[PostGIS] #6120: XX000: SQL/MM Spatial exception - curve not simple
PostGIS trac at osgeo.org
Wed Sep 2 03:33:46 PDT 2026
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.6.5
 Component:  topology           |    Version:  3.6.x
Resolution:                     |   Keywords:
Comment (by strk):
 Possibly useful workaround, when the desired effect is data cleanup, is
 simplifying the existing edge:
 SELECT topology.ST_ChangeEdgeGeom(
   't6120',
    edge_id,
    ST_Simplify(geom, 1e-14)
 FROM t6120.edge;
 Note that a simplification tolerance of 1e-15 is not enough, even if it
 does remove 1 vertex from the original 6 vertices of the edge. Tolerance
 of 1e-14 drops two of those vertices.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6120#comment:4>
