[SCM] PostGIS branch master updated. 3.7.0rc1-20-g655fc78a1
Tue Sep 1 19:39:18 PDT 2026
the project "PostGIS".
       via  655fc78a1b31311c6088d1b14b78b51a1a6a7df5 (commit)
      from  a767a934f3cb14b3f1078846db56772ea31b056b (commit)
revisions in full, below.
commit 655fc78a1b31311c6088d1b14b78b51a1a6a7df5
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Wed Sep 2 01:09:26 2026 +0000
    Translated PostGIS Manual using Weblate (Japanese)
    Currently translated at 100.0% (6037 of 6037 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 2895b96f2..f50cec97f 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2026-08-04 15:37+0000\n"
-"PO-Revision-Date: 2026-09-01 01:39+0000\n"
+"PO-Revision-Date: 2026-09-02 02:39+0000\n"
 "Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
 "manual/ja/>\n"
@@ -25388,7 +25388,7 @@ msgid ""
 msgstr ""
 "&geography_transform; ジオメトリーのバウンディングボックスに最適な平面空間参"
 "照系を決定します (UTM、ランベルト正積方位図法の北極/南極、最後はメルカトルで"
-"す)。バッファは平面空間で計算あsれ、WGS84に戻されます。このため、入力が UTM"
+"す)。バッファは平面空間で計算され、WGS84に戻されます。このため、入力が UTM"
 "ゾーンと比べて非常に大きくなったり、日付変更線とクロスしたりする場合に、求め"
 "る動作をしないことがあります"
Summary of changes:
 doc/po/ja/postgis-manual.po | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
