[SCM] PostGIS branch master updated. 3.7.0rc1-119-gdcc888996
Mon Oct 19 21:07:40 PDT 2026
the project "PostGIS".
       via  dcc88899636fbd8ad28c85e229bb2637c7f583a2 (commit)
       via  6a9387914570bcdcf6a4a4b4557a17a9c6abeb28 (commit)
      from  29d3ddac6f653edb4e74374607b2547e14ffcee5 (commit)
revisions in full, below.
commit dcc88899636fbd8ad28c85e229bb2637c7f583a2
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Oct 20 00:07:30 2026 -0400
    Prep for 3.7.0 release
diff --git a/NEWS b/NEWS
index 1751d30cc..97e97f46b 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
 PostGIS 3.7.0rc3
-2026/10/xx
+2026/10/19
 This version requires GEOS 3.10+, PostgreSQL 14-19beta3, Proj 6.1+, and libgmp.
 To take advantage of all postgis extension features, GEOS 3.15+ is needed.
diff --git a/Version.config b/Version.config
index 2e5a68cb5..de68a1315 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=7
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0rc3
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
commit 6a9387914570bcdcf6a4a4b4557a17a9c6abeb28
Author: Maksim Korotkov <m.korotkov at postgrespro.ru>
Date:   Mon Sep 7 18:06:41 2026 +0300
    loader: check column map allocations and fix cleanup
    Check the return of malloc/calloc in colmap_read and bail out with an
    error instead of dereferencing NULL on the pgfieldnames/dbffieldnames
    array and per-field string allocations. The column map arrays are now
    calloc'd so unused slots are NULL-initialized.
    Rework colmap_clean to be safe on partial state: early-return on NULL,
    free the field-name arrays unconditionally (free(NULL) is valid), and
    reset the map via colmap_init so the map is reusable and a subsequent
    ShpLoaderDestroy colmap_clean call stays safe. The calloc-failure path
    resets map->size first so the cleanup loop doesn't index a half-allocated
    array.
    Signed-off-by: Maksim Korotkov <m.korotkov at postgrespro.ru>
    Closes https://github.com/postgis/postgis/pull/1178 for 3.7.0
diff --git a/loader/shpcommon.c b/loader/shpcommon.c
index d8d0fd9d5..fd9433bbe 100644
--- a/loader/shpcommon.c
+++ b/loader/shpcommon.c
@@ -176,18 +176,21 @@ void
 colmap_clean(colmap *map)
 	int i;
-	if (map != NULL){
-		if (map->size)
+	if (map == NULL)
+		return;
+	if (map->size)
+		for (i = 0; i < map->size; i++)
-			for (i = 0; i < map->size; i++)
-				if (map->pgfieldnames[i]) free(map->pgfieldnames[i]);
-				if (map->dbffieldnames[i]) free(map->dbffieldnames[i]);
-			free(map->pgfieldnames);
-			free(map->dbffieldnames);
+			free(map->pgfieldnames[i]);
+			free(map->dbffieldnames[i]);
+	free(map->pgfieldnames);
+	free(map->dbffieldnames);
+	colmap_init(map);
 const char *
@@ -237,13 +240,30 @@ colmap_read(const char *filename, colmap *map, char *errbuf, size_t errbuflen)
     return 0;
+  /* Release any prior contents and reset the map so this call is safe to
+   * reuse on the same struct (and so ++map->size below starts from zero) */
+  colmap_clean(map);
   /* First count how many columns we have... */
   while (fgets(linebuffer, 1024, fptr) != NULL) ++map->size;
+  if (!map->size)
+    fclose(fptr);
+    return 1;
   /* Now we know the final size, allocate the arrays and load the data */
   fseek(fptr, 0, SEEK_SET);
-  map->pgfieldnames = (char **)malloc(sizeof(char *) * map->size);
-  map->dbffieldnames = (char **)malloc(sizeof(char *) * map->size);
+  map->pgfieldnames = (char **)calloc(map->size, sizeof(char *));
+  map->dbffieldnames = (char **)calloc(map->size, sizeof(char *));
+  if (!map->pgfieldnames || !map->dbffieldnames)
+    map->size = 0;
+    fclose(fptr);
+    snprintf(errbuf, errbuflen, _("ERROR: Unable to allocate memory for column map file %s"), filename);
+    return 0;
   /* Read in a line at a time... */
   curmapsize = 0;
@@ -256,6 +276,13 @@ colmap_read(const char *filename, colmap *map, char *errbuf, size_t errbuflen)
     /* Allocate memory and copy the string ensuring it is terminated */
     map->pgfieldnames[curmapsize] = malloc(fieldnamesize + 1);
+    if (!map->pgfieldnames[curmapsize])
+      fclose(fptr);
+      return 0;
     strncpy(map->pgfieldnames[curmapsize], tmpstr, fieldnamesize);
     map->pgfieldnames[curmapsize][fieldnamesize] = '\0';
@@ -268,6 +295,13 @@ colmap_read(const char *filename, colmap *map, char *errbuf, size_t errbuflen)
     map->dbffieldnames[curmapsize] = malloc(fieldnamesize + 1);
+    if (!map->dbffieldnames[curmapsize])
+      fclose(fptr);
+      return 0;
     strncpy(map->dbffieldnames[curmapsize], tmpstr, fieldnamesize);
     map->dbffieldnames[curmapsize][fieldnamesize] = '\0';
Summary of changes:
 NEWS               |  2 +-
 Version.config     |  2 +-
 loader/shpcommon.c | 56 +++++++++++++++++++++++++++++++++++++++++++-----------
 3 files changed, 47 insertions(+), 13 deletions(-)
hooks/post-receive
