[PostGIS] #6124: 3.7.0rc1 docs build failure without error message
trac at osgeo.org
Sat Oct 17 00:20:35 PDT 2026
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 3.7.0
Component: documentation | Version: master
Resolution: fixed | Keywords:
Comment (by robe):
I revised to introduce a new switch --with-visual-examples
make html will work with or without that enabled, but will only generate
images if --with-visual-examples is passed in. I made this an opt-in, so
visual examples are only generated if explicitly asked for.
Also that secondary call of running the regress visual-examples step is no
longer needed but can still be done manually if you prefer.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6124#comment:7>
