[SCM] PostGIS branch master updated. 3.7.0rc1-19-ga767a934f
Tue Sep 1 08:59:50 PDT 2026
the project "PostGIS".
       via  a767a934f3cb14b3f1078846db56772ea31b056b (commit)
      from  1863d42cf91aaf5de7d78071f834a4836b1e43d8 (commit)
revisions in full, below.
commit a767a934f3cb14b3f1078846db56772ea31b056b
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Sep 1 10:31:23 2026 -0400
    DOC BUILDING warnings
     - If doc building is requested, note that Python 3 is now required
     - Fix typo in configure when checking for xmlint it gives a note about xmlcatalog
     - Fix the README.postgis and docs to note all dependencies
diff --git a/NEWS b/NEWS
index 8fa9ba9cb..fa9879877 100644
--- a/NEWS
+++ b/NEWS
@@ -1,3 +1,174 @@
+PostGIS 3.7.0rc2
+2026/xx/xx
+This version requires GEOS 3.10+, PostgreSQL 14-19beta1, Proj 6.1+, and libgmp.
+To take advantage of all postgis extension features, GEOS 3.15+ is needed.
+To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed.
+* Breaking Changes *
+ - #5688, [topology] topology building functions now interpret tolerance 0
+          (old default) to really mean 0 and want -1 (new default) to mean
+          "use topology precision" (Sandro Santilli)
+ - #6024, Remove support for PostgreSQL 12 and 13 (Regina Obe)
+ - #6040, ST_GeoHash round trip through ST_GeomFromGeoHash (Paul Ramsey)
+ - #6053, [address_standardizer] Extension removed and moved to
+          https://github.com/postgis/address_standardizer (Paul Ramsey)
+ - #6052, [tiger_geocoder] Extension removed and moved to
+          https://git.osgeo.org/postgis/postgis_tiger_geocoder (Regina Obe)
+ - #6079, Remove support for GEOS < 3.10 (Sandro Santilli)
+ - #1793, Remove ST_MemCollect aggregate (Darafei Praliaskouski)
+ - GH-848, CG_AlphaShape now returns a MultiPolygon (Jean Felder)
+ - [docs] Python 3 and an SVG rasterizer (rsvg-convert preferred,
+          GraphicsMagick or ImageMagick supported) now required for doc
+          building (Darafei Praliaskouski)
+* New Features *
+ - #1124, #2935, #3033, #4658, #4659, [loader] Rework loader arguments:
+          shp2pgsql can create UNLOGGED tables and choose the feature id column
+          name, shp2pgsql --drop-table can emit DROP TABLE before prepare
+          output, raster2pgsql/shp2pgsql expose loader actions as long options,
+          both loaders accept long aliases for existing options, and
+          --if-not-exists makes creation actions idempotent
+          (Darafei Praliaskouski)
+ - #4208, Add single-geometry variants of ST_MaxDistance and ST_LongestLine
+ - [topology] FindVertexSegmentPairsBelowDistance function (Sandro Santilli)
+ - ST_CoverageEdges, returns MultiLinestring of distinct shared edges in
+          polygonal coverage (Paul Ramsey)
+ - ST_MinimumSpanningTree, window function to calculate MST (Paul Ramsey)
+ - #5993, [topology] Add max_edges parameter to TopoGeo_AddLinestring
+          (Sandro Santilli)
+ - #6001, support MultiLineString in ST_MakeLine (Paul Ramsey)
+ - #2858, ST_MMin and ST_MMax (Paul Ramsey)
+ - #5941, [raster] Support GDT_Float16 pixel type (Darafei Praliaskouski)
+ - #5992, Optimize GiST index for repeated edge subdivision in topology (Darafei Praliaskouski)
+ - #5702, Allow the compiler to detect the parallelism -flto=auto (Darafei Praliaskouski)
+ - #4798, ST_AsGeoJSON warns about duplicate property keys (Darafei Praliaskouski)
+ - #4222, [raster] ST_DumpAsPolygons honours PostgreSQL interrupts (Darafei Praliaskouski)
+ - #5889, [topology] Include representative locations in topology build errors (Darafei Praliaskouski)
+ - #2614, Use GEOSPreparedDistance and caching to accelerate ST_DWithin (Paul Ramsey)
+ - GH-839, ST_Multi support for TIN and surfaces (Loïc Bartoletti)
+ - #4398, Add ST_CatmullSmoothing smoothes but retains original vertices (Paul Ramsey)
+ - #4560, ST_3DInterpolatePoint for M interpolation from XYZ inputs (Paul Ramsey)
+ - #1291, ST_MakePolygon support for curved rings (Darafei Praliaskouski)
+ - GT-270, Add NURBSCurve (Loïc Bartoletti)
+ - #2863, Add ST_XSize, ST_YSize, ST_ZSize, and ST_MSize dimension helpers
+* Enhancements *
+ - #2045, pgsql2shp query dumps no longer require temporary table
+          privileges (Darafei Praliaskouski)
+ - #1577, [loader] Report unsupported .zip archive input before trying
+          to open shapefile sidecar files (Darafei Praliaskouski)
+ - #3158, Move geometry and geography typmod bit helpers out of the
+          public liblwgeom header (Darafei Praliaskouski)
+ - #3776, [raster] Keep distinct 32-bit integer pixel values separate in
+          ST_DumpAsPolygons (Darafei Praliaskouski)
+ - #4678, [raster] Move st_sum4ma neighborhood callback to C
+ - #2116, [raster] Add ST_Value nearest-neighbor boundary options
+ - #2804, #4315, [raster] Support two-argument ST_MapAlgebra callbacks
+          and pass callback call data as actual arguments (Darafei Praliaskouski)
+ - #6062, [topology] Stop using recursive snapping, for improved robustness (Sandro Santilli)
+ - #6065, Improved winding order computation robustness for rings having collapsed elements
+          (Sandro Santilli)
+ - #2137, [raster] Reuse matching source raster overviews in raster2pgsql -l
+ - #4749, Use point-in-polygon predicate fast paths for point-only
+          GeometryCollections (Darafei Praliaskouski)
+ - #2807, [raster] Preserve missing NODATA values in ST_MapAlgebra outputs
+ - #2832, [raster] Avoid padding single-tile raster2pgsql overviews
+          when padding is not requested (Darafei Praliaskouski)
+ - #2623, Generate a pgsql2shp GID field when exporting geometry-only
+          shapefiles (Darafei Praliaskouski)
+ - #2850, Preserve pgsql2shp numeric precision and scale in DBF metadata
+ - Build PostgreSQL extension modules with `-fno-semantic-interposition` when
+          available so LTO can optimize same-DSO calls to exported PostGIS
+          entry points directly instead of routing through the module PLT; in
+          a local PostgreSQL 18 `pgbench` microbenchmark over 100k four-point
+          groups this reduced `ST_Collect` aggregate latency by about 4%
+ - #5973, Install PostGIS utilities under `pg_config --bindir` by default
+          and document `pg_config`-derived install paths more accurately
+ - #2808, Clarify postgis_full_version() output when installed component
+          scripts are newer than core scripts (Darafei Praliaskouski)
+ - #2838, Emit valid X3D Coordinate nodes for 2D polygon output
+ - GH-899, [raster] Honor PostgreSQL interrupts in long-running GDAL
+          progress callbacks (Darafei Praliaskouski)
+ - #6073, #6074, Stabilize geography LRS endpoint interpolation and pole
+          centroid regressions on 32-bit systems (Darafei Praliaskouski)
+ - #2583, Preserve Z/ZM dimensional qualifiers in ST_AsEWKT output for TIN
+ - #4616, Detect pgsql2shp query keywords case-insensitively
+ - #1986, ST_GeomFromGML support for GML ArcString and curved polygon rings
+          GeometryCollections, including ST_Disjoint (Darafei Praliaskouski)
+ - #3676, Mark geometry and geography btree comparison support functions
+          as leakproof (Darafei Praliaskouski)
+ - GH-875, Allow ST_OrderingEquals joins to use hash and merge join plans
+ - #1168, [raster] Support curved geometry inputs in ST_AsRaster
+ - #1416, ST_AsX3D outputs NURBSCURVE as X3D NurbsCurve
+          and linearizes other curve geometries
+ - #3705, ST_AsX3D outputs valid coordinate nodes for 2D multi-geometries
+          and GeometryCollections (Darafei Praliaskouski)
+ - GT-484, Use column-level SELECT privileges for metadata views
+          (Arthur Bazin)
+ - #1408, #2386, #2557, #2805, #2898, #3743, #4323, #4332, #4385, #5109,
+          #5532, #5593, #5638, #5645, #5950, #6022, #6082, GH-1161, GT-584,
+          Numerous doc enhancements (Darafei Praliaskouski)
+* Bug Fixes *
+ - Fix WKB and TWKB parser resource exhaustion on malformed input
+ - #6038, Avoid stale relation lookups in geometry_columns after topology
+          objects are dropped (Darafei Praliaskouski)
+ - #5487, Improve error detail for repeated upgrades after an incomplete
+          deprecated-function cleanup (Darafei Praliaskouski)
+ - #5975, Initialize skipped union-find cluster ids deterministically
+ - #5904, [topology] Avoid MinGW format warnings when logging topology ids
+ - GH-888, [sfcgal] Avoid stale detoasted geometry access in
+          CG_Visibility empty-input handling for SFCGAL < 2.2
+ - #3179, Mark truncated libpgcommon PostgreSQL messages instead of silently
+          dropping the tail (Darafei Praliaskouski)
+ - #6003, Avoid size_t formats in liblwgeom logging/error wrappers for
+          MinGW builds (Darafei Praliaskouski)
+ - GH-886, ST_ClusterRelateWin validates NULL relate matrices before
+          detoasting them (Darafei Praliaskouski)
+ - GH-889, ST_Relate pattern inversion avoids out-of-bounds access on
+          short DE-9IM patterns (Darafei Praliaskouski)
+ - GH-890, Avoid GIDX BRIN summary merges across mismatched dimensions
+ - #5959, Prevent histogram target overflow when analysing massive tables (Darafei Praliaskouski)
+ - #6080, Avoid out-of-bounds hex WKB lookup for high-bit input bytes
+ - #4828, geometry_columns handles NOT VALID SRID checks without errors (Darafei Praliaskouski)
+ - #6048, [raster] ST_Clip no longer crashes when clipping sparse band
+          selections (Darafei Praliaskouski)
+ - GH-894, [raster] Fix Float16 import, mixed nodata warping,
+          band replacement cleanup, GDAL credential redaction, and Python
+          GDAL compatibility (Darafei Praliaskouski)
 PostGIS 3.7.0rc1
 2026/08/24
 This version requires GEOS 3.10+, PostgreSQL 14-19beta2, Proj 6.1+, libgmp.
@@ -194,170 +365,6 @@ These are only changes since 3.7.0alpha1.
-PostGIS 3.7.0dev
-2026/xx/xx
-This version requires GEOS 3.10+, PostgreSQL 14-19beta1, Proj 6.1+, libgmp.
-To take advantage of all features postgis extension features, GEOS 3.15+ is needed.
-To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed.
-* Breaking Changes *
- - #5688, [topology] topology building functions now interpret tolerance 0
-          (old default) to really mean 0 and want -1 (new default) to mean
-          "use topology precision" (Sandro Santilli)
- - #6024, Remove support for PostgreSQL 12 and 13 (Regina Obe)
- - #6040, ST_GeoHash round trip through ST_GeomFromGeoHash (Paul Ramsey)
- - #6053, [address_standardizer] Extension removed and moved to
-          https://github.com/postgis/address_standardizer (Paul Ramsey)
- - #6052, [tiger_geocoder] Extension removed and moved to
-          https://git.osgeo.org/postgis/postgis_tiger_geocoder (Regina Obe)
- - #6079, Remove support for GEOS < 3.10 (Sandro Santilli)
- - #1793, Remove ST_MemCollect aggregate (Darafei Praliaskouski)
- - GH-848, CG_AlphaShape now returns a MultiPolygon (Jean Felder)
-* New Features *
- - #1124, #2935, #3033, #4658, #4659, [loader] Rework loader arguments:
-          shp2pgsql can create UNLOGGED tables and choose the feature id column
-          name, shp2pgsql --drop-table can emit DROP TABLE before prepare
-          output, raster2pgsql/shp2pgsql expose loader actions as long options,
-          both loaders accept long aliases for existing options, and
-          --if-not-exists makes creation actions idempotent
-          (Darafei Praliaskouski)
- - #4208, Add single-geometry variants of ST_MaxDistance and ST_LongestLine
- - [topology] FindVertexSegmentPairsBelowDistance function (Sandro Santilli)
- - ST_CoverageEdges, returns MultiLinestring of distinct shared edges in
-          polygonal coverage (Paul Ramsey)
- - ST_MinimumSpanningTree, window function to calculate MST (Paul Ramsey)
- - #5993, [topology] Add max_edges parameter to TopoGeo_AddLinestring
-          (Sandro Santilli)
- - #6001, support MultiLineString in ST_MakeLine (Paul Ramsey)
- - #2858, ST_MMin and ST_MMax (Paul Ramsey)
- - #5941, [raster] Support GDT_Float16 pixel type (Darafei Praliaskouski)
- - #5992, Optimize GiST index for repeated edge subdivision in topology (Darafei Praliaskouski)
- - #5702, Allow the compiler to detect the parallelism -flto=auto (Darafei Praliaskouski)
- - #4798, ST_AsGeoJSON warns about duplicate property keys (Darafei Praliaskouski)
- - #4222, [raster] ST_DumpAsPolygons honours PostgreSQL interrupts (Darafei Praliaskouski)
- - #5889, [topology] Include representative locations in topology build errors (Darafei Praliaskouski)
- - #2614, Use GEOSPreparedDistance and caching to accelerate ST_DWithin (Paul Ramsey)
- - GH-839, ST_Multi support for TIN and surfaces (Loïc Bartoletti)
- - #4398, Add ST_CatmullSmoothing smoothes but retains original vertices (Paul Ramsey)
- - #4560, ST_3DInterpolatePoint for M interpolation from XYZ inputs (Paul Ramsey)
- - #1291, ST_MakePolygon support for curved rings (Darafei Praliaskouski)
- - GT-270, Add NURBSCurve (Loïc Bartoletti)
- - #2863, Add ST_XSize, ST_YSize, ST_ZSize, and ST_MSize dimension helpers
-* Enhancements *
- - #2045, pgsql2shp query dumps no longer require temporary table
-          privileges (Darafei Praliaskouski)
- - #1577, [loader] Report unsupported .zip archive input before trying
-          to open shapefile sidecar files (Darafei Praliaskouski)
- - #3158, Move geometry and geography typmod bit helpers out of the
-          public liblwgeom header (Darafei Praliaskouski)
- - #3776, [raster] Keep distinct 32-bit integer pixel values separate in
-          ST_DumpAsPolygons (Darafei Praliaskouski)
- - #4678, [raster] Move st_sum4ma neighborhood callback to C
- - #2116, [raster] Add ST_Value nearest-neighbor boundary options
- - #2804, #4315, [raster] Support two-argument ST_MapAlgebra callbacks
-          and pass callback call data as actual arguments (Darafei Praliaskouski)
- - #6062, [topology] Stop using recursive snapping, for improved robustness (Sandro Santilli)
- - #6065, Improved winding order computation robustness for rings having collapsed elements
-          (Sandro Santilli)
- - #2137, [raster] Reuse matching source raster overviews in raster2pgsql -l
- - #4749, Use point-in-polygon predicate fast paths for point-only
-          GeometryCollections (Darafei Praliaskouski)
- - #2807, [raster] Preserve missing NODATA values in ST_MapAlgebra outputs
- - #2832, [raster] Avoid padding single-tile raster2pgsql overviews
-          when padding is not requested (Darafei Praliaskouski)
- - #2623, Generate a pgsql2shp GID field when exporting geometry-only
-          shapefiles (Darafei Praliaskouski)
- - #2850, Preserve pgsql2shp numeric precision and scale in DBF metadata
- - Build PostgreSQL extension modules with `-fno-semantic-interposition` when
-          available so LTO can optimize same-DSO calls to exported PostGIS
-          entry points directly instead of routing through the module PLT; in
-          a local PostgreSQL 18 `pgbench` microbenchmark over 100k four-point
-          groups this reduced `ST_Collect` aggregate latency by about 4%
- - #5973, Install PostGIS utilities under `pg_config --bindir` by default
-          and document `pg_config`-derived install paths more accurately
- - #2808, Clarify postgis_full_version() output when installed component
-          scripts are newer than core scripts (Darafei Praliaskouski)
- - #2838, Emit valid X3D Coordinate nodes for 2D polygon output
- - GH-899, [raster] Honor PostgreSQL interrupts in long-running GDAL
-          progress callbacks (Darafei Praliaskouski)
- - #6073, #6074, Stabilize geography LRS endpoint interpolation and pole
-          centroid regressions on 32-bit systems (Darafei Praliaskouski)
- - #2583, Preserve Z/ZM dimensional qualifiers in ST_AsEWKT output for TIN
- - #4616, Detect pgsql2shp query keywords case-insensitively
- - #1986, ST_GeomFromGML support for GML ArcString and curved polygon rings
-          GeometryCollections, including ST_Disjoint (Darafei Praliaskouski)
- - #3676, Mark geometry and geography btree comparison support functions
-          as leakproof (Darafei Praliaskouski)
- - GH-875, Allow ST_OrderingEquals joins to use hash and merge join plans
- - #1168, [raster] Support curved geometry inputs in ST_AsRaster
- - #1416, ST_AsX3D outputs NURBSCURVE as X3D NurbsCurve
-          and linearizes other curve geometries
- - #3705, ST_AsX3D outputs valid coordinate nodes for 2D multi-geometries
-          and GeometryCollections (Darafei Praliaskouski)
- - GT-484, Use column-level SELECT privileges for metadata views
-          (Arthur Bazin)
- - #1408, #2386, #2557, #2805, #2898, #3743, #4323, #4332, #4385, #5109,
-          #5532, #5593, #5638, #5645, #5950, #6022, #6082, GH-1161, GT-584,
-          Numerous doc enhancements (Darafei Praliaskouski)
-* Bug Fixes *
- - Fix WKB and TWKB parser resource exhaustion on malformed input
- - #6038, Avoid stale relation lookups in geometry_columns after topology
-          objects are dropped (Darafei Praliaskouski)
- - #5487, Improve error detail for repeated upgrades after an incomplete
-          deprecated-function cleanup (Darafei Praliaskouski)
- - #5975, Initialize skipped union-find cluster ids deterministically
- - #5904, [topology] Avoid MinGW format warnings when logging topology ids
- - GH-888, [sfcgal] Avoid stale detoasted geometry access in
-          CG_Visibility empty-input handling for SFCGAL < 2.2
- - #3179, Mark truncated libpgcommon PostgreSQL messages instead of silently
-          dropping the tail (Darafei Praliaskouski)
- - #6003, Avoid size_t formats in liblwgeom logging/error wrappers for
-          MinGW builds (Darafei Praliaskouski)
- - GH-886, ST_ClusterRelateWin validates NULL relate matrices before
-          detoasting them (Darafei Praliaskouski)
- - GH-889, ST_Relate pattern inversion avoids out-of-bounds access on
-          short DE-9IM patterns (Darafei Praliaskouski)
- - GH-890, Avoid GIDX BRIN summary merges across mismatched dimensions
- - #5959, Prevent histogram target overflow when analysing massive tables (Darafei Praliaskouski)
- - #6080, Avoid out-of-bounds hex WKB lookup for high-bit input bytes
- - #4828, geometry_columns handles NOT VALID SRID checks without errors (Darafei Praliaskouski)
- - #6048, [raster] ST_Clip no longer crashes when clipping sparse band
-          selections (Darafei Praliaskouski)
- - GH-894, [raster] Fix Float16 import, mixed nodata warping,
-          band replacement cleanup, GDAL credential redaction, and Python
-          GDAL compatibility (Darafei Praliaskouski)
 PostGIS 3.6.0
 2025/09/01
diff --git a/README.postgis b/README.postgis
index 90f50c80d..5fe870f4f 100644
--- a/README.postgis
+++ b/README.postgis
@@ -2,7 +2,7 @@ PostGIS - Geographic Information Systems Extensions to PostgreSQL
 :Version: 3.7.0
-:Date: 2026-08-24
+:Date: 2026-09-01
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
@@ -59,14 +59,16 @@ below dependencies (except for GTK):
     libsfcgal-dev \
     libxml2-dev \
     libxml2-utils \
+    perl \
     pkg-config \
     protobuf-c-compiler \
     xsltproc
 * PROJ (Required, Version 6.1 or higher):
-  The PROJ catographic projection library is required if you want to use the
-  ST_Transform() function to reproject features within the database.
+  The PROJ cartographic projection library is required for map projection /
+  datum transformation support such as the ST_Transform() function. It is a
+  hard build requirement; configure fails if it cannot be found.
     https://proj.org
@@ -83,17 +85,19 @@ below dependencies (except for GTK):
     https://libgeos.org
-* XML SUPPORT (Required, Version 2.5.0 or higher):
+* XML SUPPORT / libxml2 (Required):
   The LibXML2 library is required to use the ST_GeomFromGML() and
-  ST_GeomFromKML() functionality.
+  ST_GeomFromKML() functionality. It is a hard build requirement; configure
+  fails if it cannot be found.
     http://xmlsoft.org/
 * GMP (Required):
   The GMP arbitrary precision arithmetic library is required by PostGIS
-  topology support.
+  topology support. It is detected via pkg-config and has no fallback, so
+  ``pkg-config`` must be available for a default build.
     https://gmplib.org
@@ -108,9 +112,11 @@ below dependencies (except for GTK):
   GNU gettext is used for loader and documentation translation support. It may
   be disabled with ``--with-gettext=no``.
-* JSON-C (Optional, Version 0.9 or higher)
+* JSON-C (Optional)
   JSON-C is used to import GeoJSON via the function ST_GeomFromGeoJson().
+  It is enabled by default but optional; if it is not found configure only
+  warns and the build continues. Disable with ``--without-json``.
     http://github.com/json-c/json-c/wiki
@@ -125,11 +131,13 @@ below dependencies (except for GTK):
   https://sfcgal.gitlab.io/sfcgal
-* protobuf-c (Optional, Version 1.1.0 or higher)
+* protobuf-c (Optional, Version 1.1.0 or higher, enabled by default)
   The protobuf-c library and compiler are required to enable ST_AsMVT and
-  ST_AsGeobuf output. Also, pkg-config is required to verify the correct
-  minimum version of protobuf-c.
+  ST_AsGeobuf output. Both the ``libprotobuf-c`` library and the ``protoc-c``
+  compiler are needed; the compiler is a hard error if you request protobuf
+  support but cannot find it. Disable with ``--without-protobuf``. Also,
+  pkg-config is used to verify the correct minimum version of protobuf-c.
     https://github.com/protobuf-c/protobuf-c
@@ -142,6 +150,23 @@ below dependencies (except for GTK):
     apt-get install libgtk2.0-dev
+Documentation Building
+Building the documentation requires the following in addition to the apt
+packages listed above (``docbook-xsl-ns``, ``libxml2-utils`` and ``xsltproc``):
+* Python 3 -- required to run the manual example tester that generates the
+  visual examples which HTML and PDF embed. Those SVGs come from running the
+  staged PostGIS build against a live PostgreSQL server via ``make -C regress
+  visual-examples``; no Python database driver is required (the tooling talks
+  to the server through the ``psql`` client).
+* An SVG rasterizer for PDF output -- ``rsvg-convert`` (from librsvg) is
+  preferred, with GraphicsMagick (``gm``) or ImageMagick (``convert`` /
+  ``magick``) as fallbacks. HTML and EPUB embed the SVG files directly and do
+  not need a rasterizer.
 CONFIGURATION
diff --git a/configure.ac b/configure.ac
index 9324966ee..7371941f1 100644
--- a/configure.ac
+++ b/configure.ac
@@ -236,11 +236,15 @@ fi
 AC_PATH_PROG([XMLLINT], [xmllint], [])
 if test "x$XMLLINT" = "x"; then
 	dnl AC_MSG_WARN([xmllint is not installed so documentation cannot be checked])
-	AC_MSG_WARN([xmlcatalog is not installed so documentation cannot be built])
+	AC_MSG_WARN([xmllint is not installed so documentation cannot be built])
 	CAN_BUILD_COMMENTS=no
 fi
+AC_PATH_PROG([PYTHON3], [python3], [])
+if test "x$PYTHON3" = "x"; then
+	AC_MSG_WARN([python3 is not installed so documentation visual examples cannot be generated])
+	AC_MSG_WARN([documentation build will fail: run 'make -C regress visual-examples' first])
+fi
 AC_PATH_PROG([XML2POT], [xml2pot], [])
 if test "x$XML2POT" = "x"; then
@@ -2011,6 +2015,7 @@ AC_MSG_RESULT([  xsltproc:             ${XSLTPROC}])
 AC_MSG_RESULT([  docbook xsl base:     ${XSLBASE}])
 AC_MSG_RESULT([  dblatex:              ${DBLATEX}])
 AC_MSG_RESULT([  convert:              ${CONVERT}])
+AC_MSG_RESULT([  python3:              ${PYTHON3}])
 AC_MSG_RESULT()
 if test "$POSTGIS_GEOS_VERSION" -lt 31200; then
diff --git a/doc/development/environment/ubuntu.md b/doc/development/environment/ubuntu.md
index 7ff95ccd6..4cc628eb5 100644
--- a/doc/development/environment/ubuntu.md
+++ b/doc/development/environment/ubuntu.md
@@ -51,7 +51,7 @@ sudo apt-get install -y --no-install-recommends \
   libxml2-dev libxslt1-dev libxml2-utils \
   libyaml-dev \
   postgresql postgresql-client postgresql-server-dev-all \
-  python3 python3-pip python3-venv python3-psycopg2 \
+  python3 python3-pip python3-venv \
   xsltproc docbook-xsl docbook-xsl-ns docbook-xml \
   zlib1g-dev
@@ -59,6 +59,11 @@ sudo apt-get install -y --no-install-recommends \
 This installs software so local workflow can exercise builds, sanitizers,
 formatters, and regression suites.
+Note that the documentation example and visual-example tooling talks to the
+PostgreSQL server through the `psql` client (spawned by the Python scripts),
+so no Python database driver such as `psycopg2` is required for documentation
+building or example tests.
 ## 2. Configure PostgreSQL for local testing
 The CI images keep PostgreSQL entirely under `/usr/local/pgsql`. On Ubuntu we
@@ -105,6 +110,8 @@ have:
 * PROTOBUF-C (for `ST_AsMVT`)
 * SFCGAL (for 3D/advanced geometry tests)
 * Libxml2, libxslt and docbook stylesheets (for documentation targets)
+* Python 3 (required to build documentation and to run the example /
+  visual-example tooling; see `make -C regress visual-examples`)
 * Valgrind (for CUnit leak checks)
 Verify their presence if `./configure` fails.
diff --git a/doc/development/release-process.md b/doc/development/release-process.md
index 579e873e1..cbf0c5e1b 100644
--- a/doc/development/release-process.md
+++ b/doc/development/release-process.md
@@ -75,7 +75,11 @@ documentation -- that means having the required software:
 * For the docs:
   - xsltproc
   - DocBook XSL scripts
-  - ImageMagic
+  - Python 3 (required to run the example tester and generate the visual
+    examples that HTML and PDF embed; the SVGs come from running the staged
+    PostGIS build against a live PostgreSQL server)
+  - rsvg-convert (preferred) or GraphicsMagick/ImageMagick (to rasterize the
+    generated SVGs for PDF)
   - DbLatex (for PDF)
 ## Release Procedure
diff --git a/doc/installation.xml b/doc/installation.xml
index 69cad523a..da7ff43e2 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -193,16 +193,27 @@ sh autogen.sh
     </listitem>
     <listitem>
     <para>
-      LibXML2, version 2.5.x or higher. LibXML2 is currently used in some imports
+      LibXML2. LibXML2 is currently used in some imports
       functions (ST_GeomFromGML and ST_GeomFromKML). LibXML2 is available for download from
       <link xlink:href="https://gitlab.gnome.org/GNOME/libxml2/-/releases">https://gitlab.gnome.org/GNOME/libxml2/-/releases</link>.
     </para>
     </listitem>
     <listitem>
     <para>
-      JSON-C, version 0.9 or higher. JSON-C is currently used to import GeoJSON via the
-      function ST_GeomFromGeoJson. JSON-C is available for download from
-      <link xlink:href="https://github.com/json-c/json-c/releases">https://github.com/json-c/json-c/releases/</link>.
+      Perl is required to build PostGIS.
+      Perl is available for download from
+      <link xlink:href="https://www.perl.org/">https://www.perl.org/</link>.
+    </para>
+    </listitem>
+    <listitem>
+    <para>
+      The iconv library is required by the shp2pgsql loader for encoding
+      conversion. On GNU/Linux systems it is typically provided by libc; on
+      other platforms you may need a separate
+      <link xlink:href="https://www.gnu.org/software/libiconv/">libiconv</link>
+      package.
     </para>
     </listitem>
@@ -211,6 +222,8 @@ sh autogen.sh
       The GNU Multiple Precision Arithmetic Library (libgmp). Used to control precision of math operations in PostGIS Topology.
       GMP is available for download from
       <link xlink:href="https://gmplib.org/">https://gmplib.org/</link>.
+      It is detected via <command>pkg-config</command> and has no fallback, so
+      <command>pkg-config</command> must be available for a default build.
     </para>
     </listitem>
@@ -244,6 +257,23 @@ sh autogen.sh
     </para>
     </listitem>
     <listitem>
+    <para>
+      JSON-C. JSON-C is currently used to import GeoJSON via the
+      function ST_GeomFromGeoJson. JSON-C is available for download from
+      <link xlink:href="https://github.com/json-c/json-c/releases">https://github.com/json-c/json-c/releases/</link>.
+      only warns and the build continues. Disable with
+      <varname>--without-json</varname>.
+    </para>
+    </listitem>
+    <listitem>
+    <para>
+      GNU gettext for loader and documentation translation support. It may be
+      disabled with <varname>--with-gettext=no</varname>.
+      <link xlink:href="https://www.gnu.org/software/gettext/">https://www.gnu.org/software/gettext/</link>.
+    </para>
+    </listitem>
+    <listitem>
     <para>
       GTK (requires GTK+2.0, 2.8+) to compile the shp2pgsql-gui shape file loader.
       <link xlink:href="http://www.gtk.org/">
@@ -290,6 +320,21 @@ sh autogen.sh
     </para>
     </listitem>
+    <listitem>
+    <para>
+      Python 3 is required to run the manual example tester that generates
+      the visual examples which the HTML and PDF documentation embed.
+      The examples are executed against a live PostgreSQL server running the
+      staged PostGIS build via <command>make -C regress visual-examples</command>;
+      no Python database driver is required, the tooling talks to the server
+      through the <command>psql</command> client. Python 3 is available from
+      <link xlink:href="https://www.python.org/">
+      https://www.python.org/
+      </link>
+    </para>
+    </listitem>
     <listitem>
     <para>
       DBLatex (<filename>dblatex</filename>) is required for building the
Summary of changes:
 NEWS                                  | 335 +++++++++++++++++-----------------
 README.postgis                        |  45 ++++-
 configure.ac                          |   9 +-
 doc/development/environment/ubuntu.md |   9 +-
 doc/development/release-process.md    |   6 +-
 doc/installation.xml                  |  53 +++++-
 6 files changed, 275 insertions(+), 182 deletions(-)
hooks/post-receive
