[SCM] PostGIS branch master updated. 3.7.0rc1-114-ge6874cb2d
git at osgeo.org
git at osgeo.org
Sun Oct 18 18:39:19 PDT 2026
the project "PostGIS".
via e6874cb2d98630e44d58c54a18c47b48388b43fc (commit)
from 0c16c2c95ebe32c51a4efff9aa9f7a484c9d8a7c (commit)
revisions in full, below.
commit e6874cb2d98630e44d58c54a18c47b48388b43fc
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Mon Oct 19 01:13:08 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 100.0% (6065 of 6065 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index fe75dc124..96708718a 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -11,7 +11,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2026-10-17 07:16+0000\n"
-"PO-Revision-Date: 2026-10-16 10:39+0000\n"
+"PO-Revision-Date: 2026-10-19 01:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -4265,6 +4265,8 @@ msgid ""
", <xref linkend=\"GetNodeEdges\"/> <xref linkend=\"getfaceedges_returntype\"/"
msgstr ""
+", <xref linkend=\"GetNodeEdges\"/>, <xref "
+"linkend=\"getfaceedges_returntype\"/>"
#. Tag: refpurpose
#, no-c-format
@@ -9738,7 +9740,7 @@ msgstr "&sqlmm_compliant; SQL-MM 3: 5.1.8"
#. Tag: refpurpose
#, no-c-format
msgid "Report locations of self-intersection or self-tangency, if any."
-msgstr ""
+msgstr "自己交差または自己接触が存在する場合には、その位置を報告します。"
#. Tag: para
#, no-c-format
@@ -9747,6 +9749,9 @@ msgid ""
"(<varname>simple</varname>) stating if a geometry is simple and a geometry "
"(<varname>location</varname>) pointing out where it is non-simple."
msgstr ""
+"<varname>simple_detail</varname> 行を返します。これにはジオメトリーが単純かど"
+"うかを明示する真偽値 (<varname>simple</varname>) と、どこが単純でないかを指摘"
+"するジオメトリー (<varname>location</varname>) が含まれます。"
#. Tag: para
#, no-c-format
@@ -9754,11 +9759,13 @@ msgid ""
"The optional <varname>findAllLocations</varname> parameter can be set to 1 "
"to report all non-simple locations, rather than just one."
msgstr ""
+"任意パラメーター <varname>findAllLocations</varname> に 1を与えると、一つだけ"
+"でなく、すべての単純でない位置を報告します。"
#. Tag: para
#, no-c-format
msgid "The optional <varname>boundaryNodeRule</varname> values are:"
-msgstr ""
+msgstr "任意パラメーター <varname>boundaryNodeRule</varname> の値は次の通りです:"
#. Tag: para
#, no-c-format
@@ -44984,6 +44991,10 @@ msgid ""
"PostgreSQL instance; they are then generated automatically when building the "
"docs (or explicitly with `make -C regress visual-examples`)."
msgstr ""
+"この文書では例の図示はデフォルトでは行いません。例の図示を伴う文書をビルドす"
+"るにはコンフィギュアで `--with-visual-examples` を付けて、かつ動作している "
+"PostgreSQL インスタンスを用意します。例を示す図は文書ビルド時 (または `make -"
+"C regress visual-examples`と明示的に実行している時) に自動的に生成されます。"
#. Tag: title
#, no-c-format
@@ -45330,6 +45341,10 @@ msgid ""
"6124\">#6124</link> --with-visual-examples opt-in configure switch to build "
"dynamic images (Regina Obe)"
msgstr ""
+"<link xlink:href=\"https://git.osgeo.org/postgis/postgis/pull/806\">GT-806</"
+"link>, <link xlink:href=\"https://trac.osgeo.org/postgis/ticket/6124\">"
+"#6124</link> 動的画像構築を有効にするためのコンフィギュレーションの"
+"スイッチ --with-visual-examples (Regina Obe さん)"
#. Tag: title
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 21 ++++++++++++++++++---
1 file changed, 18 insertions(+), 3 deletions(-)
hooks/post-receive
