[PostGIS] #6120: XX000: SQL/MM Spatial exception - curve not simple
trac at osgeo.org
Wed Sep 2 01:00:18 PDT 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.5
Component: topology | Version: 3.6.x
Resolution: | Keywords:
Comment (by strk):
I can reproduce with:
> POSTGIS="3.7.0dev 3.6.0rc2-398-gcf949fa33" [EXTENSION] PGSQL="180"
GEOS="3.15.0dev-CAPI-1.21.0" PROJ="9.8.1 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 9.4.0)
LIBXML="2.9.14" LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0
(Internal)" TOPOLOGY
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6120#comment:1>
