_cp(pa1, i1);
- const POINT2D *p2 = getPoint2d_cp(pa1, i1 + 1);
- for (i2 = 0; i2 < pa2->npoints - 1; ++i2)
- const POINT2D *q1 = getPoint2d_cp(pa2, i2);
- const POINT2D *q2 = getPoint2d_cp(pa2, i2 + 1);
- int inter;
- inter = lwsegment_intersection(p1, p2, q1, q2, &ipoint);
- /* Crossings and overlaps are never boundary only */
- if ( inter == LWSEG_INTERSECT_CROSS ||
- inter == LWSEG_INTERSECT_OVERLAP )
- return LW_TRUE;
- ** A touch on a point which is a boundary point of both lines
- ** is not a non-boundary intersection
- if ( inter == LWSEG_INTERSECT_POINT &&
- ( ! lwline_point_is_boundary(line1, &ipoint) ||
- ! lwline_point_is_boundary(line2, &ipoint) ) )
- return LW_TRUE;
- return LW_FALSE;
diff --git a/liblwgeom/topo/liblwgeom_topo.h b/liblwgeom/topo/liblwgeom_topo.h
index fb25c3a10..24967e6aa 100644
--- a/liblwgeom/topo/liblwgeom_topo.h
+++ b/liblwgeom/topo/liblwgeom_topo.h
@@ -1432,4 +1432,26 @@ LWGEOM* lwt_GetFaceGeometry(LWT_TOPOLOGY* topo, LWT_ELEMID face);
int lwt_IsTopoRingCCW(const POINTARRAY *pa);
+ * Do two lines intersect anywhere but on a point shared by both of their
+ * boundaries, evaluated with exact arithmetic?
+ * Only 2D coordinates are considered. The classification of each pair of
+ * segments is evaluated with exact rational arithmetic, so that floating
+ * point cancellation between far-away coordinates cannot make a disjoint
+ * pair of lines look like an intersecting one. Single-point
+ * intersections are always a vertex of one of the two segments: the
+ * point is copied verbatim, never computed, so its comparison against
+ * the line boundary points is exact. Lines with non-finite
+ * coordinates (NaN or Inf) are reported as intersecting, so the caller
+ * rejects them as crossing.
+ * @param line1 first line
+ * @param line2 second line
+ * @return 1 if there's a non-boundary 2d intersection, 0 if there's NO
+ * non-boundary 2d intersection
+int lwt_LineHaveNonBoundary2DIntersection(const LWLINE *line1, const LWLINE *line2);
#endif /* LIBLWGEOM_TOPO_H */
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 91efe0a20..3d8f7a8f3 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -625,6 +625,494 @@ lwt_AddIsoNode( LWT_TOPOLOGY* topo, LWT_ELEMID face,
return _lwt_AddIsoNode( topo, face, pt, skipISOChecks, 1 );
+* Exact sign of the 2D cross product (q-p1) x (p2-p1), that is the
+* orientation of q with respect to the directed segment (p1,p2).
+* The computation is carried out with exact rational arithmetic using
+* the GNU Multiple Precision Library, so the sign cannot be fooled by
+* floating point cancellation when the magnitude of the coordinates is
+* much larger than the distances between the segments.
+* The coordinates are expected to be finite, non-finite values are not
+* representable in the rationals.
+* @return -1, 0 or 1, the sign of the exact cross product
+static int
+lwt_segment_side_exact(const POINT2D *p1, const POINT2D *p2, const POINT2D *q)
+ mpq_t x1, y1, x2, y2, xq, yq;
+ mpq_t vx, vy, t1, t2, t3;
+ int side;
+ mpq_init(x1);
+ mpq_init(y1);
+ mpq_init(x2);
+ mpq_init(y2);
+ mpq_init(xq);
+ mpq_init(yq);
+ mpq_init(vx);
+ mpq_init(vy);
+ mpq_init(t1);
+ mpq_init(t2);
+ mpq_init(t3);
+ /* Exact conversion of the double coordinates to rationals */
+ mpq_set_d(x1, p1->x);
+ mpq_set_d(y1, p1->y);
+ mpq_set_d(x2, p2->x);
+ mpq_set_d(y2, p2->y);
+ mpq_set_d(xq, q->x);
+ mpq_set_d(yq, q->y);
+ /* v = p2 - p1 */
+ mpq_sub(vx, x2, x1);
+ mpq_sub(vy, y2, y1);
+ /* t3 = (qx-p1x) * (p2y-p1y) - (p2x-p1x) * (qy-p1y) */
+ mpq_sub(t1, xq, x1);
+ mpq_sub(t2, yq, y1);
+ mpq_mul(t3, t1, vy);
+ mpq_mul(t1, vx, t2);
+ mpq_sub(t3, t3, t1);
+ side = mpq_sgn(t3);
+ mpq_clear(x1);
+ mpq_clear(y1);
+ mpq_clear(x2);
+ mpq_clear(y2);
+ mpq_clear(xq);
+ mpq_clear(yq);
+ mpq_clear(vx);
+ mpq_clear(vy);
+ mpq_clear(t1);
+ mpq_clear(t2);
+ mpq_clear(t3);
+ return side;
+* Is P in the extent (bounding box) of the (A1,A2) segment?
+* All the comparisons are exact.
+static int
+lwt_pt_in_extent(const POINT2D *A1, const POINT2D *A2, const POINT2D *P)
+ return (P->x >= FP_MIN(A1->x, A2->x) && P->x <= FP_MAX(A1->x, A2->x) &&
+ P->y >= FP_MIN(A1->y, A2->y) && P->y <= FP_MAX(A1->y, A2->y));
+* Is P on the (A1,A2) segment, evaluated with exact arithmetic?
+* A point is on the segment when its exact orientation with respect
+* to it is zero and it is within its extent.
+static int
+lwt_pt_on_segment_exact(const POINT2D *A1, const POINT2D *A2, const POINT2D *P)
+ if ( lwt_segment_side_exact(A1, A2, P) != 0 )
+ return LW_FALSE;
+ /* The point is on the segment line, check it's within its extent */
+ return lwt_pt_in_extent(A1, A2, P);
+* How do the segment (P1,P2) and the segment (Q1,Q2) intersect?
+* All the orientation and projection tests are evaluated with exact
+* rational arithmetic, so the result is not affected by floating
+* point cancellation. Only finite coordinates are supported.
+* The intersection point, when the segments intersect on a single
+* point, is never computed: any such point is a vertex of one of
+* the two segments, so it is copied verbatim from the segment
+* coordinates into ipoint. Copying an existing double does not
+* round anything, the point compares exactly against the vertex it
+* came from.
+* @param P1 first point of the first segment
+* @param P2 second point of the first segment
+* @param Q1 first point of the second segment
+* @param Q2 second point of the second segment
+* @param ipoint storage for the intersection point, set when the returned
+* value is #LWSEG_INTERSECT_POINT
+* @return one of the #LWSEGMENT_INTERSECTION values
+static int
+lwt_segment_intersection_exact(const POINT2D *P1,
+ const POINT2D *P2,
+ const POINT2D *Q1,
+ const POINT2D *Q2,
+ POINT2D *ipoint)
+ mpq_t x1, y1, x2, y2, q1x, q1y, q2x, q2y;
+ mpq_t vx, vy, ux, uy;
+ mpq_t t1, t2, t3, t4;
+ mpq_t len2, tQ1, tQ2, tmin, tmax;
+ mpq_t zero;
+ int s11, s12, s21, s22;
+ int zeroP, zeroQ;
+ int ret;
+ zeroP = P2D_SAME_STRICT(P1, P2);
+ zeroQ = P2D_SAME_STRICT(Q1, Q2);
+ /* Zero length segments, if they intersect, do it on their single point */
+ if ( zeroP || zeroQ )
+ if ( zeroP && zeroQ )
+ if ( ! P2D_SAME_STRICT(P1, Q1) )
+ return LWSEG_INTERSECT_NONE;
+ else if ( zeroP )
+ if ( ! lwt_pt_on_segment_exact(Q1, Q2, P1) )
+ else
+ if ( ! lwt_pt_on_segment_exact(P1, P2, Q1) )
+ *ipoint = zeroP ? *P1 : *Q1;
+ return LWSEG_INTERSECT_POINT;
+ mpq_init(x1);
+ mpq_init(y1);
+ mpq_init(x2);
+ mpq_init(y2);
+ mpq_init(q1x);
+ mpq_init(q1y);
+ mpq_init(q2x);
+ mpq_init(q2y);
+ mpq_init(vx);
+ mpq_init(vy);
+ mpq_init(ux);
+ mpq_init(uy);
+ mpq_init(t1);
+ mpq_init(t2);
+ mpq_init(t3);
+ mpq_init(t4);
+ mpq_init(len2);
+ mpq_init(tQ1);
+ mpq_init(tQ2);
+ mpq_init(tmin);
+ mpq_init(tmax);
+ mpq_init(zero);
+ mpq_set_ui(zero, 0, 1);
+ mpq_set_d(x1, P1->x);
+ mpq_set_d(y1, P1->y);
+ mpq_set_d(x2, P2->x);
+ mpq_set_d(y2, P2->y);
+ mpq_set_d(q1x, Q1->x);
+ mpq_set_d(q1y, Q1->y);
+ mpq_set_d(q2x, Q2->x);
+ mpq_set_d(q2y, Q2->y);
+ /* v = P2 - P1 */
+ /* s11 = sign( (Q1-P1) x (P2-P1) ) */
+ mpq_sub(t1, q1x, x1);
+ mpq_sub(t2, q1y, y1);
+ mpq_mul(t4, vx, t2);
+ mpq_sub(t1, t3, t4);
+ s11 = mpq_sgn(t1);
+ /* s12 = sign( (Q2-P1) x (P2-P1) ) */
+ mpq_sub(t1, q2x, x1);
+ mpq_sub(t2, q2y, y1);
+ s12 = mpq_sgn(t1);
+ /* Are both endpoints of the second segment on the same side of the first? */
+ if ( (s11 > 0 && s12 > 0) || (s11 < 0 && s12 < 0) )
+ ret = LWSEG_INTERSECT_NONE;
+ goto cleanup;
+ /* u = Q2 - Q1 */
+ mpq_sub(ux, q2x, q1x);
+ mpq_sub(uy, q2y, q1y);
+ /* s21 = sign( (P1-Q1) x (Q2-Q1) ) */
+ mpq_sub(t1, x1, q1x);
+ mpq_sub(t2, y1, q1y);
+ mpq_mul(t3, t1, uy);
+ mpq_mul(t4, ux, t2);
+ s21 = mpq_sgn(t1);
+ /* s22 = sign( (P2-Q1) x (Q2-Q1) ) */
+ mpq_sub(t1, x2, q1x);
+ mpq_sub(t2, y2, q1y);
+ s22 = mpq_sgn(t1);
+ /* Are both endpoints of the first segment on the same side of the second? */
+ if ( (s21 > 0 && s22 > 0) || (s21 < 0 && s22 < 0) )
+ goto cleanup;
+ * Both endpoints of the second segment are on the line of the first,
+ * the segments are collinear and the intersection is their overlap.
+ * Use the projection on the (P1,P2) vector as the segment parameter,
+ * the overlap is the [0,len2] interval trimmed by the [tQ1,tQ2] one.
+ * All the computations are exact.
+ if ( s11 == 0 && s12 == 0 )
+ mpq_mul(len2, vx, vx);
+ mpq_mul(t1, vy, vy);
+ mpq_add(len2, len2, t1);
+ /* tQ1 = (Q1-P1) . (P2-P1) */
+ mpq_mul(t2, t1, vx);
+ mpq_sub(t1, q1y, y1);
+ mpq_add(tQ1, t2, t3);
+ /* tQ2 = (Q2-P1) . (P2-P1) */
+ mpq_sub(t1, q2y, y1);
+ mpq_add(tQ2, t2, t3);
+ /* tmin = max(0, min(tQ1, tQ2)) */
+ if ( mpq_cmp(tQ1, tQ2) <= 0 )
+ mpq_set(tmin, tQ1);
+ else
+ mpq_set(tmin, tQ2);
+ if ( mpq_cmp(tmin, zero) < 0 )
+ mpq_set(tmin, zero);
+ /* tmax = min(len2, max(tQ1, tQ2)) */
+ if ( mpq_cmp(tQ1, tQ2) > 0 )
+ mpq_set(tmax, tQ1);
+ else
+ mpq_set(tmax, tQ2);
+ if ( mpq_cmp(tmax, len2) > 0 )
+ mpq_set(tmax, len2);
+ /* No overlap at all */
+ if ( mpq_cmp(tmin, tmax) > 0 )
+ goto cleanup;
+ /* The segments are collinear and share a positive length */
+ if ( mpq_cmp(tmin, tmax) < 0 )
+ ret = LWSEG_INTERSECT_OVERLAP;
+ goto cleanup;
+ ** The segments touch on a single point. With non-zero-length
+ ** segments this is always one of the four segment endpoints:
+ ** tmin == tmax implies the touching parameter is 0, len2, tQ1
+ ** or tQ2, because otherwise tQ1 == tQ2 would make the second
+ ** segment zero-length. The point is copied verbatim from the
+ ** segment coordinates, never computed: no rounding of the
+ ** intersection point is involved.
+ if ( mpq_cmp(tmin, zero) == 0 )
+ *ipoint = *P1;
+ else if ( mpq_cmp(tmin, len2) == 0 )
+ *ipoint = *P2;
+ else if ( mpq_cmp(tmin, tQ1) == 0 )
+ *ipoint = *Q1;
+ else if ( mpq_cmp(tmin, tQ2) == 0 )
+ *ipoint = *Q2;
+ else
+ lwerror("%s: unreachable single-point collinear touch", __func__);
+ ret = LWSEG_INTERSECT_POINT;
+ goto cleanup;
+ * The segments are not collinear, they intersect on a single point.
+ * When that point is not a vertex of either segment it is interior
+ * to both of them. The on-segment tests are exact.
+ if ( s11 == 0 && lwt_pt_in_extent(P1, P2, Q1) )
+ *ipoint = *Q1;
+ goto cleanup;
+ if ( s12 == 0 && lwt_pt_in_extent(P1, P2, Q2) )
+ *ipoint = *Q2;
+ goto cleanup;
+ if ( s21 == 0 && lwt_pt_in_extent(Q1, Q2, P1) )
+ *ipoint = *P1;
+ goto cleanup;
+ if ( s22 == 0 && lwt_pt_in_extent(Q1, Q2, P2) )
+ *ipoint = *P2;
+ goto cleanup;
+ ret = LWSEG_INTERSECT_CROSS;
+cleanup:
+ mpq_clear(x1);
+ mpq_clear(y1);
+ mpq_clear(x2);
+ mpq_clear(y2);
+ mpq_clear(q1x);
+ mpq_clear(q1y);
+ mpq_clear(q2x);
+ mpq_clear(q2y);
+ mpq_clear(vx);
+ mpq_clear(vy);
+ mpq_clear(ux);
+ mpq_clear(uy);
+ mpq_clear(t1);
+ mpq_clear(t2);
+ mpq_clear(t3);
+ mpq_clear(t4);
+ mpq_clear(len2);
+ mpq_clear(tQ1);
+ mpq_clear(tQ2);
+ mpq_clear(tmin);
+ mpq_clear(tmax);
+ mpq_clear(zero);
+ return ret;
+ * All the orientation and projection tests are evaluated with exact
+ * rational arithmetic (see lwt_segment_intersection_exact above), so that
+ * floating point cancellation between far-away coordinates cannot make a
+ * disjoint pair of lines look like an intersecting one.
+ * Coordinates that are not finite (NaN or Inf) cannot be converted to
+ * rationals; lines with such coordinates are reported as having a
+ * non-boundary intersection, which makes the caller reject them as
+ * crossing.
+int
+lwt_LineHaveNonBoundary2DIntersection(const LWLINE *line1, const LWLINE *line2)
+ const POINTARRAY *pa1, *pa2;
+ uint32_t i1, i2;
+ POINT2D ipoint;
+ const POINT2D *s1, *e1, *s2, *e2;
+ if ( !line1 || !line2 )
+ return LW_FALSE;
+ pa1 = line1->points;
+ pa2 = line2->points;
+ /* Lines without segments can't intersect anything */
+ if ( !pa1 || !pa2 || pa1->npoints < 2 || pa2->npoints < 2 )
+ return LW_FALSE;
+ /* Non-finite coordinates cannot be converted to rationals: report
+ * them as intersecting, so the caller rejects the line as crossing */
+ for (i1 = 0; i1 < pa1->npoints; ++i1)
+ const POINT2D *p = getPoint2d_cp(pa1, i1);
+ if ( ! isfinite(p->x) || ! isfinite(p->y) )
+ return LW_TRUE;
+ for (i2 = 0; i2 < pa2->npoints; ++i2)
+ const POINT2D *p = getPoint2d_cp(pa2, i2);
+ return LW_TRUE;
+ /* Boundary points of the two lines */
+ s1 = getPoint2d_cp(pa1, 0);
+ e1 = getPoint2d_cp(pa1, pa1->npoints - 1);
+ s2 = getPoint2d_cp(pa2, 0);
+ e2 = getPoint2d_cp(pa2, pa2->npoints - 1);
+ for (i1 = 0; i1 < pa1->npoints - 1; ++i1)
+ const POINT2D *p1 = getPoint2d_cp(pa1, i1);
+ const POINT2D *p2 = getPoint2d_cp(pa1, i1 + 1);
+ for (i2 = 0; i2 < pa2->npoints - 1; ++i2)
+ const POINT2D *q1 = getPoint2d_cp(pa2, i2);
+ const POINT2D *q2 = getPoint2d_cp(pa2, i2 + 1);
+ int inter;
+ inter = lwt_segment_intersection_exact(p1, p2, q1, q2, &ipoint);
+ /* Crossings and overlaps are never boundary only */
+ if ( inter == LWSEG_INTERSECT_CROSS ||
+ inter == LWSEG_INTERSECT_OVERLAP )
+ return LW_TRUE;
+ ** A touch on a point which is a boundary point of both lines
+ ** is not a non-boundary intersection
+ if ( inter == LWSEG_INTERSECT_POINT &&
+ ( ! (P2D_SAME_STRICT(&ipoint, s1) || P2D_SAME_STRICT(&ipoint, e1)) ||
+ ! (P2D_SAME_STRICT(&ipoint, s2) || P2D_SAME_STRICT(&ipoint, e2)) ) )
+ return LW_TRUE;
+ return LW_FALSE;
* Check that an edge does not cross an existing node and
* does not have non-boundary intersection with existing edge
@@ -710,7 +1198,7 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
/* check if the edge has a non-boundary-boundary intersection with our edge */
- if ( lwline_have_nonboundary_2d_intersection(edge->geom, geom) )
+ if ( lwt_LineHaveNonBoundary2DIntersection(edge->geom, geom) )
char locinfo[128] = "";
_lwt_describe_intersection_point(lwline_as_lwgeom(edge->geom), lwline_as_lwgeom(geom), locinfo, sizeof(locinfo));
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index c96637b6e..43b5ad25e 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -5988,7 +5988,7 @@ Datum TopoEdgesHaveInteriorIntersection(PG_FUNCTION_ARGS)
PG_RETURN_NULL();
- ret = lwline_have_nonboundary_2d_intersection(lwgeom_as_lwline(lwgeom1), lwgeom_as_lwline(lwgeom2));
+ ret = lwt_LineHaveNonBoundary2DIntersection(lwgeom_as_lwline(lwgeom1), lwgeom_as_lwline(lwgeom2));
lwgeom_free(lwgeom1);
lwgeom_free(lwgeom2);
diff --git a/topology/test/regress/st_addedgemodface.sql b/topology/test/regress/st_addedgemodface.sql
index fdbb4dcf4..6384adb4c 100644
--- a/topology/test/regress/st_addedgemodface.sql
+++ b/topology/test/regress/st_addedgemodface.sql
@@ -556,6 +556,40 @@ SELECT NULL FROM ST_AddEdgeModFace('t6140', 1, 3, '0102000000030000005163B458843
SELECT 't6140', 'unexpected success', * FROM ST_AddEdgeModFace('t6140', 2, 3, '010200000002000000685E205B88333540B7363CF4E66A5140831D215B88333540107B41F4E66A5140');
ROLLBACK;
+-- Very far-away but disjoint edges
+-- See https://trac.osgeo.org/postgis/ticket/6143
+-- The two edges are disjoint: with exact arithmetic the distance
+-- between them is about 0.000070710678, so GEOS computes an empty
+-- intersection for the pair. The floating point implementation of
+-- the internal edge crossing check used to report an interior
+-- intersection, making ST_AddEdgeModFace reject the (valid) second
+-- edge with
+-- SQL/MM Spatial exception - non-boundary intersection
+-- with edge 1 at or near
+-- and, on commit d03570c85 (first implementation of the internal
+-- crossing check), crashing the backend while computing that
+-- "at or near" location.
+-- The predicate now evaluates the intersections with exact rational
+-- arithmetic, so the correct behaviour (edge 2 accepted) is what
+-- this test expects.
+BEGIN;
+SELECT 't6143', 'start';
+SELECT NULL FROM CreateTopology('t6143');
+SELECT NULL FROM ST_AddIsoNode('t6143', NULL, 'POINT(-1000000000000 -1000000000000)'); -- start node of edge 1
+SELECT NULL FROM ST_AddIsoNode('t6143', NULL, 'POINT(-1 0.0001)'); -- end node of edge 1
+SELECT NULL FROM ST_AddIsoEdge('t6143', 1, 2, 'LINESTRING(-1000000000000 -1000000000000, -1 0.0001)');
+SELECT NULL FROM ST_AddIsoNode('t6143', NULL, 'POINT(100000 -10000)'); -- start node of edge 2
+SELECT NULL FROM ST_AddIsoNode('t6143', NULL, 'POINT(-1 -0.00000000001)'); -- end node of edge 2
+-- This is the edge that used to be wrongly rejected
+SELECT 't6143', 'edge accepted', ST_AddEdgeModFace('t6143', 3, 4, 'LINESTRING(100000 -10000, -1 -0.00000000001)');
+ROLLBACK;
-- Cleanups
diff --git a/topology/test/regress/st_addedgemodface_expected b/topology/test/regress/st_addedgemodface_expected
index 4b92f3a5f..49a0bc322 100644
--- a/topology/test/regress/st_addedgemodface_expected
+++ b/topology/test/regress/st_addedgemodface_expected
@@ -205,4 +205,6 @@ F35|POLYGON((9 14,9 22,21 22,21 14,9 14))
ERROR: Backend error: Corrupted topology: ring of edge 58 is topologically non-closed
t6140|start
ERROR: SQL/MM Spatial exception - non-boundary intersection with edge 1 at or near POINT(21.2012993770454 69.6703463210545)
+t6143|start
+t6143|edge accepted|2
Topology 'city_data' dropped
Summary of changes:
liblwgeom/cunit/cu_algorithm.c | 153 -------
liblwgeom/cunit/cu_topo.c | 161 ++++++++
liblwgeom/liblwgeom_internal.h | 18 +-
liblwgeom/lwline.c | 261 ------------
liblwgeom/topo/liblwgeom_topo.h | 22 +
liblwgeom/topo/lwgeom_topo.c | 490 ++++++++++++++++++++++-
topology/postgis_topology.c | 2 +-
topology/test/regress/st_addedgemodface.sql | 34 ++
topology/test/regress/st_addedgemodface_expected | 2 +
9 files changed, 726 insertions(+), 417 deletions(-)
hooks/post-receive
