[PostGIS] #6120: XX000: SQL/MM Spatial exception - curve not simple
trac at osgeo.org
Wed Sep 2 01:24:36 PDT 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.5
Component: topology | Version: 3.6.x
Resolution: | Keywords:
Changes (by strk):
* Attachment "t6120-v0.sql" added.
Reduced testcase: 1 edge with 6 vertices as starting condition, 1 edge
with 5 vertices as offending incoming input. Both closed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6120>
