[PostGIS] #6120: XX000: SQL/MM Spatial exception - curve not simple
trac at osgeo.org
Wed Sep 2 03:24:54 PDT 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.5
Component: topology | Version: 3.6.x
Resolution: | Keywords:
Comment (by strk):
Newer PostGIS version ( 3.7.0dev 3.6.0rc2-398-gcf949fa33 ) throws a
different exception, which also contains location info:
> ERROR: Spatial exception - geometry intersects edge 673 at
POINT(20.8678219077647 69.3134366022891)
The following screenshot from QGIS shows the situation. The reported
intersection point is at the leftmost edge of the almost-coincident lines
(black is the edge, green is the incoming, stars are start/end vertices of
the two, there's no way to visually spot the vertex which is ONLY in the
edge but not in the incoming).
[[Image(case.png)]]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6120#comment:3>
