[PostGIS] #6146: BOX3D_combine () crashes on null argument
trac at osgeo.org
Tue Oct 20 04:20:49 PDT 2026
Reporter: alexanderlaw | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.7.1
Component: postgis | Version: master
Keywords: |
The following script:
CREATE TABLE t(x box2d); INSERT INTO t VALUES (NULL);
SELECT st_combinebbox(CASE WHEN x IS NULL THEN box3d(x) END,
NULL::geometry) FROM t;
triggers a server crash:
INSERT 0 1
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
Core was generated by `postgres: law pgis_test [local] SELECT '.
Program terminated with signal SIGSEGV, Segmentation fault.
(gdb) bt
#0 memcpy (__len=56, __src=0x1, __dest=0x6130a02db4b0) at
/usr/include/x86_64-linux-gnu/bits/string_fortified.h:29
#1 BOX3D_combine (fcinfo=0x6130a02d51a8) at lwgeom_box3d.c:518
#2 0x0000613076e3ccd9 in ExecInterpExpr (state=0x6130a02d4c40,
econtext=0x6130a02d47d8, isnull=0x0) at execExprInterp.c:936
#16 0x000061307716cff8 in exec_simple_query (
query_string=0x6130a0190020 "SELECT st_combinebbox(CASE WHEN x IS NULL
THEN box3d(x) END, NULL::geometry) FROM t;") at postgres.c:1290
This function checks argument 1 for null, but not argument 0:
PG_FUNCTION_INFO_V1(BOX3D_combine);
Datum BOX3D_combine(PG_FUNCTION_ARGS)
BOX3D *box = (BOX3D *)PG_GETARG_POINTER(0);
GSERIALIZED *geom = PG_ARGISNULL(1) ? NULL : (GSERIALIZED
*)PG_DETOAST_DATUM(PG_GETARG_DATUM(1));
/* Null geometry but non-null box, return the box */
else if (!geom)
result = palloc(sizeof(BOX3D));
memcpy(result, box, sizeof(BOX3D));
PG_RETURN_POINTER(result);
SELECT postgis_full_version()
POSTGIS="3.7.0rc3 3.7.0rc1-119-gdcc888996" [EXTENSION] PGSQL="190"
GEOS="3.12.1-CAPI-1.18.1" PROJ="9.4.0 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=...
DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 9.4.0)
LIBXML="2.9.14" LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0
(Internal)"
Discovered by SQLsmith test run at Databricks.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6146>
